Zaključane teme
Staro 19.08.2014., 20:35   #6361
akoj
lijevo smetalo
akoj's Avatar
Datum registracije: Jan 2014
Postovi: 1,120
Stigao je mali update za GDR1.
Nvisen Y-GX01 // BMAX Y11
akoj je offline
Staro 20.08.2014., 02:14   #6362
Facelessone
Facelessone's Avatar
Postovi: 4,204
Koliko vidim nemam vise stalno "rasuming" 😊 (update za gdr1)
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Zadnje izmijenjeno od: Facelessone. 20.08.2014. u 05:28.
Facelessone je offline
Staro 20.08.2014., 03:35   #6363
Wolverine
Wolverine's Avatar
Postovi: 12,425
Evo meni L920 upravo javila da je stigao 8.1 update. Ajd da i to vidimo. Čekao sam redoviti update jer mi se nije dalo zezat s DP-om
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Wolverine je offline
Staro 20.08.2014., 08:21   #6364
nathan.fake
Lokacija: n/a
Postovi: 1,258
Dostupan Cyan za Lumia 920 "Croatia - Country Variant".. znaci one kuljene u Tele2 i slobodnoj prodaji
Zasad samo OTA, nema ga jos na NaviFirmu.
nathan.fake je offline
Staro 20.08.2014., 09:31   #6365
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,073
Autor daxxx88 Pregled postova
(prilican offtopic)
totalni sam noob za to podrucje, ali moze pitanje - ako je na ta dva moba (doslovno) identican hardware i arhitektura (procesora i sl.), sto "hakere" na xda prijeci da na Android mob portaju WP, ili obrnuto?
ako me sjecanje dobro sluzi, doticni hd2 je bio raj za ekipu - mogli su gore stavit sta god su htjeli
jesu ovi danasnji proizvodjaci nekako dodatno zastitili pristup ROM-u ili nesto trece?
Zbog ovoga:
https://dev.windowsphone.com/en-US/O...ption_overview
Autor akoj Pregled postova
Neslužbeni changelog:
•Notification center is now smooth, doesn't have split second lag on L925/L1520, renders up icons properly after restart.
•Searching for settings(i.e Sounds/updates and so on) was broken/disabled on GDR1
•You can no longer access hidden settings through bing.
•Fixed default search issue, it used to use Bing even though you used google, as well it gone out of private mode once you did a search through it.
Autor nathan.fake Pregled postova
This makes me moist
Dobro kaj nisam ništa flashao preko Navifirma, idem ja lijepo downgrade-ati na WP8 pa rokaj na Cyan Thanks na infu!
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Mario92 je online
Staro 20.08.2014., 09:41   #6366
Wolverine
Wolverine's Avatar
Postovi: 12,425
Zasad sve šljaka OK, malo mi je retardiran redizajn photo galerije i ne znam zašto Cortana neće radit. No ionako je ne bi baš pretjerano koristio. :/
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 20.08.2014., 09:42   #6367
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,073
Regija mora biti US/UK te jezik telefona mora biti engleski iako bi trebalo raditi i sa kanadskom regijom koja je u Alpha fazi.
Međutim, kad sam htio probati UK Cortanu morao sam skidati language pack za GB, nakon toga je proradila i britanska Cortana.
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Mario92 je online
Staro 20.08.2014., 09:46   #6368
Wolverine
Wolverine's Avatar
Postovi: 12,425
Baš zato mi je i čudno da ne radi. Jer znam da je za Kanadu u Alpha fazi i jedino kaj moraš napravit je stavit speech na ENG US ili ENG UK
http://www.wpcentral.com/activate-co...-and-australia
Kad i regiju prebacim na US onda radi, vratim regiju na Canada i nula bodova. No kao što rekoh, nije mi od neke presudne važnosti tak da me ne tangira previše
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 20.08.2014., 10:15   #6369
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,073
Zato jer sam ja konj
Zaboravio sam reći da trebaš imati WP8.1 Update 1 da bi ti Cortana radila u Kanadi.
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Mario92 je online
Staro 20.08.2014., 12:36   #6370
9800pro
aka Edo, aka Syncros
9800pro's Avatar
Postovi: 1,775
Jučer curi sletio OTA 8.1 na Lumiji 520 na Tele2 mreži...
9800pro je offline
Staro 20.08.2014., 13:23   #6371
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
Opet ja i problemi sa explorerom.
nakon reseta na tvornicke, broj crasheva se smanjio, ali dosao je novi problem - decode error na svakom videu kojeg pokusavam otvorit. Sluzbeni cyan je gore. Ne znam kaj da radim vise...
fran123456 je offline
Staro 20.08.2014., 13:54   #6372
Los Sam
Los Sam's Avatar
Lokacija: Duga Resa
Postovi: 513
Zanima me jel Win 8.1 phone intuitivniji od Androida?
Ima li bolje rjeseno pohranjivanje appova izmedju interne memorije te sd kartice?
Treba li za upravljanje datotekama dodatni app ili je to rjeseno u sustavu?
Jel dovoljno 512mb rama za normalno koristenje za razliku od Androida?
Raspitujem se za sestru kojoj android ne lezi bas, a ja se pak uopce ne razumijem u win phone. L630 je zapela za oko.
Hvala!
Los Sam je offline
Staro 20.08.2014., 14:05   #6373
Postovi: 33,996
1. osobno mislim da je droid nešto intuitivniji od WP-a, ali to je moje osobno mišljenje
4. 512Mb je sasvim dovoljno jer je hardverski daleko manje zahtjevniji od Androida
coconut je online
Staro 20.08.2014., 15:06   #6374
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,073
Autor Los Sam Pregled postova
Hvala!
1.) Ja sam svoje doma daleko lakše naučio koristiti WP nego Android iako your milage can vary. Ako ništa onda je WP konzistentniji u aplikacijama i među uređajima tako da će eventualni upgrade na drugi model biti puno lakši.
Minus je u tome kad radim na nekom Androidu instinktivno isprobavam svajpati sve živo pa se razočaram
2.) WP8.1 je sredio appove na SD kartici IMHO bolje nego Android.
3.) Imaš službeni app zvan Files te uz neke novije modele dolazi predinstaliran (modele koji dolaze sa Update 1, vjerojatno od HTC-a One nadalje)
L630 je izvrstan mobitel, osobno smatram daleko bolji od Androida u tom cijenovnom rangu.
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Mario92 je online
Staro 20.08.2014., 18:26   #6375
daxxx88
daxxx88's Avatar
Lokacija: Basel/Zg
Postovi: 1,229
Narušava li se jamstvo stavljanjem DP-a?
Formalno to nije nikakvo rootanje ili slično, već instalacija službene aplikacije i update mobitela.
[ASUS ZenBook UX303UA - i7-6500U, 8GB RAM, Intel HD Graphics 520]
What man is a man that doesn't make the world better
daxxx88 je offline
Staro 20.08.2014., 19:31   #6376
Wolverine
Wolverine's Avatar
Postovi: 12,425
Autor Mario92 Pregled postova
Da, skužio sam i ja kasnije kad sam išao malo googlat.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 20.08.2014., 20:06   #6377
nathan.fake
Lokacija: n/a
Postovi: 1,258
pise u disclaimer-u, prije instalacije, DP-a da se "mozda" gubi jamstvo (may void warranty)?!
uglavnom, stav Mobisa (Nokia servisa) je da se ne gubi... al svakako, ako i flashas DP, mozes se vratit na sluzbeni FW preko Nokia Software Recovery Tool-a (u slucaju potrebe tj. reklamacije)...
znaci mozes slobodno puknit DP i vratit se na sluzbeni FW, ako ti se DP ne svidi (ili ako saljes na servis)
jedini drawback je sto pri vracanju na sluzbeni FW gubis sve podatke na mobu (pa moras radit backup/restore)
edit:
ako imas Samsunga, procedura je slicna.. neko je linko, prije par strana, proceduru za vracanje na sluzbeni FW... za HTC ne znam :/
Zadnje izmijenjeno od: nathan.fake. 20.08.2014. u 20:13.
Staro 20.08.2014., 20:18   #6378
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,073
Napravih restore na WP8, dignuo na Cyan i stavio Update 1.
Usrah se kad je Nokia Recovery Tool instalirao OS. Odem sa kompa na 2 minute, vratim se natrag i vidim BSOD na kompu i crveni ekran na mobu. Srce me strefilo
USB driver je uzrokovao BSOD ali od druge je sve prošlo kak spada.
My work is done.
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Zadnje izmijenjeno od: Mario92. 20.08.2014. u 20:30.
Mario92 je online
Staro 20.08.2014., 20:30   #6379
daxxx88
daxxx88's Avatar
Lokacija: Basel/Zg
Postovi: 1,229
edit:
Taj dio sam i ja čitao, pa me zanima kakvi su naši po pitanju "may"anja
Ativ S je u pitanju.
Poslao sam mail na Links (gdje je kupljen), pa ću vidjeti - oni će me vjerojatno preusmjeriti na Europatrade.
Nije problem za backup/restore, evo baš sam ga danas hard resetao jer mi se nakupilo u System preko 8GB sranja, a to ne mogu očistiti... Evo sad je na 2.5GB
Kontakti su syncani preko Live accounta, fotke i ostalo imam na SD kartici, aplikacije reinstaliram, par settingsa se mora poštelati nanovo, no vrijedi mi "čišćenja" memorije
Danas sam bio "na rubu" da ga stavim, ali sam odlučio još malo pričekati
Nisam baš vičan petljanju s firmwareima i sl., no dobro je znati da postoji slamka spasa ako nešto pođe po zlu.
Službenoj verziji ni traga ni glasa
Zadnje izmijenjeno od: daxxx88. 20.08.2014. u 20:39.
daxxx88 je offline
Staro 20.08.2014., 21:34   #6380
Omerta
Omerta's Avatar
Lokacija: Grobnik - Rijeka
Postovi: 3,254
Može mala pomoć za nooba. (pojma nemam o Windows Phone OS-u)
Evo danas sam napokon kupio Lumiu 625 i prije vikenda se neću baš pozabavit sa njom.
Molim vas za početak par odgovora i preporuka za bespaltne aplikacije:
1. File manager (nešto jednostavno za ulazak u datoteke, SD karticu i slično) - očito je Files dobar?
2. Dali postoji tapatalk za pregledavanje foruma?
3. Gmail aplikacija?
4. Nešto kao "market" odnosno Play store za aplikacije?
Hvala za sad..
Omerta je offline
Staro 20.08.2014., 21:37   #6381
redscro
redscro's Avatar
Lokacija: Kupres
Postovi: 4,085
1. Da, Files je ok.
2. Da, postoji.
3. Da, trebala bi ti biti već na mobitelu.
4. Naravno, postoji Store za aplikacije.
redscro je offline
Staro 20.08.2014., 21:39   #6382
daxxx88
daxxx88's Avatar
Lokacija: Basel/Zg
Postovi: 1,229
Autor Omerta Pregled postova
Hvala za sad..
dobrodosao u klub (seve u pozadini)
3. Odi u email+accounts i namjesti google racun
daxxx88 je offline
Staro 20.08.2014., 21:52   #6383
Don Kihoty
Datum registracije: Apr 2011
Lokacija: Sisak
Postovi: 1,373
Don Kihoty je offline
Staro 20.08.2014., 21:54   #6384
sibica
sibica's Avatar
Lokacija: Croatia/Crikvenica
Postovi: 499
Za prvo postoji,al ne koristim,pa ce ti drugi preporuciti,tapatalk postoji,upravo pisem preko njega.Gmail imas,doduse nesluzbene aplikacije,ali normalno radi.Market ili trgovinu ces pronaci u meniju mobitela ili mozes preko kompjutera "daljinski" poslati aplikacije na svoj mob.
sibica je offline
Staro 20.08.2014., 22:13   #6385
daxxx88
daxxx88's Avatar
Lokacija: Basel/Zg
Postovi: 1,229
i ne samo to, čak i diže više na benchu
daxxx88 je offline
Staro 20.08.2014., 22:22   #6386
Don Kihoty
Lokacija: Sisak
Postovi: 1,373
Zanima me baš koliko bi bateriju i score dobile Lumie ili Ativi sa Androidom.
Tek onda bi bi WP mogao staviti točku na I - i Gugljovci bi mogli prestati
sa kenjanjima "baterija na WP-u ne valja".
Staro 20.08.2014., 22:49   #6387
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,824
Autor Don Kihoty Pregled postova
Puuuno vise, 100%..
Ak se wp pokaze boljim, ko zna, mozda i ja doletim vama
Moram te razocarat, al android je po tom pitanju puno bolji...
zvonac je offline
Staro 20.08.2014., 22:58   #6388
daxxx88
daxxx88's Avatar
Lokacija: Basel/Zg
Postovi: 1,229
Gdje ima za ispipat L625 uživo, da vidim malo ekran i tak to, u Zg?
daxxx88 je offline
Staro 20.08.2014., 23:01   #6389
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,103
Mislim da bi ti nova emmezeta na žitnjaku mogla imati. Projurio sam pored tog dijela, ali vidio da imaju brdo mobitela koje možeš ispipati.
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
1v@n je offline
Staro 20.08.2014., 23:03   #6390
Don Kihoty
Lokacija: Sisak
Postovi: 1,373
VIP i TELE2 (i partnerske firme) imaju L625.
U Sisku u Techno 2000 imaš dvije L625 za isprobati,
u VIP-u 630, 930 i 1520.
T-COM samo 630 i prastari HTC 8S.
Zaključane teme
