|  26.06.2014., 19:24 | #3421 |
| Registered User Datum registracije: Jun 2014 Lokacija: Zagreb
					Postovi: 2
				 | Nemam SATA HDD, a napajanje mi je 400W |
|  26.06.2014., 19:41 | #3422 |
| Premium Datum registracije: Jun 2008 Lokacija: ZG
					Postovi: 88
				 | - AMD CPU Desktop Athlon II X4 740 (3.2GHz,4MB,65W,FM2) box - Matična ploča MSI A55M-E33 (SFM2+,DDR3,SATA,RAID,GLAN,USB2.0,VGA,HDMI) mATX Box - Crucial RAM 4GB DDR3 1600 MT/s (PC3-12800) CL11 Unbuffered UDIMM 240pin Single Ranked - Grafička kartica XFX AMD Radeon R7 260X Graphic Card 2GB DDR5, XFX-R7-260X-CNF4 ~ 1980kn A ak ti je šroteks napajanje: - AMD CPU Desktop Athlon II X4 740 (3.2GHz,4MB,65W,FM2) box - Matična ploča MSI A55M-E33 (SFM2+,DDR3,SATA,RAID,GLAN,USB2.0,VGA,HDMI) mATX Box - Crucial RAM 4GB DDR3 1600 MT/s (PC3-12800) CL11 Unbuffered UDIMM 240pin Single Ranked - Grafička kartica Sapphire Radeon R7 250 1G GDDR5 PCI-E HDMI / DVI-D / VGA WITH BOOST, 11215-00-20G - Zalman 500W LX Series Retail, ZAL-ZM500-LX ~ 1985kn Ili radije prištedi još par sto kn i složiš to puno bolje.. Lp EDIT: tek sad vidio da imaš i šroteks napajanje i da ti treba HDD -.- EDIT2 : Intel verzija Matična ploča ASRock H81M-VG4, 1150 Procesor Intel Celeron G1820 Procesor Intel Celeron G1820 Crucial RAM 4GB DDR3 1600 MT/s (PC3-12800) CL11 Unbuffered UDIMM 240pin Single Ranked Toshiba DT01ACA050 500GB 3.5'' Corsair VS series VS450, 450W, 230V AC, ATX, EPS 12V, PS/2, 120mm fan, up to 85% efficiency Grafička kartica Sapphire Radeon R7 250 1G GDDR5 PCI-E HDMI / DVI-D / VGA WITH BOOST, 11215-00-20G ~ 1985 kn Zadnje izmijenjeno od: yebiwetar. 26.06.2014. u 19:48. |
|  26.06.2014., 20:20 | #3423 |
| Premium Datum registracije: Apr 2013
					Postovi: 1,336
				 | ja bi to ovak za 2000kn AMD A8 5600K Black Edition FM2 Crucial RAM 4GB DDR3 1600 MS FSP300-60HCN, bulk napajanje HDD Toshiba 500GB GIGABYTE Main Board Desktop AMD A88X malo manje od 2000..dobar intergirani GPU u procu, kad skupiš para fino uzmeš R7260X, do tada ćeš se i s ovim moći sasvim ok igrat ako nije fullHD monitor..ako je onda ćeš morat dosta rezat detalje, ali identična situacija bi ti bila sa celeronom i r7 250..proc i integrušu možeš i overclockat..preporučam i da uzmeš 1866mhz memoriju ako ti se da prekoračiti budžet za par desetaka kuna |
|  27.06.2014., 09:25 | #3424 |
| Doktor znanosti! Datum registracije: Apr 2005 Lokacija: Zg,Peščenica/borongaj
					Postovi: 1,311
				 | Preporuka konfiguracije za buraza ima 11 godina. Mali oće igrat al buđet je 3000kn. Imam DVD RW, sata2 HDD od 500GB i Corsair 450W napajanje ostalo treba kupiti . Kako najbolje iscjediti 3K da zaigra nove igre. Igrat će na HD telci 55 cm znači max 720p je bit reza u igrama. Može i nešto jeftinije ako se ne gubi bitno na performancama. Plača se na karticu mastercard ili maestro raiffaisen   |
|  27.06.2014., 09:53 | #3425 |
| MiningMod Datum registracije: Jun 2005 Lokacija: Zagreb
					Postovi: 8,715
				 | Ovako nekako sa mogucnosti lake nadogradnje 1 x AMD Phenom II X4 925, 2.8GHz, 8MB, AM3 1 x Hladnjak Deepcool Gammaxx 200 1 x Gigabyte GA-970A-DS3P, AM3 1 x KINGSTON DDR3 (8GB,1600MHz(PC3-12800) CL11 1 x Sapphire R7 260X OC, 2GB GDDR5, DVI, DP, HDMI 1 x MS ORION kućište bez napajanja ili po izboru 3000Kn ili ako treba jeftinije, onda slabija ploča (manja mogucnost za nadogradnju proca, max na ovu ploču ide fx6300), manje memorije ali jača grafa 1 x AMD Phenom II X4 925, 2.8GHz, 8MB, AM3 1 x Hladnjak Deepcool Gammaxx 200 1 x GIGABYTE GA-78LMT-S2P 1 x Crucial RAM 4GB DDR3 1600 1 x SAPPHIRE Radeon R7 265 2G GDDR5/256-bit 1 x MS ORION kućište bez napajanja ili po izboru 2750Kn (s 8gb rama ispada oko 3000Kn) ili slabija grafa kao gore pa ispada dosta jeftinije (slabija grafa gore bude uredno vrtila isto sve igrice)  |
|  27.06.2014., 12:39 | #3426 |
| Banned Datum registracije: Apr 2011 Lokacija: -
					Postovi: 3,784
				 | Aha, kartice - zaboravi.   Zadnje izmijenjeno od: ShanTech. 27.06.2014. u 12:54. |
|  27.06.2014., 15:24 | #3427 |
| Registered User Datum registracije: Jun 2014 Lokacija: Whitechapel
					Postovi: 72
				Konfa
			 Pozdrav ekipa, Kihnula mi stara kanta (2003 godište) što sam ga dao materi i sad bi ona htjela drugu za surfanje i skype, a za malo para  Na jednom web dućanu (ne znam smijem li reći kojem) sam složio slijedeću konfu pa molim komentar (jel to ok, jel bi što trebao mijenjati i td.) 1. Kućište NaviaTec MATX PC Case 2. Matična Asrock s1150 H81M-VG4 3. Procesor Intel Celeron G1820 4. Memorija Corsair 2GB DDR3 1333 Value 5. HDD Desktop TOSHIBA DT01ACA050 (3.5", 500GB, 32MB, SATA III-600) 6. DVD LG GH24NS SATA 7. Napajanje MS FSP300-60HCN 8. Monitor ACER V206HQLAb 20" LED Monitor Sve skupa online na karticu: 2.479,52; cash (pouzeće) 2.231,57 Monitor je opcija da zamjenim stari 23" CRT od 100 kila, al može i bez njega pa onda izađe: Online - 1.777,01; cach - 1.603,31 (ispod 2.000,00 kn pa je uračunato 40 kn za dostavu). Zahvaljujem na cijenjenom mišljenju. Zadnje izmijenjeno od: TheRipper. 27.06.2014. u 15:40. Razlog: Ups, zaboravih HDD :) |
|  27.06.2014., 15:34 | #3429 |
					Postovi: 3,784
				 | Konfiguracija nema hard diska. |
|  27.06.2014., 15:38 | #3430 |
					Postovi: 72
				 | Ma mislim da neće biti Windoze, Linux ću puknut gore. Al mislio sam kasnije kad se malo oparim staviti još jednu pločicu rama i to je to. |
|  27.06.2014., 15:40 | #3431 |
					Postovi: 3,784
				 | Ponavljam, u konfiguraciji ti fali disk.   |
|  27.06.2014., 15:49 | #3433 |
					Postovi: 3,784
				 | Ja bi to ovako sastavio Ploča: Asrock B75M-DGS R2.0 Procesor: Intel Celeron G1610 Memorija: Patriot Sig. DDR3 1600Mhz, 4GB Kućište: Zalman ZM-T1 PLUS micro tower case Napajanje: MS Industrial MS FSP300-60HCN Disk: Seagate 1TB DVD: Samsung Monitor:AOC e950Swdak =2350 kn za keš, bez monitora 1750 kn Cijene si možeš pogledati na nabavi (www.nabava.net). |
|  27.06.2014., 15:59 | #3434 |
					Postovi: 8,715
|  27.06.2014., 16:00 | #3435 | |
					Postovi: 72
				 | Hvala na savjetu. Mogu li to kupiti u jednom dućanu i platiti online karticom na rate (amex ili maestro)? Citiraj:
|  27.06.2014., 16:13 | #3438 |
					Postovi: 3,784
|  27.06.2014., 18:48 | #3440 |
| Guest
				 | 40kn za dostavu ti nece biti dosta  |
|  27.06.2014., 20:03 | #3442 |
| Guest
				 | pa do londona |
|  27.06.2014., 21:13 | #3444 |
					Postovi: 72
				 | Hehe, da... do Londona. I mene čudilo al' sve će mi poslati direkt u Whitechapel   Prek 2000 kuna, besplatna dostava. Ipak sam ja TheRipper, prati me određena reputacija  Zadnje izmijenjeno od: TheRipper. 27.06.2014. u 22:12. Razlog: Da ne zbunjujem ljude :) |
|  03.07.2014., 20:20 | #3447 | |
| Registered User Datum registracije: Jul 2014 Lokacija: Hrvatska
					Postovi: 1
				 | Citiraj:
 1x Procesor AMD X4 6600K, Richland A8-Series,(3.9GHz 4 cores, cache 4MB L2, 100W, FM2, box, Radeon TM HD 8570D 800 MHz 1x Asrock FM2A78M-DG3+, AMD FM2+ Socket A78 Chipset MB 1x DDR3 4GB (1x4GB) Kingston, 1866MHz, CL10, HyperX FURY 1x HDD Seagate 500GB, Serial ATA III, 7200 rpm, Barracuda 7200.12 1x Zalman ZM-T1 PLUS micro tower case. 189(W) x 427,5(H) x 364(D)mm 1x Napajanje CORSAIR 430W, CX Series 80+ Bronze, EPS12V v2.3, 80+ Ukupno: 2.213,94Kn Uglavnom ne mislim OC i ostale radnje .. mozda ubacim za koju godinu bolju graficku ...  I da prepostavljam da mi fali hladnjak za cpu ali sta cu kad je max 2200 kn Slusam i bolja rijesenja od ovog i ostalo . Hvala Zadnje izmijenjeno od: Insider.. 05.07.2014. u 13:56. | |
|  03.07.2014., 23:29 | #3448 |
					Postovi: 1,336
				 | a gle, ako mora sve biti novo uzmi onda tak kak je gore..ako ne onda uzmi HDD SEAGATE Barracuda 7200 500GB NaviaTec Mid Tower ATX PC Case Chicony Active 350W INTEL Pentium Processor G2030 MSI H61M-P20 G3 Adata DDR3 4GB 1333MHz i ostaje ti 500-600 kuna za grafu..ako gledaš nove možeš dobiti nešto bzvz..ali ako skočiš na njuškalo da se već naći ok grafi koje bi lijepo pasale uz Pentiuma i onda bi se dalo zaigrati ponešto..znači gledaš nešto tipa HD7770 ili GTX 650 |
|  06.07.2014., 15:57 | #3449 |
| Premium Datum registracije: May 2007 Lokacija: Krapinske Toplice
					Postovi: 959
				 | Pozdrav, samo da zahvalim svima koji su mi pomogli u sastavljanju konfe prije 6 mjeseci, evo, stroj radi bez brige. Nego, dosao sam ovdje da mi sastavite za frenda najjeftiniju konfu bez monitora, igre nece igrati znaci moze integrirana graficka, bitnije mu je surfanje, koji film pogledati mozda i tak.. Hvala! |
|  06.07.2014., 17:38 | #3450 |
					Postovi: 8,715
				 | 1 x Procesor Intel Pentium G3220 1 x ASRock H81M-HDS, 1150 1 x Patriot Sig. DDR3 1600Mhz, 4GB 1 x HDD SEAGATE Barracuda 7200 (3.5",500GB,16MB,SATA III-600) 1 x LITE ON IHAS122 DVD-RW 22x Super Multi, SATA, Black, Bulk 1 x Aerocool Qs-101 mATX, white, 300W 1950Kn |
