Staro 04.04.2014., 21:42   #1321
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 5,838
a bio sam stavio jednu pa sam promjenio u ovo Crucial Ballistix Sport Series DDR3-1600, CL9 - 16 GB Kit ,ta je normalna ako se nevaram
http://www.caseking.de/shop/catalog/...html?from=cart
a kućište, vidiš nisam iša za tim
a u Zalman Z3 bi moralo stat?
http://www.caseking.de/shop/catalog/...rz::24361.html
a zvucnici mu nisu bitni, zato jer ce uglavnom bit headset
Ili je mozda ovo bolja opcija onda:
MBO:Gigabyte B85M-D3H
CPU:Intel Core i5-4570 3,2 GHz
HDD:Seagate Desktop SSHD 1TB
RAM:Crucial Ballistix Sport Series DDR3-1600, CL9 - 16 GB Kit
GPU:ASUS GeForce GTX 770 DC2OC, 2048 MB DDR5, DP, HDMI
PSU:Seasonic S12II, GB 80 Plus Bronze Netzteil - 620 Watt
Case:Zalman Z3-Plus Midi-Tower - schwarz
Monitor: ASUS VS239HV, IPS 58,4 cm (23 Zoll) Widescreen - HDMI, DVI, VGA 165,00€
CM Storm Devastator - Tastatur + Maus
SteelSeries 3HV2 Gaming Headset - schwarz
Microsoft Windows 7 Home Premium 64 Bit SP1, DVD LCP (englisch)
1.149,80 EUR
Zadnje izmijenjeno od: OuttaControl. 04.04.2014. u 22:10.
OuttaControl je online   Reply With Quote
Staro 04.04.2014., 22:07   #1322
ShanTech
Datum registracije: Apr 2011
Postovi: 3,784
Uzmi taj Zalman Z3 Plus.
Ne treba napajanje od preko 600W. AMD ne dolazi u obzir?
Onda ovako
Ploča: ASRock B85M Pro4 / ASRock H87 Pro4
Procesor: Intel Core i5-4570 3,2 GHz (Haswell) Sockel 1150 - tray
Hladnjak: RAIJINTEK Aidos Heatpipe CPU-Kühler, PWM - 92mm
Memorija: Team Group Elite Plus Series, DDR3-1600, CL11 - 8 GB Kit
Grafička: MSI GeForce GTX 770, N770 TF 2GD5/OC, 2048 MB DDR5, DP, HDMI
Kućište: Zalman Z3-Plus Midi-Tower - schwarz
Napajanje: Seasonic M12II Evo, AM2 80 Plus Bronze Netzteil - 520 Watt
SSD: Kingston SSDNow V300 Series 2,5 Zoll SSD, SATA 6G - 120 GB
Disk: Seagate Desktop HDD, SATA 6G, 7200RPM, 3,5 Zoll - 2 TB
Tipkovnica+miš: CM Storm Devastator - Tastatur + Maus
Zvučnici: Logitech S120 2.0 Soundsystem - black
Headset: SteelSeries 3HV2 Gaming Headset - schwarz
Mousepad: Aerocool Strike-X Fury Mousepad
OS: Microsoft Windows 7 Home Premium 64 Bit SP1, DVD LCP (englisch)
Monitor: Dell Professional P2314H 58,4 cm (23 Zoll) Widescreen - DP, DVI, VGA
Zadnje izmijenjeno od: ShanTech. 06.04.2014. u 14:12.
Staro 04.04.2014., 22:18   #1323
OuttaControl
Lokacija: Dalmacija
Postovi: 5,838
Nije da ne dolazi u obzir ali kaže da mu je nVidia draža, no ako je AMD bolji onda će njega uzet,
A posto ne misli igrat na multi monitor sustavu, taj 1 GB VRAMA mislim da nije toliko bitan
Po testovima 770 je ipak jača mrvicu na FULL HD, no na kraju se svede na koja ti je draža ako mene pitaš
A neka napajanja, ima viška proračuna, pa mi je draže da je bolje napajanje
EDIT: aaaa ti mislis na AMD procesor, a nezz nekako je Intel fan, pa bi radije Intela (losa iskustva s AMDom u proslosti), samo pomalo, hvala na pomoci
EDIT2: To je to, samo je reka uzet 1 TB HDD da mu nikad nije tribalo više od toga, i SteelSeries miš
hvala shan na savjetu i pomoci
Zadnje izmijenjeno od: OuttaControl. 05.04.2014. u 22:49.
Staro 05.04.2014., 11:21   #1324
Lepac
Datum registracije: Apr 2014
Lokacija: Zg zupanija
Postovi: 107
Poštovanje društvo. Ovak, trebao bi konfiguraciju za igre. Imam tastaturu , miš , hard , ssd i monitor samo bi trebao kučište sa komponentama. Gotovina, te ne preferiram posebno neki dućan i sastavljao bi ga sam tako da ne treba sve biti iz jednoga dućana. Ja sam razmišljao nešto ovako:
Intel core i5 4670K
Asus Z87 - PRO (treba mi bežični internet)
Zalman Z5 plus
XFX pro series 550W ili 750W
Kingston DDR3 16GB 1600MHz (2x8) KINGSTON KVR16N11K2/16
Noctua NH - D 14
Grafička: ne znam. Gledam da si za godinu dana mgu staviti u SLI ili crossfire.
(Sapphire 290 tri-x ili Asus PCIe 3.0 GTX780-DC2OC-3GD5 - GTX780 3GB , ovisno koje se bolje ponašaju u "dual modu")
Hvala unaprijed.
Lepac je offline   Reply With Quote
Staro 05.04.2014., 11:33   #1325
DragonSlayer
DragonSlayer's Avatar
Datum registracije: Nov 2012
Postovi: 723
@Lepac
Na kojoj rezoluciji igraš?
Hoćeš li raditi išta osim igranja?
DragonSlayer je offline   Reply With Quote
Staro 05.04.2014., 11:37   #1326
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
koliko para imaš uopce?
Staro 05.04.2014., 11:38   #1327
Lepac
Postovi: 107
Pa crtanje u CAD-u (3D nodeli , AUTOCAD) gledanje filmova. Sad mislim normalno na 1080p a za 3-5 godina ubosti kakav 4k monitor ako do tog vremena budu povoljni. Može do 9000 kN ili malo više.
Staro 05.04.2014., 11:44   #1328
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Treba ti bolje kuciste, npr ovako bi ja ako baš mora biti ta matična
1 x INTEL Core i5-4670K (3.40GHz,1MB,6MB,84 W,1150) Box, INTEL HD Graphics 4600
1 x Hladnjak Noctua NH-D14, Intel/AMD
1 x Matična ploča Asus Z87-PRO (C2)
2 x Corsair 1X8GB DDR3 1600 Low Profile
1 x SAPPHIRE R9 290 4Gb GDDR5 TRI-X OC
1 x Fractal ARC Midi R2, crno, bez napajanja ili R4 ili arc xl ili Corsair 550d
1 x XFX 750W Black Edition
Ukupno: 10120,53 kn
Zaboravih, to su cijene iz Futura IT
Staro 05.04.2014., 11:48   #1329
Lepac
Postovi: 107
Pa ne treba biti baš ta matična , glavno da ima wireless
Staro 05.04.2014., 11:52   #1330
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Možeš onda ovu npr Asus Z87-C + dodati si neki WiFi npr TP-Link 300Mbps Wireless N PCI i 300kn te izadje manje...
Staro 05.04.2014., 20:56   #1331
Dak1lla
Dak1lla's Avatar
Postovi: 119
Pozdrav ekipa, nisam dugo slagao neku konfu, pa bih zamolio samo za kratki review ove. U biti sto mene sada zanima dali je ovo napajanje dobar odabir, jer vidim da negdje predlazu oko 600+ za nvidiu 770. Ovo je OC verzija, mozda guta malo vise, pa sam u nedoumici.
CPU: Intel Core i7-4770K,
MBO: Asus GRYPHON Z87, MATX
RAM: 2x4GB Corsair DDR3 Vengeance Jet Black Low Profile, PC3-12800
GPU: 2GB Asus GTX 770 DirectCU II OC
PSU: 550W Corsair RM Series , Full Modular, 80 PLUS Gold 92% ili 650W RM
SSD: 240GB Corsair Force Series 3 SSD 2.5" SATA 6Gb/s, SandForce SSD
HDD: 1TB WD WD1003FZEX Black
CASE: Fractal Design ARC Mini R2 Micro ATX
COOLER: NH-D14
Svaki prijedlog je dobro dosao, uglavnom ce koristit za 1080p gaming i
kojesta, i naravno OC koliko se bude moglo.
everyone wants to go to heaven but no one wants to die
Zadnje izmijenjeno od: Dak1lla. 05.04.2014. u 21:58.
Dak1lla je offline   Reply With Quote
Staro 05.04.2014., 21:40   #1332
ShanTech
Postovi: 3,784
Napajanje od 550W je i više nego dovoljno.
Na CPU ide stock hladnjak ili neki aftermarket?
Staro 05.04.2014., 21:43   #1333
Dak1lla
Dak1lla's Avatar
Postovi: 119
Zaboravih napomenit da cu ugurat NH-D14 u kutiju , s time da imam ideju makniti ova dva hhd racka i smjestit HDD gore u tray, a SSD na MBO tray. To je opcija, mozda ne bude bilo potrebe.
@ShanTech thanks za info, cheers
Zadnje izmijenjeno od: Dak1lla. 06.04.2014. u 22:58.
Staro 07.04.2014., 15:07   #1334
Lepac
Postovi: 107
Hvala na prijedlozima. Gledajući po netu i po forumu odlučio sam se za ovo:
Kingston Technology HyperX blu 16GB DDR3-1600MHz Kit 1 034,00
Intel s1155 Core i5-3570K 1.499,00
Fractal Design Arc Midi R2 692,00
Seasonic SS-750AM2 EVO, 750W 749,73
Asrock Z77 Extreme3 - Intel Z77, ATX 675,99
Cooler Master - Hyper 212 EVO 239,00
wi fi 150
saphire R9 290 3.300,00
Jer ono kaj sam prije metnuo je preskupo i overkill za ono kaj ja trebam.
Samo me zanima dal je to seasonic napajanje dobro. Hvala unaprijed
Staro 20.04.2014., 12:51   #1335
FranKrsto
Postovi: 10
Autor Lepac Pregled postova
wi fi 150
Ako si rekao da koristis autocad i radis 3D i slicno ja bi na tvom mjestu uzeo i7 umjesto i5
FranKrsto je offline   Reply With Quote
Staro 22.04.2014., 15:02   #1336
Lepac
Postovi: 107
Pa , to što radim je oko 12 -24 sata na godinu i to samo solidworks, tako da ne radim puno. Komp bi bio prvenstveno za igre slijedećih 3-4 godine ili tak otprilike. Zato sam i uzeo grafu od 3000 kn a proc od 1500 kn. A u autocadu 2014 najvi8še radim i on šljaka na pentiumu 4 3,4 GHz i 2GB rama.
Hvala na prijedlogu.
Staro 26.04.2014., 15:01   #1337
lagrange
Lokacija: Kaštela
Postovi: 44
Pozdrav,
Treba mi krnja konfiguracija. Budžet mi je oko 5500 kn, al postam u ovaj cjenovni rang jer mi ne treba brdo stvari a mislim da ono najbitnije spada u ovaj rang. Kako bi htio i7 da upadnem u tu cijenu, otkinut ću zasad na ramu pa ću uzet samo jedan modul od 8gb pa nadogradit kasnije. dakle samo, procesor, mobo, ram, grafička, napajanje. služit će cad-u, malo i sitno rendera, i od igranja samo diablo 3, tako da grafulja ne treba bit nešto pre-uber.
uzet ću u ADM-a jer su cjenovno nešto sitno iznad EDigitala al kako čitam ED je nepouzdan ako nešto ode po zlu.
Dakle:
Procesor: Intel Core i7-4770K 3.50GHz, Haswell
Mobo: Asrock Z87 EXTREME4
GPU: Gigabyte R9 270 2GB OC
RAM: DDR3 8GB (1x8GB) Corsair 1600MHz CL9
Napajanje: Nemam pojma... treba mi prijedlog.
vidim da će to prijeć nešto tih 5500 al nema veze. pitanje je za taj proc i ploču jel to ok par. prvenstveno mislim na oc potencijal s tom pločom. inače stavio sam tu ploču jer mi se čini da daje puno više nego asus i gigabyte u tom cjenovnom rangu.
Zaboravio sam... Imam doma katanu za hladanjak proca tako da mi to ne treba kupovat. isto tako imam i hdd i ssd... i sve ostalo.
Zadnje izmijenjeno od: lagrange. 26.04.2014. u 15:12.
lagrange je offline   Reply With Quote
Staro 26.04.2014., 16:18   #1338
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
Ako ciljaš na OC, bolje ti je uzeti Ivy Bridge, osjetno manje se grije, a performanse na istom taktu lošije 5%. Napajanje modularno 80+ Gold, još malo jača grafička.
Procesor Intel Core i7 3770K
Matična ploča ASRock Z77 EXTREME3, 1155
Transcend JetRAM DDR3 DIMM, 8GB, 1600Mhz,CL11, retail, JM1600KLH-8G
Napajanje Seasonic SS-450G, 450W
XFX R9 270X 2GB DDR5, XFX-R9-270X-CDJC
Sveukupno: 5.497,52kn
Cijene su iz centra(dostava +40kn)...
Staro 26.04.2014., 20:00   #1339
ShanTech
Postovi: 3,784
Koje kućište imaš? Misliš klokati procesora? Ako misliš ganjati više taktove, katana ti nije dovoljna. Ako ne misliš uzimati "K" procesor, možeš uzeti i7-3770, skoro je 300 kn jeftiniji.
Ako ideš na LGA 1155 i put te nanese u Split, koji bi ti trebao biti blizu, imaš dobru ploču po odličnoj cijeni
http://www.nabava.net/search.php?tp=0&q=Z77H2-A3
Staro 26.04.2014., 21:39   #1340
Smartic
Smartic's Avatar
Postovi: 2,707
Autor lagrange Pregled postova
... prvenstveno mislim na oc potencijal...
@Shantech
Katana je OK za 4GHz max, za više ćeš trebati recimo Raijintek Ereboss/Scythe Ninja3/Enermax ETS-T40-Black Twister.
Staro 27.04.2014., 07:26   #1341
lagrange
Lokacija: Kaštela
Postovi: 44
ma znam da katana nije bogzna što za oc. al poanta je u tome da ja volim prčkat po kompu a ne da ću sad nešto ludo overclockat. hoću imat tu mogućnost, da sutra, kad bude para, ako mi se bude dalo, kupim hladnjak i overclockam. tako da ipak ostajem pri 1150 socketu.
Ta grafička što je Smartic spomenuo... Ja sam stavio onu gigabajtovu zato jer sam čito tu po forumu da je manje bučna i zato jer ima garu 3 godine. Ova XFXova u ADM-a košta isto ja mislim ko gigabytova. I samo generalno pitanje ako ima x u R9 270 oznaci... To je bolje?
Kasnije mi je upalo u oko da mi ploča koju sam stavio dolazi u mATX formatu a to mi se ne sviđa. Može li mi netko preporučit ploču u normalnom ATX formatu sličnih karakteristika. I volio bi da ima mogućnost za SLI/Crossfire.
Kućište mi je neko noname bezveze i to će isto doć na red... al za mjesec dva, kad bude para... nemojmo sad oko toga radit priču.
Staro 28.04.2014., 01:20   #1342
Smartic
Smartic's Avatar
Postovi: 2,707
Asrock Z87 EXTREME4, 1150, Intel® Z87, DDR3, Broj utora 4, 1600 MHz, PCI 2, PCIe x16 3, PCIe x1 2, SATA3 8, RAID 0,1,1+0,5, 6-kanalni audio, 1x 10/100/1000 Ethernet, eSATA 1, Display Port 1, USB 3.0 4, USB 2.0 3, ATX, Jamstvo : 36 mjeseca
ATX je to...
R9 270X je tvornički overclockana R9 270, znači možeš i R9 270 podići i iznad R9 270X taktova, čipovi su identični. Gigabyte je u redu.
Staro 02.05.2014., 03:10   #1343
ehohr
ehohr's Avatar
Postovi: 348
Da mijenjam nesto ili je ovo ok? Cifra je 8k sto mi se cini puno s obzirom da se ne kupuje u Hrvatskoj.
Case: Zalman Z11 Plus ATX Mid Tower Case
CPU cooler: Noctua NH-D14 CPU Cooler
SSD: Samsung 840 EVO Series Solid State Drive, 250GB
HDD: Seagate 1TB Desktop HDD SATA III w/ 64MB Cache
Memorija: Kingston HyperX Blue 8GB DDR3-1600MHz CL9 Dual Channel...
MBO: Asus Z87 GRYPHON
Napajanje: Corsair TX650M Modular Power Supply
CPU: Intel Core™ i7-4770 Processor, 3.40GHz w/ 8MB Cache
GPU: MSI R9 280X GAMING Radeon R9 280X 3GB PCI-E
ehohr je offline   Reply With Quote
Staro 02.05.2014., 10:01   #1344
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
krivi procesor je tu, pošto si uzo takav hladnjak i takvu ploču tu onda ide "K" procesor
ploču bi ja neku ATX uzeo kada već uzimaš ATX kućište ai neko drugo kućište, jer u tu ide na knap ove veće grafe, radje gledaj Z3+
grafa obavezno neka druga, tipa asus/sapphire toxic/gigabyte jer MSI 280x su jako loše i puno se kvare
Staro 02.05.2014., 10:36   #1345
Postovi: 33,987
Za gaming konfu SSD baš i nije obavezan, pogotovo ne toga kapaciteta.
Zadnje izmijenjeno od: coconut. 03.05.2014. u 10:09.
Staro 02.05.2014., 20:32   #1346
ehohr
ehohr's Avatar
Postovi: 348
Ok, ajmo ovako, mjesto gdje se treba kupit je.
http://www.memoryexpress.com/
Znaci sto bi bilo best buy konfa, jedino sto mi je bitno da ima taj SSD jer vecina igrica ima dugi load time a ssd odradi to jako brzo.
Nije bitno Intel ili AMD ( makar vjerujem da je intel i dalje bolji od FX procersora ) grafika isto nije bitna Nvidia ili ATI.
Staro 02.05.2014., 23:17   #1347
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Ovako nekako
Ako je previše metni 120Gb SSD
Staro 04.05.2014., 22:10   #1348
sloncuga
Datum registracije: May 2014
Postovi: 2
Pozdrav!
Trebao bih konfiguraciju od ~8000 kn, bez periferija.
Primarno za gaming i development, s tim da bih u njoj vrtio i virtualne mašine, tako da preferiram SSD od >200 GB na koji mogu potrpat i virtualne diskove, te 16 GB RAM-a.
Što se ostalog tiče, što bolja za gaming, da nije glasna i obavezno da nema problema s pregrijavanjem. Preferiram Intel procesor. Bilo bi idealno da se može kupiti u 1 dućanu, da mogu isklikat to na webu, naručit, oni to slože i dostave.
Hvala
sloncuga je offline   Reply With Quote
Staro 04.05.2014., 23:16   #1349
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
1 x INTEL Core i7-4770 (3.40GHz,1MB,8MB,84W,1150) Box, INTEL HD Graphics 4600
1 x CPU Hladnjak Raijintek Rhea, 92mm, PWM, Sck. 115*/775/1366
1 x Gigabyte GA-B85M-D3H,1150,iB85,D3,S3,U3,DVI,mA
2 x KINGSTON DDR3 (8GB,1600MHz(PC3-12800) CL11
1 x Grafička kartica Asus R9270X-DC2T-2GD5
1 x SSD SAM 250GB 840 EVO Basic
1 x Toshiba 1TB,7200rpm, 32MB HDD
1 x Optički uređaj LG GH24NS SATA Bulk Crni 24x
1 x Fortron Raider S 550W, 80+ SILVER
1 x Fractal ARC Mini, crno, bez napajanja
8000Kn
Trgovina po svojem izboru, iskustva raznih trgovina možeš pogledati ovdje. Ukoliko nema neke komponente u toj trgovini, pošalji upit te neka ti predlože zamjenski
Staro 05.05.2014., 20:40   #1350
sloncuga
Postovi: 2
Hvala!
