|  04.04.2014., 22:42 | #1321 |
| Premium Datum registracije: Feb 2007 Lokacija: Dalmacija
					Postovi: 5,870
				 | a bio sam stavio jednu pa sam promjenio u ovo Crucial Ballistix Sport Series DDR3-1600, CL9 - 16 GB Kit ,ta je normalna ako se nevaram http://www.caseking.de/shop/catalog/...html?from=cart a kućište, vidiš nisam iša za tim a u Zalman Z3 bi moralo stat? http://www.caseking.de/shop/catalog/...rz::24361.html a zvucnici mu nisu bitni, zato jer ce uglavnom bit headset Ili je mozda ovo bolja opcija onda: MBO:Gigabyte B85M-D3H CPU:Intel Core i5-4570 3,2 GHz HDD:Seagate Desktop SSHD 1TB RAM:Crucial Ballistix Sport Series DDR3-1600, CL9 - 16 GB Kit GPU:ASUS GeForce GTX 770 DC2OC, 2048 MB DDR5, DP, HDMI PSU:Seasonic S12II, GB 80 Plus Bronze Netzteil - 620 Watt Case:Zalman Z3-Plus Midi-Tower - schwarz Monitor: ASUS VS239HV, IPS 58,4 cm (23 Zoll) Widescreen - HDMI, DVI, VGA 165,00€ CM Storm Devastator - Tastatur + Maus SteelSeries 3HV2 Gaming Headset - schwarz Microsoft Windows 7 Home Premium 64 Bit SP1, DVD LCP (englisch) 1.149,80 EUR  Zadnje izmijenjeno od: OuttaControl. 04.04.2014. u 23:10. |
|  04.04.2014., 23:07 | #1322 |
| Banned Datum registracije: Apr 2011 Lokacija: -
					Postovi: 3,784
				 | Uzmi taj Zalman Z3 Plus.   Ne treba napajanje od preko 600W. AMD ne dolazi u obzir? Onda ovako Ploča: ASRock B85M Pro4 / ASRock H87 Pro4 Procesor: Intel Core i5-4570 3,2 GHz (Haswell) Sockel 1150 - tray Hladnjak: RAIJINTEK Aidos Heatpipe CPU-Kühler, PWM - 92mm Memorija: Team Group Elite Plus Series, DDR3-1600, CL11 - 8 GB Kit Grafička: MSI GeForce GTX 770, N770 TF 2GD5/OC, 2048 MB DDR5, DP, HDMI Kućište: Zalman Z3-Plus Midi-Tower - schwarz Napajanje: Seasonic M12II Evo, AM2 80 Plus Bronze Netzteil - 520 Watt SSD: Kingston SSDNow V300 Series 2,5 Zoll SSD, SATA 6G - 120 GB Disk: Seagate Desktop HDD, SATA 6G, 7200RPM, 3,5 Zoll - 2 TB Tipkovnica+miš: CM Storm Devastator - Tastatur + Maus Zvučnici: Logitech S120 2.0 Soundsystem - black Headset: SteelSeries 3HV2 Gaming Headset - schwarz Mousepad: Aerocool Strike-X Fury Mousepad OS: Microsoft Windows 7 Home Premium 64 Bit SP1, DVD LCP (englisch) Monitor: Dell Professional P2314H 58,4 cm (23 Zoll) Widescreen - DP, DVI, VGA Zadnje izmijenjeno od: ShanTech. 06.04.2014. u 15:12. |
|  04.04.2014., 23:18 | #1323 |
					Postovi: 5,870
				 | Nije da ne dolazi u obzir ali kaže da mu je nVidia draža, no ako je AMD bolji onda će njega uzet,  A posto ne misli igrat na multi monitor sustavu, taj 1 GB VRAMA mislim da nije toliko bitan Po testovima 770 je ipak jača mrvicu na FULL HD, no na kraju se svede na koja ti je draža ako mene pitaš  A neka napajanja, ima viška proračuna, pa mi je draže da je bolje napajanje  EDIT: aaaa ti mislis na AMD procesor, a nezz nekako je Intel fan, pa bi radije Intela (losa iskustva s AMDom u proslosti), samo pomalo, hvala na pomoci  EDIT2: To je to, samo je reka uzet 1 TB HDD da mu nikad nije tribalo više od toga, i SteelSeries miš hvala shan na savjetu i pomoci  Zadnje izmijenjeno od: OuttaControl. 05.04.2014. u 23:49. |
|  05.04.2014., 12:21 | #1324 |
| Premium Datum registracije: Apr 2014 Lokacija: Zg zupanija
					Postovi: 107
				 | Poštovanje društvo. Ovak, trebao bi konfiguraciju za igre. Imam tastaturu , miš , hard , ssd i monitor samo bi trebao kučište sa komponentama. Gotovina, te ne preferiram posebno neki dućan i sastavljao bi ga sam tako da ne treba sve biti iz jednoga dućana. Ja sam razmišljao nešto ovako:  Intel core i5 4670K Asus Z87 - PRO (treba mi bežični internet) Zalman Z5 plus XFX pro series 550W ili 750W Kingston DDR3 16GB 1600MHz (2x8) KINGSTON KVR16N11K2/16 Noctua NH - D 14 Grafička: ne znam. Gledam da si za godinu dana mgu staviti u SLI ili crossfire. (Sapphire 290 tri-x ili Asus PCIe 3.0 GTX780-DC2OC-3GD5 - GTX780 3GB , ovisno koje se bolje ponašaju u "dual modu") Hvala unaprijed. |
|  05.04.2014., 12:44 | #1328 |
| MiningMod Datum registracije: Jun 2005 Lokacija: Zagreb
					Postovi: 8,715
				 | Treba ti bolje kuciste, npr ovako bi ja ako baš mora biti ta matična 1 x INTEL Core i5-4670K (3.40GHz,1MB,6MB,84 W,1150) Box, INTEL HD Graphics 4600 1 x Hladnjak Noctua NH-D14, Intel/AMD 1 x Matična ploča Asus Z87-PRO (C2) 2 x Corsair 1X8GB DDR3 1600 Low Profile 1 x SAPPHIRE R9 290 4Gb GDDR5 TRI-X OC 1 x Fractal ARC Midi R2, crno, bez napajanja ili R4 ili arc xl ili Corsair 550d 1 x XFX 750W Black Edition Ukupno: 10120,53 kn Zaboravih, to su cijene iz Futura IT  |
|  05.04.2014., 12:52 | #1330 |
					Postovi: 8,715
				 | Možeš onda ovu npr Asus Z87-C + dodati si neki WiFi npr TP-Link 300Mbps Wireless N PCI  i 300kn te izadje manje... |
|  05.04.2014., 21:56 | #1331 |
| Premium Datum registracije: Sep 2007 Lokacija: Osijek
					Postovi: 119
				 | Pozdrav ekipa, nisam dugo slagao neku konfu, pa bih zamolio samo za kratki review ove. U biti sto mene sada zanima dali je ovo napajanje dobar odabir, jer vidim da negdje predlazu oko 600+ za nvidiu 770. Ovo je OC verzija, mozda guta malo vise, pa sam u nedoumici. CPU: Intel Core i7-4770K, MBO: Asus GRYPHON Z87, MATX RAM: 2x4GB Corsair DDR3 Vengeance Jet Black Low Profile, PC3-12800 GPU: 2GB Asus GTX 770 DirectCU II OC PSU: 550W Corsair RM Series , Full Modular, 80 PLUS Gold 92% ili 650W RM SSD: 240GB Corsair Force Series 3 SSD 2.5" SATA 6Gb/s, SandForce SSD HDD: 1TB WD WD1003FZEX Black CASE: Fractal Design ARC Mini R2 Micro ATX COOLER: NH-D14 Svaki prijedlog je dobro dosao, uglavnom ce koristit za 1080p gaming i kojesta, i naravno OC koliko se bude moglo.
				__________________ everyone wants to go to heaven but no one wants to die Zadnje izmijenjeno od: Dak1lla. 05.04.2014. u 22:58. |
|  05.04.2014., 22:40 | #1332 |
					Postovi: 3,784
				 | Napajanje od 550W je i više nego dovoljno. Na CPU ide stock hladnjak ili neki aftermarket? |
|  05.04.2014., 22:43 | #1333 |
					Postovi: 119
				 | Zaboravih napomenit da cu ugurat NH-D14 u kutiju   , s time da imam ideju makniti ova dva hhd racka i smjestit HDD gore u tray, a SSD na MBO tray. To je opcija, mozda ne bude bilo potrebe. @ShanTech thanks za info, cheers
				__________________ everyone wants to go to heaven but no one wants to die Zadnje izmijenjeno od: Dak1lla. 06.04.2014. u 23:58. |
|  07.04.2014., 16:07 | #1334 |
					Postovi: 107
				 | Hvala na prijedlozima. Gledajući po netu i po forumu odlučio sam se za ovo: Kingston Technology HyperX blu 16GB DDR3-1600MHz Kit 1 034,00 Intel s1155 Core i5-3570K 1.499,00 Fractal Design Arc Midi R2 692,00 Seasonic SS-750AM2 EVO, 750W 749,73 Asrock Z77 Extreme3 - Intel Z77, ATX 675,99 Cooler Master - Hyper 212 EVO 239,00 wi fi 150 saphire R9 290 3.300,00 Jer ono kaj sam prije metnuo je preskupo i overkill za ono kaj ja trebam. Samo me zanima dal je to seasonic napajanje dobro. Hvala unaprijed |
|  20.04.2014., 13:51 | #1335 | |
| Registered User Datum registracije: Apr 2014 Lokacija: Zagreb
					Postovi: 10
				 | Citiraj:
 Ako si rekao da koristis autocad i radis 3D i slicno ja bi na tvom mjestu uzeo i7 umjesto i5 | |
|  22.04.2014., 16:02 | #1336 |
					Postovi: 107
				 | Pa , to što radim je oko 12 -24 sata na godinu  i to samo solidworks, tako da ne radim puno. Komp bi bio prvenstveno za igre slijedećih 3-4 godine ili tak otprilike. Zato sam i uzeo grafu od 3000 kn a proc od 1500 kn. A u autocadu 2014 najvi8še radim i on šljaka na pentiumu 4 3,4 GHz i 2GB rama.  Hvala na prijedlogu. |
|  26.04.2014., 16:01 | #1337 |
| Premium Datum registracije: Feb 2006 Lokacija: Kaštela
					Postovi: 44
				 | Pozdrav, Treba mi krnja konfiguracija. Budžet mi je oko 5500 kn, al postam u ovaj cjenovni rang jer mi ne treba brdo stvari a mislim da ono najbitnije spada u ovaj rang. Kako bi htio i7 da upadnem u tu cijenu, otkinut ću zasad na ramu pa ću uzet samo jedan modul od 8gb pa nadogradit kasnije. dakle samo, procesor, mobo, ram, grafička, napajanje. služit će cad-u, malo i sitno rendera, i od igranja samo diablo 3, tako da grafulja ne treba bit nešto pre-uber. uzet ću u ADM-a jer su cjenovno nešto sitno iznad EDigitala al kako čitam ED je nepouzdan ako nešto ode po zlu. Dakle: Procesor: Intel Core i7-4770K 3.50GHz, Haswell Mobo: Asrock Z87 EXTREME4 GPU: Gigabyte R9 270 2GB OC RAM: DDR3 8GB (1x8GB) Corsair 1600MHz CL9 Napajanje: Nemam pojma... treba mi prijedlog. vidim da će to prijeć nešto tih 5500 al nema veze. pitanje je za taj proc i ploču jel to ok par. prvenstveno mislim na oc potencijal s tom pločom. inače stavio sam tu ploču jer mi se čini da daje puno više nego asus i gigabyte u tom cjenovnom rangu. Zaboravio sam... Imam doma katanu za hladanjak proca tako da mi to ne treba kupovat. isto tako imam i hdd i ssd... i sve ostalo. Zadnje izmijenjeno od: lagrange. 26.04.2014. u 16:12. |
|  26.04.2014., 17:18 | #1338 |
| Premium Datum registracije: Mar 2011 Lokacija: Varaždin
					Postovi: 2,707
				 | Ako ciljaš na OC, bolje ti je uzeti Ivy Bridge, osjetno manje se grije, a performanse na istom taktu lošije 5%. Napajanje modularno 80+ Gold, još malo jača grafička. Procesor Intel Core i7 3770K Matična ploča ASRock Z77 EXTREME3, 1155 Transcend JetRAM DDR3 DIMM, 8GB, 1600Mhz,CL11, retail, JM1600KLH-8G Napajanje Seasonic SS-450G, 450W XFX R9 270X 2GB DDR5, XFX-R9-270X-CDJC Sveukupno: 5.497,52kn Cijene su iz centra(dostava +40kn)... |
|  26.04.2014., 21:00 | #1339 |
					Postovi: 3,784
				 | Koje kućište imaš? Misliš klokati procesora? Ako misliš ganjati više taktove, katana ti nije dovoljna. Ako ne misliš uzimati "K" procesor, možeš uzeti i7-3770, skoro je 300 kn jeftiniji. Ako ideš na LGA 1155 i put te nanese u Split, koji bi ti trebao biti blizu, imaš dobru ploču po odličnoj cijeni http://www.nabava.net/search.php?tp=0&q=Z77H2-A3 |
|  27.04.2014., 08:26 | #1341 |
					Postovi: 44
				 | ma znam da katana nije bogzna što za oc. al poanta je u tome da ja volim prčkat po kompu a ne da ću sad nešto ludo overclockat. hoću imat tu mogućnost, da sutra, kad bude para, ako mi se bude dalo, kupim hladnjak i overclockam. tako da ipak ostajem pri 1150 socketu. Ta grafička što je Smartic spomenuo... Ja sam stavio onu gigabajtovu zato jer sam čito tu po forumu da je manje bučna i zato jer ima garu 3 godine. Ova XFXova u ADM-a košta isto ja mislim ko gigabytova. I samo generalno pitanje ako ima x u R9 270 oznaci... To je bolje? Kasnije mi je upalo u oko da mi ploča koju sam stavio dolazi u mATX formatu a to mi se ne sviđa. Može li mi netko preporučit ploču u normalnom ATX formatu sličnih karakteristika. I volio bi da ima mogućnost za SLI/Crossfire. Kućište mi je neko noname bezveze i to će isto doć na red... al za mjesec dva, kad bude para... nemojmo sad oko toga radit priču. |
|  28.04.2014., 02:20 | #1342 |
					Postovi: 2,707
				 | Asrock Z87 EXTREME4, 1150, Intel® Z87, DDR3, Broj utora 4, 1600 MHz, PCI 2, PCIe x16 3, PCIe x1 2, SATA3 8, RAID 0,1,1+0,5, 6-kanalni audio, 1x 10/100/1000 Ethernet, eSATA 1, Display Port 1, USB 3.0 4, USB 2.0 3, ATX, Jamstvo : 36 mjeseca ATX je to... R9 270X je tvornički overclockana R9 270, znači možeš i R9 270 podići i iznad R9 270X taktova, čipovi su identični. Gigabyte je u redu. |
|  02.05.2014., 04:10 | #1343 |
| Premium Datum registracije: Jan 2007 Lokacija: Zagreb
					Postovi: 348
				 | Da mijenjam nesto ili je ovo ok? Cifra je 8k sto mi se cini puno s obzirom da se ne kupuje u Hrvatskoj. Case: Zalman Z11 Plus ATX Mid Tower Case CPU cooler: Noctua NH-D14 CPU Cooler SSD: Samsung 840 EVO Series Solid State Drive, 250GB HDD: Seagate 1TB Desktop HDD SATA III w/ 64MB Cache Memorija: Kingston HyperX Blue 8GB DDR3-1600MHz CL9 Dual Channel... MBO: Asus Z87 GRYPHON Napajanje: Corsair TX650M Modular Power Supply CPU: Intel Core™ i7-4770 Processor, 3.40GHz w/ 8MB Cache GPU: MSI R9 280X GAMING Radeon R9 280X 3GB PCI-E |
|  02.05.2014., 11:01 | #1344 |
					Postovi: 8,715
				 | krivi procesor je tu, pošto si uzo takav hladnjak i takvu ploču tu onda ide "K" procesor ploču bi ja neku ATX uzeo kada već uzimaš ATX kućište ai neko drugo kućište, jer u tu ide na knap ove veće grafe, radje gledaj Z3+ grafa obavezno neka druga, tipa asus/sapphire toxic/gigabyte jer MSI 280x su jako loše i puno se kvare |
|  02.05.2014., 11:36 | #1345 |
| Premium Datum registracije: Mar 2006 Lokacija: Opatija
					Postovi: 34,005
				 | Za gaming konfu SSD baš i nije obavezan, pogotovo ne toga kapaciteta.
				__________________ "Dvije stvari su beskonačne - svemir i ljudska glupost. Za svemir nisam siguran." A. Einstein Zadnje izmijenjeno od: coconut. 03.05.2014. u 11:09. |
|  02.05.2014., 21:32 | #1346 |
					Postovi: 348
				 | Ok, ajmo ovako, mjesto gdje se treba kupit je. http://www.memoryexpress.com/ Znaci sto bi bilo best buy konfa, jedino sto mi je bitno da ima taj SSD jer vecina igrica ima dugi load time a ssd odradi to jako brzo. Nije bitno Intel ili AMD ( makar vjerujem da je intel i dalje bolji od FX procersora ) grafika isto nije bitna Nvidia ili ATI. |
|  04.05.2014., 23:10 | #1348 |
| Registered User Datum registracije: May 2014 Lokacija: Zagreb
					Postovi: 2
				 | Pozdrav! Trebao bih konfiguraciju od ~8000 kn, bez periferija. Primarno za gaming i development, s tim da bih u njoj vrtio i virtualne mašine, tako da preferiram SSD od >200 GB na koji mogu potrpat i virtualne diskove, te 16 GB RAM-a. Što se ostalog tiče, što bolja za gaming, da nije glasna i obavezno da nema problema s pregrijavanjem. Preferiram Intel procesor. Bilo bi idealno da se može kupiti u 1 dućanu, da mogu isklikat to na webu, naručit, oni to slože i dostave.  Hvala |
|  05.05.2014., 00:16 | #1349 |
					Postovi: 8,715
				 | 1 x INTEL Core i7-4770 (3.40GHz,1MB,8MB,84W,1150) Box, INTEL HD Graphics 4600 1 x CPU Hladnjak Raijintek Rhea, 92mm, PWM, Sck. 115*/775/1366 1 x Gigabyte GA-B85M-D3H,1150,iB85,D3,S3,U3,DVI,mA 2 x KINGSTON DDR3 (8GB,1600MHz(PC3-12800) CL11 1 x Grafička kartica Asus R9270X-DC2T-2GD5 1 x SSD SAM 250GB 840 EVO Basic 1 x Toshiba 1TB,7200rpm, 32MB HDD 1 x Optički uređaj LG GH24NS SATA Bulk Crni 24x 1 x Fortron Raider S 550W, 80+ SILVER 1 x Fractal ARC Mini, crno, bez napajanja 8000Kn Trgovina po svojem izboru, iskustva raznih trgovina možeš pogledati ovdje. Ukoliko nema neke komponente u toj trgovini, pošalji upit te neka ti predlože zamjenski  |
|  05.05.2014., 21:40 | #1350 |
					Postovi: 2
				 | Hvala! |
