Staro 25.03.2014., 19:30   #1
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Nvidia Geforce GTX Titan Z
Danas predstavljena najjaca nvidijina dvoglava kartica :
Jen Hsun Huang has just unveiled the latest GPU from the green team that pushes them beyond what Titan has to offer. It was made clear that Titan was and still is the most extreme graphics card on the planet, which makes it hard for a company to move forward. Nvidia have managed to do just that and the Titan Z has been born.
The card as you can see follows on the same sexy styling that the Titan brought to us.
Jen Hsun Huang holds the card in his hand and explains what the specifications of the card is.
A closer look of the card shows off that fantastic design and cooling solution.
With 5,760 CUDA cores, 12GB of memory, 8 TeraFLOPS and a price point of $2999.
izvor : http://www.eteknix.com/nvidia-announ...z-gpu-gtc-2014
Staro 25.03.2014., 19:47   #2
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Znači $2999
Ako u nekom slučaju jedna kartica završi kod nas, koštala bi oko €3500?
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 25.03.2014., 20:25   #3
Ecips Dlo
Ecips Dlo's Avatar
Datum registracije: May 2009
Lokacija: brlog
Postovi: 489
Autor JohnnyBoy Pregled postova
Glupost, debilizam, idiotizam to su moja 3 centa za svaku novu karticu koja kosta vise od 2k kn, mislim cemu sve to pa nek izdaju odmah ono najace sto imaju i nek prestanu zajebavat nas posten narod.
Koji idiot placa toliko novaca za komad hardwarea kad si mozes priustiti 3x zanimljiviju i bolju stvar za te novce, samo me zanima jeli ova napokon bolja od 7990 jer ako nije ja bih na njihovom mjestu prestao predstavljat ista novo.
mozda oni koji zive od toga?
edit:
stvarno impresivan napredak ako ga uspiju ostvariti
Zadnje izmijenjeno od: Ecips Dlo. 25.03.2014. u 20:43.
Ecips Dlo je offline   Reply With Quote
Staro 25.03.2014., 20:29   #4
MAGARAC
MAGARAC's Avatar
Postovi: 5,993
Naravno da je bolja. Jedna Titan Be nije daleko, pogotovo naklokana a dve je siluju.
Cijena je i mene iznenadila al to je ionak grafa kao ono, mi to mozemo i nebu se to stancalo u nekim velkim kolicinama..
Staro 25.03.2014., 20:56   #5
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Genijalnost level over9000. Pa ne koriste se takve grafe samo za igranje
Autor syss Pregled postova
onaj kojem podatak o broju cuda jezgri znači nešto
edit: sad mu pogledah datum registracije, fejsbuk đenerejšn
Autor Ecips Dlo Pregled postova
ecips, bogami ako 2016 grafe budu imale takvu snagu, nasljednik gtx 750 ce bit jaci od 780ti
Staro 25.03.2014., 21:35   #6
Garro
Postovi: 2,397
Ako gledamo "znanstvene" primjene gdje DP igra ulogu, za tu cifru se kupe tri Titana Black koji prometu pod s ovom grafom.
Za igranje, četiri 780ti i još ostane love.
Mislim, svaka čast nVidiji, ali ne vidim svrhu ovog proizvoda po ovoj cijeni.
Staro 25.03.2014., 22:52   #7
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,336
Autor Garro Pregled postova
Cijena je bezobrazna tu se slazemo (nebi smejla kostat vise od 2000$ ako je u biti zaljepljena *Tatana koji su 1000$/kom) ali trebas gledati i drugu stranu medalje. Ako bude trosila manje struje od 2*Titan a stane u jedan Dual slot (premda mi izgled akoa 2.5x slota) onda je "bolja" kupnja nego 2*Titan jer onda u konfu mozes naguarati duplo vise sange u 4 slota bez da kupujes posteni PCI-E expansion box koji sam kosta 2000-3000$ . Znaci onda mozes su konfu nagurati 4*Titan Z sto bi bilo 8 komda Titana koji inace nestanu na "normalne" ploce je rnam tolko utora niti standardnih kucista sa 16 PCI-E utora .
Svaka roba ima svog kupca
Staro 25.03.2014., 23:34   #8
Garro
Postovi: 2,397
Ne znam, ako ti treba 8 full GK110 čipova, onda uzmeš 8 Titana, 4 staviš u jednu mašinu, 4 u drugu slave i još uvijek si u plusu sa lovom. A količinu struje i topline koju 8 čipova isijava se ne usudim zamisliti.
Razumijemo se da svaka roba ima svog kupca, ali ova cijena je jednostavno bezobrazna.
Staro 25.03.2014., 23:37   #9
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,336
Ne "vrijede" mi u drugoj masini dok stelam scenu i namjestam materijale treba biti sto brze ide znaci sve u pogonu u isto vrijeme .
Staro 26.03.2014., 00:06   #10
MAGARAC
MAGARAC's Avatar
Postovi: 5,993
Svrha je cisti marketing i kcenje. Imamo najveceg, najbrzeg, najskupljeg, vjerojatno ce bit i najefikasniji u toj konkurenciji kad dode. Malo pokazuju kaj mogu.
Staro 26.03.2014., 02:08   #11
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 5,925
cekaj ako je moja racunica dobra, naspram obicnom titanu ova bi tribala kostat dolar ipo
Staro 26.03.2014., 09:34   #12
chief_wolfinjo
tako nekako , plus minus dolar
Staro 26.03.2014., 09:39   #13
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,336
To je cijena za 10 godina
Staro 26.03.2014., 10:22   #14
Garro
Postovi: 2,397
Gledam sliku sa osvjetljenim Geforce GTX logom... ili je ovo loš Photoshop ili će logo biti naopako u kućištu.
@ Lewis: ne znam, za 12.000$ koliko samo koštaju 4 TitanaZ mislim da se može složiti bolja mašina sa 8 Titana Black (8.000$) i nekakvim expanderom (valjda ne košta 4.000$).
Staro 26.03.2014., 10:42   #15
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,336
Nestor NA255A kod nas ispadne oko 2500-2600$ tako da moglo bi se slozit nesto slicno, pitanje je samo kolko dugo ce Z biti 3000$
http://www.netstor.com.tw/_03/03_02.php?MTEx
http://www.ebay.ca/itm/NETSTOR-Turbo...-/261251960120
Staro 26.03.2014., 10:52   #16
Garro
Postovi: 2,397
I još uvijek je kombinacija 8 Titana Black i Netstor kućišta jeftinija od 4 Titana Z.
A nekako sumnjam da bi 4 Titana Z mogla biti jedan kraj drugog bez poštenog vodenog hlađenja...
A za cijenu, dobro kažeš.
Staro 26.03.2014., 10:56   #17
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,336
Cisto sumnjam da i 8 titana moze biti u kutiji bez vodenog takd a to je vec druga prica .
Ali definitivno nevjerujem da ce mocu prodavati Za za 50% vecu cijenu nego 2 Titana Black, mozda par mjeseci a onda ce pasti cijena .
Staro 26.03.2014., 12:31   #18
Dottore
Dottore's Avatar
Postovi: 7,703
Autor Lewis Pregled postova
Ako ne uspiju prodati, onda padaju više.
Cijena za Z je smiješna. Pretjerano.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Dottore je online   Reply With Quote
Staro 26.03.2014., 12:51   #19
Garro
Postovi: 2,397
Možda može biti u 2 kutije? Expander, remember. Ali sam se ove sekunde sjetio da bi moglo biti 7 Titana Black, naime, jedan PCI-E slot treba za expander karticu.
Vjerujem da bi bilo manje problema s obzirom da su na singleGPU Titanima bloweri koji ispucavaju zrak van kućišta, a Titani Z pola topline vraćaju nazad u kućište... kako bi to izgledalo u zatvorenom kućištu i full loadu, strah me i pomisliti.
Staro 26.03.2014., 12:56   #20
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,336
Kolega je nedanvno slozio 3*780Ti i u renderu griju se bezobrazno (84C) tako da je na kraju zavrsio na vodenom za sve tri + oba CPUa ali taj sport kosta laganih 1000EUR . Tako da sto god stavio u kutiju od tih mrcina temp ce biti opaka u svakoj kombinaciji osim vodenoga (sad mu je 42-44C).
Staro 26.03.2014., 16:48   #21
ante2
ante2's Avatar
Postovi: 1,313
Kaj kolega honorarno radi za Pixar ili neku drugu firmu slicnog tipa .
Sad izbiljno, sta se radi sa takvom drobilicom brojeva i slova (ovisi jel razmisljate binarno ili decimalno )
MSI Z77 MPower
Intel i5 3570K @4,2GHz, NOCTUA NH-U12S
Gigabyte GTX 1070
DDR3 16GB (4x4GB) 1600Hz Corsair Vengeance
Carbide Series Air 540, Corsair RM750i
CREATIVE LABS X-Fi Titanium-Kingston HyperX Cloud
DELL U2515H
Synology DS413
ante2 je offline   Reply With Quote
Staro 26.03.2014., 17:02   #22
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,336
Autor ante2 Pregled postova
GPU rendering.
Ima jos jedan kolga sa 7 Titana . ja gledam bili uzeo 2 Titana ili 3*780Ti. Kucist mi je stiglo (900D) priej 10 dana ali nikako uhvatit vreman za sve prebacit pa pocet kemijat .
Staro 26.03.2014., 17:15   #23
MAGARAC
MAGARAC's Avatar
Postovi: 5,993
3 x 780 6gb?
Staro 26.03.2014., 17:44   #24
ante2
ante2's Avatar
Postovi: 1,313
GPU rendering.
Rendering ceka, ako nije tajna.
Mogu i ja rendering onako iz cistog gusta (da se stuja trosi), ali me zanima ko di kada i koliko, a bome i za koga.
Ako nije tajna
MSI Z77 MPower
Gigabyte GTX 1070
DELL U2515H
Synology DS413
Staro 26.03.2014., 18:14   #25
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,336
Autor MAGARAC Pregled postova
3 x 780 6gb?
Razmisljo sma i o tome ali kad vec ide htio bi da bude ful 2880 CUDA jer je poptpuno linearno ubrzanja . Mozda da izbace 780Ti 6Gb to bi bila najbolja opcija
Ako nije tajna
Animacija, reklama, raznih videa, arch-viz.... itd. itd. Za koga ? Pa 'ko god naruci .
Ovako nesto (to sam radio prije godinu i vise)
https://www.youtube.com/watch?v=9xZ-...r6xMxoArW626KQ
ili ovako:
https://www.youtube.com/watch?v=yx6H...r6xMxoArW626KQ
Staro 26.03.2014., 22:52   #26
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Ma koje rendanje ovo triba uzet za majnanje
Samo čekam da je Syss nabavi prvi
Pomelo mi sig -.-
Staro 26.03.2014., 22:58   #27
syss
syss's Avatar
Postovi: 10,805
čekam amex odobrenje
Staro 27.03.2014., 02:30   #28
ante2
ante2's Avatar
Postovi: 1,313
Cek-cek, sta ATI-AMD nije bio bolji za majnanje/rudarenje, ono osjetno bolji ???
MSI Z77 MPower
Gigabyte GTX 1070
DELL U2515H
Synology DS413
Staro 27.03.2014., 02:39   #29
MAGARAC
MAGARAC's Avatar
Postovi: 5,993
To sad kupim i kroz godinu dana popusim onak bar 10000kn..
Staro 27.03.2014., 08:45   #30
Drvoje
Drvoje's Avatar
Postovi: 4,037
Navukli se - na zayebanciju (samo dvojica zasad)
Syss je već iskusnjara, ne da se on žedan pored "žabe" prevest
Pomelo mi sig -.-
