01.10.2013., 21:25 | #181 |
Postovi: 10,805
p67 sa raid na ahci + ssd testovi na 3 kontrolera
ajmo junaci tko je na p67 ili ovoj mojoj mbo uspio srediti prebacivanje sa raid kontrolera na instaliranim win na ahci bez ubijanja sistema? cijelu večer se maltram i najbliže sam došao do bsoda pri bootu |
01.10.2013., 21:53 | #182 |
Postovi: 12,450
One dvije stavke u registryu si mijenjao?
01.10.2013., 22:04 | #184 |
Postovi: 22,674
E jesi ga precizno definirao - koji winsi ? Pretpostavljam W7 Gore si rekao RAID > AHCI. Prvo napravi backup sys particije da se možeš vratit unazad ako z . . . š, potom probaj ovo: Change to ACHI mode from RAID mode: 1 Exit all Windows-based programs. 2 Press [Win] + R or take the RUN option from the start menu. 3 Now type regedit there and press Enter Key to open up the Registry Editor Window. 4 If you receive the User Account Control dialog box, click Continue. 5 Locate and then click the following registry subkeys: Code:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\pciide HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\msahci HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStorV HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\atapi 7 In the Value data box, type 0 [3 is default], and then click OK. 8 On the File menu, click Exit to close Registry Editor. 9 Restart your computer 10 Go to UEFI/BIOS and enable AHCI, Save & Reboot 11 Another restart will be required to finish the driver installation. Note: You might not have the last registry key (iastor) as this is installed in the registry with the intel raid drivers, the default windows 7 raid driver uses the iastorV key. Po meni bolje ove promjene u registry - ju bolje napraviti offline preko nekog Win Live cd - a. Još jedan detalj, provjeri jeli odgovarajući drajver u "windows\system32\drivers" folderu, vidi fajlove u sat drajveru. Prijavi rezultat Zadnje izmijenjeno od: Nikky. 01.10.2013. u 22:12. |
01.10.2013., 22:12 | #185 |
Postovi: 10,805
napravio sam backup particije nakon što sam jedva uspio vratiti sve da radi pod raidom dobro znam to je totalna lijenost nego sada ozbiljno vidio sam taj guide i nije to to... pciide i atapi su postavke koje diraju ahci -> ide spiku i nisu mi zanimljive, ovo ostalo je sve na 0 ne bi postao da nije misterija totalna... mislim oke najjednostavnije je izbaciti raid diskove iz polja, ostaviti raid kontroler da radi makar ima non-member diskove i bok. ali neću p.s. zapravo ovo možda i ima smisla makar nema p.p.s. ako se ne javljam znači da ne radi |
01.10.2013., 22:33 | #186 |
Postovi: 12,450
Aha, sad sam skuzio da je raid u pitanju, a koji raid je bio dignut?
01.10.2013., 22:34 | #187 |
Postovi: 22,674
Nastavak na temu, vidi: http://www.overclock.net/t/1227636/h...#post_18892894 |
01.10.2013., 22:40 | #189 |
Postovi: 12,450
0...nece ic
02.10.2013., 19:20 | #191 |
Postovi: 10,805
znači ovo je bio toliki loooooongshot da je čudo kako je upalilo ovaj autofix od ms-a dovodi do bsoda i na ata i ahci postavkama, ali ajde barem kada se vrati raid bios sve radi normalno. dakle ono što je trebalo napraviti je enejblati atapi postavku u ređistriju (sa 3 na 0), nakon restarta i bacanja na ahci instalira se standard msahci driver i svi diskovi se vide kao ata diskovi u divajs menađeru, makar ih se može removati kao usb divajsovi (što je odlika ahci-ja jel) što je čudno samo po sebi. nakon toga update kontroler drivera sa zadnjeg dostupnog intelovog za moju mbo i pronađe intel desktop/workstation... bla driver i sve diskove kao scsi divajsove međutim nema više remove funkcije diskova što je isto tako čudno. no dobro eto sada znamo da raid ide na neki čudni ata i onda apdejt na ahci. dobro da mi je palo na pamet zvrtit benčeve na ssd-u sa različitim kontrolerom i driverom u suradnji pošto su rezultati prilično zanimljivi: prva slika msahci stock driveri, druga slika intel ahci driveri, treća slika intel raid kontroler + driver (s tim da je tada disk bio jedno 10ak% manje zapunjen nego na prve dvije). ajde neka sam i to riješio |
06.10.2013., 01:38 | #192 |
Datum registracije: Aug 2013
Lokacija: DR
Postovi: 5
Intel Core 2 Duo E6850 driver?
Imam manji problem "štekanja" kada igram LoL ali i kada pokrenem puna procesa tipa google chrome(muzika) + LoL + neki sitni Task i desi mi se često da mi se smrzne ekran na 2,3 sekunde (najčešće za vrijeme igranja LoL-a) ili da moram čekat chrome ili tako nešto "tri dana" da se otvori. U oba slučaja kada pokrenem Task Manager uhvatim CPU na 100%, sad, nemam iskustva ni znanja o tome koliko je procesor ovisan on driveru i da li se za procesor update-aju ovi driveri iz Device Managera (kolko čitam na stranim forumima ne) pa me zanima vaše mišljenje šta bi se tu moglo napravit. Evo i konfiguracije i procesora: Također zanima me i ovo stanje procesora di piše, pretpostavljam, da radi na 2.07GHz a to je 3.0GHz procesor... da li to smijem podizat? Hvala! |
06.10.2013., 02:48 | #193 |
Postovi: 5,702
Uključen ti je opcija spustanja takta, tzv EIST (Enhanced Intel SpeedStep® Technology)i to si mozes isključit u biosu. A sto se tiče ovog stekanja na par sekundi, ja bi na tvom mjestu najprije probao sa format c: i novom instalacijom windowsa |
06.10.2013., 14:14 | #194 |
Lokacija: DR
Postovi: 5
Tako i jesam, pred nekih dva tjedna je formatiran C disk i stavio sam windowse ponovo. Da li išta sa D diska (particije na kojoj držim filmove, igre, programe,... uglavnom ništa na taj ne instaliram) može utjecat na to? |
07.10.2013., 15:41 | #198 |
Datum registracije: Jun 2011
Lokacija: istra
Postovi: 33
malo dignut voltazu proca stvarno za jako malo i onda staviti na 400x8 i jos neke sitnice tamo na turbo i tako uglavnom moras se igrati ali nevjerujem da zbog toga imas stekanje...dizel ne zafrkavaj covjeka nema divera za cpu..probaj naci zadnje drivere za chipset Zadnje izmijenjeno od: puma29x. 07.10.2013. u 15:54. |
07.10.2013., 16:18 | #199 |
Postovi: 180
Ima tu iskusnijih od mene, ali ja nebi isključivao eist jer on podigne na deklariranu frekvenciju po potrebi,odnosno spusti kad nema potrebe za to,tako da nema štete od njega. Za početak vidi u task manageru što ti najviše zauzima procesor i onda to ugasi ako ti nije potrebno, iako mislim da tu nije ništa više od toga da opteretiš proc više nego on može. |
07.12.2013., 00:56 | #201 |
Lost soul still wondering
Lokacija: Aiur
Postovi: 474
Gigabyte GA-Z87-HD3 problem
pozdrav imam problema sa GA-Z87-HD3 pločom. Problem je u tome da radi samo sa 1 memorijom, čim stavim drugi keks ne boota. probal sam staviti novi bios, uključiti default postavke, xmp isto ne pomaže i ne mogu ju natjerati da mi radi sa obje memorije. Memorija je corsair vengance 2x4 gb 2133 mhz. kaj još eventualno mogu probati?
Da nije nas bile za grabu bi spal |
07.12.2013., 11:21 | #203 |
Lokacija: Aiur
Postovi: 474
Uspio sam natjerati da i druga memorija proradi. Želi raditi samo u 1 od ostala 3 memorijska slota. Za sad barem radi, pa se mogu kasnije pozabaviti gdje je problem.
27.01.2014., 14:03 | #204 |
Postovi: 251
Pozdrav, imam pitanje za vas. Imam DDR2 667mhz rame i upario bi to sa recimo Intel E7300 koji ima fsb 1066mhz. Da li bi to radilo i jel bi procesor radio na manjem taktu?
Kad sam bio mlad mislio sam da je novac najvažnija stvar u životu; sad kad sam ostario znam da jest! - Oscar Wilde |
27.01.2014., 14:24 | #205 |
Protupožarac
Lokacija: Tamo gdje sunce vječno sja
27.01.2014., 14:44 | #206 |
Postovi: 251
Čisto sigurnosti radi, ovo "nebi" se odnosilo na brzinu procesora, a ne na prvi dio pitanja jel bi radilo? Hvala na brzom odgovoru
27.01.2014., 14:52 | #207 |
Protupožarac
Sorry, neki puta napišem tako smislen post da ni sam ne znam kaj znači Uglavnom, nećeš imati problema. Mi imamo u firmi strojeve sa 533MHz RAM-om, pa svi procesori rade na svojim nominalnim taktovima. |
02.02.2014., 21:20 | #208 |
Lokacija: U kuci
Postovi: 1
Problem sa RAM
Pozz svima Imam problema sa ramima, imam 2x 2gb ddr2 Transcend (obe kartice su iste) Testirane svaka posebno i svaka posebno u utorima, na maticnoj ploci imam 2 utora za ram, ako je samo jedna kartica unutra bilo koja od te dvije komp radi normalno, ako su zajedno pojavi mi se blue screen ili se samo smrzne nakon nekog vremena, probo sam skenirat sa memtest i nema problema svaku karticu posebno i obe zajedno. A i na windows mi pokazuje ( installed memory 4gb (3,87 gb usable) ). Windows 7 64 bit. Zna li neko gdje je problem pomagajte |
08.02.2014., 12:36 | #209 |
Postovi: 72
Intel class 5, 3400 chipset controller NE STARTA :/
Svaki put kada se Win7 starta, ovaj USB kontroler ne starta i nije moguće spojiti USB uređaje (ima onaj žuti uskličnik uz ikonicu). Tek nakon što ga disable(am) pa zatim odmah enable(am) eto ga, prorati i polovi sve USB uređaje spojene u utore... Može li se ova disable-enable varijanta nekako automatizmom odraditi ili... baš i ne? Aha, naravno, pod Linux-om radi sve super! Hvala za sugestije! ps komp: Toshiba Satellite L835-133 |
