Staro 19.01.2014., 21:56   #571
gmax
Tuco “the Rat” Ramirez
gmax's Avatar
Postovi: 469
Ak su već sad na polovici EP pali fizički/kondicijski, bolje da se već večeras vrate doma prvim avionom.
Staro 19.01.2014., 21:56   #572
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,741
Autor wnbeeeE Pregled postova
fizički/kondicijski smo pali.
Da, ali radi idiotske taktike. Kažu svi; čudna utakmica. Da, je. Zato što je Onesta rastavio Golužu i igru.
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 19.01.2014., 21:59   #573
snorky_vk
snorky_vk's Avatar
Lokacija: u mraku
Postovi: 846
Psihologija
snorky_vk je offline   Reply With Quote
Staro 19.01.2014., 22:00   #574
nino
nino's Avatar
Postovi: 12,599
Meni je sve bilo jasno kad je Omeyer dosao na gol. Kad se ugrijao, to je bilo to.
Staro 19.01.2014., 22:05   #575
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
prvih 20 minuta - jebite, ovo bi moglo biti slatko gazenje francuzica.
sljedecih 10 minuta, od 20e minute do poluvremena - hm, jebemu, opet onaj osjecaj kada padamo i moglo bi biti svasta, ali ajd, poslije poluvremena ce malo doci k sebi.
drugo poluvrijeme - . al' jebote, ko' da su svi zakazali. prvi Goluza, pa u PM da smo mi valjda jedni od rijetkih koji imamo samo nase trenere, pa jebemu ako nema nikoga od nas - uvezi ga od nekuda! tako se svejedno sve uvozi u ovoj drzavi, daj par pametnih ljudi koji vode te reprezentacije, da se dovede nekakav kontinuitet i konstanta.
veceras su Francuzi ponudili saku, mi smo mogli odgristi cijelu ruku. ali ispalo smijesno, Francuzi losi - mi jos losiji .
Staro 19.01.2014., 22:12   #576
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Autor nino Pregled postova
Tocno to.
Staro 19.01.2014., 22:48   #577
wnbeeeE
wnbeeeE's Avatar
Datum registracije: Mar 2009
Postovi: 600
ugrijao se Omeyer, to stoji.. ali ruku na srce to su sve bili polu-udarci u drugom dijelu, za njega lako branjivi. U prvom dijelu je sijevalo muški.
Darker than a moonless night and hotter than hell itself, that is coffee.
wnbeeeE je offline   Reply With Quote
Staro 19.01.2014., 23:38   #578
vision19
Datum registracije: Jan 2011
Lokacija: Vinkovci / Njemačka
Postovi: 494
Psihologija. Već 100 puta viđeno, ali ja neću dizati Omeyera u nebesa iako bi možda trebao, nego naš balkanski 'lako ćemo' mentalitet.
Karabatić dobije 2 minute, mi imamo +3 čini mi se i 2 napada za redom gubimo loptu (ispada Kopljaru i još nekome) i oni se vraćaju na -1. Sve ostalo je povijest. Samo nam dobar psiholog treba, kad stari didica stane na gol da se ne puca ravno u njega i to je to. Nemoguće da Kopljar zabije u 25 min 7 golova a u drugom poluvremenu niti jedan i šutne par puta na gol. A i svi ostali.
"Anyone who has never made a mistake has never tried anything new." A.E.
vision19 je offline   Reply With Quote
Staro 19.01.2014., 23:41   #579
Mad_Duke
Balkasnki "lako ćemo" mentalitet ne postoji u sportu. Tko god da se bavio dotičnim u bilo kojem obliku to zna.
Staro 19.01.2014., 23:42   #580
Kompleksaši. I goluža na čelu i dalje... A zlata nikakvog već 10 godina...
Staro 19.01.2014., 23:49   #581
Guls
Guls's Avatar
Lokacija: Sveta Nedelja
Postovi: 2,938
Bit ce sve to ok. Ima jos tekmi.
Intel i7 9700F
32GB Hyper-X DDR4-2666
2TB 970Pro PCIe NVMe M.2
Windows 11 Professional
Periferija
2 x 27" Dell P2723D
Corsair SP2500 2.1
Logitech MK270
17,3 FHD IPS 144Hz
AMD Ryzen 7 5800H
16GB DDR4-3200 RAM
1TB PCIe NVMe SSD
Sony Playstation 5
Staro 20.01.2014., 00:54   #582
robert7
robert7's Avatar
Postovi: 1,708
Goluža je trebao biti autoritet i izvaditi Duvnjaka nakon sto je poklonio 3 lopte u napadu na naših +3, uništio je moral momčadi danas i bio uvjerljivo najgori igrač na terenu, počeo se rano svađati sa sucima, ok, tuku te, ne sude ti, digni se iznad toga jer ipak si TI vođa ekipa ( iako je Vori kapetan ). On je pao pod pritisak u kojem su ga francuzi taktički uništili, i poveo ekipu sa sobom.
Goluža je tu kriv jer to nije prepoznao i izvadio ga zadnjih 10-15 min prvog poluvremena ( iako bi bilo tko drugi odigrao znatno lošije ) ali bi imao možda šansu da urazumi Duvnjaka i u drugom poluvremenu podigne ekipu protiv katastrofalne francuske.
http://eu.prepsafe.com
robert7 je offline   Reply With Quote
Staro 20.01.2014., 07:44   #583
ExtremePower
ExtremePower's Avatar
Datum registracije: Aug 2008
Lokacija: Moj dom Krapina
Postovi: 246
Situacija već viđena...
Sutra Švedska pobijedi Poljsku, Francuzi Bjelorusiju i možemo se slikati...
Nebi se čudio da onda u zadnjem kolu Švedska sa točno 2 gola pobijedi Francuze. Možemo mi onda Ruse i Poljake dobiti 20 razlike, ali idemo prvim avionom doma.
ExtremePower je offline   Reply With Quote
Staro 20.01.2014., 08:28   #584
ONeill
ONeill's Avatar
Datum registracije: Mar 2008
Postovi: 347
Ne znam kako to izgleda uživo, ali ovako gledajući na televiziji, kad je time-out i Goluža nešto priča, imam osjećaj da ga nitko od naših igrača ne sluša već su odsutni negdje.
ONeill je offline   Reply With Quote
Staro 20.01.2014., 08:32   #585
Guls
Guls's Avatar
Postovi: 2,938
Općenito većina igrača ne sluša trenera u time outu jer su svi krepani i dolaze do zraka, možda actually nešto i čuješ, ali sigurno to ne apliciraš u igru
Iskreno, nisam imao nikakva očekivanja što se tiče naše repke ove godine tako da su i one tri pobjede za mene bile pojam pojmova. Meni sasvim dosta, da si ipak ne ubijemo ugled, a ostanemo opasan protivnik. Treba nekad biti zadovoljan s malim stvarima, a ne očekivati čuda. Ne znam da li se slažete, ali mislim da polako treba ići u tom smjeru s novom generacijom.
Intel i7 9700F
Periferija
2 x 27" Dell P2723D
Corsair SP2500 2.1
Logitech MK270
17,3 FHD IPS 144Hz
AMD Ryzen 7 5800H
16GB DDR4-3200 RAM
1TB PCIe NVMe SSD
Sony Playstation 5
Staro 20.01.2014., 12:37   #586
Dr_faca
Dr_faca's Avatar
Datum registracije: Oct 2010
Postovi: 289
Autor ONeill Pregled postova
Pa naravno da ne slusaju,jer je frajer jazavac.Druga stvar,protiv svedana on u timeoutu govori..."ako izgubite loptu,trcite nazad u obranu..."
Pa daj se rani...
Sjecam se kad je tek preuzeo klupu,tehnicke zamisli su mi bile,cvrsto u obrani i dignite ruke...
Dr_faca je offline   Reply With Quote
Staro 20.01.2014., 13:03   #587
brodjo
Playmaker
brodjo's Avatar
Lokacija: Osijek/Wien
Postovi: 1,660
brodjo je offline   Reply With Quote
Staro 20.01.2014., 13:35   #588
Dr_faca
Dr_faca's Avatar
Postovi: 289
Autor brodjo Pregled postova
Staro 20.01.2014., 13:44   #589
chief_wolfinjo
hahahah
Staro 20.01.2014., 13:49   #590
electro
electro's Avatar
Lokacija: Zapresic
Postovi: 692
Autor robert7 Pregled postova
slažem se
siluju po sredini a krila gledaju tj.
ne dobivaju iskoristive lopte
electro je offline   Reply With Quote
Staro 20.01.2014., 23:52   #591
listerstorm
listerstorm's Avatar
Datum registracije: Apr 2011
Postovi: 1,428
Tako je. Dovoljno je pogledati polufinale protiv Španjolske 2003. Gubili i sa 6-7 razlike a ono svjetski prvaci na kraju. Toliko o balkanskom mentalitetu.
listerstorm je online   Reply With Quote
Staro 21.01.2014., 00:02   #592
brodjo
Playmaker
brodjo's Avatar
Postovi: 1,660
Evo gledam danas Dansku, Hansena vadi svakih 5 minuta van da se odmori koju minutu. A ne ovaj Goluža izvadi ga u 45. minuti prvi put kad ovaj više ne može disat -.-
Staro 21.01.2014., 07:03   #593
snorky_vk
snorky_vk's Avatar
Lokacija: u mraku
Postovi: 846
Pa imamo valcica.... i kaki je to igrac koji ne moze trcat vamo tamo 50min? od ekipe sa dupliranim pozicijama pali smo opet na 8 imena...
Staro 21.01.2014., 07:42   #594
ExtremePower
Postovi: 246
Danas naši protiv Rusije.
Poslije u 20.15h Poljska-Švedska na Sport1,
baš se veselim toj utakmici...
Navijam za Poljake
Staro 21.01.2014., 12:56   #595
Dr_faca
Dr_faca's Avatar
Postovi: 289
Autor snorky_vk Pregled postova
Lol...Valcica...
Pa za koji je k.... Vukovica zvao?Vec dvije tekme sjedi na klupi....
Autor ExtremePower Pregled postova
Navijam za Poljake
Rusi su svaku tekmu rjesavali tj gubili u egalu,bit ce tesko danas,ali par kontri cupica i strleka ce ih razmontirat...
Staro 21.01.2014., 15:53   #596
snorky_vk
snorky_vk's Avatar
Lokacija: u mraku
Postovi: 846
Autor Dr_faca Pregled postova
Lol...Valcica...
to se i ja pitam... vukovica nigdje , a uvijek je imao solidne role.... nekako imam filing da slavko nema dovoljno taktičkog znanja za malo kompliciranije protivnike....
edit: ni protiv ovakvih rusa mi ne možemo bez duvnjaka.... što reći....
Zadnje izmijenjeno od: snorky_vk. 21.01.2014. u 16:37.
Staro 21.01.2014., 20:23   #597
ExtremePower
Postovi: 246
Sveđani razbijaju Poljake 5-1 na početku.
Sve ide prema crnom scenariju zasad...
Staro 21.01.2014., 20:25   #598
esc
Lynnfield
Datum registracije: Sep 2012
Postovi: 1,023
Može pojašnjenje,ne pratim,znači ak švedi dobiju mi smo papa,jedan poraz i gotovo sve,pa kako
esc je offline   Reply With Quote
Staro 21.01.2014., 20:52   #599
snorky_vk
snorky_vk's Avatar
Lokacija: u mraku
Postovi: 846
Autor esc Pregled postova
Poljaci vode . Ko na kakoj supstanci da su trenutno...
Zadnje izmijenjeno od: snorky_vk. 21.01.2014. u 20:58.
Staro 21.01.2014., 21:00   #600
ExtremePower
Postovi: 246
esc, naravno da može pojašnjenje.
U slučaju današnje pobjede Švedske protiv Poljske i ako bi sutra
pobijedili Francuze 1 ili 2 gola razlike, tada se možemo pakirati.
Ali Poljaci ponoreli, vode na poluvremenu 15-12
