Rezultati ankete: Grid.org Team
Osnujmo Team 111 70.25%
Ne zanima nas 8 5.06%
Ma boli me briga 39 24.68%
Glasači: 158. Ne možete glasati na ovoj anketi
Staro 22.07.2005., 20:38   #721
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
meni je ipak bio problem u ud monitoru, zajebo mi je par resulta...
zato ga sad koristim samo kad mjenjam cache slotove (kad mi je jedan poso gotov prebacim na drugi)...
Slanje resultata ostavljam gridu....
Staro 22.07.2005., 23:47   #722
gpremec
matroxfanatic
gpremec's Avatar
Lokacija: Zagreb, na zapadu
Postovi: 2,444
Thumbs up proradilo!
grid.org official communication 7/22/2005:
http://forum.grid.org/phpBB/viewtopic.php?t=17442
"We would like to thank all of our members for their continued patience over the last couple of days while our servers have been offline for maintenance.
At this point, our grid servers should now be operational and distributing workunits again. Unfortunately, there are some complications that all members will want to be aware of:
- If your UD Agent displays a login prompt and asks you to enter your password again, please select the checkbox indicating that you are an existing user, and then re-enter your old password. (If you have forgotten your password, you can try the password-recovery facility at https://www.grid.org/services/login/recover_login.htm, or worst case re-create a new user account.) Once you do this procedure, your Agent should download a new workunit and begin working again.
- The "Total Points" and "Total CPU Time" values displayed by the UD Agent may be temporarily desynchronized (slightly lower) than the values displayed on the Member Web pages at https://www.grid.org/services/. We will be working to resynchronize these values, and we expect all point and cpu time totals to be properly reflected as soon as possible.
Thanks again for your continued support!"
Holly: "Appreciate what vou've got, because basically, I'm fantastic!"
my UD stats
gpremec je offline   Reply With Quote
Staro 23.07.2005., 00:06   #723
IceFisherman
Magister Mundi sum!
IceFisherman's Avatar
Datum registracije: Jun 2003
Lokacija: Zagorje
Postovi: 2,335
damn .... poništil mi prijašnji posel od 60 i nekaj sati .. well her we go again
Sapphire radeon x1650PRO
2x512mb 433mhz Kingmax
AOC 17", LCD, LM760
Win XP PRO SP2 & SUSE 10.1
www.crazywarriors.com
Staro 23.07.2005., 00:27   #724
sYsT3m
Datum registracije: May 2005
Lokacija: Ankum
Postovi: 161
lool nekuzim, posaljem obradjeno i za uzvrat dobim k...... i jos mi oduzme 1 bod, niti vrijeme rada proc ne pribroji... : finger : ode 96 sati u vjetar...: finger :
sYsT3m je offline   Reply With Quote
Staro 23.07.2005., 00:51   #725
Black Dragon
Black Dragon's Avatar
Lokacija: Agram
Postovi: 2,982
ne znam ja .. ja sam uredno odaslal i primio nove pakete i uknjižio nove tisućice jedino me tražio da se ponovo ulogiram i to je bilo sve od neuobičajenog ... meni sve 5. Možda taj UD manager malo prca ... mislim ja sam bahato 0-24 on line dok je Fleta pa ne koristim to pa nemam niti dobri niti loših iskustava ...
Staro 23.07.2005., 01:11   #726
Black Dragon
Lokacija: Agram
Postovi: 2,982
hm ... prvo čitaj a onda s*ri ... uglavnom imam oko 500 sati propalog rada ... 3 paketa nisu donjela ništa ... dva od 150 sati na dal AMDu i jedan sa jednog PIII-S ... a niš ... i ovak bi procevi zujali u prazno ovako su zujali korisno 2 godine i neš tako da tih 20 dana CPU vremena su kap u moru ...
Staro 23.07.2005., 01:12   #727
IceFisherman
Magister Mundi sum!
Lokacija: Zagorje
Postovi: 2,335
ja nemam taj UD monitor ili kaj vec pak me je zaribal vrag .... paket obrađeni čeka i onda ga ni poslal nego je samo skinul novoga a staroga ko da nije ni bilo
AOC 17", LCD, LM760
Staro 23.07.2005., 12:05   #728
FERRYS
AutoCad & Allplan expert
FERRYS's Avatar
Postovi: 2,159
il sam ja zaboravil password il me ud-agent zajebava??? al nemrem se logirat
none
Staro 23.07.2005., 13:15   #729
FERRYS
FERRYS's Avatar
Postovi: 2,159
gledam sad tamo onu listu clanova pcex teama i pise da sam RETIRED??? a nisam...
kak da to rjesim???
none
Staro 23.07.2005., 14:57   #730
IceFisherman
Magister Mundi sum!
Lokacija: Zagorje
Postovi: 2,335
kak da to rjesim???
vjerovatno se bu samo popravilo nakon kaj pošalješ sljedeči obrađeni paket
AOC 17", LCD, LM760
Staro 23.07.2005., 15:29   #731
FERRYS
FERRYS's Avatar
Postovi: 2,159
moral sam se re registrirat, napravil sam to sa starim imenom passeordom i pocel je obradjivat novi paket... ALI imam 0 bodova, 0 vremena, 0 paketa?????
nis mi ni jasno....
sam ja sad to pocel iz pocetka s novim istim imenom koje sam i imal??? jer na listi jos uvjek pise da sam umirovljen....
sve u quratz..
edit: cini mi ce da mi je novi nick Vogler?????
none
Staro 24.07.2005., 13:16   #732
FERRYS
FERRYS's Avatar
Postovi: 2,159
ode 7 dana darovanog cpu vremena u vjetar....
none
Staro 25.07.2005., 15:02   #733
vodokotlic
vodokotlic's Avatar
Lokacija: ZG - VŽ
Postovi: 375
ista stvar i ovdje. kad se spoji samo trazi ponovni login i skine nove paket. nije poslo rezultate niti ima ikakvog pomaka u bodovima... covjek tu volontira i jos te onda zajebavaju
vodokotlic je offline   Reply With Quote
Staro 26.07.2005., 10:49   #734
FERRYS
FERRYS's Avatar
Postovi: 2,159
posljednji update im je bio 19.7:confused:
none
Staro 03.08.2005., 12:36   #735
vodokotlic
vodokotlic's Avatar
Lokacija: ZG - VŽ
Postovi: 375
jel zna neko jel radi grid trenutno, tj jel ima svrhe slat gotove pakete ili je sve jos ukomirano?
Staro 03.08.2005., 12:36   #736
vodokotlic
vodokotlic's Avatar
Lokacija: ZG - VŽ
Postovi: 375
Staro 03.08.2005., 19:41   #737
Dragon Killer
Kompjuterov frend
Dragon Killer's Avatar
Postovi: 326
Pa ja ih normalno šaljem i nikakvih problema nema zakaj ih nebi slao
Bolje je šutjeti i pustiti da te smatraju budalom, nego progovoriti i otkloniti svaku sumnju.
A. Lincoln
Dragon Killer je offline   Reply With Quote
Staro 04.08.2005., 01:20   #738
IceFisherman
Magister Mundi sum!
Lokacija: Zagorje
Postovi: 2,335
koji vrag se događa sa UD-ovim stranicama ... zake ne apdejtaju nič ?
AOC 17", LCD, LM760
Staro 04.08.2005., 01:40   #739
Chuby
Chuby's Avatar
Datum registracije: Feb 2004
Postovi: 1,307
zato kaj tamo ocito vlada rasulo i anarhija
Chuby je offline   Reply With Quote
Staro 04.08.2005., 02:04   #740
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
JA sam se umirovio nakon sto je poceo grid srati previse,......
I da onaj ud agent nevalja kurcu popusio sam 5 rezultata.... ili ti oko 60sati .
Tako da mi se neda razmisljati o tome vise dao sam 24k bodova dosta im.
.i.
Razer Blade 15
Staro 07.08.2005., 10:04   #741
Dragon Killer
Kompjuterov frend
Postovi: 326
Ljudi jeste mogli jučer i jel možete danas posla rezultate meni uporno neče
A. Lincoln
Staro 07.08.2005., 10:49   #742
gpremec
matroxfanatic
gpremec's Avatar
Postovi: 2,444
Cool Sve je objasnjeno na njihovom forumu
grid.org official communication 8/05/2005 (re: Team Stats):
"Dear members,
We forgot to mention that we continue to work diligently at repairing the Team Stats figures. The problem appears to be related to a corrupted table, which just so happens to host the team statistics; the data is ok - it's just the table that seems to be problematic. To fix, we are going through a process of 1) exporting all team stats data from the corrupted table, 2) recreating a new team stats table, 3) importing team stats data back into new table.
The explanation above sounds rather simplistic, but it's very intensive due to the enormity of the data contained in this table. Just the exercise of moving the data around via the export/import is very time consuming - so we beg for your continued patience. Thank you very much.
Kindest regards,
grid.org team"
grid.org official communication 8/05/2005:
"Dear members,
Thanks for being so patient. Below is a current update on grid.org:
A new LigandFit Pancreatic Cancer job is still pending new data from our European partner. In the meantime, the grid.org team will be performing some LigandFit post-processing script improvements on our LigandFit grid infrastructure in order to prepare for the new Cancer project data soon to arrive from our European partner. As a result, the old LigandFit Cancer job that is currently running will be suspended briefly in order for our team to make the necessary preparations offline.
The Rosetta Human Proteome Folding batches of jobs on grid.org continue to run well, and results are being post-processed nicely. Thanks for contributing your compute time.
Kindest Regards,
grid.org team"
my UD stats
Staro 09.08.2005., 00:13   #743
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
Ma ja više ne znam.
Sad sam došo s mora i upalio komp, grid se restarto, izbacio me iz tima, imam 0 bodova, i iskreno uopće mi se neda sa tim opet zajebavat.
Pitaj boga kaj oni rade sa tim svime...
Sam Fischer je online   Reply With Quote
Staro 09.08.2005., 01:13   #744
gpremec
matroxfanatic
gpremec's Avatar
Postovi: 2,444
Originally posted by Sam Fischer
Ma ja više ne znam.
A gle, moras se zapitati: radis li ovo samo zbog natjecanja, ili (i) zbog doniranja procesorskog vremena u potrazi za lijekom protiv raka i jos ponekih (plemenitih) stvari. I ja sam se vratio s mora prosli tjedan i na svom kompu doma morao ponovno registrirati grid.org klijenta. Samo neka on meni radi u pozadini.
Istina je da si bas poceo kada je grid.org imao poprilicne probleme (i jos sredjuju dio njih), ali i to ce se srediti. Budi malo uporniji, ponovno registriraj svog klijenta, i vrti ga makar kao screensaver. I sam sam odustajao u dva navrata od svega ovoga, tako da imam barem dvije rupe od 3 i vise mjeseci neaktivnosti, ali ipak sam odlucio i dalje sudjelovati u svemu ovome. Tako sam sada na 30-tak dana o 6 godina doniranog procesorskog vremena.
my UD stats
Staro 09.08.2005., 17:15   #745
Chuby
Chuby's Avatar
Postovi: 1,307
stvar je u tome sto cijeli projekt ocito ide u khm....... stalni kvarovi hardwarea
nemogucnost updatea
i tako mjesec dana ili vise....... bas me zanima sto se dogodilo s svim rezultatima koje smo vec obradili ako nemogu dignut obicnu tablicu s clanovima i updejtat jednom u par dana
tamo se ocito nista ne radi, iz kojeg razloga neznam ali za mjesec dana se nisu pomakli s mjesta navodno zbog kvara hardwrea i recoverija podataka, da imaju 10 zaposlenih vec bi to 15 puta napravili
Staro 09.08.2005., 17:34   #746
gpremec
matroxfanatic
gpremec's Avatar
Postovi: 2,444
@ Chuby: vidi se da nikada nisi radio sa serverima.
Meni se cini da nisu imali kvalitetan backup, jer njih ne muci HW problem (to, uostalom, niti nije problem), vec to da su imali graske u bazi koje su se vremenom multiplicirale, a kako ih ne mogu ispraviti/eliminirati, morali su vratjati backup. I tek su im tada krenuli problemi, jer, ako malo bacimo pogled na zadnja 3-4 mjeseca, problemi su bili sve veci i veci, a kulminiralo je prije dva-tri tjedna, kada se sve raspalo do kraja. Kako nisu imali potpuni (ili uopce ispravni) backup, izgleda da su morali odredjene djelove baze kreirati iz nule (od tuda ono da smo morali nanovo registrirati svoje grid.org klijente). Od tada rade na tome da im statistike prorade, a usred svega toga im je dosao novi paket zadataka za Cancer Research.
I iza cijelog grid.org projekta stoji odredjena grupica (ili grupa, ili grupetina,...) ljudi, a oni (kao i mi) su od krvi i mesa, i ne mogu rijesavati probleme brze nego jedan po jedan.
my UD stats
Staro 09.08.2005., 17:37   #747
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
Tek sam sad zavirio u ovu temu na pc ekspertovom forumu...i vidio da se radi o nečemu zanimljivom i korisnom, a neda mi se čitat 70-tak stranica pa vas molim da mi opišete to u 1-2 posta....please
Pošteni Trgovci: 1,2
Staro 09.08.2005., 17:42   #748
Black Dragon
Lokacija: Agram
Postovi: 2,982
baze podataka su osjetljiva stvar i to će ti reći svaki i najmanji knjigovodstveni servis i u bana republici ili ti ovdje. Sav hardware je totalno nebitan u poslu, podaci su ono šo važi i vrijedi, tako je svakoj firmi i korporaciji ... ako se ne sjećate 1st National Bank of USA (mislim da je ona) je nedavno IZGUBILA !!! podatke o 1.000.000 tekućih računa i još nisu sve sanirali do kraja (prošlo već mislim i mjesec dana) a ako oni nemaju ljdskih resursa nema niko, para valjda imaju pa jesu ili nisu banka A ovi isto to rade za nekoliko milijuna korisnika samo ne za pare već za bodove ...
Staro 09.08.2005., 17:52   #749
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
Question
malo sam čitao...izgleda zanimljivo, ako se koristi u dobrotvorne svrhe naravno....nebih htio davati procesorsku snagu u neki weapon of mass destruction nikako. Je radi taj grid.org uopće?:confused: dali da malo mučim svog (pra) starog celerona pomaganjem za dobrotvorne svrhe? je registration free?
Staro 09.08.2005., 21:25   #750
Black Dragon
Lokacija: Agram
Postovi: 2,982
je registracija je free, da naravno da ga treba tlačiti Meni radi sve bez greške ...
