Staro 17.12.2013., 20:03   #31
Ati freak
aka Striko
Ati freak's Avatar
Lokacija: Krapina - Zagreb
Postovi: 1,757
Kakve su integrirane grafe u tim procevima? Dovoljne za vrtit YT i slicne stvari?
Staro 17.12.2013., 20:16   #32
boy005
boy005's Avatar
Postovi: 598
dovoljna za wot u fhd-u...
(naravno uz low i off postavke)
Zadnje izmijenjeno od: boy005. 17.12.2013. u 20:23.
boy005 je offline   Reply With Quote
Staro 17.12.2013., 20:24   #33
Dottore
Dottore's Avatar
Postovi: 7,712
Dovoljna. Dosad nisam primjetio trzanje. Evo, kolega Boy005 uvalio meni dobar komad procesor G550 Prezadovoljan sam i ima dovoljno snage. Ne bi vjerovao i na low brzini radi fino. Temperatura kao ljudsko tijelo.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 18.12.2013., 23:03   #34
windfucker
@Razer:
Evo pogledao, ide do - 300mV u offset-u.
Fiksne napone niti nema u opcijama.
Da, dovoljan je ovaj proc i za HD materijal, guta bez problema sve do sada pokušano.
Staro 20.12.2013., 10:33   #35
Ranma 1/2
Anything Goes Martial Art
Ranma 1/2's Avatar
Lokacija: Tendo Dojo
Postovi: 542
Koju bi ste plocu i chipset preporucili za ovaj proc imajuci u vidu da se u buducnosti mozda gore pikne neki i5 ali bez o/c.
"Water! Why does it always have to be water?!"
Ranma 1/2 je offline   Reply With Quote
Staro 20.12.2013., 10:55   #36
hedgehog
hedgehog's Avatar
Datum registracije: Apr 2013
Postovi: 1,336
bilo koja H81 ili B85 ploča..obje imaju i USB3 i SATA3 i sve potrebno prosječnom korisniku a Intelovim procesorima koji nisu otključani ne treba ništa više..
hedgehog je offline   Reply With Quote
Staro 20.12.2013., 11:45   #37
ShanTech
Datum registracije: Apr 2011
Postovi: 3,784
Kod H81 ploča malo bolje obrati pozornost na to kako su opremljene. Naravno, uvijek se gleda kako su opremljene, ali npr. ASRock H81M-HDS, koja je 15-20 kn skuplja od najjeftinije H81 ploče ima ASMedia ASM1042 USB 3.0 kontroler (interni konektor), koji ima dobre performanse i dobra je investicija za sadašnje/buduće kućište s prednjim USB 3.0.
Zadnje izmijenjeno od: ShanTech. 20.12.2013. u 11:52.
Staro 21.12.2013., 00:21   #38
Ranma 1/2
Ranma 1/2's Avatar
Postovi: 542
par H81 ploča koje sam randomly pogledao mi i nisu ostavile neki dojam. prilično su loše opremljene a neke su imale samo VGA izlaz. zato me i zanima ako ima neki konkretan model koji bi mogli preporučiti.
B85 već izgleda bolje.
Staro 21.12.2013., 00:29   #39
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
e33 ploce su mi bile ok do sad. Imal sam dvije 1155 i za lovu kolko su kostale su odlicno opremljene iako to nemre bit ko skuplje ploce..
http://www.msi.com/product/mb/B85M-E33.html
Staro 29.12.2013., 16:18   #40
6Finger
Lokacija: Zagreb, trešnjevka
Postovi: 1,166
Potaknut ovim osvrtom na proc, malo iz znatiželje a malko zbog nedostatka novaca
uzeo uzeo sam navedenog mališu u kombinaciji sa Gigabyte B85-HD3 makar na koji mjesec
dok ne kupim za ostatak komponenti.
Moji dojmovi su super pozitivni, grafa odrađuje posao vrhunski, daje "ugodnu" sliku a youtube u HD rezoluciji netrza ni najmanje.
S vremenom ću ga uparit sa više rama i dikretnom grafom prije nego i njega zamjenim pa javim dojmove kako funkcionira u toj kombinaciji.
Ali ono što sigurno mogu reći je da za te novce radi extra dobro i ako ste u dvojbi krpljenja nekog starog kompa, ovaj proc u kombinaciji sa jeftinijom pločom odrađuje sve ono čime se 90% i više korisnika ionako bavi na kompu :P
6Finger je offline   Reply With Quote
Staro 26.03.2014., 17:02   #41
Brain32
Brain32's Avatar
Postovi: 498
Autor 6Finger Pregled postova
Viš upravo mi je to interesantno, ja sam nekako bacio oko na G3420 koji dela na 3,2GHz mališa je cijenom iznimno privlačan kao i potrebna prateća "stolarija" u vidu MBO i memorije...
E sad, jedino što sam nedavno igrom slučaja stekao baš GTX660 pa se sad malo cimam, i prije nego mi se netko javi i veli: "Kaj? GTX660? Treba ti minimalno Core I-770 TwinTurbo extreme MCMXVI core"...da jasno mi je da bi neki i5, i7 bio mrak ali ove G-pizdarijice koštaju 300-400kn e sad zanima me da li su razlike u performansama vrijedne tih 1000-1500kn+ s obzirom da iako radim svašta na kompu od nijedne od tih stvari ne živim niti mogu okrenut lovu na njima tak da ono...ne dam, jebiga škot sam po duši...
Brain32 je offline   Reply With Quote
Staro 28.03.2014., 20:08   #42
tutanjkamen
tutanjkamen's Avatar
Datum registracije: Sep 2011
Lokacija: VG
Postovi: 23
Autor Brain32 Pregled postova
U ovom testu ( http://www.legitreviews.com/intel-pe...eview_137016/6 ) su usporedili G3220 sa I5 i i7 procesorima pa baci pogled. pri fhd rezoluciji vrlo malo zaostaje za njima. ono sto ih je iznenadilo je da G3220 nije bio botleneck GTX670 grafickoj sa kojom su testirali.
tutanjkamen je offline   Reply With Quote
Staro 25.04.2014., 18:41   #43
Brain32
Brain32's Avatar
Postovi: 498
Evo ja uzeo G3420 (znači 3.2 GHz verzija) i za sada prezadovoljan, puno hvala Razeru koji mi je ovom temom u velikoj mjeri pomogao pri odabiru kao i tutanjkamenu na linku koji je definitivno prevagnuo.
Inače sve skupa ovo pod moj komp je zastarjelo i popakirano po svojim kutijama a u kanti je:
G3420
MSI Z87-G43
2x4GB HyperBeast 2400 - znam, znam ali kad je fakat bilo jeftino nisam vidio smisla za iste novce uzet 1600...
i
GTX660 standardna ASUS-ica znači 980/3000
E sad u znak zahvale i ako ima interesa mogu ispitati teoriju o ovim procesorima i karticama ranga 650 Ti/660 pa ako ima tko kakav prijedlog mogu odvrtiti nešto sad za vikend (inače prošao sam BF3 SP na brzinu i na ultra/1680x1050 leti ko blesavo)
Inače stock cooler radi ok, temperature idu do 60c ali kućište mi je trenutno koma, jedva sam natiskao sve unutra pa to još mogu popravit jedino kaj se mali gad čuje, zavija ko turbina a kad se full usafta bome i ruži...brijem da ću si piknut neki možda i overkill samo da je tiho na kraju...
