Zaključane teme
Staro 09.12.2013., 12:21   #61
Vjerojatno je vecina fixeva za sam OS, tj. 4.4.1 je bas update. Da je samo za nexus,sigurno bi bio nekakav manji OTA update koji bi ostao na 4.4. Moje misljenje naravno
Odlično. To onda znači da mi koji nismo nexusari, a dobit ćemo KK, da će to već tada biti prilično ispeglane verzije. Da, istina je da će nexus tad već bit na 4.5 ili 5.0
Brko je offline
Staro 09.12.2013., 12:23   #62
spawn
spawn's Avatar
Postovi: 8,399
LG mobiteli
Takav je bio i JB 4.1. Vecina uredjaja je dobila 4.1.1 a dosta i 4.1.2 u startu. Jako malo uredjaja sam vidio s 4.1
spawn je offline
Staro 09.12.2013., 23:47   #63
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,818
Dostupan je 4.4.2 za N5...
Vjerojatno nebum ni ugledal 4.4.1 neg bum mozda imal ponudjen noviji update (4.4.2).
zvonac je offline
Staro 10.12.2013., 00:41   #64
Postovi: 10,024
Autor zvonac Pregled postova
Načekat ćeš se bome Sideloadao sam maloprije 4.4.1 i odmah mi je bio ponuđen 4.4.2 (koji je izgleda pušten velikoj većini, ako ne i svim 4.4.1 korisnicima jer je to mali fix). Btw, out of the box mi nije nudio update ni na 4.4.1 niti na 4.4.2.
xlr je offline
Staro 10.12.2013., 07:57   #65
zvonac
zvonac's Avatar
Postovi: 5,818
Bit ce....
Why hasn't the OTA hit my device yet? I keep mashing the "check now" button!
Morrill also explains the "rollout" process of Nexus OTA's.
Quote:
Rollouts are conducted in phases. Typically they start at 1% of devices for around 24 - 48 hours; we watch the return rates and resulting device checkins and error reports (if any), and make sure nothing looks wrong before sending it to more. Then typically it goes to 25%, 50%, 100% over the course of a week or two.
What the percentages mean is that when your device checks in, it has a 1% chance (for example) of being offered the OTA. If it doesn't (randomly) get an offer, it will never get an offer until the next batch.
IOW, once your device checks in and gets turned down, that's it until the next batch. Mashing on the "check for updates" button just causes your device to check in again, and get automatically turned down again. Think about how that makes your device feel! WON'T SOMEONE PLEASE THINK OF THE PHONES?!
That said, once the new batch does start, hitting that button does give you a new roll of the dice -- but once. Since devices usually only check in for system updates every 24 hours (I think? Certainly on a many-hours basis) this can get you your shot sooner than it would happen on its own.
So, mash away. Just be patient, and mashing on it more often than once or twice a day isn't going to gain you anything.
Edit: also, keep in mind that this isn't first-come/first-served. You're not racing other devices to get your slot in the current batch, or something. -Dan Morrill
zvonac je offline
Staro 10.12.2013., 09:30   #66
antebr
antebr's Avatar
Postovi: 418
Autor xlr Pregled postova
Upravo stavija factory image KRT16S, i odma nakon instalacije napravija OTA update na 4.4.2. (Nexus 4).
antebr je online
Staro 10.12.2013., 10:28   #67
zvonac
zvonac's Avatar
Postovi: 5,818
Javlja mi cannot read update.zip...
Zadnje izmijenjeno od: zvonac. 10.12.2013. u 10:37.
zvonac je offline
Staro 10.12.2013., 12:43   #68
gin.tonic
gin.tonic's Avatar
Postovi: 2,434
Vidim da neki forumaši ovdje imaju imaju Nexus 5 a nisu podjelili dojmove s ostalim forumašima
gin.tonic je offline
Staro 10.12.2013., 12:44   #69
Postovi: 10,024
Q: Why do I get a "cannot read update.zip" error when trying to sideload?
A: If you named the file update.zip, the actual name would be update.zip.zip. Windows auto names extensions by default. That could be your problem. If not try another usb cable or a different usb port. If that still doesn't work, make sure you type exactly what you renamed the file. You may have made a typo. It is also case-sensitive.
http://forum.xda-developers.com/show....php?t=2523217
xlr je offline
Staro 10.12.2013., 15:59   #70
zvonac
zvonac's Avatar
Postovi: 5,818
Ma probal sam, dost se ljudi zali na taj problem...
zvonac je offline
Staro 10.12.2013., 16:34   #71
Postovi: 10,024
Meni je prvi put izbacilo neki error jer imam stari adb. Kada upisem "adb devices" izlista uredjaj i pokaze ga kao offline, pa sideload nije prolazio. Na tom linku sam nasao novi adb i onda je prepoznao mob.
xlr je offline
Staro 10.12.2013., 22:51   #72
zvonac
zvonac's Avatar
Postovi: 5,818
Pripremim sve fajlove za flešanje, kad ono, prek OTA dobijem update 4.4.2 54mb...
Izgleda da su se setili mene
zvonac je offline
Staro 11.12.2013., 09:57   #73
tutix
tutix's Avatar
Postovi: 4,068
Stigao i meni 4.2.2 OTA za N4. Jel netko skuzio sta drgacije?
tutix je offline
Staro 11.12.2013., 11:03   #74
zvonac
zvonac's Avatar
Postovi: 5,818
Bolji fotić, i video, potonji radi jako smooth, konstantnih 29.80 bilo lošiji bilo dobri svjetlosni uvjeti, dok mi je na 4.4 video bil zbluran (20 fps). Zvučnik je jači tj glasniji, sad ne znam kakav je zvuk u slušalici..
Još nek ubace u apdejt video sa 60 fps i vozi..
zvonac je offline
Staro 13.12.2013., 16:25   #75
Broken Arrow
The Man
Broken Arrow's Avatar
Lokacija: Novi Zagreb
Postovi: 1,252
Tako i ja postah vlasnikom LG G2... nakon samsung galaxy S(1)... preporod...
"Everybody's at war with different things...I'm at war with my own heart sometimes"
Broken Arrow je offline
Staro 15.12.2013., 08:50   #76
zvonac
zvonac's Avatar
Postovi: 5,818
Izgleda da bum reklamiral N5..
1.backlight bleed, gornji desni kut, naravno vidljivo samo na crnoj podlozi.. (yellow tint)
2. power tipka se klima
3. vibru jedva da osjetim u džepu
4. Nadam se da naši nebu delali probleme oko garancije..
5. hrpa ljudi s istim tj sličnim problemom..
http://forum.xda-developers.com/show...515575&page=39
A i zapal me među prvim modelima (310)..
Zadnje izmijenjeno od: zvonac. 15.12.2013. u 09:38.
zvonac je offline
Staro 15.12.2013., 09:33   #77
suba
Vozi katru :))
Datum registracije: May 2003
Postovi: 163
http://blog.box.com/2011/11/50-gb-fr...roid-features/
za vlasnike LG-a box.com nudi 50 gb
suba je offline
Staro 15.12.2013., 09:51   #78
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,550
Di budes to reklamiral?
Novi mob kod mas ne budes dobio, a sad kolko su strucni popraviti to ne znam.
Juice je offline
Staro 15.12.2013., 09:59   #79
zvonac
zvonac's Avatar
Postovi: 5,818
Svijet Medija, od tam je garancija...
Kolko vidim na xda forumu ekipa uredno dobiva nove, al izgleda zato kaj su kupili prek GSa...
Većina N5 ima taj bb, negdje je to više, negdje manje izraženo..
zvonac je offline
Staro 15.12.2013., 10:22   #80
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,550
Da, u servisu novi ne budeš dobio jer kolko mi je poznato Svijet medija ne nabavlja preko LG Hrvatska Nexuse(LG ih uopće nije nigdje pustio kod nas) tak da je jedina šansa je u dućanu tražiti novi mob.
Juice je offline
Staro 15.12.2013., 10:33   #81
Postovi: 10,024
I Agram i LG su potvrdili da popravljaju uredjaje ako treba samo zamijeniti neki dio. U mom slucaju jer sam ga kupio preko Gplaya kazu da se za zamjenu uredjaja moram obratiti guglu. Vjerojatno se ti onda moras javiti Svijetu medija.
Takodjer imam mali bb gore lijevo sto se vidi samo na max osvjetljenju, manje nego tvoje, bez yellow tintinga. Vibra mi je bila slaba ali to sam rijesio promjenom kernela (nemam drugi N5 za usporediti je li to defekt ili ne). Power button sam zakrpao, a onog mrtvog pixela se vise i ne sjecam gdje je.
Takodjer sam mislio slati mob na servis u hrv. radi svega navedenog, ali sad me to vise ne smeta. Eventualno na ebayu jednog dana kupim vibromotor i zamijenim i to jedino ako netko potvrdi da moze izazvati pomicanje tektonskih ploca.
xlr je offline
Staro 15.12.2013., 10:55   #82
zvonac
zvonac's Avatar
Postovi: 5,818
A kaje zapravo bilo, bil sam u kupaoni tuširal se, a mob zamotan u majicu, čopim majicu i mob mi je ruknul na pod (nema oštećenja, nema ničeg vidljivog kaj bi upućivalo na to, nam nikavu pikicu i sl) malo se rasklopil na vrhu, zaklopil ga i vozi dalje
E onda sam skužil taj bb, pa ni vrag da ga je to smrdalo, taj pad?
Nea veze, neg onda zamjene display..
Al mene zanima dal to ide pod garanciju?
zvonac je offline
Staro 15.12.2013., 12:22   #83
Postovi: 10,024
A to ti ne bi znao reći. Google je poznat po svom srdačnom customer supportu gdje dosta ljudi čeka nove "ispravne" serije da zamijene kompletan uređaj. Kod nas mislim da neće biti lako niti jedan dio zamijeniti..
Sumnjam da ga je pad zdrmao.
xlr je offline
Staro 15.12.2013., 12:28   #84
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Da velim svoje iskustvo sa agram servisom i LG.
Imal sam puknuce LCD displaya na e975, i malo nagnjecenje u g desnom uglu, jer je pao na taj ugao.
Odnio u agram, oni su mi zamjenili cijelo kuciste, znaci nisu prckali po ekranu nego sam dobio jednostavno cijelo kuciste sa ekranom....kad sam to vidio puko sam od srece, jer opet imam doslovno nov mobitel bez pikice.
A kaj se tice reklamacija, 100% su mi potvrdili da mi vrijedi garancija 24 mj iako je kupljen u Njemackoj, bitno je bilo to da je kupljen iza 1.7.
Al su spori do bola, za dijagnostiku im je trebalo 5 radnih dana, za popravak jos 3....koma. no obavio sam to i jako sam zadovoljan sa zamjenom....znaci ne kemijaju samo zamjene i to je to, jer ja sam mislio da ce mi grijat mob odkeljivat ekran i ljepit.nov...ali ispalo je na najbolji moguci nacin.
A cijena nije ni velika kak sam ocekival, na kraju jeftinije je nek kod privatnih servisera...
+ ostala mi vazeca garancija.
danc00 je offline
Staro 15.12.2013., 13:04   #85
zvonac
zvonac's Avatar
Postovi: 5,818
Imal sam prije GNex, na kojem je zamjenjen display (imal je purple tinting) u servisu, bez pogovora..
Tak da ne vidim neku frku oko ovog ak bi kojim slučajem radili..
Nemam nikakvih ostalih anomalija, kaj se tiče displaya, yellow tinting je isključen, skinul sam app BB Test, stavil bijelu podlogu, i bijela je bijela..
zvonac je offline
Staro 15.12.2013., 13:08   #86
Postovi: 10,024
Eh, sada treba netko provjeriti kakvog su raspolozenja kada zelis zamijeniti ispravan ekran na teret garancije
Tnx za podjelu iskustva s njima!
xlr je offline
Staro 16.12.2013., 12:21   #87
zvonac
zvonac's Avatar
Postovi: 5,818
Odfural mob na servis..
Još dok bi dobil novi, iz novije serije
Uz bb problem, još sam imal povremeno gubljenje signala, sugovornika čujem tek nakon 2-3 sec nakon uspostave poziva..
Uglavnom svi simptomi kaj zahvaćaju tu seriju Nexusa..
zvonac je offline
Staro 16.12.2013., 13:10   #88
Postovi: 10,024
Keep us posted
xlr je offline
Staro 16.12.2013., 13:42   #89
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Si osobno nosil u Agram?
danc00 je offline
Staro 16.12.2013., 13:53   #90
zvonac
zvonac's Avatar
Postovi: 5,818
U Svijet medija, tip mi veli da sam ga dofural u roku od 7 dana dobil (kasnim 2 dana) bi novi, al bude videl možda prođe, pa mi se posreći
zvonac je offline
Zaključane teme
