Staro 09.12.2013., 23:40   #2101
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Autor rak21 Pregled postova
Meni bas i nije, mislim da je Hunt dobio ovaj meč..
Ja sam, kao i obično, navijao za Hunta 100%. I stvarno sam želio da pobjedi, ali sve drugo osim neodlučenog bilo bi krivo. Zanimljivo bi bilo vidjeti broj udaraca.
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 12.12.2013., 01:29   #2102
zhaccc
zhaccc's Avatar
Postovi: 120
UFC on Fox: Johnson vs. Benevidez 2 ovaj vikend! Tri team alpha male borca na main cardu!
PICKOVI:
Benevidez - volio bi da vidimo njegov 3. K.O. u 2013. (ali sumnjam prebrz je mouse i predobro eskivira, ici ce vjerojatno na odluku)
Faber - mislim da ce zbog iskustva dobiti McDonalda
Mendes - isto kao i Benevidez, team alpha male je zbilja "on the roll" sa nokautima
Lauzon - moj omiljeni borac protiv borca koji mi bas nije bio drag na ultimate fighter show-u... biti ce mi zanimljivo za gledat! Lauzon bi ovu borbu trebao dobiti bez problema
zhaccc je offline   Reply With Quote
Staro 13.12.2013., 23:26   #2103
Toorop
Mother Russia
Toorop's Avatar
Datum registracije: Mar 2013
Postovi: 326
Toorop je offline   Reply With Quote
Staro 14.12.2013., 12:22   #2104
zhaccc
zhaccc's Avatar
Postovi: 120
Autor Toorop Pregled postova
Da bas sam to vidio. Sramota.
Staro 14.12.2013., 12:28   #2105
wnbeeeE
wnbeeeE's Avatar
Datum registracije: Mar 2009
Postovi: 600
lawler ispred condita.. cudno. Mislim da hendricksu ovaj put nemoze nista stati na put
Darker than a moonless night and hotter than hell itself, that is coffee.
wnbeeeE je offline   Reply With Quote
Staro 14.12.2013., 17:28   #2106
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Meni je Lawler vs Hendrix uzbudljivija borba od Condita. Lawler je puno iskusniji borac sa bombama u rukama i ide na sve i nista i moglo bi se desit svasta u toj borbi. Meni se svida taj matchup u svako sl. Nije da nije Lawler to zasluzio. Ima 3:0 i dva jako respektabilna protivnika medu ta tri wina.
MAGARAC je online   Reply With Quote
Staro 14.12.2013., 17:53   #2107
2 die 4
2 die 4's Avatar
Postovi: 2,276
Ma gdje je to još. Ajmo se mi koncentrirati na današnji event.
Bit će zanimljivo. Dobar card je posložen.
Favoriti?
RedGreenBlue
Staro 15.12.2013., 13:05   #2108
wnbeeeE
wnbeeeE's Avatar
Postovi: 600
mendes dosta loše, navodno problemi sa disanjem..
johnson - nevjerojatno, kakav flash od čoeka Svaka čast, neće njega tako brzo skinuti sa trona !
faber - standard, kondicija, snaga, neumorljivost - bingo !
neloš event, dobri pickovi, dobre borbe !
Staro 15.12.2013., 20:00   #2109
zhaccc
zhaccc's Avatar
Postovi: 120
Da Mighty Mouse me poprilicno iznenadio, bio sam poprilicno uvjeren da ce Benevidez to napraviti njemu, hehe.
Autor wnbeeeE Pregled postova
Staro 17.12.2013., 20:39   #2110
perich
I hate mondays..........
perich's Avatar
Datum registracije: Nov 2002
Lokacija: Zagreb - Zaprešić
Postovi: 1,541
perich je offline   Reply With Quote
Staro 17.12.2013., 20:42   #2111
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Autor perich Pregled postova
Super..
Staro 18.12.2013., 16:22   #2112
gsxr750k9
Datum registracije: Apr 2011
Lokacija: Agram
Postovi: 603
http://mmajunkie.com/2013/12/antonio...medium=twitter
naravno da se vidlo iz aviona. 5 rundi masakra nikakav prirodni adrenalin to nemre.
gsxr750k9 je offline   Reply With Quote
Staro 18.12.2013., 18:14   #2113
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Moze Hunt i to bolje od "dignutog" Silve. Bar je Hunt sad dobil njegov bonus, 50k. Trebal bi dobit i borbu da ima pravde.
Staro 18.12.2013., 18:24   #2114
hylem
Postovi: 279
Autor MAGARAC Pregled postova
Slažem se, ali borba je svejedno bila odlična
hylem je offline   Reply With Quote
Staro 18.12.2013., 20:52   #2115
2 die 4
2 die 4's Avatar
Postovi: 2,276
Silva mi nikada nije bio drag.
Nikakav borac, samo je velik, fizički.
Glup ko stup, sve što zna je nasrnuti ko bik ako mu prođe neki udarac i naravno sa svom to masom iza sebe u nekim borbama mu je to i prošlo, ali čim naleti na iole inteligentnog borca, tipa hunt, cain... koji malo i misle prije neko djeluju on nema šanse nikakave. baš sam si pogledao njegov fajt protiv Daniel Cormier-a u polufinalu Strikeforce-a
https://www.youtube.com/watch?v=WGs1bmjPWsg
Može on biti crni pojas 100 puta ali to mu ništa ne znači kad naiđe na nekoga tko mu se samo malo izmakne i tu i tamo pogodi tu ogromnu bradu!
A da je bio na nekim drogama me uopće ne čudi, pa ono šta je on izdržao protiv Hunt-a nebi ni razjareni bik izdržao. Pa taj je čovjek nabio zub iz čeljusti Stefan Struve-u i pritom mu je polomio jednim udarcem!
https://www.youtube.com/watch?featur...Me-vehwp8#t=59
Dakle bika ruši a ovaj nije ostao dolje spavati!
Nadrogirani majmun, kao i većina brazilaca! (čast izuzetcima)
RedGreenBlue
Staro 23.12.2013., 12:01   #2116
Router
Hejter
Postovi: 6,521
Ufc 168 za nadolazeći vikend, uzvrat Weidman - Silva svakako je jedna od najiščekivanijih borbi(i money maker za danu i lorenza), baš se veselim vidjeti može li Silva povratiti titlu,a za Weidmana hoće li ga Matt Serra i Ray Longo još jednom vrhunski spremiti na sve što Silva može, i da obrani titulu. A i ostatak carda bi mogao biti ok,pogtovo Poirer i Brandao.
Staro 23.12.2013., 12:11   #2117
wnbeeeE
wnbeeeE's Avatar
Postovi: 600
mislim da se silva sam pobjedio last time.
Staro 23.12.2013., 12:29   #2118
2 die 4
2 die 4's Avatar
Postovi: 2,276
A Ronda i Misha
RedGreenBlue
Staro 23.12.2013., 12:46   #2119
wnbeeeE
wnbeeeE's Avatar
Postovi: 600
gogo misha
Staro 23.12.2013., 19:06   #2120
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Iako ne volim Rondu navijam za nju iz "religijskih" razloga. Volio bi i da Silva dobije i to u svom stilu. Ak zgubi mislim da je i on gotov.
Staro 23.12.2013., 19:14   #2121
2 die 4
2 die 4's Avatar
Postovi: 2,276
Gotov????
Zato kaj je izgubio od jednog borca?
Pa onda se isto može reći i za Cigana! Izgubio je od najjačeg i eto, sad je gotov, nema kaj više tražiti u UFC-u!?!?!
Daj molim te objasni mi svoju izjavu?
A ja navijam za Weidman-a jer mi se Silva gadi, ali to ne umanjuje njegovu snagu, znanje i umjeće da razbije svakog drugog, osim njega!
Kaj se tiče žemskinja, Ronda mi je odličan borac ali ono njeno ponašanje nije uredu (osim ak nije gluma, a nekako sumnjam da je), ali ni Miesha mi nije baš nekaj posebno prirasla srcu, tak da nemam favorita, jedino čemu se nadam je jeben fajt.
RedGreenBlue
Staro 23.12.2013., 19:33   #2122
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Ne zato. Nego jer ima skoro 4 banke. 15 godina u MMA i 7 godina prvak u srednjoj. Cak ako i dobije, vrlo lako bi se mogao povuc. Narocito nakon njegovih izjava nakon zadnjeg i prvog poraza od 06. Mislim da je njemu vec lagano dosta i da mu je kraj jako blizu. Ova i mozda jos jedan fight i gotovo.
Staro 23.12.2013., 21:05   #2123
2 die 4
2 die 4's Avatar
Postovi: 2,276
NEznam dali si gledao ove interview-e sa njime, ali u njemu se ni izdaleka ne vidi da je spreman na povlačenje, dapače, potpisao je novi ugovor na novih 9 borbi i kako je sam Dana rekao "his new contract is very motivating".
A ovo sa godinama, pa frajer je spremniji od mnogih u oktagonu, ako ne i najspremniji što se kondicije tiče! Nije ni zadihan nakon prve runde!
Ja nisam dobio dojam da se on sprema na išta osim na ponovnu dominaciju u toj kategoriji, osim što će mu Weidman stati na put i ovaj put
RedGreenBlue
Staro 23.12.2013., 21:16   #2124
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,485
Autor gsxr750k9 Pregled postova
Cain Velasquez?
Staro 23.12.2013., 21:25   #2125
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Pusti spike od Whitea. Taj ugovor od 9 borbi je na tapeti vec neko vrijeme jos prije zadnje borbe i ko zna kaj pise u njemu. Ja imam dojam da Silva ima jos dva fajta max u UFCu i onda ce se povuc, eventualno vratit kasnije mozda i ne. Bumu vidli kaj bu bilo...
Velasquez je kardio fenomen.
Staro 24.12.2013., 16:22   #2126
gsxr750k9
Lokacija: Agram
Postovi: 603
Cain Velasquez?
nisma mislio na kardio vec na mogucnost stajanja na nogama nakon teskih, preteskih batina
Staro 24.12.2013., 17:30   #2127
wnbeeeE
wnbeeeE's Avatar
Postovi: 600
pa eto ti dos santosa u zadnjoj borbi protiv caina, imas to u sigu.
Staro 24.12.2013., 17:35   #2128
gsxr750k9
Lokacija: Agram
Postovi: 603
pa i cigano je nakljukan
ne znam koji borac nije. to smo vec davno apsolvirali.
Staro 24.12.2013., 17:36   #2129
wnbeeeE
wnbeeeE's Avatar
Postovi: 600
ma dobro to je sad relativno. Očito moraju prolazit testiranja, da nemoraju ne bi ni padali kao što je pao bigfoot silva. To su sve mitovi.
Naravno, sve je moguce.
Staro 24.12.2013., 17:56   #2130
gsxr750k9
Lokacija: Agram
Postovi: 603
pa naravno da prolaze testiranja.
na nacin da rade pauze i ciscenja kak ne bi nasli tragove zabranjenih sredstava.
ovdje je bio ocit propust njegovih "doktora"
ili su ga svjesno nasusali prije samog matcha.
