#61 | |
#64 | |
Postovi: 10,047
#65 |
Lokacija: Sv.Nedelja
Postovi: 5,820
Bit ce.... Why hasn't the OTA hit my device yet? I keep mashing the "check now" button! Morrill also explains the "rollout" process of Nexus OTA's. * Quote: Rollouts are conducted in phases. Typically they start at 1% of devices for around 24 - 48 hours; we watch the return rates and resulting device checkins and error reports (if any), and make sure nothing looks wrong before sending it to more. Then typically it goes to 25%, 50%, 100% over the course of a week or two. What the percentages mean is that when your device checks in, it has a 1% chance (for example) of being offered the OTA. If it doesn't (randomly) get an offer, it will never get an offer until the next batch. IOW, once your device checks in and gets turned down, that's it until the next batch. Mashing on the "check for updates" button just causes your device to check in again, and get automatically turned down again. Think about how that makes your device feel! WON'T SOMEONE PLEASE THINK OF THE PHONES?! That said, once the new batch does start, hitting that button does give you a new roll of the dice -- but once. Since devices usually only check in for system updates every 24 hours (I think? Certainly on a many-hours basis) this can get you your shot sooner than it would happen on its own. So, mash away. Just be patient, and mashing on it more often than once or twice a day isn't going to gain you anything. Edit: also, keep in mind that this isn't first-come/first-served. You're not racing other devices to get your slot in the current batch, or something. -Dan Morrill |
#66 |
Postovi: 419
Upravo stavija factory image KRT16S, i odma nakon instalacije napravija OTA update na 4.4.2. (Nexus 4). |
#69 |
Postovi: 10,047
Q: Why do I get a "cannot read update.zip" error when trying to sideload? A: If you named the file update.zip, the actual name would be update.zip.zip. Windows auto names extensions by default. That could be your problem. If not try another usb cable or a different usb port. If that still doesn't work, make sure you type exactly what you renamed the file. You may have made a typo. It is also case-sensitive. http://forum.xda-developers.com/show....php?t=2523217
#71 |
Postovi: 10,047
Meni je prvi put izbacilo neki error jer imam stari adb. Kada upisem "adb devices" izlista uredjaj i pokaze ga kao offline, pa sideload nije prolazio. Na tom linku sam nasao novi adb i onda je prepoznao mob.
#74 |
Postovi: 5,820
Bolji fotić, i video, potonji radi jako smooth, konstantnih 29.80 bilo lošiji bilo dobri svjetlosni uvjeti, dok mi je na 4.4 video bil zbluran (20 fps). Zvučnik je jači tj glasniji, sad ne znam kakav je zvuk u slušalici.. Još nek ubace u apdejt video sa 60 fps i vozi.. |
#76 |
Postovi: 5,820
Izgleda da bum reklamiral N5.. 1.backlight bleed, gornji desni kut, naravno vidljivo samo na crnoj podlozi.. (yellow tint) 2. power tipka se klima 3. vibru jedva da osjetim u džepu 4. Nadam se da naši nebu delali probleme oko garancije.. 5. hrpa ljudi s istim tj sličnim problemom.. http://forum.xda-developers.com/show...515575&page=39 A i zapal me među prvim modelima (310).. ![]() ![]() ![]() Zadnje izmijenjeno od: zvonac. 15.12.2013. u 09:38. |
#77 |
Vozi katru :))
Datum registracije: May 2003
Postovi: 163
#78 | |
Fresh Juice
Postovi: 4,550
Novi mob kod mas ne budes dobio, a sad kolko su strucni popraviti to ne znam. |
#79 |
Postovi: 5,820
Svijet Medija, od tam je garancija... Kolko vidim na xda forumu ekipa uredno dobiva nove, al izgleda zato kaj su kupili prek GSa... Većina N5 ima taj bb, negdje je to više, negdje manje izraženo.. |
#80 |
Fresh Juice
Postovi: 4,550
Da, u servisu novi ne budeš dobio jer kolko mi je poznato Svijet medija ne nabavlja preko LG Hrvatska Nexuse(LG ih uopće nije nigdje pustio kod nas) tak da je jedina šansa je u dućanu tražiti novi mob. |
#81 |
Postovi: 10,047
I Agram i LG su potvrdili da popravljaju uredjaje ako treba samo zamijeniti neki dio. U mom slucaju jer sam ga kupio preko Gplaya kazu da se za zamjenu uredjaja moram obratiti guglu. Vjerojatno se ti onda moras javiti Svijetu medija. Takodjer imam mali bb gore lijevo sto se vidi samo na max osvjetljenju, manje nego tvoje, bez yellow tintinga. Vibra mi je bila slaba ali to sam rijesio promjenom kernela (nemam drugi N5 za usporediti je li to defekt ili ne). Power button sam zakrpao, a onog mrtvog pixela se vise i ne sjecam gdje je. Takodjer sam mislio slati mob na servis u hrv. radi svega navedenog, ali sad me to vise ne smeta. Eventualno na ebayu jednog dana kupim vibromotor i zamijenim i to jedino ako netko potvrdi da moze izazvati pomicanje tektonskih ploca.
#82 |
Postovi: 5,820
A kaje zapravo bilo, bil sam u kupaoni tuširal se, a mob zamotan u majicu, čopim majicu i mob mi je ruknul na pod (nema oštećenja, nema ničeg vidljivog kaj bi upućivalo na to, nam nikavu pikicu i sl) malo se rasklopil na vrhu, zaklopil ga i vozi dalje ![]() E onda sam skužil taj bb, pa ni vrag da ga je to smrdalo, taj pad? Nea veze, neg onda zamjene display.. Al mene zanima dal to ide pod garanciju? |
#83 |
Postovi: 10,047
A to ti ne bi znao reći. Google je poznat po svom srdačnom customer supportu gdje dosta ljudi čeka nove "ispravne" serije da zamijene kompletan uređaj. Kod nas mislim da neće biti lako niti jedan dio zamijeniti.. Sumnjam da ga je pad zdrmao.
#84 |
Why so serious
Postovi: 3,415
Da velim svoje iskustvo sa agram servisom i LG. Imal sam puknuce LCD displaya na e975, i malo nagnjecenje u g desnom uglu, jer je pao na taj ugao. Odnio u agram, oni su mi zamjenili cijelo kuciste, znaci nisu prckali po ekranu nego sam dobio jednostavno cijelo kuciste sa ekranom....kad sam to vidio puko sam od srece, jer opet imam doslovno nov mobitel bez pikice. A kaj se tice reklamacija, 100% su mi potvrdili da mi vrijedi garancija 24 mj iako je kupljen u Njemackoj, bitno je bilo to da je kupljen iza 1.7. Al su spori do bola, za dijagnostiku im je trebalo 5 radnih dana, za popravak jos 3....koma. no obavio sam to i jako sam zadovoljan sa zamjenom....znaci ne kemijaju samo zamjene i to je to, jer ja sam mislio da ce mi grijat mob odkeljivat ekran i ljepit.nov...ali ispalo je na najbolji moguci nacin. A cijena nije ni velika kak sam ocekival, na kraju jeftinije je nek kod privatnih servisera... + ostala mi vazeca garancija. |
#85 | |
Postovi: 5,820
Imal sam prije GNex, na kojem je zamjenjen display (imal je purple tinting) u servisu, bez pogovora.. Tak da ne vidim neku frku oko ovog ak bi kojim slučajem radili.. Nemam nikakvih ostalih anomalija, kaj se tiče displaya, yellow tinting je isključen, skinul sam app BB Test, stavil bijelu podlogu, i bijela je bijela.. |
#86 |
Postovi: 10,047
Eh, sada treba netko provjeriti kakvog su raspolozenja kada zelis zamijeniti ispravan ekran na teret garancije ![]() Tnx za podjelu iskustva s njima!
#87 |
Postovi: 5,820
Odfural mob na servis.. Još dok bi dobil novi, iz novije serije ![]() Uz bb problem, još sam imal povremeno gubljenje signala, sugovornika čujem tek nakon 2-3 sec nakon uspostave poziva.. Uglavnom svi simptomi kaj zahvaćaju tu seriju Nexusa.. |
#89 |
Why so serious
Postovi: 3,415
