Staro 18.07.2005., 14:39   #1
Mailman
Mailman's Avatar
Postovi: 1,606
Ati Tray Tools 1.0.3.720
1.0.3.720 (July 18, 2005)
+ Added new options into Game Profiles. Direct3D9 tweaks. Using this tweaks you can override some hardware information about your video board.
+ Added support for SMARTGART. Look in "Hardware" menu. (SMARTGART service must be installed and enabled!)
+ Added 5 new hotkeys for manual overclocking GPU and Memory by 1 step up or down.
+ Added new tweaks databases Video Acceleration settings and Display Tweaks.
+ Added Default buttons for Standard Tweaks window, Direct3D and OpenGL Tweaks.
+ Added options to execute applications when entering 3D mode and when leaving it.
* Updated installation procedure. Added two shortcuts to Install and Uninstall ATT Windows Shell Integration.
* Updated Shared Memory. Now FPS counter is included in global ATT Shared Memory.
* Improved command line support. Added command line options:
/LD3D [name of profile] - load Direct3D (or 3D in Control Center mode) profile
/LDGL [name of profile] - load OpenGL profile
/LDOV [name of profile] - load Overclocking profile
/LDTV [name of profile] - load Display/TV profile
/LDGP /LOADGAME [name of profile] - load Game Profile (If ATT is already started /EXIT command line parameter has no effect) /RSTCLK - reset clocks to default values
/EXIT - Exit from ATT
For example if you want to load overclocking profile and exit from ATT, you can add shortcut to ATT into Startup folder of system menu and add this command line. Always put profile name in quotation marks.
atitray.exe /LDOV "My Stable OverProfile" /EXIT
* Fixed bug when TV Properties Tab doesn't visible with extended desktop mode. Now TV Options will be accessible all times, even if you don't have TV attached to the board.
* Updated screenshot system. Added support for JPG/PNG file creating. Screenshot without active game always will be saved as BMP.
* Fixed broken support for temperature monitoring and fan control for ASUS 9800XT boards.
* Improved OSD rendering in situation when game clipped part of screen with ViewPort.
* Fixed error with hotkeys (Hide/Show FPS/FlashOSD)
* Updated Advanced Tweaks editor
* Updated "No overclocking" mode. If you Radeon doesn't supported by ATI Tray Tools (IGP series) you can disable all overclocking functions in atitray.ini. Set opt_disable_ovr value to 1. In this mode all modules depended on GPU and Memory clocks will be disabled. For example Overclocking, hardware monitoring, Auto 2d/3d Overclocking and so on. But you still can use all other functions!
* Fixed wrong OSD color calculation for some old Direct3D (D3D 7/6/5) games.
http://www.radeon2.ru/atitray/
Mailman je offline   Reply With Quote
Staro 18.07.2005., 15:23   #2
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Baš sam skinuo, kad se natjeram da instaliram nove 5.7 budem probao samo divere (bez CP-a) i ATT.
Staro 19.07.2005., 13:36   #3
Router
Hejter
Postovi: 6,521
sa kolkom sigurnoscu treba uzeti rezultate koje att da za max clock gpu i meme? meni daje osjetno manje rezultate od onih sa kojim sam uspio igrati se bez artefekata , i to osjetno manje . da mu vjerujem ili ne?
Router je online   Reply With Quote
Staro 19.07.2005., 13:54   #4
Jelc
Super Moderators
Postovi: 17,485
Ma, bolje ti je ravnati se po igrama.
Ja to još nisam ni probao, idem sad...
Staro 19.07.2005., 16:19   #5
Router
Hejter
Postovi: 6,521
To sam i mislio .
Staro 20.07.2005., 02:49   #6
SIR_KILL@LOT
SIR_KILL@LOT's Avatar
Postovi: 184
Artifac tester u ATT-u ( i u svakom drugmo sličnom programu Ati tool npr.) ti skenira renderiranu scenu i prijavljuje i najmanje artifakte na koje naiđe.. dok ti to nećeš vidjeti u igri nekoj sigurno...
ali to je glupo jer bi nakon par sati pokazao artifakt i na STOCKU grafičke... ono my guess... ma preoprezno je to..
najbolje je u giri nekoj ili nekoj drugoj zahtvjenoj 3d aplikaciji..
..zavrti 3d mark 2003 game test 2 tamo meni uvjek pokaže artifakte( onaj sa ženskom i mačom i gobilnom itd.)...
:: TH3_R3dR0cket // MSI I865PE - Neo2 FIS2R @ Ultra Turbo Mode, AGB BUS@70mhz@1.6V ::
:: Intel Pentium 4 2,6ghz@3.51ghz (270FSB) -CM JET4 cooled::
:: 2x512mb Kingmax SuperRAM DDR 433 ( 2-3-3-6, 2.7V) // Gigabyte Silentpipe 6800@1.39V 16,6 415/875 ::
:: WD EIDE 80gb 7200rpm, 8mb cache // TITAN Hard disk cooler - 2 venta + aluminijski heatsink ::
:: LG DVD ROM 48x max // LG CD/RW 52x/24x/52x // Samsung 1.44mb Floppy drive //Hiper 525W PSU ::
:: 3D Mark 2001SE - 20960 // 3D Mark 2003 - 12402 // 3D Mark 2005 - 5013 // Aquamark3 - 68062 ::
:: www.cro-gaming.com ::
SIR_KILL@LOT je offline   Reply With Quote
Staro 20.07.2005., 03:15   #7
Router
Hejter
Postovi: 6,521
vrtio sam cijelo popodne 03 i stao zasad na 517/420 , i samo na prvom testu sa avionima se vidi na jednom mjestu par crnih tockica , a poslije u niti jednom nisam uspio zamijetiti. a att mi je stao na 486/393 haha . jos samo da da i stavim nove drivere , 4.9 su malo out-of-date .
Staro 20.07.2005., 03:17   #8
Jelc
Super Moderators
Postovi: 17,485
Stavi si zadnju Omegu i bog.
Staro 20.07.2005., 03:31   #9
Router
Hejter
Postovi: 6,521
zadnji put kad sam stavio omegu . morao sam re-instalirati windowse , ali to je vec neka druga prica mozda opet riskiram
Staro 20.07.2005., 03:34   #10
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Ja više ne stavljam Omegu,uvjek imam neka sranja s njom a dobici su ono,nemjerljivi,jedino što piše Omega
Staro 20.07.2005., 03:45   #11
Jelc
Super Moderators
Postovi: 17,485
Je da, treba de-instalirati stare drivere i sve fino očistiti a to se vama ne da...
Staro 20.07.2005., 04:16   #12
Router
Hejter
Postovi: 6,521
evo sad sam htio dokazati nesto - stavio sam omegu baziranu na 4.12 catalystima , jedino sam tu nasao na nekom cd-u . jedino me zivcira radlinker - odmah stavlja shortcut u onaj meni kad na desktopu opalim desni click , i sad ga se nemrem rijesiti . i stavio sam opet att za diazati takt , sad spavat , a poslije opet 04
Staro 20.07.2005., 08:31   #13
Mailman
Mailman's Avatar
Postovi: 1,606
a zašto bi ga se rješavao? ako imaš shortcut, 3dmarka npr., na desktopu: desni klik->radlinker i namjestiš si setingze za svaku aplikaciju posebno....
inače, add-remove programs...
Staro 20.07.2005., 11:00   #14
Router
Hejter
Postovi: 6,521
A sorry , u 3 ujutro pisem gluposti . ali dobre su omege - RADE - i daju par markova vise na istom clocku .
Staro 20.07.2005., 11:18   #15
Jelc
Super Moderators
Postovi: 17,485
Kaj nemaš ni jednu stariju verziju???
Pa 15 megi su ti zadnji...5.6 Omega a ovaj tjedan izlaze 5.7.
Staro 20.07.2005., 13:07   #16
Veki-os
Veki-os's Avatar
Postovi: 3,996
Sve ja to napravim s Driver cleanerom,cab cleaner pa onda da očisti sranja od Ati-a ali uvjek ta omega zeza nešto.
Staro 20.07.2005., 13:18   #17
Router
Hejter
Postovi: 6,521
taman ce onda posluziti ovaj tjedan
Staro 23.07.2005., 15:10   #18
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
ovako..
meni je problem kod Att, što clock grafičke ne mogu pomaknuti dalje od 375mhz (gpu9, je je po biosu 250 default, pa vfaljda zato... a gpu mi ide do 420 bez problema...
kako natjerat preko 375?
Staro 23.07.2005., 15:29   #19
Jelc
Super Moderators
Postovi: 17,485
Originally posted by Gabre
ovako..
Tools&Options-General Options i isključi overclock limit.
