Super Moderators
Datum registracije: May 2002
Postovi: 17,485
PCI Latency Tool 2.3
Za ponosne vlasnike 6xxx serije ovo je koristan prog za smanjivanje ili potpuno eliminiranje stutteringa. Inače se koristi i za eliminiranje problema sa nekim modelima zvučnih kartica. Koristan prog kojeg bi svaki ozbiljniji tweaker morao imati integriranog. Utility to set PCI Latency and possibly prevent game stutter or improve FPS. This tweak is an important one, and one well worth checking into. Apparently, newer high-end video cards hog PCI latency for no known reason. This makes other components wait for access and causes stutters and thus lower frame rates. If you adjust the latency this might benefit you, users are reporting big improvements. You can download this small utility program that allows you set your PCI latency. Adjust the PCI latency from for example 248 to 64, and there's a very good chance of stutter free performance & sound. STEP 1. open the pci latency tool STEP 2. Rightclick on your graphics card and click change setting(s) STEP 3. change to desired setting and hit ok Step 4. click settings and select apply at startup so it has a tick next to it STEP 5. click settings and select save so everything you have just done is saved STEP 6. right click on your video card and click quickset latency (if you want to set it straight away). More information and user experiences can be found in this forum thread: http://forums.guru3d.com/showthread....hreadid=121190 Skidanje: http://downloads.guru3d.com/download...c13b5674e0dc22 Korisna stvar u samo 250kb ![]() |
Pink Floyd fan
Lokacija: Santa Clara, CA
Postovi: 5,544
Evo kako je kod mene po defaultu
Zadnje izmijenjeno od: LAcy. 05.03.2007. u 23:53. |
#4 | |
Postovi: 498
Meni je po defaultu sve(grafa,AGP i modem) na 32 a ostalo na 00 |
The Man
Lokacija: Novi Zagreb
Postovi: 1,252
Evo ga i sve je u redu još samo da probam u cod-u i wow-u Pod latency piše 248 ,a pod new latency 064 EDIT: Ipak mi se čini da se bolje ponaša kada je na 128 nego kada je na 64 ,pa sam zato ostavio na 128 EDIT 2: Razlike u cod-u i nema ,ali u wow-u se dosta vidi
"Everybody's at war with different things...I'm at war with my own heart sometimes" Zadnje izmijenjeno od: Broken Arrow. 18.07.2005. u 01:09. |
#6 | |
Super Moderators
Postovi: 17,485
Ti imaš PCI-E grafu, to šljaka samo na AGP i PCI uređajima. Dosta ljudi koji imaju npr. LIVE seriju zvučnih su riješili probleme sa tim progom. |
#8 | |
Super Moderators
Postovi: 17,485
