Zaključane teme
Staro 15.10.2013., 22:49   #841
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Brijes.
Imamo super individualce ali kao ekipa....
Fakat mi nije jasno sto strinic i kalinic rade u repki.
Siguran sam da bi jedna Rijeka ili Lokomotiva pruzila bolji nogomet.
Hamm je offline
Staro 15.10.2013., 22:50   #842
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Autor gsxr750k9 Pregled postova
... pa to je bilo drvo da je bukva il hrast nisam siguran..!
Drevo bukovo!
Fino ide taj trening. Treniraju kako ne igrati ništa i kako primati golove. Bravo Štimac!
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline
Staro 15.10.2013., 22:52   #843
gmax
Tuco “the Rat” Ramirez
gmax's Avatar
Postovi: 477
Sad ce Stimac ufurat Ademija i on ce rijesiti tekmu.
gmax je offline
Staro 15.10.2013., 22:52   #844
gsxr750k9
Datum registracije: Apr 2011
Lokacija: Agram
Postovi: 603
stativa ko mandzukic bi mogel bit bilo ko s PCE foruma da ima suigrace kao sto su ribery i robben.. o šljukici da ne pricam, kakvu on mrtvu ekipu ima..a ni uz njih nije bas bajan..
uskoro leti iz madrida!
gsxr750k9 je offline
Staro 15.10.2013., 22:57   #845
Omerta
Omerta's Avatar
Lokacija: Grobnik - Rijeka
Postovi: 3,255
Pustite tog Stimca malo sa strane..
Igraci se ne bore, nema zelje, nema snage, nema znanja, nema ideja..
Jad i bijeda..
Nakon Bosne sad kad gledam ovo, pa ovo ja ne vjerujem.
Ocajni smo, ocajni..
Kad bi nas barem nabili onako posteno..
Recite sto hocete, ali bolje da doma budemo..
Odgovoran trgovac:1, 2, 3, 4, 5, 6, 7, 8, 9
Omerta je offline
Staro 15.10.2013., 22:58   #846
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Bože daj mi malo konde i idem onaj Mandžin volej poslat gdje je mjesto!
Katastrofa. Pomak je, jer Perišić neigra, to mi već puno znači. Striniću uzimam za zlo što je napravio par prodora protiv Belgije, ali jadan je pokazao da mentalitetom nespada u taj dio terena(nedaj Bože ak treba desnom nogom nešto napravit), on pokriva jako malu kvadraturu i samo to zna(upitno jelte).
Pad je, psihićki je ogroman pad u repki, i Štimac pod hitno mora ća...da se vrate neki stari treneri ja garantiram da bi to bolje bilo, ovaj lik je panjina. Samo da se nedesi da Vlaović kasnije bude trener..i on nešto kao komentira.
Halos je offline
Staro 15.10.2013., 22:59   #847
draksa
Postovi: 333
Ma sta ce Modric na 40-50m od njihovog gola
Nama su playevi Lovren i Corluka, dodaju se 2-3 puta medjusobno pa nabiju na krilo loptu Srni il Strinicu koju nebi ni Ronaldo uhvatio a kamo ovaj panj ili Mandzukicu daju neku loptu koju i da primi bi oko sebe imo 4 Skota i mogo bi ju lagano predat njima u noge
draksa je offline
Staro 15.10.2013., 23:00   #848
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
To je i mene strah, ovo sa komentatorima koji postaju treneri.
Treba neki stari maher iz neke jake nogometne zemlje, nije nikakva sramota imat stranog trenera. Nist nemre bit vec sramota od ove igre i Stimcevog trenerskog potencijala.
MAGARAC je online
Staro 15.10.2013., 23:03   #849
gmax
gmax's Avatar
Postovi: 477
Kad su predviđene te utakmice dodatnih kvalifikacija?
gmax je offline
Staro 15.10.2013., 23:03   #850
Perki
Lokacija: VG
Postovi: 775
Da je Bugarin zvao vi se Deblov. Ili Balvanov. Možda čak i Trupcov.
Trust me - I know what I'm doing!
Perki je offline
Staro 15.10.2013., 23:05   #851
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Placko Drvojev... Stimac bi bio Zadrt Tupoljev, to je vec malo Rusko-nesto.
Ne to je Maminjo. Pljacko Dinamov.
Meni je Ok Mandzu ali ga ovaj Zadrt ne zna koristit. Ima on nos za gol iako nije bas neka tehnika.
Zadnje izmijenjeno od: MAGARAC. 15.10.2013. u 23:14.
MAGARAC je online
Staro 15.10.2013., 23:07   #852
gsxr750k9
Lokacija: Agram
Postovi: 603
lol Šljuka Modrić i Pljačko Drvojev. bolest
P.:S ak nekaj ne rijese u skorije virjem mislim da nam nogomet ide putem kosarke.. a to znaci godine pusione!
Staro 15.10.2013., 23:10   #853
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Kad izgubimo, puštam si ovo:
Žao mi je stvarno igrača naših, nisu to loši dečki, al kad imaju tromba za trenera...šta da im čovjek kaže. Igraju loše, jer im igru diktira neznalica koja skuplja iskustvo u repki a igračima troši i fizičku i psihičku spremu.
Halos je offline
Staro 15.10.2013., 23:19   #854
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Kalinic van, Eduardo unutra. Napokon!!!
Hamm je offline
Staro 15.10.2013., 23:19   #855
srale7
srale7's Avatar
Postovi: 5,798
Jbte kad vidim kranjčarov korner, ostra lopta na peterac, sjetim se Srninih 20 kornera u ovim kvalifikacijama, sve na prvu stativu, tj protivničkog braniča.
EDIT: Drugi korner, ala Srna. Jbga, pohvalis ga i odmah kiksa
srale7 je offline
Staro 15.10.2013., 23:24   #856
Perki
Lokacija: VG
Postovi: 775
Ma jel' smo to mi imali priliku?
Perki je offline
Staro 15.10.2013., 23:25   #857
Roberto
Roberto's Avatar
Postovi: 2,654
ma, kranjcar je svejedno doktor nogometa za sve nase ostale veziste. puno smo konkretniji prema naprijed s njim.
Roberto je offline
Staro 15.10.2013., 23:26   #858
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Evo ga! Ulazi majstor Perišić!
Sad ćemo dobit još dva u roku 10min.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 15.10.2013., 23:27   #859
gsxr750k9
Lokacija: Agram
Postovi: 603
Autor estugarda Pregled postova
haha uporno forsa tog idiota. ne kuzim. kome ga misle uvaljat??
barceloni?
Staro 15.10.2013., 23:28   #860
Roberto
Roberto's Avatar
Postovi: 2,654
da puknes od smijeha
penal za skote
kak ono stoji armenija?
Roberto je offline
Staro 15.10.2013., 23:30   #861
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Tebali bi Benka trebali uzet u repku, makar da ulazi sa klupe zadnjih 15 min. Frajer je sad u spici.
I da, kazneni udarac. Meni je taj Vida bezveze. Obrana je neshvatljivo nonsalantna i Stimca treba sterat zbog toga jer to traje i traje. Jos ce nas ovi natrpat posteno.
MAGARAC je online
Staro 15.10.2013., 23:31   #862
Perki
Lokacija: VG
Postovi: 775
Loooooooooooooooool!
Perki je offline
Staro 15.10.2013., 23:31   #863
gsxr750k9
Lokacija: Agram
Postovi: 603
treba se rijesit svih ovih KVAZI igraca zvijezdi i zvjezdica...
pozvat mlade igrace zeljne dokazivanja i krenut sve iz pocetka..
nema nam druge!
Staro 15.10.2013., 23:32   #864
tutix
tutix's Avatar
Postovi: 4,069
Lovren odličan stoper
tutix je offline
Staro 15.10.2013., 23:32   #865
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Perišić! Odgovorno tvrdim da je to panj kojemu se porećio jedan volej u Njemačkoj ..i sad igra u repki.
Hvala, doviđenja.
Halos je offline
Staro 15.10.2013., 23:32   #866
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Evo ga. Za 5min. Još imaju 5 min za drugi.
Je li to sad konačno dosta da počnu letit glave?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 15.10.2013., 23:33   #867
Postovi: 8,243
lol
Pupo je offline
Staro 15.10.2013., 23:33   #868
Perki
Lokacija: VG
Postovi: 775
Ovo je fakat u kujcu. Frajer skine penal i svejedno nam ga uvale. Strašno.
Perki je offline
Staro 15.10.2013., 23:33   #869
gmax
gmax's Avatar
Postovi: 477
Mogli bi nas Škoti pošteno razmontirati večeras.
gmax je offline
Staro 15.10.2013., 23:34   #870
Perki
Lokacija: VG
Postovi: 775
Autor gmax Pregled postova
Razmontirani smo mi već neko vrijeme.
Perki je offline
Zaključane teme
