Zaključane teme
Staro 03.10.2013., 21:21   #841
gsxr750k9
Datum registracije: Apr 2011
Lokacija: Agram
Postovi: 603
ne znam kak da slikovit opisem igru ovog dinama. mislim da bi prekrsil sva pravila ovog foruma. jebo mi pas mater!
gsxr750k9 je offline
Staro 03.10.2013., 21:24   #842
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,741
negledljivo....odustajem...
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline
Staro 03.10.2013., 21:40   #843
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
kakva prokletinja...kažu nisi navijač ako bla bla bla, a onda nisam , zajebi ovo
Halos je offline
Staro 03.10.2013., 21:45   #844
panda505
panda505's Avatar
Lokacija: Beertopia
Postovi: 2,013
Ajmo ljudi otvorit kladaru, kad Mamić saziva press konferenciju da objavi otkaz Ivankovića i ponovno uzimanje Jurčića kao trenera?
54' / 74' / 90' / 2014
panda505 je offline
Staro 03.10.2013., 21:46   #845
ShanTech
Postovi: 3,784
Tamo negdi oko 23:30 se vraća Jurčić
Eto ga na, preteče me
ShanTech je offline
Staro 03.10.2013., 21:46   #846
esc
Lynnfield
Datum registracije: Sep 2012
Postovi: 1,023
znači vraća se krunoslav jurčić,nije ga ni trebal maknut
esc je offline
Staro 03.10.2013., 21:47   #847
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,343
Ugasio tv, ovo nije igra.
žmnpp
buljo je offline
Staro 03.10.2013., 21:59   #848
ThePornstar
ThePornstar's Avatar
Postovi: 4,400
Ovog Sarea treba deportirat, on fakat nije normalan i to se vidlo iz aviona iz tih par tekmi kaj je igral.
Da je samo malo potrcal kad je golman krivo ispucal...
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
ThePornstar je online
Staro 03.10.2013., 22:16   #849
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
Ne znam kak su oni mislili igrat LP sa takvom ekipom, igrom. Oborili bi sve rekorde po primljenim golovima.
MAGARAC je offline
Staro 03.10.2013., 22:22   #850
panda505
panda505's Avatar
Lokacija: Beertopia
Postovi: 2,013
Autor ShanTech Pregled postova
a ili će Krunek ili Ante Čačić, ali svakak mislim da tanac posle 23:30 nije više trener dinama
panda505 je offline
Staro 03.10.2013., 22:28   #851
robert7
robert7's Avatar
Postovi: 1,708
Nek oni sam vrate ime Croatia Zagreb, tad se bar igrao nogomet.
Jebes dinamo
http://eu.prepsafe.com
robert7 je offline
Staro 03.10.2013., 22:29   #852
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Petardinjo će bit do kraja tekme .
Neštima "vibra" u tom Dinamu, to je raspad sistema...
Se može vratit tandem Krznar-mamić, pa one 2 tekme su bile ok.
Halos je offline
Staro 03.10.2013., 22:32   #853
Spikeman
Lokacija: bi volio znat?
Postovi: 1,220
ovo bi bilo prigodno stavit tu
http://www.youtube.com/watch?v=k3DoUe6LVfU
Spikeman je offline
Staro 03.10.2013., 22:37   #854
Banx
Banx's Avatar
Lokacija: Čepin
Postovi: 258
ma i treba,ili glupi narod nikada nece shvatiti...
"There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die."
Banx je offline
Staro 03.10.2013., 22:39   #855
Roberto
Roberto's Avatar
Postovi: 2,636
Tko je ono reko da ce prije Dinamo razbit Ludogorec nego Rijeka otkinut bod Betisu?
Canjuga vrati se.
Cestitke Rijeci. Tak se umire muski protiv jacih, i usput otkine pokoji bod. Trener ipak puno znaci, vidljivo na nasem domacem primjeru.
Roberto je offline
Staro 03.10.2013., 22:41   #856
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,734
Rijeci svaka čast. Ekipa igra VRHUNSKI.
Dinamo...nemam komentara.
Hamm je offline
Staro 03.10.2013., 23:36   #857
vision19
Datum registracije: Jan 2011
Lokacija: Vinkovci / Njemačka
Postovi: 494
Dinamo nije odigro ali opet fascinira činjenica da Ludogorec bez stvorene šanse pobjedi 3-0 tu je nešto stvarno trulo.
Rijeka odlična, neću reći da su osvojili bod nego da su ostali bez 2 trebali su zašamarat Betis do kraja i nek ide u k*** sve
"Anyone who has never made a mistake has never tried anything new." A.E.
vision19 je offline
Staro 04.10.2013., 00:37   #858
panda505
panda505's Avatar
Lokacija: Beertopia
Postovi: 2,013
Kad pogledaš koliko je potrošeno na transfere, kolike su plaće tih igrača i onda ovakvi rezultati
treba tu neki stranac koji bi to postrojio i posložio kak se spada
e da je samo Rangnick dostupan
panda505 je offline
Staro 04.10.2013., 06:03   #859
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Kaj se žalite,uzimajte pare dok je zdravka!! Svaka dva tjedna prilika za duplanje plaće! Prije 2 tj je bilo i x5 akcija za jednu HR plaću
trouble je offline
Staro 04.10.2013., 06:22   #860
MeanBoss
|CTS|MeanBoss|
MeanBoss's Avatar
Lokacija: Sinj
Postovi: 1,005
Autor trouble Pregled postova
hahah legende...znas da mi je to veceras palo na pamet i jos pogledam rijeku sinoc...pa budu li s pola one zelje igrali protiv ovih legionara bit ce hendikep lagani!
MeanBoss je offline
Staro 04.10.2013., 06:35   #861
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Ne al fakat parodija... prije 2 tj kad su ukrajinci igrali bilo je 5.50 na ukrajince... pola birtije navija za dinamo,pola urla za goste čik pogodi ko je sretniji bio hahha
No kako ni hard core Dinamovci nisu imuni na majku zvanu dojčmark(nekadašnja verzija eura ) jučer su svi u jedan glas vikali..."hebo majku,hebo oca ko ne voli ludogorca"
trouble je offline
Staro 04.10.2013., 06:51   #862
ivan77
Autor ivan77 Pregled postova
danas Ludogorets pobjeđuje sa 2 ili više gola razlike.
Staro 04.10.2013., 09:19   #863
Roberto
Roberto's Avatar
Postovi: 2,636
I ćorava koka nakljuca zrno
Dinamo, šta se više tu može reći.
Mamić je opet usio - atomski dinamo je ponovo rastavljen na atome
Roberto je offline
Staro 04.10.2013., 10:15   #864
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
ovaku komediju od igre već dugo nisam gledao...
Dizel je offline
Staro 04.10.2013., 10:48   #865
Roberto
Roberto's Avatar
Postovi: 2,636
Autor Dizel Pregled postova
Što se igre tiče, nema tu ništa lošije u odnosu na ono što ''igraju'' od početka sezone. Ovakve golove ne bi primio ni Radnik iz Lučkog.
Roberto je offline
Staro 04.10.2013., 11:08   #866
gsxr750k9
Lokacija: Agram
Postovi: 603
Ovaj mamicev Dinamo je teska sramota!
Iskljucivi krivac za jucerasnji poraz je glava himself.
Njegovi kvazi-treneri, pogresne taktike.
Upropastiti onakva dva krilna napadaca ko sto su soudani i fernandes i staviti ih u eksperiment na pozicije u europskoj tekmi..to moze samo idiot!
Takticka postava nula.. sammir..deportacija i oduzimanje drzavljanstva.
nevidjen bahatluk i uzivanje svih blagodati..raskalaseno ponasanje sramota.
Fino je tonel rekao u clanku za VL.
pijanac.
ja jednostavno ne vjerujem u ono kaj sma jucer gledal.
taj covjek je upropastio jedan od najboljih klubova s prostora bivse juge.
nema navijace, ima sacicu placenika koji ga podrzavaju, represivni aparat, mafiju.
e da se vratit u vremena lepog caneta i dr FT-a
ono je bila idila i nikad vise takvog dinama.
P.S. ja ma rekao da ce dinamo pobijedit jer nisam ni u najgoroj nocnoj mori mogel sanjat da cu vidjet ono kaj sma jucer videl!
da ne velim bajku/basnu nazovimo kak hocete sa Pablom Miglioreom...kak je tip potpisal ugovor i onda brzo skuzil muljazu dvojice brace i pobegel glavom bez obzira natrag u Argentinu... a sjetite se smao kakve su price nakon tog dogadjaja bile servirane u meidjima...
ak pratite argentinsku ligu pogledajte malo kak tip brani. lik je svemirac..
Zadnje izmijenjeno od: gsxr750k9. 04.10.2013. u 11:20.
Staro 04.10.2013., 12:05   #867
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Autor gsxr750k9 Pregled postova
ispravak netočnog navoda
trouble je offline
Staro 04.10.2013., 16:58   #868
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Kao da je Canjugin i Franjin NK Croatia osvojio Kup prvaka europe...isti kurac, navijači su bili samo ovi iz stranke, svima je išao na živce taj klub. Sve bitne utakmice smo ispušili, od Newcastlea pa nadalje.
Po meni bi najbolje bilo ugasiti klub, srušit i zapalit stadion i tu livadu asfaltirat u neko parkiralište.
Dizel je offline
Staro 04.10.2013., 17:19   #869
listerstorm
listerstorm's Avatar
Postovi: 1,428
Ladić, Jurić, Mladinić, Tomas, Šimić, Krznar, Rukavina, Marić, Šarić, Mujčin, Jurčić, Petrović, Prosinečki, Cvitanović, Viduka - e to je bila kvaliteta a ne ovo.
listerstorm je offline
Staro 04.10.2013., 17:37   #870
gsxr750k9
Lokacija: Agram
Postovi: 603
pricas nebuloze. spominjes newcastle? zasto smo popusili tu tekmu? jesi bio na tekmi? tu, gore?
opasan si kuzator ako po tebi klub ne valja jer nije bio prvak...nevjerojatno
pricas o navijacima iz stranke? ociti nisi bio ni blizu stadionu devedesetih godina.
bez uvrede.
Zaključane teme
