Staro 19.09.2013., 15:13   #1
viper
super user
viper's Avatar
Lokacija: Houston, TX
Postovi: 1,805
Lightbulb Nvidia GeForce v327.23 WHQL Driver
http://www.geforce.co.uk/drivers/results/66800
Release Summary
This Game Ready WHQL driver ensures you’ll have the best possible gaming experience and is also a recommended driver update for the Windows 8.1 Preview. GeForce R326 drivers also provide performance increases for a variety of different games.
New in GeForce R326 Drivers
  • Performance Boost – Increases performance by up to 19% for GeForce 400/500/600/700 series GPUs in several PC games vs. GeForce 320.49 WHQL-certified drivers. Results will vary depending on your GPU and system configuration. Here is one example of measured gains:
  • GeForce GTX 770:
    • Up to 15% in Dirt: Showdown
    • Up to 6% in Tomb Raider
  • GeForce GTX 770 SLI:
    • Up to 19% in Dirt: Showdown
    • Up to 11% in F1 2012
  • SLI Technology
    • Added SLI profile for Spinter Cell: Blacklist
    • Added SLI profile for Batman: Arkham Origins
  • 4K Displays
    • Adds support for additional tiled 4K displays
    • Adds support for 4K FCAT testing
    • Extended support for tiled 4K features
Additional Details
  • Installs new PhysX System Software 9.13.0725.
  • Installs HD Audio v1.3.26.4
  • Includes support for applications built using CUDA 5.5 or earlier version of the CUDA Toolkit. More information at http://developer.nvidia.com/cuda-toolkit
  • Supports OpenGL 4.3 for GeForce 400-series and later GPUs.
  • Supports DisplayPort 1.2 for GeForce GTX 600 series GPUs.
  • Supports multiple languages and APIs for GPU computing: CUDA C, CUDA C++, CUDA Fortran, OpenCL, DirectCompute, and Microsoft C++ AMP.
  • Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, DirectX 11, and OpenGL, including 3-way SLI, Quad SLI, and SLI support on SLI-certified Intel and AMD motherboards.
Release Notes (v327.23)
viper je offline   Reply With Quote
Staro 20.09.2013., 10:07   #2
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,143
opet je pljuvacnica po njima ko i sve nakon 314.22 .
imam osjecaj da cu zauvjek ostat na 314.22 .
ocito cu i ja, kao okorjeli nVidia-š, pocet razmisljat o crvenim .
Staro 20.09.2013., 11:00   #3
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
Ja sam jucer stavio, preko GeForce exp. i najbezbriznija i najbrza instalacija koju sam probao do sad. Ovo kaj igram radi bez problema kao i sa starijim verzijama.
Citam i ja Nvidia forum i precesto vidim da problemi proizlaze iz beskonacnih brisanja i deinstaliranja drivera i sl. pokusaja da se maknu. Dosta sam se namucio sa time sa starim Catalystima i od tad vise nikad ne koristim driver sweaper, niti instaliram ili deinstaliram samo neku komponentu drivere nego cijeli. Cak se ni ne sjecam kad sam zadnji put radio uninstall drivera jer samo instaliram nove i na stare zaboravim, osim sto ih pobrisem radi mjesta na disku. Sve radim najjedonstavnije kaj se moze i vec jako dugo nemam bas nikakvih problema sa driverima, skoro da ne znam da postoje.
Zadnje izmijenjeno od: MAGARAC. 20.09.2013. u 11:25.
MAGARAC je online   Reply With Quote
Staro 20.09.2013., 11:45   #4
Mrakky
Mrakky's Avatar
Datum registracije: Oct 2012
Lokacija: Velika Gorica
Postovi: 115
ajd napokon da su izbacili nekaj kaj valja, bar kod mene sve funkcionira kak treba, bez ikakvih errora u even vieweru.
Mrakky je offline   Reply With Quote
Staro 20.09.2013., 14:21   #5
Thermaltake
1
Thermaltake's Avatar
Postovi: 3,563
Ja sam danas instaliro i u win. sve dobro radi i nema nikakvih errora nit mi je prije bilo na 314.22 za igrice nažalost nemogu reć jer ih baš i ne igram.
Zadnje izmijenjeno od: Thermaltake. 20.09.2013. u 15:18.
Staro 21.09.2013., 20:39   #6
SetH
SetH's Avatar
Lokacija: ZG/Borongaj
Postovi: 3,324
isto sranje
SetH je offline   Reply With Quote
Staro 21.09.2013., 23:18   #7
viper
super user
viper's Avatar
Postovi: 1,805
Ja sam zadnju betu pregazio sa ovim whqlom i nema nikakvih problema a kolko vidim ni poboljšanja velikih.
@ MSI 660
Staro 22.09.2013., 20:09   #8
NemoRS
NemoRS's Avatar
Postovi: 518
Opet mi prestaju radit i komp mi se smrzne
NemoRS je offline   Reply With Quote
Staro 22.09.2013., 23:16   #9
hetz
Datum registracije: May 2009
Postovi: 73
Ja moram priznat da nemam nikakvih problema s ovim driverima, nema errora niti problema sa igama, Za sad da kucnem u drvo sve radi kako spada.
hetz je offline   Reply With Quote
Staro 23.09.2013., 14:21   #10
Ne kužim ovo. Ima nas ovdje nekoliko sa istom serijom kartica. gtx 660 non-ti i ti. Neki nemaju nikih problema, a neki imaju i dalje iste probleme.
Ja isto stavio i pičio Metro Last Light i nijednom mi se nije zdrkalo. OK, Metro LL mi izbaci uvijek na istom mjestu, ali to je zbog igre, ne zbog drivera. BF3, World in Conflict, Metro 2033 i Call of Pripyat rade najnormalnije bez ikakvih pizdarija.
Staro 23.09.2013., 14:42   #11
SetH
SetH's Avatar
Postovi: 3,324
bilo koji driveri NE rade na defaultnim postavkama dok na gpu/mem -15mhz rade normalno. A burn in na defaultu radi normalno kao i bilo koji "mark". Make sense none -.-
Zadnje izmijenjeno od: SetH. 23.09.2013. u 14:48.
Staro 23.09.2013., 15:44   #12
PointDexter
PointDexter's Avatar
Lokacija: Éire
Postovi: 1,810
Meni čude svi ti problemi sa driverima. I dok sam bio na ati-u (desktop i mobile) i sada na nvidia-i neznam ako su mi se ijednom srušili display driveri ili su radili neke velike probleme.
Jedini primjetan problem sam imao sa bc2 i jednom verzijom catalysta kada bio se pojavio microstuttering.
alien-smilies-0046.gif von smiliesuche.de
PointDexter je offline   Reply With Quote
Staro 23.09.2013., 17:49   #13
Autor PointDexter Pregled postova
Vjerojatno ima tu puno više faktora, da nisu samo driveri u pitanju.
Staro 18.10.2013., 15:28   #14
windfucker
Evo i meni problem sa "driver has stopped..." (crni ekran), 660Ti@SLI, w7x64.
Totalno random, nikada u igrama već uvijek u windowsima, nebitno jel se nešto otvara ili ne (rokne i u mirovanju).
I tako već neko vrijeme, dok igram nema problema pa me i ne pati toliko
Staro 18.10.2013., 16:44   #15
zhaccc
zhaccc's Avatar
Postovi: 120
Dakle standard, jos uvijek se ne micemo sa 314.22...
zhaccc je offline   Reply With Quote
Staro 18.10.2013., 17:54   #16
Goc 101
Goc 101's Avatar
Datum registracije: Aug 2011
Lokacija: Sesvete
Postovi: 129
Pogotovo ne mi sa 400/500 serijom. Ako na ovim novim i radi nama nece.
Goc 101 je offline   Reply With Quote
Staro 21.10.2013., 11:52   #17
Tvrdi
Sremium
Datum registracije: Oct 2013
Postovi: 2,854
Autor zhaccc Pregled postova
Ja sam baš na tim drajverima. I mislim da, pogotovo za kartice do 7xx modela i nema smisla stavljati novije jer sam u igrama koje igram dobio nešto bolje rezultate sa 314 u usporedbi sa zadnjim serijama.
