Staro 18.08.2013., 14:30   #1771
Dottore
Dottore's Avatar
Postovi: 7,644
Autor HumWeed Pregled postova
mmm neznam na sta mislis
velicina mu je 666 kb
a u task manageru nemogu rec jer sva 3 procesa su nazvani "iron.exe"
Zbilja? Ajde provjeri još jednom
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 18.08.2013., 15:41   #1772
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,136
posto nisi rekao sto tocno da provjerim ...
/snip/
Why would you invite a mushroom to a Christmas party? He's a fun guy to be with.
Why do mummies like Christmas so much? Because of all the wrapping.
Why does Santa have three gardens? So he can "ho ho ho".
Zadnje izmijenjeno od: HumWeed. 18.08.2013. u 16:01.
HumWeed je offline   Reply With Quote
Staro 18.08.2013., 15:48   #1773
Dottore
Dottore's Avatar
Postovi: 7,644
Rekao sam ti, gdje si instalirao Iron portable?? Na usb ili na C:\ disku? I tamo provjeri veličinu. Početak instalacije ima malen file a nakon surfanja skoči visoko.
Iskreno, malo pucaš visoko s Operom. Strpi se. Usput, isporobaj Operu portable.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 29.08.2013., 10:58   #1774
Dac
Dac's Avatar
Lokacija: Bjelovar
Postovi: 672
Malo sam tužan. Opera 12.16 mi se konstantno ruši na 2 potpuno različita računala (hardver, namjena, OS - sve različito), Opera 16 je i dalje siromašna i nikakva. Super radi, ali fali mi customizacija, da si stavim buttonse koje i gdje hoću, fale mi pravi bookmarksi sa lijeve strane kako sam navikao, fali mi toggle button u lijevom rubu da se isti pokažu i sakriju. Ekstenzija je tek toliko da nešto ima, zapravo sramotno nakon mogućnosti koje su bile prisutne zadnjih 10 godina.
Nema čak ni ctrl+enter da sam ispuni http... .com kad se upiše adresa!
Dac je online   Reply With Quote
Staro 29.08.2013., 14:19   #1775
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,136
revertaj se na 11.52 ili .64
te se neruse, imaju samo problem nekad kod gledanja YT videa
za to si mozes skinut neki drugi portabilni browser
Staro 04.09.2013., 12:58   #1776
win32
win32's Avatar
Datum registracije: Apr 2008
Postovi: 1,517
Ok, nakon dugo vremena sam opet pokusao prilagoditi se na Operu i ova Opera 16 me malo neugodno iznenadila pa trebam par savjeta.
Prvo, gdje se nalazi apperance postavka (ili kaoo se vec prije zvala) da slozim toolbarove?
Gdje je opcija da stavim bookmarkse odmah ispod address bara?
Gdje se nalazi opcija kojom bih stavio ikonu za home page i sve to razmjestio kako ja hocu?
Ove postavke koja ja sada vidim su uzasne i ne daju useru da nista sam poslozi.
Gledao sam i pod "about:flags", ali ni tu ne nalazim nista sta bi posluzilo.
Privremeno sam bookmarkse slozio s ekstenzijom Bookmarks Manager, ali to moze biti samo privremeno rijesenje jer sam time dobio samo to da sam prebacio bookmarkse iz Chrome-a u Operu.
Moze li se ovo sto sam naveo uopce slozit u novoj Operi ili kao i obicno ide dolje s mojeg OS-a (steta jer sam mislio napokon promjenit browser).
Po ovome sta vidim, Firefox kojega bas i ne obozavam je miljama ispred Opere, bar sto se tice samih postavki i podesavanje izgleda.
Trenutno mi je default browser Chrome i nakon toliko godina koristenja, rado bi presao na nesto drugo, ali ne ide mi se s konja na magarca, jer sta ce mi browser na kojemu ne mogu najobicnije bookmarkse poslozit kako hocu ili slozit bar njegov osnovni izgled (pozicija ikona, dodavanje novih ikona i sl.).
Vjerujem da se sve to da slozit i da cu dobiti odgovore na svoja pitanja, a jos cu malo prouciti i help, ali ako s nista ne moze slozit onda su ga gadno zeznili.
Pozitivna stvar je sto je nova Opera temeljena na Chromiumu i ekstenzija "Download Chrome Etension" spasava stvar s nekim ekstenzijama koje su mi jako korisne na Chrome-u.
Tek sam je sinoc instalirao pa moguce da je sve to moguce poslozit te zato i pitam ovdje ljude koji se malo duze druze s Operom, mogu li mi pomoci oko tih par kozmetickih zahvata da si olakasam samo koristenje browsera i da ga prilagodim svojim potrebama posto je ovo po defaultu za mene osobno poprilicno lose slozeno.
"In the beginning there was 0. And then there was 1. A mind-bending meditation on the transcendent power of digital computation."
Pošteni trgovac: 1, 2, 3, 4, 5...
win32 je offline   Reply With Quote
Staro 04.09.2013., 16:48   #1777
MiroGavran
Datum registracije: Feb 2011
Postovi: 190
možeš ostat na 12ici dok/ako i kako budu implementirali funkcije na "novu operu"
na 17ici već imaš par pomaka: http://my.opera.com/desktopteam/blog...stream-preview
ali dok se sve ne sredi kak spada ja ću biti na 12ici
MiroGavran je offline   Reply With Quote
Staro 04.09.2013., 17:05   #1778
Dottore
Dottore's Avatar
Postovi: 7,644
Autor MiroGavran Pregled postova
Što imaš od ekstenzije? Ja sam još na 12.10. i full stabilno.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 04.09.2013., 19:16   #1779
MiroGavran
Postovi: 190
Autor Dottore Pregled postova
instant dictionary, translator, x-notifier i disejblan extended tube
Staro 04.09.2013., 21:18   #1780
Dac
Dac's Avatar
Lokacija: Bjelovar
Postovi: 672
@win32 - za opcije moraš instalirati verziju 12.x jer je sve ovo novije za sada tek Chrome klon. Barem korisnik to tako vidi, neki su oduševljeni ali stari operaši su uglavnom zgroženi. Nadamo se napretku i vraćanju svih opcija u nove verzije ali treba strpljenja
Staro 04.09.2013., 21:24   #1781
win32
win32's Avatar
Postovi: 1,517
Autor Dac Pregled postova
Gle, ali da je bar Chrome klon s nekim funkcijama od Opere, ovako sada izgleda kao okrljusten Chrome koji nema cak ni bookmarks bar ni osnovne stvar koje ti trebaju za ugodan rad i surfanje.
Damn, a taman sam pomislio da ce biti bolje.
Svida mi se sto su npr. izbacili mail klijent, ali definitivno su trebali ostaviti bar neke opcije koje su imali, a ne ovo sada kada cak ni ikone ne mogu slozit kako hocu ni da ne mogu imati najobicniji bookmarks bar.
Malo cu za bookmarkse pronjuuskat po ekstenzijama od Chrome-a, mozda se nade nesto korisno.
Staro 04.09.2013., 23:02   #1782
MiroGavran
Postovi: 190
Autor win32 Pregled postova
fora je u tome da su izbacili browser tek toloko da ga ljudi "čim prije počnu koristiti"
brz je, ali siromašan tako da je stara opera i dalje u funkciji, barem su 12.16 izbacili
Staro 07.09.2013., 23:00   #1783
Lika091
Lika091's Avatar
Lokacija: Zagreb - Brinje
Postovi: 838
Zasto mi Opera ovako prikazuje Google i još neke stranice. Skroz ih suzi!
Staro 08.09.2013., 15:18   #1784
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,136
iskljuci "fit to width"
Staro 09.09.2013., 20:47   #1785
Lika091
Lika091's Avatar
Postovi: 838
to je to. hvala
Staro 23.10.2013., 23:23   #1786
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,136
nekuzim cemu postoji https://addons.opera.com/themes/‎
kad "najnovija stabilna" verzija (17) to uopce nepodrzava
Staro 23.10.2013., 23:29   #1787
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,853
Ja dobio 404.
A usput, ima još jako puno ljudi koji su na 12.x verziji ili ranijoj, kao ja, ali teme nikad nisam koristio.
Spoiler alert!
Staro 24.10.2013., 00:50   #1788
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,136
ma nest se zezno copy paste: https://addons.opera.com/en/themes/
ja koristim v11, ali me cisto jucer zanimalo koliko su u brzini i stabilnosti fixali od 15 do 17
//edit, vidim da se mora instaliranje tema ukljucit u "flags"
Zadnje izmijenjeno od: HumWeed. 25.10.2013. u 01:10. Razlog: x
Staro 02.11.2013., 11:16   #1789
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,550
Stavio v17. Stabilna je, brza, sve super, ali fale mi bookmarksi. Mislim, ko pametan izbaci bookmarks tab iz browsera? Pa neću ih imat sve na speed dialu
Staro 02.11.2013., 12:59   #1790
domis
Lokacija: Hrvatistan
Postovi: 4,164
još na 12.16, ne mičem se tak dugo dok ne izbace v50 koja bude možda približno dobra ko te starije verzije
jeba im i chrome i blink
Staro 02.11.2013., 14:18   #1791
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,136
ja sam probavao 18 dev, bio je brzi i stabilniji od 17
ali overall oba su spora do bola pri pokretanju
onda sam jednostavno skino Iron (opet), skino speed dial plugin
i sad mi ko opera :P s tim da je puno brzi
naravno to mi samo za stranice gdje v11.52 neradi
Staro 04.11.2013., 10:30   #1792
Mileni
Mileni's Avatar
Postovi: 1,554
Ja sam izbrisao Operu sa HDD-a. Nakon vise od 8 godina druzenja. Ne vidim smisla. Provjerit cu ih ponovno za 2-3 godine, no ne nadam se previse. Jednostavno su upropastili sve ono sto ih je krasilo i sto ih je isticalo naspram konkurencijom.
A verzija 12 je nazalost prespora + rusi se. A fixeve necemo dobiti. Nisam imao izbora vise, i nekako sumnjam da cu se ikad vise vratiti na Operu. Koji idiot je donio odluku da predju na blink ?
Staro 04.11.2013., 11:54   #1793
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,054
Presto engine i njegovo održavanje bilo je preveliki zalogaj i vremenski/financijski si nisu to mogli priuštiti.
Blink je jako dobar engine i omogućuje developerima više vremena za koncentraciju na fičre.
Taj "idiot" je možda na dugoročne staze spasio Operu.
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Mario92 je online   Reply With Quote
Staro 04.11.2013., 12:12   #1794
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 5,796
Samo nek oni vrate dragonfly i ostale fancy sheme iz Opere, blink je vrhunski backend, em je brz em je stabilan, ali mi fale neke mogucnosti iz opere 12, napisa sam vec prije koje, ako to vrate ja prezadovoljan
Staro 04.11.2013., 13:47   #1795
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,136
webkit/blink nije vrhunski ali je nazalost najzastupljeniji (safari, gchrome i sad opera)
u biti im i je lakse sad kad su "udruzene snage" drugih da se usavrsava engine
da mnoge stranice namirno nisu sabotirale operu sa Presto, onda bi se vidjelo da Presto nije
uopce bio los, dapace meni opera 11 puno brze radi na nekim sajtovima nego ovi "moderni" chrome/iron/opera 15+
a to ukljucuje i JS engine
tako da bar po meni odluka nije pala zbog kompliciranosti (to je PR sranje za javnost)
nego su se htjeli rjesit tereta developa i pojacat publiku webkitom
al eto sjebali se...
Staro 04.11.2013., 20:22   #1796
Mileni
Mileni's Avatar
Postovi: 1,554
Autor Mario92 Pregled postova
Taj po tebi "idiot" je idiot. Ne radi rjesavanja Presto enginea koji je sve samo ne dobar. Vec sto je to napravio na nacin na koji je napravio. Ovako su izgubili dobar dio svojih poklonika, dosta njih vjerojatno bespovratno.
A dobili smo samo jos jedan chrome browser. Malo ljepsi od chromea istina, no nista vise ni bolje od istoga, dapace, trenutacno je i losiji od chromea.
Problem je sto su to trebali napraviti tek kad vecinu korisnih funkcija prebace na blink engine. No nisu. Prvo su odbacili bookmarkse (heej ?!), rekli da ih vise nece drzati nikako, pa onda najavili da ih vracaju... Ukrakto, nemaju pojma gdje idu. Obecali su i tabstacking do 18 verzije, no naravno da nema jos ni govora o istome.
No sve to cak i nije najveci problem. Najveci problem je masovni otkazi koje su developeri u Operi dali unazad godinu dana. Po netu se moze naci da je otislo dosta developera koji su od Opere napravili ono sto je istu cinilo tako dobrom, koji su na Opera browseru radili od samih pocetaka, itd.
Tako da oprosti na mom izrazavanju sa rijeci 'idiot', no ja jednostavno ne znam kako drugacije nazvati tu osobu? Meni je idiot, tebi nije. Samo ce vrijeme pokazati tko je bio u pravu. Radi same Opere volio bih da si ti u pravu, no na zalost nekako sumnjam u to.
Staro 10.11.2013., 22:49   #1797
rodriguez
rodriguez's Avatar
Postovi: 2,058
Jel misle u novoj Operi ubacit bookmarkse?
Thinkpad T430 running
Staro 10.11.2013., 23:47   #1798
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,054
Navodno u Operi 18 budu stigli bookmarski.
Ali, tako su najavili i za 17 pa pogledaj kak delaju
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 10.11.2013., 23:48   #1799
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,550
U Next(v18) verziji ih nema još.
Staro 11.11.2013., 00:02   #1800
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,054
Autor Juice Pregled postova
Sad baš prčkam i upalim Quick Access Bar u about://flags.
Rezultat:
Može se dodati i folder desnim klikom na prazni dio.
Opera 17
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
