Staro 31.08.2013., 20:50   #1621
Pc User 0
Datum registracije: Aug 2013
Postovi: 9
Ima tko možda kakva iskustva ili ikakva saznanja o AMD FX-Series X4 4350 ili AMD FX-Series X6 6350 procesorima ? Koja je vaša preporuka za kupovanje između ta dva, naravno jasno mi je da je jedan četvero jezgreni a drugi šest jezgreni procesor pitam čisto iz uloženog dobivenog. Dosta sam često čuo da je ponekad četverojezgreni procesor "bolji" tj iskoristiviji od šest jezgrenog.....
Pc User 0 je offline   Reply With Quote
Staro 02.09.2013., 02:58   #1622
DiRT
► Play ▌▌ Pause ■ Stop
DiRT's Avatar
Datum registracije: Jan 2010
Postovi: 1,179
Pa onako, X6 je bolji u nekim stvarima, evo link. Bit ćeš dulje vrijeme mirniji jer imaš 2 jezgre više, no kod tih proceva i nema neke pretjerane razlike.
PC:
CPU:
Intel Core i7-7700
COOLER:
SCYTHE Mugen 3 rev. B
MBO:
MSI B250 GAMING M3
GPU:
ASUS Dual Radeon RX 6650 XT OC Edition 8GB GDDR6
RAM:
Kingston HyperX Fury (2x8GB) 2133MHz@2400MHz CL16 DDR4
SSD:
Samsung 870 EVO (500GB)
Samsung 970 EVO Plus (2TB)
HDD:
WD1003FZEX (1TB)
WD20EZRZ (2TB)
EXTERNI HDD/SSD:
Seagate Basic Portable Drive (1TB)
WD My Passport (1TB)
WD My Passport (2TB)
WD Elements (2TB)
Verbatim Vx500 (240GB)
Silicon Power PC60 (240GB)
Kingston XS1000 (1TB)
PSU:
Corsair 650W RM650, 2019, 80 PLUS Gold
MONITOR (TV):
Dell G2724D + Dell U2414H
Samsung UE55NU8002TXXH
Samsung QE43Q60AAUXXH
Philips 43PUS8506/12
KUĆIŠTE:
Antec 300, 2xSCYTHE Slip Stream 120mm (500rpm, 7.5 dB)
OS:
Windows 10 Pro 64-bit
TIPKOVNICA:
Logitech K800 Illuminated
MIŠ:
Logitech G502 Proteus Spectrum RGB + SteelSeries QcK Edge - Medium
Logitech MX Master 3 Black
Logitech MX Master 2S Bluetooth Edition Graphite
Logitech M590 Silent
ZVUČNICI:
Logitech Z-5500 (S/PDIF) + Logitech Bluetooth Audio Receiver
MAGNAT Monitor Supreme 202 Black 2-way bass reflex bookshelf speakers
MAGNAT Monitor Supreme Center 252 Mocca
SLUŠALICE:
Logitech Zone Vibe 100
Samsung Galaxy Buds3 Pro
Xiaomi Redmi Buds 5 Pro
Xiaomi Buds 3 Star Wars Edition
Mi True Wireless Earbuds Basic 2
Sennheiser CX 3.00
AKG Samsung Galaxy Earbuds
AKG Y500 Wireless
MOB:
Samsung Galaxy S7 Black, 4/32GB +
Samsung microSDXC 64GB EVO+
Samsung Galaxy S10e Black, 6/128GB +
Samsung microSDXC 256GB EVO+
Huawei P50 Pro Golden Black, 8/256GB
Samsung Galaxy A55 5G Awesome Navy, 8/256GB
Samsung Galaxy S24+ Onyx Black, 12/256GB
Samsung Galaxy S25+ Blue Black, 12/256GB
LAPTOP:
(Lenovo ThinkPad E560)
CPU: Intel Core i3-6100U
MBO: -
GPU: Intel HD Graphics 520
RAM: 2x4GB DDR3L 1600MHz
SSD: Kingston A400 480GB
OSTALO: 15.6-inch HD TN
OS: Windows 11 Pro 64-bit
PC POSAO:
(HP Z2 Tower G9 Workstation)
CPU: Intel Core i7-14700K
MBO: HP 895C
GPU: Nvidia RTX A2000 12GB
RAM: 1x16GB DDR5
SSD: Samsung 512GB
HDD: WD 2TB
MONITORI: 2 komada HP Z27 27-inch 4K UHD
PERIFERIJA: Logitech K750 Solar, Logitech MX Master 3 Graphite + Logitech MX Master 2S Bluetooth Edition Graphite
LAPTOP POSAO:
(Apple MacBook Air 13.6-inch M2 8/256GB MLXY3CR/A Silver)
(HP EliteBook x360 1040 G11 2-in-1, 14-inch WUXGA Touchscreen, Intel Core Ultra 7 155H, 16GB LPDDR5x, Samsung 1TB PCIe Gen4 NVMe TLC M.2 SSD, Backlit Keyboard, Windows 11 Pro 64-bit)
(HP ProBook 450 G7, 15.6-inch FHD, Intel Core i5-10210U, 8GB DDR4, Samsung 512GB NVMe M.2 SSD, MX250 Graphics, Backlit Keyboard, Windows 11 Pro 64-bit)
DiRT je online   Reply With Quote
Staro 02.09.2013., 03:02   #1623
Pc User 0
Postovi: 9
Hvala na savijetu.
Staro 02.09.2013., 09:07   #1624
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Autor Pc User 0 Pregled postova
niti jedan...
radje 6300 - 8320
jer ovi nikako nisu isplativi
Staro 04.09.2013., 14:09   #1625
vava
vava's Avatar
Datum registracije: Mar 2009
Lokacija: Dubrava kod Vrbovca
Postovi: 270
Razmisljam o kupnji amd procesora,ali jos se nisam odlucio za koji.
Imam dva kandidata 5800k ili fx8320
S time da ce ici vjerojato gore ici 7970 grafa.
Jedna ploca je sigurna GIGABYTE GA-F2A85X-UP4,a za am3 jos nisam odlucio koju.
Hoce li 5800k zadovoljit 7970 u igrama?
Neki limit za mbo i cpu bi bio 2000-2200kn
vava je offline   Reply With Quote
Staro 04.09.2013., 14:30   #1626
hedgehog
hedgehog's Avatar
Datum registracije: Apr 2013
Postovi: 1,336
FX8320..APU ima smisla za budget gaming i slično, ali ako dodaješ kasnije 7970 svakako 8320, a i 5800k ne bi mogao izgurat 7970
hedgehog je offline   Reply With Quote
Staro 04.09.2013., 14:59   #1627
lolofuxy
lolofuxy's Avatar
Datum registracije: Jun 2010
Postovi: 3,319
FX 8320 + GIGABYTE 970A UD3 + CM 212+ EVO ili ZALMAN CNPS10X OPTIMA ti je minimum od Amd-a ako zelis kak spada nahraniti HD 7970.
Apu nemas kaj gledat u kombinaciji s HD 7970 jer je preslab za nju,a i ako gledas FM2 i zasebnu graficku onda se gledaju defektni Apu-u tzv. Athloni X4 740, X4 750K, X4 760K za koji su maksimum GTX 650 Ti BOOST/HD 7850.
lolofuxy je offline   Reply With Quote
Staro 04.09.2013., 20:12   #1628
Billy007
Postovi: 95
APU se ne isplati ako ćeš korisiti drugu grafičku.
Imaš na FM2 socketu Athlona bez grafike.
PROCESOR AMD ATHLON II X4 760K, BLACK EDITION
Otključan je i možeš ga sigurno držat preko 4 Ghz.
Hladnjak je COOLER SCYTHE ASHURA SCASR-1000, S.
A ploča MATIČNA PLOČA ECS A85F2-A GOLDEN BLACK SERIES, AMD A85X, DDR3, ZVUK, S-ATA, RAID, G-LAN, PCI-E, VGA, DVI, HDMI, ESATA, USB 3.0, ATX, S. FM2
Sve skupa oko 1700 - 1800 kn.
Za razliku u cijeni uzmeš bržu memoriju.
I ove gore kombinacije nisu loše sa 8230.
Billy007 je offline   Reply With Quote
Staro 05.09.2013., 00:04   #1629
hedgehog
hedgehog's Avatar
Postovi: 1,336
samo što je 760K isti procesor ko i 5800K i ne bi mogao izgurat 7970...
Staro 05.09.2013., 08:32   #1630
vava
vava's Avatar
Postovi: 270
FX 8320 uzimam
Memoriju imam tridente na 2400mhz
Za hladnjak se brine voda.
Staro 05.09.2013., 08:38   #1631
Billy007
Postovi: 95
A10-5800 je Trinity (October 2, 2012) a 760k Je Richland (June 30, 2013). Sigurno je da su kod Richlanda ispravili neke male sitnice u proizvodnom procesu. U načelu jesu isti, čak kod 760k turbo je na 4.1Ghz a ne na 4.2 kao kod 5800.
Kako je to otključan proc i jednostavan za klokat sa malo dignutim taktom i ne bi bio usko grlo jednoj 7970 kartici.
U načelu on kupuje gamersku mašinu i pitanje je koliko bude iskoristio svih 8 jezgri po pitanju igara.
Staro 05.09.2013., 10:19   #1632
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
nemreju ti procesori gurati takvu grafičku...pa to je slabije od i3 IB
ni fx 6300 nemre gurati takvu grafu...vec samo neki i5 ili 8320
Staro 05.09.2013., 10:47   #1633
Billy007
Postovi: 95
Čovjek je kupio. Nema smisla raspravljat.
760k je slabiji ali ne toliko.
http://www.tomshardware.com/reviews/...ck,3106-5.html
Jasno se vidi da je desno u drugom redu 8320, a red ispod slijede 4170 i 5800.
Nisu tu razlike tako velike u igrama.
Naravno i TDP je manji za 25W.
i3 IB su cijenom preko 900kn dok ovaj 760k je ispod 600kn.
Staro 05.09.2013., 11:19   #1634
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
ja ti kazem jedno, jer znam iz prve ruke... 750k sa 7970 nema koristi i isto radi kao neka 7850 2gb...te jednostavno čemu imati takvu grafičku gore ako ju ne mozes iskoristiti kako treba?
Staro 05.09.2013., 11:59   #1635
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
Autor FRipper Pregled postova
Ja kažem iz prve ruke da je i nekakav stari Phenom dovoljan, a i ekipa iz
guru3d me podržava:
http://www.guru3d.com/articles_pages..._review,6.html
Staro 05.09.2013., 15:59   #1636
Penryn
Penryn's Avatar
Lokacija: Silicon Valley
Postovi: 109
Dovoljan za što? Ajde kad znaš iz prve ruke pokaži nam kako je to Phenom dovoljan da izvuče 100% iz HD7970 u Crysisu 3, BF3 MP, Hitman Absolution, Company of Heroesu 2, Far Cry 3 itd.?
Našao si pravi primjer, AvP, kojem je dovoljan Celeron 420 da izgura HD7970.
Najjači su mi ovakvi koji pričaju o nečem šta ne znaju, i to još iz prve ruke.
Penryn je offline   Reply With Quote
Staro 05.09.2013., 19:20   #1637
Zvonimir_s
Zvonimir_s's Avatar
Postovi: 406
Kako za koju igru...
Osjetio sam znacajan boost kad sam zamjenio 4890 s 7950....no ArmA 3 jos nije mogla raditi glatko na visokoj rezoluciji..
Kad sam stavio 8320 umjesto OC-nog Q6600..igra radi glatko na ultra postavkama..
Zanimljivo je to da je q6600 uspjevao drzati graf na 100%...sto bi pretpostavili da CPU nije "usko grlo "
Zvonimir_s je offline   Reply With Quote
Staro 05.09.2013., 19:37   #1638
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
guru3d me podržava:
neki dan sam gtx 760 testirao na ocanom phenomu 965, 4,2GHZ i nemre maleni to gurati kamo li 7970 koja je jača...
zato pusti priče i pisanje ako nisi sam testirao...
al dosta of topic
Staro 05.09.2013., 22:52   #1639
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
al dosta of topic
Na 800x600? Ili u nekom sintetičkom benchu koji uzima u obzir i snagu proca, bez obzira što se to u igrama ne vidi?
Autor Penryn Pregled postova
http://uk.hardware.info/reviews/3714...-battlefield-3
Nisam našao skaliranje CPU-a na 7970 u Crysis 3, ali na gtx680 Phenom se sasvim dobro drži:
naravno ne tvrdim da sa jačim procesorom neće bolje raditi, ali nije baš ni da su stari procesori za smeće
Zadnje izmijenjeno od: segregator. 05.09.2013. u 23:16.
Staro 05.09.2013., 23:27   #1640
Penryn
Penryn's Avatar
Postovi: 109
Nemoj mi nisam našao ovo ono, nego svoje testove, iz prve ruke, kako si i rekao.
Mogu i ja dati bezbroj linkova sa neta gdje Phenom X4 ne može ni blizu izvući 100% iz HD7970 ili GTX680.
link1, link2, link3, link4, link5, link6, link7 itd itd.
Tako da, dok ne odvrtiš sve to sam i dokažeš suprotno, molim te nemoj širiti ovakve dezinformacije okolo. Meni bi bilo drago da to dokažeš, jer onda nitko ne bi trebao kupovat nekakve i5 i FX-ove već bi i stari Phenom X4 od 500kn bio dovoljan.
Zadnje izmijenjeno od: Penryn. 05.09.2013. u 23:36.
Staro 05.09.2013., 23:53   #1641
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
@segregator
ti prvo moraš naučiti što je bottleneck pa onda meni doći sa nekim pametnim riječima da se uopče možemo raspravljati oko nečega....
ovo nema smisla...
Staro 06.09.2013., 00:26   #1642
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
Prva dva linka samo potvrđuju ovo što sam rekao, tako da mi se nije dalo gledati ostale, a benchanjem se ne bavim jedno 10 godina...puno je zanimljivije igranje (na procu od 500kn)
Staro 06.09.2013., 12:20   #1643
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
Polakše sa "glup si" i sličnim izljevima, može se tipkati i bez toga.
Staro 06.09.2013., 12:29   #1644
Penryn
Penryn's Avatar
Postovi: 109
Dam ti dokaze a ti 'neda mi se gledati'.. ako ćeš tako onda je daljnja rasprava nepotrebna.
Inače moje isprike moderatoru za 'glup si' izljeve. Ja ozbiljno raspravljam a segregator u nedostatku kvalitetnih argumenata se ide praviti glup, pa se nisam mogao suzdržat.
Staro 06.09.2013., 13:45   #1645
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
"Dokaze" u obliku linkova na testove dvaput jače i skuplje Titan kartice...nije li to ipak pokazatelj neobjektivnosti i tjeranja vode na svoj mlin?
Ja sam se bar potrudio i našao test GTX680 koja je puno bliža Radeonu po performansama
Staro 06.09.2013., 14:43   #1646
Penryn
Penryn's Avatar
Postovi: 109
Dobro eto izvlači se sad da sam stavio prejaku karticu. Iako je korištena u samo 3 testa, to poništava sve moje tvrdnje i linkove.
Ne trebam više ništa govorit, eto segregator garantira da je procesor od 500kn star skoro 5 godina(konkretno: Phenom X4 955BE) dovoljan da izvuče preko 90% iz HD7970/GTX680. Pa ako tko slučajno upari to dvoje i ne ispadne tako, slobodno se obratite odgovornom da vas demantira iz prve ruke.
Staro 06.09.2013., 16:06   #1647
suedamA obmaR
Game, PC ,motobikes, bike
suedamA obmaR's Avatar
Lokacija: Sibenik
Postovi: 779
Meni phenom x4 ne moze pogurati 7850 do kraja u Bf 3 i slicnim igrama, a kamo li neku jacu grafu, ali ipak dosta igara radi perfektno s ovom kombinacijom.
suedamA obmaR je offline   Reply With Quote
Staro 06.09.2013., 16:09   #1648
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,191
Meni je isto pretjerana ta fama oko CPU bottleneck-a, kao da neki CPU lobij to tjera da svi prelaze na i7-3960X. I nije baš neka usporedba, TITAN je čudo od kartice i ima jako, slikovito rečeno, široku bocu, tako da i vrh cpu ponude može biti usko grlo u određenim situacijama.
Ljudi su dosta nerealni i subjektivni oko svega toga i oslanjaju se na neki svoj "feeling za osjećaj" što će biti usko grlo ili ne.
Vidio sam svašta, čovjeka koji na renomiranom stranom forumu, tvrdi da će i5-4570 biti bottleneck HD7950, a ustolom, meni je jedan član na ovom forumu pisao da mi se ne isplati staviti ništa drugo osim HD7850. A moj stari X6 phenom na 4,1ghz je maltene uz bok FX-8320 u dosta testova, a još mu i bolje idu single thread operacije koje su u krajnjoj liniji najbitnije za igre.
Tako da, kolega seregator, sve to uzmeš sa zrnom soli, ako tebi dobro rade igre i zadovoljan si, kog boli ona stvar.
I ustalom da li se isplati mijenjati Cpu/matičnu/platformu zbog 5-10% Fps-a u igrama, to čovjek zaključuje sam.
Staro 06.09.2013., 16:19   #1649
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
Autor suedamA obmaR Pregled postova
580-tka bi mislim trebala biti i malo jača od 7850, a izgleda da na njoj BF3 vrte OK čak i daleko slabiji procesori od mog i tvog
Ja osobno sam isto malo nervozan jer ovaj procesor koji imam je u računalu preko 4 godine i htio bi uzeti nešto novo,
ali jednostavno ne vidim ništa s čim bi ga zamijenio, a da nemam osjećaj da sam bacio novce (samo za usporedbu, između
1995-te i 2005-te mislim da mi se nijedan proc nije zadržao u računalu dulje od pola godine)
Staro 06.09.2013., 18:02   #1650
suedamA obmaR
Lokacija: Sibenik
Postovi: 779
Sergator, to su rezultati iz single playera, multyplayer je totalno druga prica po zahtjevu procesorske snage.
