Datum registracije: Nov 2002
Postovi: 10
Kako odrediti cach pod winXP
Aba |
matroxfanatic
Lokacija: Zagreb, na zapadu
Postovi: 2,444
Cash sto? Swap file? Internet cash files? Preciznije malo ![]()
Holly: "Appreciate what vou've got, because basically, I'm fantastic!"
Postovi: 10
cache memorija
cache memoriju u odnosu na radnu računala.(vcache) Minimalna i maximalna?!
Aba |
#5 | |
Datum registracije: May 2002
Postovi: 75
Re: cache memorija
to radis u WINME i ranijim verzijama u virtual memory settings by right clicking on 'my computer', selecting the performance tab, click 'virtual memory'. is it set for windows to manage it, or is windows running on a set ammount of virtual memory? eto tako si namjesti koliko zelis virtualne memorije... ![]()
Take the path that is your own...INDIVIDUALITY. |
Postovi: 75
A ako te zanima kako i sta to radi odi na http://www.howstuffworks.com/question684.htm mozda ti pomogne ... A ako ti treba za XP probaj... Go to control panel,system,advanced,setting(performance),advanced,change(virtual),set ili What are your virtual memory settings? To find them, go to Start > Settings > Control Panel > System > Advanced > Performance > Settings > Advanced > Change. There are at least a couple of possibilities: (a) If the setting is "No paging file", you can change this to either "System managed size" or "Custom size". Most people on the various fora suggest changing to Custom and specifying a fixed amount (both maximum and minimum the same value) of 1.5 times amount of ram. I don't believe that XP is as bad about eating your system alive by constantly changing the sizes as earlier windows systems, so changing to System managed might not be all that bad. (b) If the setting is already for System managed virtual memory, you may need to defragment your HDD or put your virtual memory on a larger disk. (c) If the display shows that the specified maximum is in use, increase the maximum.
Postovi: 10
Ljudi šta to nikada niste radili na Wim 98 recimo Start ,run ,sysedit, i u sistem.ini fajlu pod vcache upisati min VIRTUALNOG cacha i max. Samo je pod XP malo drugačije pa pitam ,a ako niste to ni prije radili onda ništa , u svakom slučaju hvala na trudu
Aba |
matroxfanatic
Postovi: 2,444
Ah, dobra stara vremena Windowsa NT 4.0... Evo, bas sam jucer detaljno provijerio Antivirus server u firmi: Win 4.0 Server, 64MB, radi neprestano vec 4 mjeseca (tada su bili radovi u server sali), ima 300+700MB swap fajla, a on je od tada maksimalono u jednom trenutku koristio cak 25MB. Di ces bolje. ![]()
#10 | |
Night shift
Datum registracije: Jul 2002
Postovi: 884
"NOBODY expects the Spanish Inquisition! Our chief weapon is surprise...surprise and fear...fear and surprise.... Our two weapons are fear and surprise...and ruthless efficiency.... Our *three* weapons are fear, surprise, and ruthless efficiency...and an almost fanatical devotion to the Pope.... Our *four*...no... *Amongst* our weapons.... Amongst our weaponry...are such elements as fear, surprise.... I'll come in again." --uoɥʇʎd ʎʇuoɯ-- |
#11 | |
matroxfanatic
Postovi: 2,444
#12 | |
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
Re: sysedit
#13 | |
matroxfanatic
Postovi: 2,444
Re: Re: sysedit
#14 | |
Lokacija: Vinkovci
Postovi: 5,231
Re: Re: Re: sysedit
