#1741 |
Postovi: 31
Hvala , ali tu se mora ugurati komplet tj. monitor do 22" i ostala periferija ?
Intel i7-875K / Gigabyte P55 UD3 /NVIDIA GeForce GTX 770 /720W HIPER POWER /OCZ SSD 128Gb/ 8Gb DDR3 1600MHz ; HP EliteBook 8770w Zadnje izmijenjeno od: Futro. 06.04.2013. u 15:12. Razlog: dodana veličina monirora |
#1742 |
MiningMod
Postovi: 8,715
AMD FX-Series X8 8320 AM3 Box Hladnjak za procesor Thermaltake Contac 21 Matična ploča Asus M5A97 R2.0 Memorija PC-12800, 8 GB, MUSHKIN Essentials, 997030, DDR3 1600MHz, kit 2x4GB HDD TOSHIBA DT01ACA100 (3.5", 1TB, 32MB, SATA III-600) MSI Video Card Radeon HD 7870 GDDR5 2GB/256bit DVD RW -RW RAM LG DualLay SATA Zalman 500W GS Series Retail Linkworld Gaming ATX Case AOC LED 21.5" E2250SWDNK, 5ms, VGA, DVI Chicony USB Multimedia Tipkovica Logitech Gaming Mouse G400 Futura-It.hr 6,998.44Kn Besplatno sastavljan je i dostava *Ukoliko ti trebaju i zvucnici Izbaci G400, metni Genius Maurus + 2.0 Logitech Z130 = 7,017.08 |
#1744 |
Datum registracije: Jun 2010
Postovi: 3,319
@Futro Ukoliko konfiguracija može biti od Intela razmotri si i ovu opciju: i5 3350P MSI B75 P45 MUSHKIN 2X4 GB 1600 MHZ (8GB) TOSHIBA 3,5 1TB MSI HD 7870 2GB OC LG DVD-RW SATA CORSAIR CX 430W SILVERSTONE PRECISION PS08 AOC I2367FH AH IPS WIRELESS SET 100 TIP+MIŠ GENIUS 2.0 SP-HF 360A Ukupno: 6994 kn besplatno slaganje i dostava - Futura it |
#1745 |
Datum registracije: Apr 2011
Postovi: 3,784
@Futro Ploča: ASUS M5A97 R2.0 Procesor: FX-8320 Hladnjak: Thermaltake Contac 21 Memorija: DDR3 8GB (1x8GB) Kingston, Value, 1600MHz, CL11, KVR16N11/8 Grafička: MSI HD 7870 2GB GDDR5 256bit, R7870-2GD5T/OC, 28nm,dual fan Kućište: Zalman Z5 Plus mid tower case (USB 3.0) Napajanje: XFX 550 Disk: Hitachi 1TB, Desktop Deskstar 7K1000.D, 32MB,SATA III-600 DVD: LG GH24NS Monitor: AOC E2250SWDNK Tipkovnica + miš: Logitech Desktop MK120, Tipkovnica + Miš, USB Zvučnici: Genius SP-HF500A, 14W RMS, wood =6987,97 kn, sastavljanje i dostava u cijeni, dućan www.adm.hr Ploča: MSI B75MA-E33 Procesor: i5-3350P Memorija: DDR3 8GB (1x8GB) Kingston, Value, 1600MHz, CL11, KVR16N11/8 Grafička: MSI GTX660 Ti OC 2048MB GDDR5 , N660Ti-2GD5/OC, 941MHz Core Kućište: Zalman Z5 Plus mid tower case (USB 3.0) Napajanje: Zalman 500-GS PSU, 500W Disk: Hitachi 1TB, Desktop Deskstar 7K1000.D, 32MB,SATA III-600 DVD: LG GH24NS Monitor: AOC E2250SWDNK Tipkovnica + miš: Logitech Desktop MK120, Tipkovnica + Miš, USB Zvučnici: Genius SP-HF500A, 14W RMS, wood =6990,96 kn, sastavljanje i dostava u cijeni, dućan www.adm.hr Zadnje izmijenjeno od: ShanTech. 09.05.2013. u 14:37. |
#1747 |
MiningMod
Postovi: 8,715
Monitor 23'' LED PHILIPS 236V4LAB, 5ms, 250 cd/m2, 10.000.000:1, D-SUB, DVI, crni Cooler ARCTIC COOLING Freezer 13, s. 775/1155/1156/1366/754/939/AM2/AM3 Matična ploča GIGABYTE GA-970A-UD3, AMD 970/SB950, DDR3, USB 3.0, FW, ATX, s. AM3 / AM3+ Memorija PC-12800, 8 GB, CORSAIR CMX8GX3M2A1600C9, DDR3 1600 MHz, KIT 2x4GB Tvrdi disk 500.0 GB TOSHIBA TSH-DT01ACA050, SATA3, 32MB cache, 7200 okr/min, za desktop Grafička kartica PCI-E XFX AMD RADEON HD 7950 DD, 3GB DDR5, HDMI, DVI, 2xDP, HDTV DVD±RW LG GH24NS95, 24x, SATA, Dual layer, crna, bulk Napajanje 560W, LC POWER Silent Giant GREEN POWER LC6560GP3 V2.3, 140mm vent. Kućište LC POWER Pro-917B Titus X, MIDI, crno, bez PS ukupno: 7.041,00 KN -ovo sto je na akciji |
#1749 |
Datum registracije: May 2012
Postovi: 4
molim Vas za konfiguraciju.
Molim poštovane članove ovog foruma da mi pomognu oko sastavljana PC KONF. Budžet - 6500 - 6800 kn. Bez periferije ali molim Vas preporuke za "24" Led monitor. Služi za web diz. i grafički diz. tipa Adobe paleta programa.... i neke free alternative istoga..... ++++ ponekad neka igra čisto radi gušta... U obzir dolaze AMD i Intel ponude... Kupujem sve za keš ( ok bi bio popust na keš ).... igraju mi trgovine u ZG. Koliko sam čuo za ozbiljan rad dizajnera ide samo nvidia pa eto uzmite to u obzir.... Unarpijed zahvaljuem svima ..... ![]() |
#1750 |
MiningMod
Postovi: 8,715
Procesor Intel Core i5 3350P MSI H77MA-G43 Patriot Viper3,1600Mhz, 16GB (2x8GB) PoV GTX660Ti 2GB 2 fan Kingston SSD V300, R450/W450,120GB,7mm HDD Desktop TOSHIBA DT01ACA100 (3.5", 1TB, 32MB, SATA III-600) DVD RW -RW RAM LG DualLay SATA Zalman micro tower case black Zalman 500W GS Series Retail Futura-It.hr 6,874.82Kn Besplatno sastavljanje i dostava Monitor LCD DELL UltraSharp U2412M (24", 1920x1200, IPS) 2147Kn Ako ti je puno za monitor toliko dati, radje smanji onda nesto na kompu, npr ubaci gtx 660 grafu i samo 8gb rama... |
#1751 |
Postovi: 3,784
@shark21 Ploča: MSI H77MA-G43, Socket : 1155,CPU : Sandy Bridge, Intel® H77 Procesor: Intel Core i5-3470 3.2GHz (Max Turbo FQ 3.6 GHz) ,6MB Memorija: DDR3 8GB (1x8GB) Kingston, Value, 1600MHz, CL11, KVR16N11/8 *2 komada Grafička: MSI GTX660 OC 2048MB GDDR5 , N660-2GD5/OC, 1006MHz Core Kućište: Zalman Z12 mid tower case. 215(W) x 470(H) x 480(D)mm Napajanje: Zalman 500-GS PSU, 500W, ATX12V V2.3, dual rail +12V SSD: OCZ SSD Vertex 4 128GB, Indilinx Everest 2, 2.5" SATA III, 5 god Disk: HDD WD 1TB, Caviar Blue 10EZEX, 1000 GB, SATA3,64 MB, 3,5", 24mj DVD: DVD upisivač LG GH24NS, DVD±RW, 24x DVD±R ,8x DL , 40x CD-R =6.949,95 kn, sastavljanje i dostava u cijeni, dućan www.adm.hr + Monitor: Dell U2412M - 2085 kn, isti dućan, dostava u cijeni |
#1752 |
Postovi: 3,319
@shark21 Evo ti i Amd verzije s nešto jačim procesorom: FX 8320 TT CONTAC 30 AS ROCK 970 EXTREME3 2X MUSHKIN 8GB SILVER LINE (16 GB) SAMSUNG 840 120 GB SSD WD BLUE 1TB POV GTX 660 2GB LG DVD-RW SATA CORSAIR CX 500W LW GAMING ATX Ukupno: 6845 kn besplatno slaganje i dostava - Futura it Ak nemaš za Dell-a pogledaj si ovaj LG. |
#1753 |
Lokacija: ask?
Postovi: 243
Evo da vam javim da mi je stigla konfa,ali bez graficke posto je nije bilo. A i prirasla mi je srcu pa cu pricekat nju dok ne bude dostupna,pa cu je narucit. Za zamjenu je privremeno tu 9500gt. Imam jedno pitanje. Kad ubacim hard disk s vanjske strane u onaj utor. Ne ucita mi ga odma nego tek kad restartiram komp? Da li se to moze kako sredit da ucita hdd cim ga ubacim? |
#1755 |
MiningMod
Postovi: 8,715
pa ne mozes to ukljuciti koliko ja znam, to je hot swap, hdd se metne kada je komp ugasen i kada upalis on ga očita u biosu i tako prikaze u windowsima stavljati i skidati dok komp radi se ne smije |
#1756 |
Postovi: 34,094
Otkud ti to? Imam na kućištu SATA dock i hot swap fercera bez problema. Na XP-u sam morao isključiti komp, staviti hard u dock i onda opet uključiti.
#1757 |
Datum registracije: Mar 2009
Postovi: 41
pozdrav, molim ako se netkom da složiti konfu do max 7k kn, ali ako može jeftinije onda super. Prioritet je apsolutno tih rad, zatim SSD + HD, možda rađe AMD FX8xxx, bez monitora i periferije. Ne igram se puno, tako da netreba 7950 unutra. Hvala unaprijed. |
#1758 |
Postovi: 3,784
Na kojem monitoru se igraš (rezolucija)? Koja je primarna namjena računala, te koji je način plaćanja? Zadnje izmijenjeno od: ShanTech. 23.04.2013. u 22:55. |
#1759 |
MiningMod
Postovi: 8,715
Procesor AMD X8 FX-8320 COOLERMASTER Hyper 212 EVO CPU Cooler GA-970A-UD3,AM3,A970,D3,S3,U3,FW,A 8GB (2x4) 1600MHz DDR3 CL9 DIMM HyperX black Series Giga GF GTX650 Ti Boost OC,2GB GDDR5,DVI KINGSTON HyperX 3K Solid State Drive 2.5" SATA III-600 120 GB MLC, Retail HDD Desktop TOSHIBA DT01ACA100 (3.5", 1TB, 32MB, SATA III-600) DVD RW -RW RAM LG DualLay SATA Zalman Z9+ mid tower case black XFX CoreEdition 80 550W Futura-It.hr 6,917.75Kn Besplatno sastavljanje i dostava ili ovako: Intel Core i7-3770 Soc 1155 MSI B75MA-P45 Memorija Kingston DDR3 8GB (2x4) 1333MHz Giga GF GTX650 Ti Boost OC,2GB GDDR5,DVI KINGSTON HyperX 3K Solid State Drive 2.5" SATA III-600 120 GB MLC, Retail HDD Desktop TOSHIBA DT01ACA100 (3.5", 1TB, 32MB, SATA III-600) DVD RW -RW RAM LG DualLay SATA Zalman 500W GS Series Retail Zalman T1/T2 micro tower case black Futura-It.hr 6,807.75Kn Besplatno sastavljanje i dostava |
#1760 |
Postovi: 41
Hvala na konfi FRipper Rezolucija je full HD. Primarna namjena je rad u Visual Studiu 2012 i Blendu. Povremeno igram, ali to je SWTOR, koji nije zahtjevan. Tako da mislim da možda i nije potrebno potrošiti cijeli budget? Najbitnije mi je da je apsokutno tiho u radu. |
#1761 |
Postovi: 3,319
Ako bi se išlo na trošenje cijelog buđeta napravi ovako: FX 8320 CM 212+ EVO GIGABYTE 970A UD3 KINGSTON HYPER X 2X4 GB 1600 MHZ (8GB) WD BLUE 1TB SAMSUNG 840 120 GB SSD POV GTX 650 Ti 1GB OC LG DVD-RW SATA XFX 550W 80+ FRACTAL DESIGN DEFINE R4 Ukupno: 6957 kn besplatno slaganje i dostava - Futura it Sve redom kvalitetne komponente i naravno tihe + kućište je obloženo antinoise spužvom za dodatno smanjenje buke. - ako želiš malo smanjiti cijenu gore ubaci POV GTX 550 Ti. Jeftinija verzija bi ti ovako izgledala: i5 3350P MSI B75 P45 KINGSTON 8GB 1333 MHZ WD BLUE 1TB SAMSUNG 840 120 GB SSD POV GTX 550 Ti 1GB LG DVD-RW SATA OCZ MKIII SILENCER 400W ZALMAN T2 Ukupno: 5116 kn -II- U ovom slučaju aftermarket nije potreban što zbog nemogučnosti oc-anja navedenog procesora, što zbog toga jer je stock dovoljno tih i dobro hladi. Možeš i u ovom slučaju staviti R4 i ATX mbo MSI B75A G41 pa ćeš isto biti ispod 6K. Zadnje izmijenjeno od: lolofuxy. 24.04.2013. u 10:11. |
#1762 |
MiningMod
Postovi: 8,715
Gle onda idi na intel konfu jer je tiša i manje se grije a i jača.... Ako neces potrositi 6800, onda uzmi Core i5 3350P umjesto i7 i opet ces imati jak komp, a 1000kn ce te manje izaci, kasnije lako nadogradujes ako bude slab Ovako je definitivno najtise i neces potrositi sav iznos a imas dobar i jak komp ;=)Procesor Intel Core i5 3350P MSI B75A-G41 Memorija Kingston DDR3 8GB (2x4) 1333MHz PoV GTX650 1GB GDDR5 128bit AC Hladnjak HDD Desktop TOSHIBA DT01ACA100 (3.5", 1TB, 32MB, SATA III-600) KINGSTON HyperX 3K Solid State Drive 2.5" SATA III-600 120 GB MLC, Retail DVD RW -RW RAM LG DualLay SATA Kućište Fractal Design Define R4 Black Pearl OCZ PSU Silencer Mk III Series™ 400W Modular Futura-It.hr 6,117.12Kn Besplatno sastavljanje i dostava SLIKA Zadnje izmijenjeno od: FRipper. 24.04.2013. u 10:17. |
#1763 |
Postovi: 88
@dema6 Svakako bih na tvome mjestu za te potrebe uzeo Intela, AMD-ov stock cooler je po defaultu "raspjevan".. Evo prijedloga: INTEL I5 3330 MSI B75MA-E33 KINGSTON 8GB RAM WD BLUE 1TB KINGSTON SSD 120GB V300 MSI RADEON 7850 1GB DDR5/OC SAMSUNG DVD-RW CORSAIR CARBRIDE 200R OCZ SILENCER 400W MODULAR Centro.hr - 5.867,67 - besplatno sastavljanje Corsair Carbride 200R ima kolega s posla i opako mi se sviđa (kučište, ne kolega, da ne bi bilo zabune), nije skupo a djeluje mi dosta kvalitetno kučište, komp je gotovo nečujan.. ili kako je FRipper predložio, Define R4 od Fractala, izvrsno kučište, samo je 400-tinjak kn skuplje. Namjerno nisam stavljao 3350P proc iz razloga što je 3330 sa grafikom u procu a kako ti komp služi za posao, ne daj Bože da crkne grafa - samo će igranje čekat, posao ne ![]() |
#1764 |
Lokacija: Ivanec
Postovi: 4
1.) LCD 21,5 Wide , 5ms, 16:9, IPS Tipk i Miš Logitech Desktop MK120 Intel Core i5 3350P Sck1155 Memorija Kingston DDR3 8GB (2x4) 1333MHz MSI B75MA-P45 Sck1155 PointOfView GTX650 1GB GDDR5 128bit SEAGATE/SAMSUNG HD502HJ (3.5", 500GB, 16MB, SATA II-300) DVD RW -RW RAM LG DualLay SATA Zalman micro tower case black Chicony Active 80Plus 400W ATX PSU Futura-It.hr 5,278.08Kn Besplatno sastavljanje i dostava 2.) 1 x Logitech Desktop MK120, Tipkovnica + Miš, USB 1 x Zvučnica Logitech Z-120 zvučnici, 2.0, 1.2 W (RMS) , USB 1 x Spire Sonex 6010, kućište ATX/micro ATX 1 x Napajanje Zalman 500-GS PSU, 500W, ATX12V V2.3, dual rail +12V 1 x HDD WD 500GB, 5000AAKX, SATA 3, Buffer 16MB, 7.200 rpm , 8,9 ms 1 x DVD upisivač LG GH24NS, DVD±RW, 24x DVD±R ,8x DL , 40x CD-R 1 x XFX HD7770 1000M 1GB DDR5+Far Cry 3 & Hitman Absol, CORE EDITION 1 x DDR3 8GB (1x8GB) Patriot Viper3,1600Mhz 1 x Procesor AMD FX-Series X6 6300 3.5GHz,14MB,95W,AM3+, FD6300WMHK 1 x Asrock 970 Pro3 - AMD 970, AMD SB950, ATX, FSB2400,4xDDR3 1 x LG 22EN33S-B, 21,5", 16:9, 1920x1080, 200 cd/m2, DC 5.000.000:1 5.070,95Kn 3.) i5 3350P AS ROCK B75 PRO3-M PATRIOT VIPER 3 8GB 1600 MHZ WD BLUE 500 GB KINGSTON V300 60 GB MSI GTX 650 1GB SAMSUNG DVD-RW SATA CHICONY HP 400W 80+ ZALMAN T2 ADM + AOC 22" AH-IPS u Diskontu - sve zajedno je cca 5,6k Molim pomoć između ove 3 ponude što uzeti. Hitno mi je! Hvala! |
#1765 |
Postovi: 3,784
Ja bi to malo drugačije sastavio...za koje namjene bi se koristilo računalo? Vidim da treća konfiguracija nema tipkovnicu i miša? To treba ili ne? Kešom se plaća? |
#1766 | |
Lokacija: Ivanec
Postovi: 4
Ma tipkovnica i miš se doda, nije problem to. Plaćanje keš. |
#1767 |
MiningMod
Postovi: 8,715
A koliko ti je max budzet? Opcija 1 ako imas toliko love, preporuka da ides na to Procesor Intel Core i5 3350P MSI B75MA-E33 Kingston DDR3 1600MHz,C11, 8GB PoV GTX650Ti 1GB GDDR5 128bit HDD Desktop TOSHIBA DT01ACA050 (3.5", 500GB, 32MB, SATA III-600) Kingston SSD 60GB V300, 2.5" 7mm, SATA 3 6G, drive only DVD RW -RW RAM LG DualLay SATA Chicony Active 80Plus 400W ATX PSU Zalman micro tower case black LCD 21,5 Wide , 5ms, 16:9, IPS Futura-It.hr 5,689.51 Kn Besplatno sastavljanje i dostava + Mogucnost da osvojiš poklon bon 500kn Opcija 2 sa slabijom grafom Procesor Intel Core i5 3350P MSI B75MA-E33 Kingston DDR3 1600MHz,C11, 8GB PoV GTX650 1GB GDDR5 128bit HDD Desktop TOSHIBA DT01ACA050 (3.5", 500GB, 32MB, SATA III-600) Kingston SSD 60GB V300, 2.5" 7mm, SATA 3 6G, drive only DVD RW -RW RAM LG DualLay SATA Chicony Active 80Plus 400W ATX PSU Zalman micro tower case black LCD 21,5 Wide , 5ms, 16:9, IPS Futura-It.hr 5,516.33 Kn Besplatno sastavljanje i dostava Zadnje izmijenjeno od: FRipper. 02.05.2013. u 15:28. |
#1768 | |
Lokacija: Ivanec
Postovi: 4
#1769 |
Lokacija: Ivanec
Postovi: 4
Sviđa mi se ova tvoja prva opcija i mislim da ću ići na to... Thanks! |
#1770 |
Datum registracije: May 2013
Lokacija: vtc
Postovi: 1
poz namjeravam uzet ovu konfu, savjeti dobrodošli Procesor Intel i5 3350p MSI B75A-G43 MSI GTX660 OC 2048MB GDDR5 DDR3 8GB (1x8GB) Corsair,1600Hz Vengeance OCZ 550W Fatal1ty Series Power Supply Kingston SSD 120GB V+200 Thermaltake Commander MS-III sa USB 3.0 Midi tower cijena 5.932,99Kn u adm-u Zadnje izmijenjeno od: bobosmrad1. 19.05.2013. u 00:19. |
