		#363 |
			Datum registracije: Mar 2009
				Lokacija: Zagorje
					Postovi: 1,001
		 Trenutno je na 1.288v @ 3.78Ghz , idle ~42-40-36-45, 1h prime-a ~64-63-60-60, s tim da je vent podesen: do 60° min okretaji, 60-67° 900rpm, 67°+ max rpm, a cooler je thermax eclipse 2 sa ventom od mugena 2, mada sam vec trebal pastu promjeniti al mi se neda  ![]() Vjerojatno bum ga sad po zimi malo stisnul cisto radi eksperimenta, da vidim je'l ga godine umaraju, zadnji put je (isto cisto eksperimentalno) sa 1.305v povukel na 4.15GHz 8h prime-a stabilno i nije prelazil 70°.  |
		#364 |
			Datum registracije: Sep 2010
				Lokacija: Peljesac
					Postovi: 293
		 Evo mala pomoc za sve clockere: bios postavke na asus maximus 2 formuli sa q9550 e0 rock stable dva tjedna na 4 ghz ![]() Extreme Tweaker Ai Overclock Tuner : Manual OC From CPU Level Up : AUTO Ratio CMOS Setting : AUTO FSB Frequency :470 CPU Clock Skew : normal NB Clock Skew : normal FSB Strap to North Bridge : 333 DRAM Frequency: 940 DRAM CLK Skew On Channel A1: AUTO DRAM CLK Skew On Channel A2: AUTO DRAM CLK Skew On Channel B1: AUTO DRAM CLK Skew On Channel B2: AUTO DRAM Timing Control: Manual CAS# Latency :5 RAS# to CAS# Delay :5 RAS# Precharge : 5 RAS# Activate to Precha :15 RAS# to RAS# Delay : AUTO Row Refresh Cycle Time : AUTO Write Recovery Time : AUTO Read to Precharge Time : AUTO Read to Write Delay (S/D) : AUTO Write to Read Delay (S) : AUTO Write to Read Delay (D) : AUTO Read to Read Delay (S) : AUTO Read to Read Delay (D) : AUTO Write to Write Delay (S) : AUTO Write to Write Delay (D) : AUTO Write to Pre Delay : Auto Read to Pre Delay : Auto Pre to Pre Delay : Auto All Pre to act Delay : Auto All Pre to Ref Delay : Auto DRAM Static Read Control: Disabled Dram Read Training : disabled Mem. OC Charger : Enabled Ai Clock Twister : manual 10 Transaction Booster : moderate PCIE Freguency : 100 CPU Voltage : 1.3 CPU PLL Voltage :1.54 FSB Termination Voltage :1.3 DRAM Voltage : 2.06 North Bridge Voltage : 1.36 South Bridge 1.5 Voltage : 1.5 South Bridge 1.1 Voltage : 1.1 CPU GTL Reference (0) :AUTO CPU GTL Reference (1) :AUTO CPU GTL Reference (2) :AUTO CPU GTL Reference (3) :AUTO NB GTL Reference : AUTO DDR2 ChA Reference Voltage : AUTO DDR2 ChB Reference Voltage :AUTO North Bridge DDR Reference :AUTO CPU Configuration Ratio CMOS Setting :8.5 C1E Suppport : Disabled Max CPUID Value Limit : Disabled Intel (R) Virtualization Tech. disabled CPU Disable Bit Disabled Execute Disable Bit : Disabled Intel (R) Speed Step (tm) Tech disabled Load-Line Calibration :Enabled CPU Spread Spectrum : Disabled  |
		#365 |
				Lokacija: Hercegovac
					Postovi: 974
	HP OMEN G16 AMD Ryzen™ 7 7840HS | NVIDIA® GeForce RTX™ 4060 8 GB GDDR6 | 16 GB DDR5-5600 MHz RAM | 1 TB PCIe® Gen4 NVMe™ M.2 SSD  |
		#366 | |
	  pa daj ga na 475 x 8,5 pa da vidimo onda kako diše na 4 GHz.i gdje si ga ubo i za koliko, ako nije tajna.  |
		#367 |
					Postovi: 974
		 Dobio ga pod borom ! Kaže susjed da vidio "božić-batu" kak mi ulazi u dimnjak!  ![]() ![]() ![]() Ma polako...prvo treba malo vidjet el to meni uopće treba...možda će mi E8400 bit dovoljan...ali svakako ću ga nafrljit kad uhvatim vremena...barem na 3.6 ! ![]()
		#368 |
				Lokacija: Slavonija
					Postovi: 2,066
		 Treba bez problema ići na 3,8 bez dizanja voltaže igdje. Ploče su nam slične. Da se razumijemo, nisam neki clocker (extra-noob u clockanju sam), ali ja sam ga uspio dić tu na stabilno, tako da ga netko, sa imalo znanja, može i više (na zraku).  |
		#369 |
					Postovi: 974
		 A koji batch imaš ? E vidiš ploče jesu slične,ali ima i jedna bitna razlika...tvoja ploča ima 8 faznu regulaciju napona,a moja 16 faznu. Iz prakse znam da je bolja za overklok jer moj E8400 je sa P5QE bio stabilan na 4.5ghz tek uz 1.416V,a na ovoj deluxici mu treba samo 1.376V. No nebitno ako sam dobio loš primjerak neće ga ni mila majka vidjet na 4ghz. Btw...jedan brzinski klok...default napon... ![]()
			HP OMEN G16 AMD Ryzen™ 7 7840HS | NVIDIA® GeForce RTX™ 4060 8 GB GDDR6 | 16 GB DDR5-5600 MHz RAM | 1 TB PCIe® Gen4 NVMe™ M.2 SSD Zadnje izmijenjeno od: bixsy the king. 03.01.2012. u 19:56.  |
		#371 |
				Lokacija: Sinj
					Postovi: 1,080
		 Evo da dignem malo staru temu, imam jedan čudan problem, tj situaciju, imam Q9400 uparen sa Kingston HX DDR3 1600 Mhz memorijom  na starom Gigabyte P35 hibridu- E sad, prva stvar je šta to radi bez problema na postavkama na slici: ![]() Međutim, čim pomaknem FSB malo gore, kaos, memoriju moram vratit na niske grane da stvar uopće posta, o ulasku u win uopće nema govora, šta mi je čudno jer ovaj procesor ide na 3.6 bez neke muke. Zanima me dal je ipak problem u memoriji i prastaroj ploči( šta mi je čudno jer na ovim postavkama memorija je na punom taktu i latencijama, lol) il je nešto treće u pitanju?
		#372 |
				Lokacija: izmedu sb & ng
					Postovi: 117
		 evo jedan sa q8300 na 3.56 ghz sa samo 1.2v memorija je kit g-skill 2x2 gb ddr1333 ocana na 1900 mhz sa istim latencijama ali je napon 1.7v http://www.pohrani.com/?3U/L8/1boHEglo/q8300.png za 24/7 je proc na 3.4 i mema na 1820mhz za 3.0ghz mu treba samo 1.05v  |
		#373 |
					Postovi: 974
		 El se ne da više nafrljit ? Ne ide fsb više ?  |
		#375 |
					Postovi: 974
		 Šteta...inače dobar primjerak...ja sam uspio na asus p5q deluxe navući 505 fsb sa Q9550...ali naravno to ovisi od procesora do procesora.  |
		#377 |
					Postovi: 974
		#378 |
					Postovi: 1,317
		 Ma na netu sam našao na 5 mjesta gdje ta ploča s tim procom ide na 470,a ja bi dupeta dao za 450 i ne bi trebao više.Ali šta god probao ruši se,FSB i RAM rade na 450 - 1800 ako je proc na x7 ali čim idem na x8 ni da bi. Jel bi pomoglo možda prelazak na EP45T-UD3P matičnu. Zadnje izmijenjeno od: Prki. 18.02.2013. u 19:59.  |
		#379 |
			Datum registracije: Oct 2012
					Postovi: 37
		 evo zanima me koja su iskustva u clockingu Q9400 2,66 Ghz  , meni je sa  stock coolerom na 3,2 Ghz --- 400x8 , memorija  400x2,66d --1066, FSb  RAM 3:4 , pa molim savjet  do koliko moze ic ,mislim uzet Corsair h60  vodeno hlađenje ili za manju lovu Hladnjak za procesor Thermaltake Contac 29 BP, pa molim savjest ,testiro sam u Prime 95 i sve je ok cpu _ Procesor QuadCore Intel Core 2 Quad Q9400, 3200 MHz (8 x 400) maticna Gigabyte GA-EP45-DS4 memorija 2x2 Kingstone DDR2-1066 napanjanje 600 w OCZ xfx 4870 512 mb  |
		#380 | |
			Datum registracije: Oct 2010
					Postovi: 10
 http://imageshack.us/photo/my-images/199/q8200oc.png/  |
		#381 | |
		#382 |
			 Varilnik
					Postovi: 1,648
		 Ja na svojoj gigabytici sa q9300 mogu 24/7 bez beda držati na 466FSB, tj 3,5GHz što je ujedno i max clock za ovaj proc koliko sam skužio a mogao sam i na staroj MSI P35 Platinum. Na ovoj koju imam i sa DDR2 i DDR3 bez beda drzi tih 466MHz.  |
		#383 | |
   OK, može ploča biti neko ofrlje pa se dogodi da ne može, ali generalno gledajući, P45 je kao stvoren za naganjanje rekorda na taktovima FSB-a. |
		#384 |
					Postovi: 10
		 necu reci , nego tvrdim . Moj Q9200 sa plocom Gigabyte GA-EP45-DS4 sa istim komponentama pratecim nije htio preko 418 x 7 sa bilo kakvim postavkama i bilo kojim voltazama (vjerojatno FSB wall ) , dok na Gigabyte P35C-DS3R radi na 444 x 7 sa temp. oko <30 u idle , a radio je na 466 x 7 ali se nisam usudio ostavit ga duze na voltažama koje su potrebne da se upali na tom taktu . Ostale komponente su Mushkin Yellowline 1066MHz DDR2 x 4GB i napajanje je Corsair VX450 . I uz to na ponekim OC stranicama mozes naci isto moje misljenje koje tvrdi da je P35 chip stabilniji i bolji za OC od P45 .  |
		#385 | |
		#386 |
					Postovi: 10
		#387 |
		 Ne netko, već ja. Mislim da kad sam imao, što privatno, što u firmi 20+ điđibajtovih P31/P35/P45 ploča koje su umrle bez ikakvog ganjanja ili imaju težih problema u radu, onda sam kompetentan reći kako je to odron od firme, naravno u svom mišljenju. Tebi naravno, to može biti najbolji brand, i neka ti bude. Dao Bog da ne imao nikad problema kakvih sam ja imao. Eto, sad imam doma EP45-UD3P, kao vrhunsku P45 điđibajt ploču, koja iz nepoznatih razloga svakih 9-10 put kad boota, ne želi bootati nego pišti po špranci koja nije opisana niti điđibajt podrška ne zna što bi to bilo ![]()  |
		#388 |
			 Varilnik
					Postovi: 1,648
		 Ma sve ok, samo sam htio reći svoje iskustvo da kolega vidi da ide bez beda iznad 400. P45 i P35 su odlični chispeti tako da nema smisla govoriti da P35 isto ne ide daleko. Opet sve ovisi na koju ploču naiđeš.  |
		#389 |
					Postovi: 974
		 A čuj...ta p45 ds4 je dobra ploča,ali nema ona šta tražit pored asusa P5Q serije. Imao sam dvije gigabajtice...jedna p35 ds3r koja nije išla preko 505 fsb...druga je bila EP P45 DS3P ona je stala na cca 550 fsb. S ovom drugom gigabajticom sam imao stalno neke pizdarije,could boot,problem s biosom jer nije htjela radit sa novijom verzijom,pa mi otišao lan...ma uglavnom užas koliko sam problema imao s njom. Ali asus...to je majstore moj druga priča...imao 5B P35 deluxe s kojom je fsb išao na 560,a kod P5QE sam nasvirao fsb 580 s tim da je njezin prijašnji vlasnik uspio s istom navući 600fsb. Tamo kad nešto naštimaš u biosu onda to i radi kako spada...a kod gigabajtice povećam napon za chipset i mrak...kuja neće radit. Tako da nemoj mi tu prodavat fore o fsbu na p35 chipsetu i gigabajt pločama...ja sam ih malo više izmjenjao... ![]()  |
		#390 |
			Datum registracije: Jan 2015
				Lokacija: mars
					Postovi: 104
		 joj što volim kad netko mjenja kompjuter, pa ti pokloni stare djelove! kao naprimjer.... 4 x 2 gb corsair twinx 4-4-4-12 v1.1 sa micron D9 čipovima ![]() http://i.imgur.com/jPAiQxo.jpg http://i.imgur.com/xtRFpk0.jpg  |
