Staro 11.02.2013., 15:40   #31
Strong
Strong's Avatar
Lokacija: Našice
Postovi: 186
Komp pod Moj Komp
Sve na defoultu
http://www.3dmark.com/3dm/99139
Strong je offline   Reply With Quote
Staro 11.02.2013., 15:48   #32
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,932
Staro 11.02.2013., 17:33   #33
MAGARAC
MAGARAC's Avatar
Postovi: 5,987
Zanimljivo WHQL nije valid a beta je. 313.96 u grubo 300 bodova vise od 313.90.
Moja 670 boosta prek 1250mhz po defaultu tak da je rezultat nesto veci. Fire Strike naravno.
http://www.3dmark.com/3dm/191008
Staro 11.02.2013., 20:21   #34
KarloB
Jedem skoro svaki dan.
KarloB's Avatar
Datum registracije: Mar 2011
Lokacija: LV426
Postovi: 272
Evo jedan undervoltani 955 BE na 3.7 i HD6850 @ 930/1150
link
KarloB je offline   Reply With Quote
Staro 12.02.2013., 12:16   #35
MAGARAC
MAGARAC's Avatar
Postovi: 5,987
Evo i A6 5400K klokanog do krajnjih stabilnih taktova pod stock hladnjakom...
http://www.3dmark.com/3dm/198330
Staro 12.02.2013., 13:00   #36
Wolverine
Wolverine's Avatar
Postovi: 12,425
Evo FireStrike test s HD7870 Black (Tahiti)
http://www.3dmark.com/3dm/198833
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 12.02.2013., 13:30   #37
HCS
Premijum
HCS's Avatar
Postovi: 1,360
7950 na 1250/1450, score
Staro 12.02.2013., 18:03   #38
golfw12
golfw12's Avatar
Postovi: 424
evo i moja kanta i7 2600k,8gb ddr3, 7870, sve na defaultu cpu i gpu
http://www.3dmark.com/3dm/200936
CPU: AMD Ryzen 5 PRO 4650G@3.7GHz@ CM Hyper 212X
MBO: Gigabyte B450 AORUS PRO
RAM: 2 x 8 GB DDR4 3200Mhz CL16 Kingston HyperX Predator RGB
GPU: Radeon Onboard Graphics
SSD: Samsung 1Tb, NVMe
HDD: Seagate 1TB, Sata III
PSU: Corsair RM650X 650W
CASE: Phanteks ECLIPSE P400
MONITOR: AOC 24G2U @ 144HZ
MOUSE: Logitech MX518 Batman Edition
KEYBOARD: Logitech K200
PERIPHERY: RAZER Goliathus Control Alpha
OS: Windows 10 Home x64
PRINTER: HP LaserJet Pro M12w
CONNECT: T-Com VDSL 30/6 Mb Flat
CPU: Intel® Core™ i5-8250U@1.6GHz
RAM: 2 x 8 GB DDR4 2400Mhz
GPU: Intel® UHD Graphics 620
HDD: 256 GB M.2 SSD
PSU: HP 90W
LCD: 1.920 x 1.080 FHD-Display SVA
golfw12 je offline   Reply With Quote
Staro 12.02.2013., 19:45   #39
listerstorm
listerstorm's Avatar
Datum registracije: Apr 2011
Postovi: 1,428
Autor HCS Pregled postova
Impresivna kartica, na tim frekvencijama u fire strikeu HD 7950 odere i GTX 670 i HD 7970 a vrlo vjerojatno i GTX 680.
Staro 12.02.2013., 21:52   #40
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Autor listerstorm Pregled postova
Da, zanimljivo, nemoze ni dosta OCana GTX 680 parirat u firestrikeu, nece bit valjda da ATi ima bolje drivere?
Staro 12.02.2013., 22:07   #41
listerstorm
Postovi: 1,428
Nije prvi put. Sjećam se kako je Ati 2900 XT dočekana kad je izašla tamo negdje 2007.
Podbačaj u odnosu na 8800 seriju da bi nakon nekog vremena novim driverima prilično poboljšala performanse.
IMO Ati u najgorem slučaju ima hardware jednakih mogućnosti kao i Nvidia ali im uvijek treba vremana da iz njega izvuku 100%.
Iako, 3D Mark je jedno a igre nešto drugo i neke više leže Ati karticama i obratno al u prosjeku za visoke rezolucije i max detalje prije bih stavio kunu na Ati.
Staro 13.02.2013., 08:22   #42
m&n
Datum registracije: Mar 2008
Postovi: 893
znaci ja na svojoj gtx 680 jetstream na ovim default povisenim taktovima ti ne mogu doci niti blizu a kada karticu klokam maks kolko ide opet te ne mogu stici
btw.. vidim da imas asus direct cu, ja imao direct cu II hd 7970 i bila je 0 bodova za klokanje, dok referentna sapphire hd 7970 isla u nebesa..
phantomka gtx 670 se dala klokat vise nego sadasnja gtx 680...
danas uzimam 99.9% 2 x hd 7950 xfx dd
m&n je offline   Reply With Quote
Staro 13.02.2013., 13:00   #43
Pegasus8
Pegasus8's Avatar
Postovi: 480
Evo HD 6850 (stock) i E7500 @ 3,96HGz
http://www.3dmark.com/3dm/207215
Pegasus8 je offline   Reply With Quote
Staro 13.02.2013., 13:46   #44
Broken Arrow
The Man
Broken Arrow's Avatar
Lokacija: Novi Zagreb
Postovi: 1,252
Nisam pokretao 3D mark ima goooodina... pa pokrenuh 3D Mark 2011...
vidim da ovdje su liknovi na neki drugi 3D mark... dajte recite koji pa da i njega puknem... ali evo ovih reza sa lapa iz Moj komp:
http://www.3dmark.com/3dm11/5902480
Nisam ništa dirao, kako lap došao tako samo pokrenuo...
"Everybody's at war with different things...I'm at war with my own heart sometimes"
Broken Arrow je offline   Reply With Quote
Staro 13.02.2013., 13:48   #45
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Autor m&n Pregled postova
Da, nema veze cija je kartica, pa cak ni toliko cooler gore koliko sama kvaliteta chipa, lutrija, ova moja je koliko vidim dosta dobar primjerak, nije joj tih 1250 kraj, samo mi je se neda forsirat preko dok ovaj bench tako dugo traje.
Lude su te 7950, postigne se na njima bez problema 50% OC-a i vise sa pocetnih, smijesnih 800 MHz. Kad ti stignu, vrati se u ovu temu
Staro 13.02.2013., 14:02   #46
Šole
Šole's Avatar
Datum registracije: Aug 2009
Lokacija: Zürich
Postovi: 709
Šole je online   Reply With Quote
Staro 14.02.2013., 07:44   #47
m&n
Postovi: 893
evo me sa cf-om ja što kažem to i održim
m&n -11869 XFX 7950 DD CrossfireX@ 1050/1450zrak -i7 3770k @ 4.7ghz zrak
inace vise sam aktivan na bug forumu tamo sam toxic..
evo i slika setupa... doduse sve cu ja to jos bolje poslozit kada uhvatim vremena
slika
a recimo ovo mi je bio mask score sa gtx 680 jetstream
toxic/m&n - 7238 gtx680@ 1195/1778 zrak -i7 3770k @ 4.7ghz zrak
e da htio sam te pitat daj provjeri koji ti je asic na grafi.. npr meni je 60% na jednoj a 63% na drugoj.. naime taj asic govori kakav chip imaš provjeri ga preko gpuz-a
http://www.techpowerup.com/forums/sh...d.php?t=173667
e sad po ovim mojim postocima mogo bi još ocat garant i da što nije tvoja na 900mhz??
Zadnje izmijenjeno od: m&n. 14.02.2013. u 07:51.
Staro 14.02.2013., 08:05   #48
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Ček, ti si nabavio 7950CF sad u dva dana?
Staro 14.02.2013., 08:30   #49
m&n
Postovi: 893
Autor Halos Pregled postova
imam ja vec duze to u planu ali u 1 dan
Staro 14.02.2013., 13:48   #50
HCS
Premijum
HCS's Avatar
Postovi: 1,360
slika
Nisam sumnjao da budes, moj je 63,5%, ne znam bas koliko im je to tocno. Na def. naponu od 1,093 ide do 1075MHz i tu je drzim hladnu i necujnu, s time da to nije taj napon nego se vrti oko 1,07-1,08.
Inace, super to izgleda, kakve su im temp, def. napon? Koliko idu na njemu, koliko mozes dic napon?
EDIT: Da, na 900 MHz je dignuta serijski, mislio sam na non-OC verzije i njihovih stock 800 MHz.
Zadnje izmijenjeno od: HCS. 14.02.2013. u 15:59.
Staro 14.02.2013., 16:03   #51
m&n
Postovi: 893
budem sada testirao sve juceer nisam bas stigo tolko, inace na kojem naponu si drzao grafu za onaj takt?
Staro 14.02.2013., 19:42   #52
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Za 1250 MHz, 1,27 AB, realnih 1,25-6. S time da u 11-ici prolazi na 1,26 u afterburneru, dosta je ovo i duze i zahtjevnije.
Staro 14.02.2013., 22:24   #53
m&n
Postovi: 893
evo da podebljam score
m&n -12205 XFX 7950 DD CrossfireX@ 1100/1450zrak -i7 3770k @ 4.7ghz zrak
ide to još sigurno dosta gore..
Staro 15.02.2013., 08:11   #54
odlični rezultati, svaka čast. I dobar CPU primjerak, kad odrađuje taj takt na manje od 1,1V.
Kao i račun za struju
Staro 15.02.2013., 08:20   #55
Postovi: 8,214
Gigabajtice nepokazuju napon kako treba, tj. pokazuju krivi napon, ne vcore.
Staro 15.02.2013., 08:40   #56
m&n
Postovi: 893
nije to napon dobar radi on na vise.. cpuz iz nekog razloga ne ocitava napon procesora, dok aida pokazuje recimo dobro.. mislim da je ovdje napon 1.2v
a zbog racuna za struju se ne brinem sa obzirom da ocam iskljucivo za testove a to je niti 30 minuta dnevno
Staro 19.02.2013., 17:02   #57
domina
domina's Avatar
Lokacija: KC (HR)
Postovi: 916
Vidi mog
http://www.3dmark.com/3dm/253267
Treba zamjenit proc .
Staro 23.02.2013., 10:02   #58
mhadina
mhadina's Avatar
Postovi: 436
Moj komp i rezultat
  • Vidiš li čovjeka koji se sam sebi mudrim čini? Znaj, i od bezumnika ima više nade nego od njega!
  • San dolazi od mnogo briga, a lud govor od mnogo riječi.
  • Neka su ti mnogi poznanici, ali pouzdanik samo jedan od tisuću.
  • Ne ponizuj se pred budalom i ne budi pristran pred mogućnicima.
  • Ne budi silovit na jeziku a lijen i mlitav na djelu.
mhadina je offline   Reply With Quote
Staro 27.02.2013., 11:33   #59
Šole
Šole's Avatar
Lokacija: Zürich
Postovi: 709
Zadnje izmijenjeno od: Šole. 28.02.2013. u 13:41.
Staro 03.03.2013., 20:34   #60
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,932
