Povratak   PC Ekspert Forum > Računala > Periferija > Ostalo
Staro 21.12.2011., 11:08   #61
housel
aka Sizif
housel's Avatar
Lokacija: požega
Postovi: 581
..ili samo skine kotačiće sa stolice
housel je offline   Reply With Quote
Staro 21.12.2011., 11:11   #62
O9g1
Bee-do Bee-do Bee-do, TUP
O9g1's Avatar
Datum registracije: Aug 2009
Postovi: 323
He, he, kažu da je pretpostavka majka svih zaje**!
Možda čovjek ima običnu kuhinjsku ispred kompa... LOLČINA!
CPU: Intel i5 2500k (BX80623I52500K) cooled by Scythe Ninja3 (SCNJ-3000)
MBO: Asus P8Z68-V PRO/GEN3
RAM: 2x4GB Kingston 1600MHz, DDR3, XMP (KHX1600C9D3K2/8G)
GPU: GIGABYTE Radeon R9 290 4GB Windforce 3x (GV-R929OC-4GD)
SSD: Samsung 840 EVO 120GB (MZ-7TE120BW) - System
HDD1: WD Caviar Black 500GB (WD5001AALS) - Storage
HDD2: WD 250GB (WD2500JS-22MHB0 ) - Backup
ODD: Samsung 22/8/8/48/32x (SH-S222AB)
PSU: XFX XXX Edition P1-650X-CAG9 650W
CASE: Fractal Design Arc midi
FAN CONTROL: Scythe KAZE MASTER 5.25″ Bay Fan Controller (KM01-BK)
FAN: 2x Fractal Design Dynamic GP-14, 140 mm intake+2X Scythe S-flex 120mm (SFF21E) exhaust
OS: W10 x64
LCD:MASTER: LG 29UM57-P Ultra širok đubar, jooooj što ga volem... , SLAVE: Dell 17"
KEYBOARD: Logitech UltraX keyboard (Y-BL49)
MOUSE: Logitech G400
SOUND: Creative Sound Blaster X-Fi XtremeMusic
HEADSET: Steelseries Siberia v2
RALLYING GEAR: Logitech G25+homemade cokpit+handbrake (modani Genius MaxFighter F-16U)
IF IN DOUBT, FLAT OUT!!!
Don't touch it! It is mine! It's all miiiiineeee!!!
Lenovo Essential B580
CPU: Intel Celeron Dual Core B820 1.70GHz (2MB cache)
LCD: 15.6" HD LED 1366 x 768
GPU: Intel HD Graphics 3000
RAM: 4GB DDR3 1600MHz
HDD: 320GB SATA
ODD: DVDRW DL
PSU: Up to 4hours (Li-Ion 6 cell)
ETHERNET: Yes (Gb LAN)
COMM: Yes (802.11b/g/n)
BLUETOOTH: Yes
AUDIO IN/OUT: Yes
VGA OUT: Yes
HDMI: Yes
CASE: Lenovo
CARD READER: Yes
FINGERPRINT READER: Yes
CAMERA: Yes
OS: Windows 7 Profesional
Lenovo ThinkPad E560
CPU: Intel Core i7-6500U 2.5 GHz
LCD: 15.6 inch 16:9, 1920x1080, IPS-Panel, LED-Backlight, glossy: no
Extern LCD:Lenovo X24a, 24 inch 16:10, 1920x1200, IPS-Panel, LED-Backlight
GPU: AMD Radeon R7 M370 2 GB GDDR5
RAM: 16GB, 2 x 8 GB DDR3L-1600
HDD: 250GB SSD
ODD: DVD+/-RW
PSU: 48 Wh (6 cell)
ETHERNET: Gigabit Ethernet
COMM: 802.11ac, Bluetooth, Intel Dual Band Wireless-AC 8260 - M.2 Card
CONNECTIONS: 3 x USB 3.0, HDMI, VGA, OneLink connector, LAN, Headphone/microphone combo jack
CARD READER: 4 in 1 ( SD Card, MultiMediaCard, SDHC Card, SDXC Card )
CAMERA: Yes
OS: Windows 10 64x
Poštena, dobra i odgovorna trgovina +još jedna...
Straight roads are for fast cars, turns are for fast drivers!
O9g1 je offline   Reply With Quote
Staro 21.12.2011., 15:41   #63
lolofuxy
lolofuxy's Avatar
Datum registracije: Jun 2010
Postovi: 3,319
Uredska stolica, ali bez kotačića, a za ovo neuredno sam malo bio sarkastičan zbog ekipe koja mi je presmiješna kad napiše "oprostite ak je malo neuredno" a nema trunke prašine i nereda ...nadam se da se razumijemo sad
A setup ću neki složit već kad malo dođem do slobodnog vremena. Šteta je tom volanu uskratit pravo postolje.
lolofuxy je offline   Reply With Quote
Staro 21.12.2011., 17:21   #64
O9g1
O9g1's Avatar
Postovi: 323
Ma skužilo se to odmah, pa nisi valjda iz mog posta zaključio da sam stvarno toliko šokiran. Našlo se vremena, pa sam si jedan dan iz dosade išao crtuckati u CAD-u, pošaljem ti ako misliš da bi išta od ovoga moga mogao iskoristiti
OS: W10 x64
HDD: 320GB SATA
ODD: DVDRW DL
BLUETOOTH: Yes
AUDIO IN/OUT: Yes
VGA OUT: Yes
HDMI: Yes
CASE: Lenovo
CARD READER: Yes
CAMERA: Yes
HDD: 250GB SSD
ODD: DVD+/-RW
PSU: 48 Wh (6 cell)
CAMERA: Yes
OS: Windows 10 64x
Staro 20.07.2012., 17:49   #65
mislav_os
freak
Postovi: 2,688
Je li ovo best buy volan do 1000kn? Razmišljam o kupnji istoga, a nemam iskustva s njim, pa ne znam da li postoji što bolje za te novce. Iako vidim da u HR nemamo baš neki veliki izbor volana :S.
Staro 20.07.2012., 18:10   #66
syss
syss's Avatar
Postovi: 10,805
postoji... rabljeni g25
Staro 20.07.2012., 18:46   #67
mislav_os
freak
Postovi: 2,688
Pronjuškat ću po oglasnicima onda da vidim da li se nađe neki u ok stanju za te novce. Vdijet ću da bude tu blizu, jer će me poštarina sigurno izać još 100kn pošto je porpilično velik paket. Iako volim novo, ali možda nađem neki s garancijom .
Staro 20.07.2012., 20:04   #68
M.U.P.
M.U.P.'s Avatar
Lokacija: Rijeka - malo iznad :)
Postovi: 372
i ja sam u slicnoj dilemi..
do 1000 kn bi svakako trazio neki g25.. g27 se novi nadje po 1500 tako da ovisi koliko volis hobi
ako vec mislis o dfgt, idu po 500/600 kn sa garancijom..
postarina te dodje do 50 kn.. ja sam 2 volana tako kupio.. ako se tipu da to spakirat..
M.U.P. je offline   Reply With Quote
Staro 20.07.2012., 20:39   #69
mislav_os
freak
Postovi: 2,688
A onda dobro, isplatilo bi se i uzeti od "dalje", ali to ću svakako pričekati neki oglas na forumu, jer njuškalu i sl. ne vjerujem, ovdje bar vidim po članu kakav je.
Staro 16.01.2013., 15:01   #70
lord of camelot
lord of camelot's Avatar
Datum registracije: Jan 2013
Lokacija: bosna i hercegovina
Postovi: 4
volan za pc
kada igram bilo koju igru na volanu za pc auto mi uvijek ide u lijevo kako se to moze i da li se moze popravit ???
lord of camelot je offline   Reply With Quote
Staro 16.01.2013., 18:50   #71
M.U.P.
M.U.P.'s Avatar
Postovi: 372
koji volan, koja igra, koji driveri .. ..
dal ti se izravna kad namotas do kraja u suprotnu stranu?
ako se radi o logitech momo volanu, to im je poznata boljka i nema bas spasa..
i kod ostalih se volana zna javit problem decentralizacije, ali vrlo rijetko..
dal ti je volan ok van igre? gledajuci u programu volana? (pr logitech profiler za logitech)
jedino sto donekle smanji problem jer otvaranje kucista volana i ciscenje senzora.. al generalno - ukoliko se pojavljuje decentralizacija kod naglih kontri, prelaska preko pasica, kod dodira sa drugim autom - nema bas nekog spasa..
Staro 17.01.2013., 16:02   #72
lord of camelot
Postovi: 4
Autor M.U.P. Pregled postova
u pitanju je smartbox pxu-v9 igra je need for speed underground 2
da izravna mi se kad ga do kraja namotam u suprotnu stranu
Staro 17.01.2013., 16:08   #73
lord of camelot
Postovi: 4
igre za pc
da li znate neku igru za pc koja se moze igrati sa volanom kao npr. life for speed
Staro 17.01.2013., 16:17   #74
M.U.P.
M.U.P.'s Avatar
Postovi: 372
rfactor, dalje ne moras trazit..
http://f1hracing.co.nf/
skoci na nas sajt, pa i na nas forum
gdje ces dobit sav help koji ti treba
Staro 17.01.2013., 19:15   #75
Ati freak
aka Striko
Ati freak's Avatar
Lokacija: Krapina - Zagreb
Postovi: 1,743
Zadnje izmijenjeno od: Ati freak. 17.01.2013. u 19:55.
Ati freak je online   Reply With Quote
Staro 17.01.2013., 20:28   #76
O9g1
O9g1's Avatar
Postovi: 323
E, jbg, dajmo čovjeku malo izbora...
a ganjamo se tu u vrancuza
OS: W10 x64
HDD: 320GB SATA
ODD: DVDRW DL
BLUETOOTH: Yes
AUDIO IN/OUT: Yes
VGA OUT: Yes
HDMI: Yes
CASE: Lenovo
CARD READER: Yes
CAMERA: Yes
HDD: 250GB SSD
ODD: DVD+/-RW
PSU: 48 Wh (6 cell)
CAMERA: Yes
OS: Windows 10 64x
Staro 18.01.2013., 14:34   #77
lord of camelot
Postovi: 4
igre za pc
treba mi igra sa volanom ali da moze na ovu graficku intel(r) 82865g
Staro 18.01.2013., 17:49   #78
M.U.P.
M.U.P.'s Avatar
Postovi: 372
pa jel ti citas odgovore upucene tebi?
neznam sto mislis i zelis igrat - ako zelis vozit sim game, a ne arkadne gluposti, izbori su ti navedeni..
ako zelis vozit kruzne utrke, na prakticki bilo kojoj stazi koju mozes zamisliti, sve do grobnika, sa prakticki kojim god autom zelis, sve do yuga i fiole, zelis vozit i online - izbor je rfactor,
ako zelis vozit rally, izbor je samo jedan - richard burns rally za kojeg imas takodjer modove i pregrst auta..
obje su igre starije, i nezahtjevne, pogotvo rbr, a i rfactor mozes vozit na svakom govnu, obzirom da ga mozes pokrenut i u direct7 ili 8..
Staro 08.02.2013., 23:31   #79
Ivša
Ivša's Avatar
Datum registracije: Aug 2010
Postovi: 28
Ljudi, koji bi bila preporuka da pređem sa Logitech Formula Force EX, OK je volan i kvalitetan je, ali nekako nemam "full" dojam s njim, mislim da je vrijeme da se prijeđe na šeto ozbiljnije, jel može preporuka?!
Ivša je offline   Reply With Quote
Staro 09.02.2013., 13:02   #80
suedamA obmaR
Game, PC ,motobikes, bike
suedamA obmaR's Avatar
Datum registracije: Jan 2010
Lokacija: Sibenik
Postovi: 777
Driving Force Pro < Driving Force GT < G25 < G27.
suedamA obmaR je offline   Reply With Quote
Staro 09.02.2013., 13:32   #81
Prki
Prki's Avatar
Postovi: 1,317
Ma i Momo Logitech je sasvim ok, to ti je ko i sa procom i7 je odličan ali ti sve isto dobro radi i sa poštenim quadom ili dualcorom.Tak je i sa volanima Momo je ok, G27 je bolji ali pare ne rastu na drvetu.
Staro 09.02.2013., 15:21   #82
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Ja imam trenutno Force EX kod sebe, a nedavno sam si uzeo Driving Force Pro i stvarno super uložen novac. Testirao sam ih nedavno i razlika je očita, za force ex nemogu sjest i ozbiljno vozit...
Staro 09.02.2013., 22:52   #83
O9g1
O9g1's Avatar
Postovi: 323
Autor Prki Pregled postova
Autor Halos Pregled postova
He, he, probajte negdje obojica G25 ili 27, pa će vam i komentari evoluirati, a postoji još bolje i od toga - Fanatec, samo problem je što toliko više i košta LOL (posebno njihove pedale)
Znam što govorim, jer sam i sam imao par godina Logitech Wingman FF, dobar PVC-jac, ali igračka u odnosu na G seriju.
Naravno ovo pod "ozbiljno vozit" podrazumijeva neku od vozačkih simulacija, inače za arkade, po meni bačen novac.
OS: W10 x64
HDD: 320GB SATA
ODD: DVDRW DL
BLUETOOTH: Yes
AUDIO IN/OUT: Yes
VGA OUT: Yes
HDMI: Yes
CASE: Lenovo
CARD READER: Yes
CAMERA: Yes
HDD: 250GB SSD
ODD: DVD+/-RW
PSU: 48 Wh (6 cell)
CAMERA: Yes
OS: Windows 10 64x
Staro 10.02.2013., 11:34   #84
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Lako za komentare, đep malo teže evoluira .
Probao sam G27, tu sam se i navukao na rFactor. Dfp tu nema što raditi, ali svejedno s obzirom na novce za koje se da nabavit nije loš...
Staro 17.02.2013., 00:13   #85
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,066
Trebao bih što jeftiniji volan za PC.
Do sad sam imao ovaj:
Uglavnom vozim GTR2 i NFS Shift i to onako, nekoliko puta mjesečno tako da mi je bezveze davati nekakve bjesne pare za nešto toliko nevažno
Dva uvjeta su - da postoje driveri za Windows 8 i da se volan učvršćuje sa šarafcingama (nemrem se sjetit kak bi to drugačije nazvao )
Thanks!
EDIT: Još bi bolje bilo kad bi se negdje mogle kupiti samo pedale jer su mi je gas otišao
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Zadnje izmijenjeno od: Mario92. 17.02.2013. u 00:20.
Staro 23.05.2013., 17:01   #86
SamSpade
SamSpade's Avatar
Datum registracije: Feb 2012
Postovi: 11
amen
SamSpade je offline   Reply With Quote
Staro 15.06.2013., 15:53   #87
Krešimir-ZG
Krešimir-ZG's Avatar
Datum registracije: Jan 2011
Postovi: 324
Driving Force GT (700 [kn]) ili DFP (350 [kn]) ?? generalno gledano, znaci i FF, i [°] i osjecaj pri voznji. Vidim, ima vas kronera dosta
I evo, cisto da preporucim igru >>> SimRaceway. Ekipa iz silikonske doline je odradila nenadjebiv posao, a imaju i svoj wireless (znam, zvuci glupo, ali pratite) volan sa G-senzorima i FF-om. Probajte, ako vec niste.
Zadnje izmijenjeno od: Krešimir-ZG. 15.06.2013. u 16:46.
Krešimir-ZG je offline   Reply With Quote
Staro 15.06.2013., 17:09   #88
M.U.P.
M.U.P.'s Avatar
Postovi: 372
ma kakav simraceway.. auti po 30$..
probajte raceroom, free preko steama sa par auta, i natjecanja koja su isto free (hotlapiranje).. jos je u beti, nema multiplayera..
prilicno iznenadjujuce dobra voznjica..
svi su naslovi jos u beti, pa do izlaska asseto corse i finishiranja rfactora 2, tu je i dalje simulacija koja je postavila standarde - dobri stari rfactor
sto se tice volana, 700 kn za dfgt je previse, s garancijom su oko 500 kn..
dfp je isto solidan volancic, 900 stupnjeva takodjer, ffb osjetno slabiji i "meksi" od dfgta, al ne los volancic za pocetak..
trazi radije dfgt za 500 kn, il neki g25 u dobrom stanju za kakvih 800 mozda..
Staro 15.06.2013., 17:14   #89
Krešimir-ZG
Postovi: 324
raceway sam igrao sa free autima i jako sam zadovoljan odrađenim poslom ekipe. TO sto se auti placaju - jbg.
kaj velis za logi momo ? - 300kn < < < misljenje?
Zadnje izmijenjeno od: Krešimir-ZG. 15.06.2013. u 17:36.
Staro 15.06.2013., 17:22   #90
M.U.P.
M.U.P.'s Avatar
Postovi: 372
nije stvar ni u samom placanju koliko u cijenama..
al malo sam se zaletio, znam da su neki auti po 30$ pa sam pretpostavio da ni ostali nisu jako daleko, al evo sto pise
with 21 cars launched so far, 16 of them are priced at below $3 (and nine of those are below $1).
to je fer.. i 20-ak kn nije puno..
imaju cudnu politiku:
To make buying a car as straightforward as possible, we use a simple method of calculating prices, offering them for exactly 1/100,000 of their real-world market value. For vintage cars, we calculate market value using a variety of reputable sources and for racing cars we use a team's operating budget minus their operations, overhead and travel costs.
raceroom je pak pohlepniji..
auti su nekih 250 bodova na gore, staze oko 500, a 500 bodova je 5€..
dakle za 10€ kupis jedan auto i stazu i jedan skin..
to je malo previse..
ni sjena iracingu doduse
