Staro 14.05.2005., 01:05   #1
Black Dragon
Black Dragon's Avatar
Lokacija: Agram
Postovi: 2,983
Nod 2.5
Eto izašao može sve ovo a i novo je sve ovo dole pobrojano:
Key Features Include:
* Centralized management of the resident antivirus modules and filters.
* Intuitive directory tree style system for easy access to:
o Automatic, internet/LAN Update module
o Centralized system of log files for all installed modules
o AMON - resident on-access monitor
o NOD32 - on-demand scanner
o IMON - Internet monitor - scans e-mails incoming via the POP3 protocol
o EMON - complementary e-mail scanner module - scans e-mails incoming via MAPI interface (details below)
o Flexible task scheduler and planning module
o Quarantine directory
o Key system information
Changelog
May 12, 2005 - Program components version 2.50.16
* Kernel
o Adware/Spyware/Riskware detection
o ThreatSense.Net Early Warning System
o License manager
* AMON
o Improved in-depth analysis of newly created files
o Automatic movement of newly created files to Quarantine
* DMON
o Manual start of the monitor
o Improved compatibility with Internet Explorer when DMON is disabled
* EMON
o Brand new module compatible with all versions of MS Outlook
* IMON
o Different compatibility mode for different servers
o Access blocking for websites with malicious content
* XMON
o Improved algorithm for calculating the real file size
o Option added for quick enabling/disabling rules
o Rule added for checking file size
* NOD32
o Information on file from which the memory infiltration originated
o Improved file specification by mask
o NTFS Alternate Data Streams (ADS) check
NOD32 trial version download:
NOD32 for DOS:
http://u4.eset.com/eval/msdos/noddosen.exe
NOD32 for Windows 95/98/ME:
http://u4.eset.com/eval/win/v2/ne98enst.exe
NOD32 for Windows NT/2000/2003/XP:
http://u4.eset.com/eval/win/v2/nentenst.exe
For full versions you have to be a registered user!
Download and info:
http://www.nod32.com/download/download.htm
Staro 14.05.2005., 13:02   #2
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
Šoram ga još od bete, i mljac. Nikakvih problema ni sa betom, idem staviti finalnu.
Staro 14.05.2005., 16:18   #3
MasterX
do you speak it?
Lokacija: ::1
Postovi: 1,630
ja sam stavio NOD32 v2.5 final juce, vidim da su neke stvari dodali, ostaje mi jos jedno tjedan dva da ga mucim da vidim kako dise... inace sve 5, prezadovoljan sam sa nod-om
Drinking Rum before 10am makes you a Pirate, not an Alcoholic.
MasterX je offline   Reply With Quote
Staro 14.05.2005., 16:36   #4
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
He, he promjenili su splash screen Guba...
Staro 14.05.2005., 16:38   #5
sNNooPY
sNNooPY's Avatar
Postovi: 1,908
Dragon, hvala na infou. stavio ga i radi OK.
mora da je to najveci improvement u 2.5.
sNNooPY je offline   Reply With Quote
Staro 15.05.2005., 19:56   #6
MasterX
do you speak it?
Lokacija: ::1
Postovi: 1,630
a ja sam uporan u DO NOT SHOW SPLASH SCREEN ON STARTUP tako da ga nisam ni vidio
Staro 15.05.2005., 21:27   #7
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
Šteta, a baš je lepi
Staro 15.05.2005., 23:55   #8
MasterX
do you speak it?
Lokacija: ::1
Postovi: 1,630
moracu ti vjerovati na rijec
Staro 17.05.2005., 14:52   #9
Veky
Veky's Avatar
Datum registracije: Nov 2002
Postovi: 1,950
evo bas sam instaliro novi nod, uninstall starog pa install medutoa imam neke rupu u gui-u :confused:
slika:
sta mu bi?
Zadnje izmijenjeno od: Veky. 25.03.2006. u 09:27.
Veky je offline   Reply With Quote
Staro 17.05.2005., 16:49   #10
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
Nešto nije dobro sijelo. Tu treba pisati s lijeva control cenetr, a desno NOD32...Možda imaš neidentificirani leteći NOD.
Staro 25.05.2005., 18:29   #11
cancel
Lokacija: somewhere around..
Postovi: 7
Thumbs up
nod rulz i od verzije jedan..
ova 2.5 je samo još bolja..
= AMD user =
cancel je offline   Reply With Quote
Staro 25.05.2005., 23:49   #12
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 895
[QUOTE]Originally posted by tor
[B]Nešto nije dobro sijelo. Tu treba pisati s lijeva control cenetr, a desno nod32
desno treba pisati Settings
damir1 je offline   Reply With Quote
Staro 29.05.2005., 15:44   #13
Veky
Veky's Avatar
Postovi: 1,950
rijeseno pomicanjem hardware acceleration opcije pod display settings za jedan korak
Staro 29.05.2005., 16:17   #14
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
[QUOTE]Originally posted by damir1
[B]
Da, zavisi na kojem si modulu...
