Staro 08.10.2012., 22:36   #1021
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
SCYTHE Ikazuti
ali mislim da ga jos ima samo u protisu -.-
ali da core 3000 je naj...ako imas love uzmi
Staro 08.10.2012., 22:40   #1022
H@rdc0r3M1nD
H@rdc0r3M1nD's Avatar
Lokacija: Croatia;Velebit
Postovi: 465
A moze koja rijec o BitFenix kucistima? kvaliteta, omjer cijene/kvalitete?
H@rdc0r3M1nD je offline   Reply With Quote
Staro 08.10.2012., 22:51   #1023
H@rdc0r3M1nD
Postovi: 465
Autor FRipper Pregled postova
SCYTHE Ikazuti
Ako se slazete oko core 3000 onda je to to... stisnut cu se i ustedjet jos koju kunu i idem po c3000
Staro 15.10.2012., 21:23   #1024
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
NZXT Phantom 820
Stigao novi Phantom 820, jako, jako lijepo kuciste, oduvijek su mi se svidala NZXT kucista...evo i spec:
MODEL Phantom 820
CASE TYPE Full Tower
FRONT PANEL MATERIAL Plastic/Steel
DIMENSIONS (W x H x D) 235mm (W) x 650mm (H) x 612mm (D)
Special Features Integrated HUE LED lighting system, SD Card Reader, 4-channel 15-watt Fan Digital Controller
COOLING SYSTEM
1x200mm@800rpm Front
1x200mm@800rpm Top
1x200mm@800rpm Side
1x140mm@1100rpm Rear
Fan Blades white fin/black frame
Fan Capacity Top: 2x 200mm/2x 140mm/3x 120mm
Front: 1x 200mm
Bottom: 2x 140mm/2x 120mm
Rear: 1x 140mm/1x 120mm
Side: 1x 200mm
Pivot: 1x 140mm/1x 120mm
Radiator Capacity Top: 2x 140mm/3x 120mm
DRIVE BAYS 4 EXTERNAL 5.25" DRIVE BAYS
6 INTERNAL 3.5" DRIVE BAYS
Screwless Rail Design
MATERIAL(S) Steel, Plastic
EXPANSION SLOTS 9
WEIGHT 15kg, 32lbs
MOTHERBOARD SUPPORT E-ATX, XL-ATX, ATX, MICRO-ATX, Mini-ITX
I najbitnije, foto galerija
Staro 15.10.2012., 21:46   #1025
SetH
SetH's Avatar
Lokacija: DS
Postovi: 3,328
imaš na jutubu review...puno previše plastičurije
SetH je online   Reply With Quote
Staro 18.10.2012., 13:24   #1026
NinjaZec
Lokacija: SK/ZG
Postovi: 209
Molio bih preporuku za novo kućište, ovo staro mi je stvarno postalo odvratno, ni nesejćam se koliko generacija je staro.
Uvijeti su slijedeći:
Rupe za ventilator iza i sa desne strane mi ne trebaju i ne upotrijebljive su, dakle samo sa lijeve strane i napred mi trebaju, nilo bi dobro da dolazi sa ventilatorima (ili da je utoliko koliko koštaju ventilatori jeftinije, može onda i preporuke za ventilatore)
Također nebi htio ledice nikakve, da mi po noći ne svjetli cijela soba, kad legnem spavat.
Max cijena je 500kn s tim da ako ima to sta trazim za 400 jos bolje.
Trenutni komp je pod moj komp ali pošto je grafička otišla možda kupim hd7750 (plafon,), a maticnu proc i rame u nekoj skorijoj budućnosti (2g max)
S napajanjem neznam ni sam šta ću mislim da neću sad kupovat nego kad budem i ove ostale komponente.
Ova napajanja šta idu sa kućištima nemam pojma šta da mislim o tome, ako išta valjaju ta napajanju i ako se ustedi neka lova u odnosu na kupovinu odvojenog, onda ajd, mogu i sad uzet napajanje.
Što se tiče ovih preporuka Fractal 3000 mi nije lijep, nebi htio te neke minimalisticke kockaste modele više sam za haf 912 i z9 što se izgleda tiče.
Funkcionalno ATX matična, 3 diska, kablove nikad nisam slagao, ali voljan sam ih slozit (nisam siguran jel to ovisi o duzini kablova na napajanju, ili se kupuju produžetci ili šta)
Nije mi potrebna nikakva ručkica ni ništa, ne nosam ga nikud.
NinjaZec je offline   Reply With Quote
Staro 18.10.2012., 13:28   #1027
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
Sam si sebi odg. na pitanje, uzmi Zalman Z9+
Staro 18.10.2012., 14:30   #1028
NinjaZec
Lokacija: SK/ZG
Postovi: 209
Pa nadao sam se nekim alternativama, pogotovo možda kojem jeftinijem rješenju
Staro 18.10.2012., 14:37   #1029
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
Hm..taj Zalman ti je odlicne kvalitete. Pogledaj si Spire Maverick ( al ako te svjetla smetaju promjeni prednji vent ) Imas ga za nekih 220kn.
Ili gledaj polovni Coolermaster 690 ( bez pleksija )
Staro 18.10.2012., 14:43   #1030
lolofuxy
lolofuxy's Avatar
Datum registracije: Jun 2010
Postovi: 3,319
Ak imaš love za Zalman Z9+ idi na njega, ak gledaš koju kunu uštedit, a opet ima slodino opremljeni case gledaj ovoga - specifikacije.
lolofuxy je offline   Reply With Quote
Staro 20.10.2012., 05:07   #1031
Rade0n
Datum registracije: Jun 2012
Postovi: 820
A ovo: Thermaltake Commander MS-III
358 kn, cini mi se kao dobra kupnja, 36 mjeseci garancije takodjer je plus, a tu je i USB 3.0.
Zadnje izmijenjeno od: Rade0n. 20.10.2012. u 05:13.
Rade0n je offline   Reply With Quote
Staro 20.10.2012., 07:54   #1032
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
Autor Rade0n Pregled postova
TT su debelo precjenjena kucista, nebih to preporucio. Idi na Zalmana i neces falit
Staro 29.10.2012., 18:45   #1033
perica980
Lokacija: bih
Postovi: 67
Nasao sam upute kako izracunati koliko mi jak UPS treba. Pise da prvo otvorim kuciste i vidim snagu napojne jedinice i pomnozim volte i ampere da bih dobio VA.
PC -> 230v x 5Y = 1150VA
Zatim da to isto uradim za monitor i ostale uredjaje koje zelim prikopcati.
Monitor -> 240V x 1A = 240VA
Printer -> 240V x 2.5A = 600VA
Ruter -> cca 12VA
U konacnici sve ovo saberem i dobijem da mi treba UPS snage 2242VA.
Gledam ponude i vecina ih se krece od 550VA do 1200VA.
Mora da sam ovo nesto pogresno shvatio i sracunao. Moze li mi itko pomoci?!
perica980 je offline   Reply With Quote
Staro 29.10.2012., 18:54   #1034
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Kakve to ima veze sa ovom temom?
Uzmi si APC Back ES 550VA ili neki drugi APC
Staro 30.10.2012., 11:55   #1035
perica980
Lokacija: bih
Postovi: 67
Sorry, ja procitao naziv teme Koji ups kupiti. prebacujem...
Staro 12.11.2012., 15:27   #1036
tomo808
Datum registracije: Apr 2012
Postovi: 1
Pozdrav, molim preporuku za mini tower kućište mATX do cca 300- 350 kuna
tomo808 je offline   Reply With Quote
Staro 12.11.2012., 15:50   #1037
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Fractal Design Core 1000 ako ga jos negdje nadjes
Staro 12.11.2012., 21:51   #1038
Matta
El Mattador
Matta's Avatar
Lokacija: <->
Postovi: 1,944
Arc Mini ili Define Mini ?
U njega ide ASRock Z77 Extreme4-M i i5 3570k.
Posto ce kuciste biti u prostoru koje nikad nije tiho nije mi bitna tisina. Bitno mi je dobro hladjenje posto tu ljeti bude i do 35 stupnjeva. Takodjer filteri za prasinu igraju vecu ulogu.
Sami izgled takodjer nebitan posto ce biti diskretno smjesten.
Matta je offline   Reply With Quote
Staro 12.11.2012., 22:05   #1039
Postovi: 8,245
Arc Mini
Samo neki dobar hladnjak na proc i teraj. Define je isto super kućišta, al možda malo prerestriktivno.
Staro 12.11.2012., 23:24   #1040
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Autor Matta Pregled postova
Ak ti je bitno to sto si napisao ni jedno ni drugo. Ima midi kanti sa dokazanim perf. koliko hoces. Nisu mozda tak kvatitetni ili vizualno privlacni ali hlade bolje. CM 690, jeftiniji corsevi i sl. su kucista koja su orijentirana prema perf. a to je kaj trazis, osim ak nekim slucajem trebas bas mini kuciste. Onda je prvi super.
Zadnje izmijenjeno od: MAGARAC. 12.11.2012. u 23:31.
Staro 12.11.2012., 23:46   #1041
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
Arc mini je kuciste s vise propuha, ali ima jednu manu..
Kuciste nema naprijed filter koji se lako vadi, vec sva prasina ostaje na prednjoj masci kucista, i vidi se i nije bas lijepo, a da bi to ocistio, moras skinuti prednju masku, a da bi nju skinuo, moras odspojiti ventilatore.. Sto je muka ako imas slozen kejbljob, moras sve stranice skidat.. Mogu se i ventovi skinuti, ali malo teze ide i bojim se da ce drzaci pupucati.. Tak da nisam nikad skidao prednju masku, vec samo prodjem usisavacem po toj prasini, ostane jos mali trag u onoj pjeni ali ok..
Dok su na Defineu pravi filteri koji se daju vaditi i nevidi se prasina dok se neotvore oni mali poklopci iza prednje maske. Ali ta prednja maska je preplasticna, imao sam Define R3, nije bas lijepo kao na slikama. Nakupi se prasine po tome i vrlo lako se moze ogrebat (meni je na podu) i tak
Unutrasnjost je gotovo identicna.. Jedino spuzva na defineovim stranicama i jedan otvor manje na vrhu kucista za ventilator.. Ali spuzva i nije od neke koristi jer se osjete i cuju diskovi unutra (WD black).. Isto tak je i u Arcu, ali SSD je utisao cijeli komp
Trenutno imam Arc mini Nisam htio Define mini jer mi se ipak ovaj cini malo ljepsi I na kraju sam zadovoljniji s Arcom minijem nego s Defineom R3.. Mozda je mini nest bolji od R3, ali to je skoro isto samo umanjeno..
Drugih mATX kucista da na nesto lice nema u toj cjenovnoj kategoriji.. Tj, nije mi se nista svidjalo osim fractala
Campeonato je offline   Reply With Quote
Staro 12.11.2012., 23:57   #1042
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
a imal' neko informaciju kad ce R4 napokon?
Msi x79a GD65
Intel i7 3930k @ 4.7 1.4V
4x 4GB Kingston 1866 9-11-9
Gigabyte gtx 460 1gb
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Coolermaster Stacker 831
HP LP2065 / LG IPS231P
Windows 7 Enterprise
Trenutno nepostojeci
Staro 13.11.2012., 09:00   #1043
Matta
El Mattador
Matta's Avatar
Lokacija: <->
Postovi: 1,944
Autor MAGARAC Pregled postova
Treba mi kuciste do maksimalno 42cm visine, radi toga sam isao na Fractala. Ako znas nesto u toj dimenziji (a bolje od Fractala) slobodno preporuci.
Staro 13.11.2012., 09:11   #1044
Postovi: 8,245
Vjerujem da ima kućišta u kojemu je lakše ohladit komponente od recimo Definea, al Arc je totalna suprotnost Defineu što se hlađenja tiče i u rangu je 690 po tom pitanju.
Staro 13.11.2012., 10:07   #1045
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Define je dobar,samo se metnu bolji ventovi naprijed, a orginal metnes za ispuh...
Staro 14.11.2012., 14:25   #1046
vision19
Datum registracije: Jan 2011
Lokacija: Vinkovci / Njemačka
Postovi: 494
Autor antrax Pregled postova
Tu negdje sam pročitao da bi trebao kao 'idući tjedan' ili vrlo brzo.
No, htio sam pitati jel itko zna okvirno kolika bi cijena bila jer mi je to kućište predobro
"Anyone who has never made a mistake has never tried anything new." A.E.
vision19 je offline   Reply With Quote
Staro 14.11.2012., 14:28   #1047
Postovi: 34,085
Vani 100 EUR, što znači kod nas jedno 1k kn.
http://www.techpowerup.com/reviews/F...fine_R4/6.html
Staro 14.11.2012., 14:37   #1048
vision19
Postovi: 494
Ajoj, paprena cijena. Očekivao sam (točnije nadao se) oko 800 kod nas da će biti
Staro 22.11.2012., 00:16   #1049
kiki86
Tehničar
Datum registracije: Dec 2011
Postovi: 1,097
namjeravam kupit drugo kuciste, pa sam nabasao na cm 690 za 300kn. sad me zanima kakvo je kuciste? prvenstveno mi je bitno da je kuciste dobro ventilirano, buka mi nije bitna, temperatura prije svega. Zanima me dal u njega komodno stanu veći hladnjaci tipa noctue, mugena i sl?
Staro 22.11.2012., 01:11   #1050
skitnica
Debeli gad
skitnica's Avatar
Lokacija: Makarska
Postovi: 843
Plusevi: sve ti stane u njega i kuciste je dobro provjetreno.
Minusi: ruzno, relativno bucni stock ventilatori i sakupljac prasine.
skitnica je offline   Reply With Quote
