Administrator
Lokacija: Sesvete
Postovi: 15,963
Rat konzola-PS3
Za nestrpljive, evo malo detaljnijih specifikacija: CPU Cell Processor PowerPC-base Core @3.2GHz 1 VMX vector unit per core 512KB L2 cache 7 x SPE @3.2GHz 7 x 128b 128 SIMD GPRs 7 x 256KB SRAM for SPE * 1 of 8 SPEs reserved for redundancy total floating point performance: 218 GFLOPS GPU RSX @550MHz 1.8 TFLOPS floating point performance Full HD (up to 1080p) x 2 channels Multi-way programmable parallel floating point shader pipelines Sound Dolby 5.1ch, DTS, LPCM, etc. (Cell- base processing) Memory 256MB XDR Main RAM @3.2GHz 256MB GDDR3 VRAM @700MHz System Bandwidth Main RAM 25.6GB/s VRAM 22.4GB/s RSX 20GB/s (write) + 15GB/s (read) SB< 2.5GB/s (write) + 2.5GB/s (read) System Floating Point Performance 2 TFLOPS Storage Detachable 2.5" HDD slot x 1 I/O USB Front x 4, Rear x 2 (USB2.0) Memory Stick standard/Duo, PRO x 1 SD standard/mini x 1 CompactFlash (Type I, II) x 1 Communication Ethernet (10BASE-T, 100BASE-TX, 1000BASE-T) x 3 (input x 1 + output x 2) Wi-Fi IEEE 802.11 b/g Bluetooth 2.0 (EDR) Controller Bluetooth (up to 7) USB 2.0 (wired) Wi-Fi (PSP) Network (over IP) AV Output Screen size: 480i, 480p, 720p, 1080i, 1080p HDMI: HDMI out x 2 Analog: AV MULTI OUT x 1 Digital audio: DIGITAL OUT (OPTICAL) x 1 Disc Media CD PlayStation CD-ROM, PlayStation 2 CD-ROM, CD-DA, CD-DA (ROM), CD-R, CD-RW, SACD, SACD Hybrid (CD layer), SACD HD, DualDisc, DualDisc (audio side), DualDisc (DVD side) DVD: PlayStation 2 DVD-ROM, PlayStation 3 DVD-ROM, DVD-Video, DVD-ROM, DVD-R, DVD-RW, DVD+R, DVD+RW Blu-ray Disc: PlayStation 3 BD-ROM, BD-Video, BD-ROM, BD-R, BD-RE |
Head Of The Radio
Datum registracije: May 2003
Postovi: 672
Ne bih se složio ja još uvijek mislim da je X360 jači jer ATi GPU je neš amblivbl ipak je tu 48 pipelina i 10Mb eDRAM(a pravi eksperti znaju što ovaj eDRAM znači ![]() P.S Tak i tak budem sve kupil ali X360 prvo.A jedna stvar kod tih svih novih konzola mi je najzanimljivija Revolution(NINTENDO) će koristiti(napokon) standardni medij a to znači napokon i nitendo kod gusara.(Zelda za 20kn ![]() ![]() |
Head Of The Radio
Postovi: 672
Đojstiki su faking banana i po izgledu i u prenesenom značenju ![]() ![]() ![]() ![]() |
#9 | |
Lokacija: Zabok
Postovi: 3,385
PS3 ne koristi eDRAM za grafiku ali zato koristi XDRAM za sistem koji bi trebao biti veće propusnosti nego DDR3 700Mhz kod Xboxa. Također je broj jezgri procesora duplo veći i ostvaruje se duplo više FLOPS-a. Gigabit ethernet, Fi-Wi, Bluetooth, 6 xUSB ... možeš uštekat što hoćeš. BlueRay optikaner se također spominje. Što se tiče grafike ne vjerujem da će biti lošija od Atija s obzirom da su na tome radili Nvidia, Sony i Toshiba (proizvodnja). Kažu da bi trebala biti jača od 2x6800Ultra u SLi modu pa ćemo vidjeti dal je to tako. Ja prednost dajem Sony-u. |
Postovi: 1,116
u prednosti ce biti : na zapadu, ko se pojavi u pravom trenutku (pred bozic) na istoku, za koga budu dobavljive igre po popularnoj tarifi ![]() olakotna okolnost za oba slucaja kompatibilnost u rikverc sto se tice snage, obije je imaju u ovom trenutku vise nego dovoljno (ako je istina to sto pise....)
SS |
nemam kaj napisati
Lokacija: Međimurje
Postovi: 1,303
Ak se ne varam PS3 bi druge godine trebao doći u Hrvatsku. Kolika cijena bi se mogla očekivati? |
#12 | |
Postovi: 1,606
![]() http://www.gamespot.com/news/2005/05...s_6125423.html |
#14 | |
Head Of The Radio
Postovi: 672
PS2 ti je imao dva pomoćna vektorska procesora samo u Cell inačici su oni puuuuno prošireni x4 + 3 Gigaherca. A ovo s propusnosti XDRAMA ti vrijedi samo za Celll ali ne i za Grafikčku a kod atija ti tih 'sitnih' 10Mb ostvarduje brandwith od 256 Gb a sama XDR memorija 25.36 Gb. A što se tiče flopsa ja neznam zašto su svi zapeli za flopse pa proc u PS2 ima 6.4GFLOPS-a što ti je jednako P4 na 2.9GHz a Xbox1 ti je imao 380MFLOPSA što je otprilike jednako Duronu na 600MHz tak da manimo mi te flopse jer to se nikako ne može izmjerit već sony i Ms daju marketing podatke kak im se hoće... ![]() Da budem iskren nekako mi se Nitendo sada čini u najboljoj poziciji... |
