Staro 23.09.2012., 22:43   #1321
dinos3
Dino Saur
dinos3's Avatar
Datum registracije: Jan 2012
Postovi: 941
http://www.randomphantasmagoria.com/...nexus-s/i9023/ sa 4.1.1 bi se trebao vratiti na 2.3.6.. zaina me ako bi skinuo flashable zip i flashao dali bi nesto potrgao ? zato jer je drugciji Bootloader...
dinos3 je offline   Reply With Quote
Staro 24.09.2012., 01:48   #1322
spawn
spawn's Avatar
Postovi: 8,504
Ne. Doduse, nisam vracao s 4.1.1 ali sam vracao s icsa i nije bilo problema Samo ces downgradeati bootloader. Skini 2.3.6 full rom
Staro 24.09.2012., 01:51   #1323
dinos3
Dino Saur
dinos3's Avatar
Postovi: 941
i mislio sam da ce tako biti, hvala..
Staro 24.09.2012., 20:36   #1324
dinos3
Dino Saur
dinos3's Avatar
Postovi: 941
samo da te jos pitam prije flashanja, znaci udem u cwmr od wipea samo da napravim factory reset ? i onda flasham rom.. ili bi jos nesto trebalo wipeat?
Staro 24.09.2012., 21:38   #1325
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
Ja sam na S-u wipeao sve i data i dalvik i cache partition i nikad problema. Ovdje imas full 2.3.6 http://nexusshacks.com/nexus-s-hacks...0ti9020ai9023/
Staro 24.09.2012., 21:58   #1326
Dottore
Dottore's Avatar
Postovi: 7,711
Autor dinos3 Pregled postova
Misliš na orginalni rom? Nema potrebe kad flashaš preko Odina. Ako na custom na custom ( u pitanju drugi rom onda Wipe, cache i dalvik )
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 24.09.2012., 22:21   #1327
dinos3
Dino Saur
dinos3's Avatar
Postovi: 941
@xulos ovaj moj flashable je unrootan stock rom.. to cu full wipeat (kao sto si ti reko) i flashat i nosim u VIP ujutro..
@dottore : preko cwmra flasham..
Staro 25.09.2012., 03:52   #1328
Mar
Suit up!
Mar's Avatar
Postovi: 5,977
Fala na info, ali ima li to smisla sad ili bolje čekat službeni update. Valjda bi trebao ubrzo doći?
Ja bi najradije službeni, ali bez bloatwarea koji se ne može maknut. Koji će mi vrag Twitter, Google+, Samsung Apps i slične gluposti...
Autor HCS Pregled postova
Ja sam stavio ipak German 4.0.4, tu ti je sve objasnjeno. Mozes cak i noviji odma stavit, dosao je neki dan update nekih sitnig 5mb. Taj soft koristi novi launcher, od S3, galerija je nova, i opcenito dosta to brze radi, kazu ljudi uvjerljivo najbolji stock ICS za Notea, slazem se.
Ja sam prvo gore fleshao stock German GB preko Odina, nije se htio opce startat kak treba jer sam prvo morao u recovery wipe data wipe cach (oslo mi jedno 2 godine zivota) Nakon toga, flashah opet preko Odina taj German 4.0.4 i to bi trebalo biti to. Samo pazi da ne radis nikakav wipe ili reset na njemu, jer i on i dalje ima brick bug.
- Barney Stinson
Staro 25.09.2012., 14:13   #1329
DANCI
Postovi: 735
Imam jedan upit uz vezi Samsung Fit S5670 kupljen za bonove kod TELE2, gore je
ServiseMode
[1] Sellout SMS: OFF
[2] PCode: GT-S5670HKATWO
[3] Mode: Prod
Version
PDA: S5670XWKS4
PHONE: S5670XWKS3
CSC: S5670OXFKQ4
Mene zanima da samo rootam iz jednostavnog razloga da mogu istaliravati aplikacije na SD karticu jer je interna sranje kada imas svega 180mb, a već na 160mb veli da je puna memorija. I za drugo mi praktički ništa netreba da ga nebacim u viječna lovišta.
Mob je pod garancijom još dobrih godinu i pol dana, i sad mene zanima kako da ga samo rootam i da tu mogućnost povratim nazad na stock tj. unrootam u slučaju kvara radi reklamacije.
Nažalost na prvoj stranici uopće nema spomena oko Samsung Fit S5670 niti sam našao narednih 20 stranica na ovoj temi. Tako da ja neznam jel je to svejedno ili nije što se tiće postupaka.
Recite na što moram posebno obratiti pažnju prije rutanja i što treba poslije napraviti da bi se moglo nositi na reklamaciju zbog kvara uređaja ?
Imam SD karticu SanDisk class10 od 8gb i podržava čitanje 30mb/s, koju sam ubacio ovako samo za probu i radi.
DANCI je offline   Reply With Quote
Staro 25.09.2012., 14:27   #1330
spawn
spawn's Avatar
Postovi: 8,504
Ako ces samo rootati,skini si superoneclik 2.3.3 i rootaj telefon,a kasnije mozes istiom napraviti unroot. Postoji i jedan zip file s kojim takodjer mozes napraviti root i unroot. Vise o tome OVDJE
Staro 25.09.2012., 15:15   #1331
DANCI
Postovi: 735
Znači ovim postupkom netrebam ići na to da moram obavezno bekapirati jer stock room nediram ?
Gdje da skinem taj superoneclik 2.3.3 ?
Ili je možda bolje da upotrijebim te .zip datoteke ?
inače imam Android 2.3.5
Zadnje izmijenjeno od: DANCI. 25.09.2012. u 15:20.
Staro 25.09.2012., 15:35   #1332
tutix
tutix's Avatar
Postovi: 4,069
Pozdrav
Ovak, frend ima problem sa i9000 iz VIP-a. Uglavnom mobitel je u svrhu otključavanja na sve mreže "silovan" sa CM 9 nightly inačicom iz petog mjeseca (znači nedovršenom). Sad je to dosta nestabilno pa bi on to sve vratio nazad na stock. Vidio sam da se to prilično lako riješi ODIN-a ali me zabrinjava taj unlock, zna netko više o tome? Mislio sam stavit Froyo iz VIP-a, updateat preko KIES-a na GB i onda šta treba već za taj unlock (root?).
Mob je star preko godinu dana i ima garanciju, ali nema računa pa su ga iz VIP-a glatko odbili. Može li se otključat recimo sa IMEI i preko eBaya pa da je softverski neovisno?
Staro 25.09.2012., 16:20   #1333
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,890
Ima unlockova za taj mobitel gdje god hoćeš, doslovno One-click. I sve je besplatno.
Staro 25.09.2012., 17:19   #1334
DANCI
Postovi: 735
Autor tutix Pregled postova
Pozdrav
vidio sam na onaj google play da ima app za otkljucavanje
Staro 25.09.2012., 18:03   #1335
spawn
spawn's Avatar
Postovi: 8,504
Autor DANCI Pregled postova
Imas na XDA superoneclick. Svejedno je sto koristis,ja samo koristio oba i oba rade. I root i unroot. Superoneclick ne radi na 2.3.6 i 2.3.7.
Pozdrav
Stavi stock Froyo,rootaj ga i preko marketa skini nekakav sgs unlock i pokreni.
Autor thezero Pregled postova
ajde molim te ako ti se nekad bude dalo da ga uppaš pa mi ovdje ili na pm šibneš link..
bio bih ti jako zahvalan...
Uploadan Stock ICS za N7000 nebrendiran.
Zadnje izmijenjeno od: spawn. 27.09.2012. u 16:56.
Staro 28.09.2012., 00:42   #1336
thezero
thezero's Avatar
Postovi: 238
Hvala najljepša, imaš pivu kad se vidimo
thezero je offline   Reply With Quote
Staro 28.09.2012., 01:20   #1337
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Autor Mar Pregled postova
Ko to zna, i ako dode doci ce "obican" 4.0.4 za slovence, bez S3 launchera. Mene je najvise iritirao deep sleep bug prisutan na 4.0.3 svaki put kad se odspoji s izvora struje.
Ovako imam German ICS i on ce prvi dobiti official JB kao sto je i dosad opcenito najvise updatani ICS. Nije mi jasno zasto je slo jos uvijek na 4.0.3, valjda jedini u svijetu jos.
Staro 01.10.2012., 18:38   #1338
NenadS
Datum registracije: Nov 2011
Lokacija: Beograd
Postovi: 37
Drug mi ima Galaxy Note i nedavno je uradio update na ICS, ništa root, ništa CWM, sve stock i OTA update.
Uradio je factory reset nakon upgrade-a, a problem je nastao nakon nekoliko dana, neće ponekad da se uključi. Onda se magično uključi kada pokuša nakon izvesnog vremena. Pokušavao je samo vađenje baterije. Nosio je dva puta u VIP, tamo se uvek uključi. Hardver, ili softver? Inače, power dugme uvek reaguje kada je tel uključen.
NenadS je offline   Reply With Quote
Staro 06.10.2012., 14:50   #1339
CsH_58
CsH_58's Avatar
Lokacija: Dublin
Postovi: 178
Bok, zanima me koji je najbezbolniji način za preć sa iPhona na GS3? Naletio sam na ovaj Easy phone sync pa me zanima ako je to netko radio i dali je sve prošlo ok? Znači ja bi prebacio sve, ne samo kontakte, već poruke i slike.. ?
edit: evo sad sam prosurfao još malo, znači napravim backup iPhona, prodam ga (recimo), kupim samsung gs3, uključim ovo čudo, syncam sa iTunesima i to je to.. nemogu vjerovat.. ako netko može potvrdit da je simple as that, stavljam iphone u oglase..
All I'm gonna do is just go on, and do what I feel..
Jimi Hendrix
Zadnje izmijenjeno od: CsH_58. 06.10.2012. u 14:56.
CsH_58 je offline   Reply With Quote
Staro 07.10.2012., 08:03   #1340
Postovi: 34,092
Možda bi ti bilo pametnije da prvo kupiš novi mob, sve prebaciš, a tek onda prodaš iPhone. Da ne bi bilo kasnije čupanja kose i sl.
Staro 09.10.2012., 21:29   #1341
CsH_58
CsH_58's Avatar
Lokacija: Dublin
Postovi: 178
Autor coconut Pregled postova
Slažem se u potpunosti, samo mi fali 3500 kn, pa zato i pitam..
Jimi Hendrix
Staro 09.10.2012., 21:32   #1342
hrki
Lokacija: ZG - VŽ - KR
Postovi: 279
a kaj bi ti prebacio kontakte, slike, muziku ili?
pa napravi svega backup i onda ubaci u sgs3
hrki je offline   Reply With Quote
Staro 09.10.2012., 21:49   #1343
CsH_58
CsH_58's Avatar
Lokacija: Dublin
Postovi: 178
Vidio sam da se sa easy phone sync mogu prebaciti, poruke, kontakti i slike, za drugo mi nije bitno.. samo ne znam koliko je pouzdano, pa zato pitam.. mada mislim da neću tako brzo do sgs3, ali dobro je znati iskustva drugih ako je netko to radio..
Jimi Hendrix
Staro 10.10.2012., 20:46   #1344
rodriguez
rodriguez's Avatar
Postovi: 2,067
Igrao se sa S3 maloprije, to je čovjeće cigla, preveliko je to. I galaxy nexus mi je isto too much.
4 incha majka.
Thinkpad T430 running
Staro 10.10.2012., 21:10   #1345
Dottore
Dottore's Avatar
Postovi: 7,711
Šteta, meni je taman Galaxy Nexus 4.65" a S3 4,8" tu negdje taman. Veliku šapu imam a rezultat da brže plivam kao Majklo Felps Fap , fap
Oboje su vrhunski aparati. Ali, imam veliki dojam da plastika na Gnex ( skraćeno Galaxy Nexus ) kvalitetnija.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 11.10.2012., 06:31   #1346
Postovi: 34,092
SGS3 Mini nema veze sa svojim starijim bratom osim sličnog dizajna. Šteta. Osobna prognoza: fail.
http://www.engadget.com/2012/10/10/s...xy-s-iii-mini/
Staro 11.10.2012., 09:56   #1347
Ivo_Strojnica
PRO
Postovi: 4,890
4 incha majka.
potpuna istina, meni je to isto savršena veličina moba.
ako bude cijena, kao šta govore da će biti, uistinu je fail.
Staro 13.10.2012., 15:04   #1348
Neo-ST
Neo-ST's Avatar
Postovi: 8,601
Koji modem preporučujete za SGS2, trenutno imam BVLP7 ali mi se čini da se čudno ponaša. Brzina i ping 3G-a mi variraju previše...
Staro 18.10.2012., 00:42   #1349
frizbi
Datum registracije: Mar 2009
Lokacija: osijek
Postovi: 80
Imam problem, ne mogu slati MMS, a problem je jako neobičan..
Mob: Galaxy S2
android verzija: 4.1.2
baseband: KPA
Kernel: Dorimanx - v7.0 - JB
Rom: Paranoidandroid 2.21
mreža: t-mobile
Naime nikako ne želi poslati MMS preko mobilne mreže. Jedino što se uspije je jako mala slika (logo) veličine 2-3 KB i to ponekad, a čim se šalje nešto veće samo stoji na ''sending'' i kao da dođe do prekida data mreže. Zanimljivo je, da kad mi je spojen na wlan, MMS uredno prolazi (iako MMS ne bi trebao imati nikakve veze s njim), ali jednostavno šalje, čim se prebacim na 3g opet ništa.. to mi se počelo događati prvo na custom romu ICS i sada nastavilo na JB. Provjerio sam sve, apn-ovi za Internet i MMS su uredno postavljeni, SMSC je ok. Probao sam flash-at i drugi baseband ali i dalje isto, SIM kartica je provjerena - stavio sam drugu u svoj mob. koja provjereno radi u mom mobu ne radi. Sa SZK sve provjereno..
Stvarno više nemam ideja, ako je tko imao sličnu situaciju, pliz pomoć..
frizbi je offline   Reply With Quote
Staro 27.10.2012., 17:31   #1350
Shockre
Shockre's Avatar
Lokacija: Dublin
Postovi: 582
danas/sutra/prekosutra cu vjerojatno uzet titanuim grey GS3 prek njuskala, treba mi za vip mrezu. zanima me ak je lockan na t-mobile npr, jel ja to mogu rijesit bez problema? i jos me zanima ovo updateanje na andoridima, vidim da ide po operaterima, jel onda svejedno kojeg uzmem il ne? naravno, ocu odmah najnoviji software. i jos jedno, zasad ne mislim rootat nit stavljat custom firmware dok ne skuzim android kak spada (dosad sam samo iOS koristio), ali kasnije ak me pukne, jel to mice garanciju ili je ko jailbreakanje kod iPhonea - vratim normalni software i ko da nis nije bilo? i jos samo, kolko sam skuzio ima hrpa bloatwarea od operatera i samsunga, jel ja to mogu bez problema maknut il moram stavljat drugi rom gore il kak?
pun mi ku*ac iPhonea nakon 4 godine, a i peticu su usrali, grebe se nenormalno. a dok lumie dodu i vidim oce sta bit od tog ce proc 2 mjeseca, neda mi se cekat vise..
Zadnje izmijenjeno od: Shockre. 27.10.2012. u 18:43.
Shockre je offline   Reply With Quote
