Staro 21.08.2012., 10:29   #1
konig_karl
lurkerus maximus
Datum registracije: Aug 2008
Lokacija: V.G.
Postovi: 91
BSOD prilikom bootanja
Bok
prilikom bootanja mi se pojavi BSOD, javlja ove errore:
stop: 0x00000051 (0x0000000000000013, 0xFFFFF8A000021370, 0xFFFFF80003419EE8, 0xFFFFFFFFC000009A)
Nemam pojma do čega bi moglo biti jer nisam stavljao ništa od novog hardveraja, nisam nit nešto tweakao, ništa novo instalirano. Windowsi su friško instalirani jer sam i tjedan dana ranije imao sličnih problema. Tad sam se vodio krilaticom "jovo nanovo" jer mi se nije dalo troublešutati. Nakon reinstalacije nisam napravio backup registrya. whocrashed javlja:
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Tue 8/21/2012 07:55:19 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082112-36675-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7F1C0)
Bugcheck code: 0x51 (0x13, 0xFFFFF8A000021370, 0xFFFFF80003419EE8, 0xFFFFFFFFC000009A)
Error: REGISTRY_ERROR
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a severe registry error has occurred.
This bug check indicates there is a problem related to your registry.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
On Tue 8/21/2012 07:46:22 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082112-37128-01.dmp
Bugcheck code: 0x74 (0x2, 0xFFFFF880067B3B20, 0x2, 0xFFFFFFFFC000009A)
Error: BAD_SYSTEM_CONFIG_INFO
Bug check description: This bug check indicates that there is an error in the registry.
Najmanji je problem reinstalirati win no stvarno ne zelim raditi na tjednoj bazi pa jel imate kakav hint sto da provjerim ili sto bi moglo uzrokovati ovaj problem
CPU: AMD Athlon II x4 640
MBO: ASrock 870 Extreme3
RAM: 2x Corsair 2gb DDR3 (1333Mhz)
HDD: WD5000AAKS
VGA: Point of view GeForce GTX 460 768Mb
PSU: Corsair CX400W
Case: NZXT Source 210
Monitor: LG M2262D (22", 1920:1080)
OS: Windows 7 x64
Toshiba A200-23K
ekran: 15,4" WXGA
CPU: C2D T450 1.66 GHz
RAM: 1 Gb
HDD: Hitachi 160 Gb
VGA: HD2600 256MB
OS: Windows 7 x86
Samsung HD502IJ@IcyBox
Logitech Driving Force Pro
Logitech Wireless Desktop MK710
Sony NWZ-E443 + Koss SparkPlug
Creative WP 350
Nokia N97
Scott Sportster P3 2010
Frame: New Sportster Frame Alloy 6061
Fork: Sun tour NEX 4610 V2 HLO, Lockout susspensionfork 1 1/8, 63mm travel, Integrated 700C
Front Derailleur: Shimano Deore
Rear Derailleur: Shimano Deore RD-M592 / Shadow Type
Shifters: Shimano Deore SL-M590
Chain set: Shimano FC-M443-8-S
Chain rings: 48×36×26 Teeth
Bottom Bracket: Shimano BB-ES-25
Cassette: Shimano CS-HG50-9 11-32 Teeth
Chain: Shimano CN-HG53
Pedals: Wellgo C 128
Front Brake: Shimano BR-M486 F/R 160 mm Rotor
Rear Brake: Shimano BR-M486 F/R 160 mm Rotor
Brake Levers: Shimano BL-M 486 Disc
Handlebars: Scott Sportster OS
Stem: Scott Comp
Rims: Alex XC-44 Disc
Front Hub: Scott Comp Disc CL
Rear Hub: Shimano FH-RM65 CL
Spokes: stainless black, 14G / 2mm
Front Tyre: Schwalbe Smart Sam 700×35C
Rear Tyre: Schwalbe Smart Sam 700×35C
Seat post: Scott Sportster/Solution
Weight: 13.10kg
konig_karl je offline   Reply With Quote
Staro 21.08.2012., 11:10   #2
ShanTech
Datum registracije: Apr 2011
Postovi: 3,784
Staro 21.08.2012., 21:03   #3
konig_karl
lurkerus maximus
Lokacija: V.G.
Postovi: 91
radi se o racunalu imena PC (vidi se u potpisu...), os = windows 7 sp1
HDD: WD5000AAKS
PSU: Corsair CX400W
OS: Windows 7 x64
Toshiba A200-23K
ekran: 15,4" WXGA
RAM: 1 Gb
HDD: Hitachi 160 Gb
VGA: HD2600 256MB
OS: Windows 7 x86
Creative WP 350
Nokia N97
Stem: Scott Comp
Weight: 13.10kg
