Staro 25.07.2012., 14:15   #9811
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,722
Autor fanATIk Pregled postova
Tek sad si ih pogledao???
I onda daš istu ocjenu dark knightu kao i misterioznim znakovima???
Čudan ukus, al dobro, tvoj je ukus.
Dark Knight samo gledao u kinu kada je izašao, i ovo mi je sveukupno 3. put.
Prvi dio nisam nikad gledao, mislio sam da jesam, no pomiješao sam.
Pa i nije baš ista ocjena... Signs (2002) - 7/10, dobar-vrlo dobar (6.7), Dark Knight mi je vrlo dobar, cca 7.4
MMA
Staro 25.07.2012., 15:16   #9812
vranjba
vranjba's Avatar
Datum registracije: Aug 2009
Postovi: 613
The Dark Knight je po meni debelo precjenjen film, ne mogu vjerovat da je 8. na listi svih vremena po imdb-u. Bolji su mi Burtonovi batmani pa i Batman Begins. Ovaj najnovij nisam još gledao, a i ne žurim se.
CPU: AMD Phenom II X2 545 @X4 B45 + AC Freezer 64 Pro PWM
MBO: Asrock a780GXH @ bios 1.70
RAM: Kingmax 2x2GB PC2-8500
VGA: Sapphire HD5570 1GB
Zvučna: Asus xonar d1
HDD: WD6401AALS + WD2000JB + WD3200AAJS
PSU: Corsair cx400W
Case: Gigabyte GZ-X6
Keyboard: Logitech mk520 + Microsoft Natural Wireless Mouse 6000
Daljnski: Mce ir
Zvučnici: Swans d1080mkii 08
Monitori: Philips 220SW + HP L1950g
TV: Panasonic TX-P50C3E
AIO: HP Deskjet F4280
OS: Windows 7 x64
HP Compaq nx7010
CPU: Pentium centrino 2.0 GHz
RAM: 1gb + 512mb PC2700
VGA: ATI Mobility Radeon 9200 32mb
HDD: wd 40 GB
OS: Win XP SP3 x32
CPU: Pentium 3 1.0 GHz + Glacialtech igloo 2520
MBO: Intel D815EFV
RAM: 2x 256mb PC133
HDD: Maxtor 80gb + Seagate Barracuda 7200.7 160gb
PSU: Codegen 400W
OS: Win XP SP3 x32
PCI Lan: Linksys cisco gigabit EG1032 v3
Routher: Thomson ST780i WL
Net: T-com Flat
Acernote lite 350pc
CPU: Pentium 100 MHz
RAM: 8 mb edo onboard
VGA: chips&tech f65545
HDD: ibm 540 mb
OS: win 95
CPU: pentium 166 MHz
MBO: ga 586vx rev 3.37
RAM: 4x16 mb edo ram
VGA: Ati 3D rage II +dvd 4 mb
HDD: quantum fireball se2.1a 2.1 gb
PSU: seasonic ssa-200g
Monitor: Acer 13"
OS: dos 6.22
vranjba je offline   Reply With Quote
Staro 25.07.2012., 15:17   #9813
syss
syss's Avatar
Postovi: 10,805
potpis... begins mi je odličan, a dark night je jedan od rijetkih filmova koji me je uspio uspavati i to jedno 2 ili 3 puta.
Staro 25.07.2012., 15:50   #9814
panda505
panda505's Avatar
Lokacija: Beertopia
Postovi: 2,013
pa ne gledaš svaki film isti mjesec kad izađe, previše bi toga bilo
ja sam isto Begins tek pogledao jučer, a za koji dan ću The Dark Knight, pa onda u IMAX zadnji dio
54' / 74' / 90' / 2014
Staro 25.07.2012., 16:42   #9815
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,722
Begins me se nije dojmio tako, očito radi Katie Holmes i Liam Neeson koji mi nikako nisu sjeli u filmu, što karakterno što ulogom. Vjerojatno ću u IMAX pogledat 3. dio zato sam išao pogledat sada 1. i 2. dio tako da mogu povezati priče... Iako me više vuče Spiderman, koji sam gledao barem 12 puta, sva tri djela.
MMA
Staro 25.07.2012., 17:59   #9816
Igorr
Flajing super šiiiip
Igorr's Avatar
Lokacija: Zd -- Zg
Postovi: 1,714
Pogledah novog spidermena - meni je cisto ok ispao, moguce zato sto su mi prosli spidermeni bili s*anje. Dao bi mu nekih 7.5, malo me i nasmijao ali sto je najbitnije zabavio me. Preporuka!
Pogledah i Ted-a - stvarno ima genijalnih fora, pa cak i onih s kojima se mozes poistovjetiti (kad ga lik okine nakon odlaska doticne cure ), i dajem mu cistih 8. Mozda sam pod utjecajem jer u zadnje vrijeme nema nesto kvalitetnih komedija pa bi u skladu s time i ocjena trebala biti manja, ali ni tad definitivno ne bi pala ocjena ispod 7. Preporuka!
5.1.4 setup:
Zvučnici - 2x Arendal 1723 S monitors, 1x 1723 S center, 4x 1961 height, 2x 1961 surround, XTZ 12.17 EDGE
Amps - Marantz Cinema 40 + ROTEL RMB-1585
Igorr je offline   Reply With Quote
Staro 25.07.2012., 18:07   #9817
maker1
Datum registracije: Mar 2012
Lokacija: na internetu
Postovi: 0
Danas sam malo čeprkala među starim filmovima i listajući 1997 godinu pronašla neke jako kvalitetne filmove koji su svakako vredni pomena, i dobitnici mnogih nagrada, i zaslužuju preporuku svakako. Ukoliko niste, pod OBAVEZNO pogledajte sledece filmove:
Life Is Beautiful - Život je lep
Boogie Nights - Noći bugija
Face/Off - Čovek bez lica
Good Will Hunting - Dobri Vil Hanting
maker1 je offline   Reply With Quote
Staro 25.07.2012., 18:49   #9818
listerstorm
listerstorm's Avatar
Datum registracije: Apr 2011
Postovi: 1,431
U 1997. svakako treba spomenuti i L.A. Confidential.
Staro 27.07.2012., 14:19   #9819
ivan77
The Dark Knight Rises - 10/10 film je vrh! Najbolji Batman i definitvno film godine! Onaj IMAX mi je malo preglasan..al to nije stvar filma.
Phantom Soldiers 1987
- 5/10 , ugodan povratak u 80 te i hladnoratovske akciće-
Staro 28.07.2012., 02:15   #9820
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,763
The Dark Knight Rises - imho zasluzena ocjena na imdb-u, necu se sloziti da je najbolji Batman sveukupno - drugi najbolji da ,
no film sam po sebi je najspektakularniji u Batman serijalu definitivno. Jedino mi zao sto nisam gleda u Imax-u, fckin Cinestar
Staro 28.07.2012., 08:12   #9821
domis
Lokacija: Hrvatistan
Postovi: 4,165
samo kad si malo rezimiram, tok price mi je isti kao i na prijasnja dva naslova, odnosno...uvod u pricicu, prvi veliki "fajt", betmen izgubi bitku (fizicki ili psihicki) i onda se vrati ko feniks iz pepela
btw...jedna najava me razveselila dok sam cekal film
imho, taj batman ima mrvicu previsoku ocjenu na imdb-u, vjerojatno radi tog hype-a, ima puno boljih filmova s losijim ocijenama.
a sad, da je spektakl, bogme je...
Staro 28.07.2012., 09:23   #9822
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,722
Autor domis Pregled postova
Da da, također. Film je nedavno završen, kroz 2 mjeseca se čeka izlazak...
MMA
Staro 28.07.2012., 09:28   #9823
syss
syss's Avatar
Postovi: 10,805
nisam mogao bolje vijesti pročitati ovako ujutro
Staro 28.07.2012., 09:38   #9824
Omerta
Omerta's Avatar
Lokacija: Grobnik - Rijeka
Postovi: 3,255
Evo bome ni ja.. Na prvome sam se ježio, nadam se da ću i na drugome
Odgovoran trgovac:1, 2, 3, 4, 5, 6, 7, 8, 9
Staro 28.07.2012., 09:49   #9825
mislav_os
freak
Postovi: 2,688
Jedva čekam, prvi dio je odličan, nadam se da će i drugi biti pa makar 80% dobar kao i prvi
Staro 28.07.2012., 14:12   #9826
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,722
Pogledao:
Bel Ami (2012) - 5/10
MMA
Staro 29.07.2012., 01:48   #9827
Omerta
Omerta's Avatar
Postovi: 3,255
Upravo se vratih iz Cinestara sa Betmena.
Dok smo izlazili iz dvorane neki lik iza mene kaze: Ajme koje sranje od filma.
Morat cu se slozit sa tim likom. Laku noc
Staro 29.07.2012., 09:35   #9828
fanATIk
fanATIk's Avatar
Lokacija: Maksimir / Dugave
Postovi: 4,021
Nisam gledao, još, al frendovi koji jesu vele da je odličan. Zašto je sranje?
Asrock FM2A78M-DG3+
G.SKILL RipjawsX series 8 GB
Palit GTX 460
Corsair VS550
Thermaltake Core V21
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Canon CanoScan 4400F
Win 10
Unique case by fanATIk
Avatar BIG SIZE
Staro 29.07.2012., 10:08   #9829
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Belyy tigr
Malo ruske kinematografije. Dobra ideja ali film je tako prokleto spor. Užas.
Nije spor zbog količine priče koja bi činila neki smisleni sadržaje nego je baš generalno usporeno sve.
Staro 29.07.2012., 10:21   #9830
Omerta
Omerta's Avatar
Postovi: 3,255
I što sad na kraju, on je kao živ, pije kafu sa onom tipicom ili je to samo u glavi Alfreda? Jer baš me interesira kako je preživio nuklearku.. Čak mislim da je ipak osposobio autopilota na vozilu i prije zaljeva iskočio van.
A jbg, bolesna ocjena na IMDB-u, veliki hajp oko filma, svi govore da je odličan, ALI usprkos tome, nekako je rastegnut, razvodnjen, naporan, jedva sam čekao da završi a to nikako nije dobro, naravno.
Ima odličnih efekata, daleko od toga, i na momente je to fenomenalano ukomponirano u radnju (prvi dio filma) ali nakon PAUZE sve to pada u vodu, rastegnuto do bola.
Da se razumijemo, ja ne generaliziram, to je samo moje mišljenje, jer ipak tolika ocjena nije od par ljudi nego od većine, pa očito je većini genijalan, ali eto.
Osobno ga više nebi pogledao.
Staro 29.07.2012., 11:04   #9831
Nick7
Lokacija: Velika Gorica
Postovi: 1,537
Pogledao Lockout - 2/10. Lose, lose i lose. Cak su i CGI efekti napravljeni k'o u crticu.
S druge strane, pogledao par godina stariji film Seven Pounds - 10/10. Film me iznenadio. Ocekivao nesto 'meh', a kad ono stvarno iznenadjujuce dobar!
Staro 29.07.2012., 11:56   #9832
syss
syss's Avatar
Postovi: 10,805
seven pounds je obavezno štivo čovječe
pronađi još pursuit of happyness ili tak nekaj, isto vil smit.
Staro 29.07.2012., 12:56   #9833
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,722
Pogledao:
The Lorax (2012) - 6/10, lijep crtić sa lijepom porukom. Slatko...
MMA
Staro 29.07.2012., 15:20   #9834
m4dm4n
Does youer dewg byte?
m4dm4n's Avatar
Postovi: 1,955
Pa da, to se na samom kraju filma vidi kad se otkrije da ga je on osposobio 6 mjeseci prije već.
Autor Omerta Pregled postova
m4dm4n je online   Reply With Quote
Staro 29.07.2012., 15:45   #9835
mighty
mighty's Avatar
Postovi: 519
prvi dio nabijen akcijom, od drugog ne očekujem ništa manje...
mighty je offline   Reply With Quote
Staro 29.07.2012., 18:58   #9836
Nick7
Postovi: 1,537
Autor syss Pregled postova
I shalt check it out!
Tnx
Staro 29.07.2012., 20:43   #9837
Thorax
Doomster
Thorax's Avatar
Datum registracije: Mar 2008
Lokacija: Kraj Donji
Postovi: 400
Autor Sa_Stilom Pregled postova
Pogledao:
Upravo tak nekak, neka djeca misle malo zelenije
Pogledao i Space Battleship Yamato (2010), japanski SF, zaslužena ocjena od 6 i kusur, mogla je cijela radnja i priča biti malo bolje odrađena. U svakom slučaju, iznenadili su me prilično dobri efekti obzirom na mali budžet. Tko voli SF neka navali
CPU: AMD Athlon 640 under TX3
MBO: Asrock 870 Extreme3
RAM: 8 GB DDR3 Mushkin @ 1333, CL8
VGA: XFX HD4830
HDD: WD 6400AAKS
Monitor: Samsung 2470H
PSU: Fortron PNF 400W
OS: Win 7 Enterprise x64 SP1
Net: 12 Mbit/1,25 Mbit
Sound: Logitech X-530
CPU: Intel Celeron T3100
MBO: HP 1526
RAM: 2 GB DDR3
VGA: GMA 4500MHD
HDD: WD3200BEVT
Monitor: 15,6“ LCD
PSU: HP 65 W
OS: Win 7 Enterprise x86 SP1
Sound: Arctic Sound P281
CPU: AMD Athlon M320 undervolt @ 0.975 V
MBO: AMD 785
RAM: 2 GB DDR2 800
VGA: Integrated HD4200
HDD: Hitachi 250 GB
Monitor: LCD 15,6“
PSU: Delta Electronics 65 W
OS: Win 7 Ultimate x86
Net: 8 Mbit/768 kbit
Sound: integrated
Thorax je offline   Reply With Quote
Staro 30.07.2012., 07:52   #9838
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,722
Pogledao:
Dear John (2010) - 5-6/10, sjećam se velikih najava filma, još od prije 2 godine, stoga me film blago razočarao.
Mama Mia! (2008) - 6/10, slatki mjuzikl, komedičan pomalo, solidno
Chloe (2009) - 6-7/10, dobra-vrlodobra drama triler
Boogie Woogie (2009) - 3-4/10, zaobići
MMA
Zadnje izmijenjeno od: Sa_Stilom. 31.07.2012. u 21:19.
Staro 31.07.2012., 15:41   #9839
fanATIk
fanATIk's Avatar
Postovi: 4,021
Pogledao The Dark Knight Rises u IMAX-u.
Ocjena 8.
Bilo bi i više da nije ponekih loše napisanih i loše odglumljenih dijaloga te ponekih karaktera koji kao da su tu upali iz neke B produkcije.
Inače, dojmljiv, efektan i dostojan završetak trilogije. Poseban plus mjuzi u filmu koja mu je dala dodatnu ocjenu. Mada sam možda i pod dojmom hrpetine kilowata IMAX-ovih subova.
Osobno, možda mi je prethodnik mrvicu bolji ali i ovaj je odličan.
IMO, naravno.
Asrock FM2A78M-DG3+
Palit GTX 460
Corsair VS550
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Win 10
Avatar BIG SIZE
Staro 31.07.2012., 21:31   #9840
Vendetta
Vendetta's Avatar
Postovi: 919
I kakav krvavi završetak trilogije ?! Taman te navuku sa budućim robinom, catwoman itd... i onda kao kraj, nema više.
Bane?! Ovo nije fucking Bane, bane je životinja na steroidu zvanom Venom. Ovo je lik sa modificiranim inhalatorom za astmu, kojeg navodno udreš jednom šakom u aparaturu i on odma proplače jer mu se jedna cjevčica odspojila i previše ga boli.
Bane sa kričavim glasom koji zvuči ko neki naci švabo general iz 1940ih.
Jedini lik koji je Batmanu u stripovima slomija kičmu, a u filmu je to napravio Batmanu koji jedva hoda (nema više hrskavice u koljenima i laktovima itd...) i 8 godina atrofira zatvoren u sobi šepajući sa štapom za hodanje ko dr. House. I nakon šta se taj isti B. Wayne/Batman magično oporavi od slomljene kičme u nekoj rupi od zatvora u zapadnoj africi (!?) na način da malo radi sklekove, trbušnjake i zgibove u ćeliji, unutar 5 mjeseci se vrati i namlati Banea ko malog školarca u sceni borbe od 2 min. i to je to ?!?!!
Nimalo epski kako se kaže, nimalo. Banu je otet show na kraju sa ono sugavom tučom gdje prelako izgubi, i oduzet mu je show od strane one zenskice i njenog švicarskog nožića.
Pogleda sam i ja novog Batmana sinoć i neznam šta da kažem, film je odličan i prolete 2 ipo sata u čas. Ali imam nekakv osjecaj da nešto fali, kao da je uvod u novi film gdje se Bane vraća luđi i jači, ali ne...
Zadnje izmijenjeno od: Vendetta. 31.07.2012. u 22:10.
Vendetta je offline   Reply With Quote
