Postovi: 506
dfi lp ut problem
Dakle, imam ploču DFI lanparty UT. Kad instaliravam windowse i stavljam drivere za raid, nakon što učita drivere i veli "starting windows" (na početku instalacije windowsa) mi baci blue screen. Prvo sam mislio da je problem u raidu, pa sam maknuo raid i opet isti problem. Zatim sam instalirao bez raid-a, i bez drivera od nvidije i onda je bilo ok. Kad tako instaliram, pa kasnije u win instaliram forceware (ata driver) mi pc više neće bootati. U čemu bi bio problem? Probao sam na sva 4 sata kontrolera zaštekati, promijenio kabele, pa čak probao bez uštekanih sata kabela i diskova. |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Ovako si radio? SATA RAID building is a bit complicated on this series board, because NF4 chipset provides multi functions, e.g. SATA and IDE hard disks can be combined together to build RAID, such as Mirroring (RAID 1), Striping (RAID 0) and Stripe Mirroring (RAID 0+1) simultaneously. Please refer to the setup procedures below. 1. Enable SATA RAID in BIOS. 2. BIOS >> Integrated Peripherals >> RAID Configuration. 3. Enable the hard disks expected to be created RAID in here, save, exit, and then reboot. 4. Hit "F10" to enter RAID BIOS when the RAID detecting screen appears; follow the hint bar in the bottom of screen to create RAID. Finish setting, hit "Crtl + X" to exit RAID BIOS. 5. Hit F6 immediately when Windows Blue Setup Screen appears and put the RAID utility diskette into floppy. 6. The following step is extremely crucial, there are two essential files must be installed. Please hit "S" for installing one RAID driver, and then hit "S" again to install another one. Please be sure both of them have been installed completely, or Windows Setup will be failure with RAID. 7. After installing operating system, just check the partition in hard ware management if it is correct or not. Please treat hard disk cables as extreme caution while creating RAID, if one of them is breakage, the operating system will be messed up. And it will not boot again, all the data in the hard disk will completely disappear. No save ways available to recover back. |
Postovi: 506
Hvala na odgovoru, ali se problem dešava i bez raida. Prije mi je raid radio bez problema, i sve sam složio kako je bilo napisano. Sada kad nemam raid i nvidia drivere, radi ok. Čim instaliram nvidia drivere, win više neće bootati. |
Datum registracije: Sep 2002
Postovi: 278
Ali NF4 setu treba dodati GART drivere... Sto se RAID BIOSa tice, mozes ga i sam ubaciti u bilo koju verziju BIOSa za plocu pa flashati takav moddani. |
