Staro 05.04.2005., 15:37   #1
Pink_Floyd
Postovi: 325
Šta je ovo?
Znači dok igran cs ovo mi se dogodi samo na istom serveru!
evo tu neki report
Statistics:
Task start time: 4.4.2005 15:43:43
Task completion time: 4.4.2005 21:32:51
Settings:
Notifications:
ON
Blocking of the attacking computer:
OFF
Invisible mode:
OFF
Report:
Helkern;Attack via protocol UDP from address 202.97.174.226 to local port 1434 was successfully repelled.;4.4.2005 18:16:36
Helkern;Attack via protocol UDP from address 69.205.134.9 to local port 1434 was successfully repelled.;4.4.2005 18:50:37
Helkern;Attack via protocol UDP from address 66.78.4.2 to local port 1434 was successfully repelled.;4.4.2005 19:18:10
Helkern;Attack via protocol UDP from address 61.134.56.4 to local port 1434 was successfully repelled.;4.4.2005 20:17:57
Pink_Floyd je online   Reply With Quote
Staro 03.05.2005., 15:45   #2
tjeren
tjeren's Avatar
Postovi: 75
eh i mene to pikalo u oko pa ja ljepo ušao u trag njemu pa kaže da je to neka adresa sa dalekog istoka,bar kod mene,ugl. imao sam neki standard spyware i on niš nije našao dok nisam isprobao pest patrol i gle čuda više nema toga. znači ili neko sranje od virusa ili sl. imaš na kompu i stalno šalje tvoju IP.
tjeren je offline   Reply With Quote
