#1 | |
Jack of all, master of none
Lokacija: Matulji - Rijeka
Postovi: 6,214
Nvidia GeForce GTX 670
Gainward GeForce GTX 670 Goes Up For Pre-Order in The Philippines Citiraj:
#2 | |
ODUZIMAM VAM RIJEČ
Postovi: 13,455
http://www.techpowerup.com/165033/Re...-Pictured.html Citiraj:
Xulos :)
Postovi: 7,573
Third GK104-based Single GPU Graphics Card SKU Detailed "After GeForce GTX 680, which has all components of the 28 nm GK104 enabled, a dual-GPU GeForce GTX 690, which features two of these chips, and the GeForce GTX 670, NVIDIA is readying its third single-GPU GK104-based SKU. We know from older reports that this SKU could be named GeForce GTX 660 (Ti). A fresh report suggests that it will be carved out by disabling an entire graphics processing cluster (GPC) on the GK104 silicon, resulting in a CUDA core count of 1152; reducing the memory bus width of 192-bit GDDR5; and most likely reducing the ROP count to 24. This SKU could be used to capture a price point of around US $249, targeting AMD's Radeon HD 7800 series. "
#7 | |
Lokacija: Sinj
Postovi: 3,538
MSI's GEFORCE GTX 670 poses for the camera
![]() ![]() Sviđa mi se design ![]() Izvor
Pošten trgovac: 1, 2, 3 ,4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16 ,17, 18, 19 Zadnje izmijenjeno od: QuidZz. 02.05.2012. u 08:24. |
Vršni visioc
Postovi: 2,209
Obozavam ove "feature"...features sales politika, koju je po mom misljenju uveo gigabyte te prvi put ulozio lovu u dizajn koji je digo firmu jebeno. Mislim ono: "Ready for 3D Mark 11" ![]()
Bez potpisa. |
Datum registracije: Oct 2011
Lokacija: _
Postovi: 277
Zadnje izmijenjeno od: sapunko_HR. 02.05.2012. u 12:03. |
Postovi: 5,991
Nije tesko za izracunat u grubo koliko ce bit sporija od 680... 10tak % manji takt i oko 12.5% manje CUDA jezgri = 15 do 20% manje perf = 15% brze od gtx 580, 10% brze od 7950 Bit ce to super grafa samo nebu jeftina. |
Xulos :)
Postovi: 7,573
#14 | |
Lokacija: _
Postovi: 277
Premium spammer
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
A wild GTX 670 has appeared! http://www.gpureview.com/a-wild-gtx-...ticle-943.html Colorful GeForce GTX 670 Graphics Card Pictured http://www.techpowerup.com/165336/Co...-Pictured.html |
#16 |
Lokacija: _
Postovi: 277
#17 |
Postovi: 5,991
Njihova 670 ima 1000mhz visi efektivni klok memorije i 15mhz(tko zna koliko turbo kloka) vise GPUa od ove gore MSIjeve ali svejedno mi je malo cudno da je samo par% sporija 680. Nije im ni izbor igri bas neki, fale najbitnije igre. Treba pricekat ostale.. Bilo bi super da je tak, odmah trcim po novu trgovinu.. Ova je ocito full size. Ima 8 + 6 pin napajanje i djeluje jako dobro.. ![]() Zadnje izmijenjeno od: MAGARAC. 05.05.2012. u 16:54. |
#18 | |
Lokacija: _
Postovi: 277
Čini mi se da 570 hvata 580,7950 hvata i prestiže 7970, onda je moguće da nereferentne gtx 670 overclockom lako preskoče i prestignu gtx 680 obične |
#20 |
Lokacija: Sinj
Postovi: 3,538
#21 | |
Postovi: 874
#23 |
Casual Racist
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
Slike su ponovo up na TT reviewu. Valjda su imali Gigabyte OC karticu na testu kad je tako blizu gtx680. Vidjeh na Hforumu da ta GB ima base 980MHz, a boost 1058, dakle slicno kao gtx680. Stoga ne cude ovakvi rezultati. Inace je stock 915->980MHz, a memorija je svima na 6GHz ![]() |
#25 |
Unregistered User
Datum registracije: Jun 2002
Lokacija: Beč
Postovi: 722
http://www.overclock.net/t/1253432/g...rsion-hands-on Kupujem prvi dan dolaska nereferentnih modela. AWESOME |
#29 |
Postovi: 5,991
Ja bi isto jednu. Jedva cekam neke ozbiljnije rezultate, OC i ostalo. Jer uopce pise gdje kad ce bit pustena u prodaju? Naso sam 10.5. za 400$ ili oko 3200 - 3500kn. Klasicna Gigabyte, WindForce, plavi PCB itd. Provjeren recept za dovoljno hladnu i tihu grafu. Ova ima 6 +8 pin adapter pa vjerojatno i custom PCB. Jos jedan + 670 je da ima mogucnost 3 SLI kao prava high end grafa.. Zadnje izmijenjeno od: MAGARAC. 07.05.2012. u 01:29. |
#30 |
Postovi: 10,805
plavi pcb je i dalje za papke ![]() |
