Staro 26.04.2012., 09:17   #1
Deyo238
Grazie Michael
Deyo238's Avatar
Lokacija: Ogulin
Postovi: 360
Catalyst 12.4 WHQL
Win Vista/7 32-bit
Win Vista/7 64-bit
Win XP 32-bit
Win XP 64-bit
Highlights of the AMD Catalyst 12.4 Windows release includes:
NEW FEATURES
Windows XP support for the AMD Radeon HD 7900 Series, AMD Radeon HD 7800, and AMD Radeon HD 7700 Series
  • In addition to Windows 7 and Windows Vista support, Catalyst 12.4 now also introduces Windows XP (64-bit/32-bit) support for the AMD Radeon HD 7900, AMD Radeon HD 7800, and AMD Radeon HD 7700 Series
Super Sampling Anti-Aliasing: Level of Detail (LOD) Image Quality enhancements
  • Supported on the AMD Radeon HD 7900, AMD Radeon HD 7800, and AMD Radeon HD 7700 Series
  • LOD Image quality enhancements have been improved when enabling Super Sample Anti-Aliasing and Adaptive Anti-Aliasing through the AMD Catalyst™ Control Center for DirectX® 10 and DirectX® 11 applications.
  • Applications must support in game Anti-Aliasing for the feature to work (Forced on Anti-Aliasing through the Catalyst Control Center is not supported for DirectX 10 and DirectX 11 applications)
Morphological Anti-Aliasing (MLAA): Significant performance enhancements
  • Supported on the AMD Radeon HD 7900, AMD Radeon HD 7800, AMD Radeon HD 7700 Series, AMD Radeon HD 6000 Series, and AMD Radeon HD 5000 Series
  • MLAA now operates up to 80% faster than previous versions
Texture filtering quality improvements
  • Improvements have been made to the texture filtering algorithm (for both DirectX9 and DirectX10/DirectX11 applications) to increase the quality of rendered textures, with no impact to performance
Full Release Notes
CPU: Intel Core i7 3930k C2 Sandy Bridge E 3200MHz @ 4500MHz (100x45 @ 1.288V) HT enabled
CLR: Corsair H100x
MBO: ASUS RAMPAGE IV FORMULA
RAM: Crucial DDR3-1600 2x8GB + 2x4GB (24GB) @ 1600MHz - 10-11-10-24-1T @ 1.535V
VGA: KFA2 GeForce GTX1070 8GB EXOC
HDD: ADATA SUV800 256GB ++ WD BLUE WD30EZRZ 3TB ++ WD Blue WD6400AAKS 640GB
PSU: Corsair CS550M 550W 80+ Gold Modular
BOX: Jonsbo W2
LCD: DELL P2417H 24" LED @ 1920x1080
OS1: MICROSOFT Windows 10 Pro N x64
GSM: iPhone 11 black 4/64GB
ROM: latest iOS
Zadnje izmijenjeno od: Deyo238. 26.04.2012. u 10:14.
Deyo238 je offline   Reply With Quote
Staro 26.04.2012., 09:41   #2
AlphaDog
AlphaDog's Avatar
Datum registracije: Dec 2010
Lokacija: Ri
Postovi: 37
7970 ide preko 8K u 3D11 s ovim driverom
u BF3 isto solidna poboljšanja
AlphaDog je offline   Reply With Quote
Staro 26.04.2012., 11:50   #3
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
7870 stock 7000 čmarkova...skok od 300. Neloše.
Bez potpisa.
Staro 26.04.2012., 16:14   #4
Xatrix
Xatrix's Avatar
Lokacija: Zagreb, Croatia
Postovi: 10
Hvala na informaciji deyo, skroz sam zaboravio da bi trebali izaci whql driveri ovih dana, trenutno sam na 12.4 beta koji su mi sasvim okej ali cu probati ove.
Thx jos jednom za podsjetnik.
Xatrix je offline   Reply With Quote
Staro 26.04.2012., 19:40   #5
Facelessone
Facelessone's Avatar
Postovi: 4,205
Da li netko ima sličan problem. Nastalo nakon updatea drivera. Također, tekst u WOT-u mi je isto takav.
Edit:
nešto vezano uz Morphological AA. Uglavom, u drivere, uključit ga, isključit ga, restartat msn i radi ko i prije.
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Zadnje izmijenjeno od: Facelessone. 26.04.2012. u 19:56.
Staro 26.04.2012., 23:29   #6
Romano.Cule
Outer Space
Romano.Cule's Avatar
Lokacija: Vinkovci
Postovi: 836
A okorjeli nVidijasi kazu da nece biti poboljsanja s novim driverima i da je to to sa 7970.O'rly mr Scotty ?!
Staro 28.04.2012., 21:47   #7
VandaL.pr!
VandaL.pr!'s Avatar
Lokacija: zaDAR
Postovi: 838
Meni je popravilo sto nisam imao zvuka preko HDMI na TVu, to mi je dovoljno za igre nisam ni gledao
VandaL.pr! je online   Reply With Quote
Staro 29.04.2012., 19:34   #8
Ivan_1
Lokacija: Duga Resa
Postovi: 823
Da li netko zna jeli istina sto sam negdje procitao da ce ova verzija catalysta biti ujedno zadnja koja ce podrzavati dosta starijih verzija kartica posebno iz HD serije?
Ivan_1 je offline   Reply With Quote
Staro 29.04.2012., 20:01   #9
Shockre
Shockre's Avatar
Lokacija: Dublin
Postovi: 582
jes, mislim da se odnosi na 2000, 3000 i 4000 seriju.
Shockre je offline   Reply With Quote
Staro 29.04.2012., 21:48   #10
ZOX
ZOX's Avatar
Lokacija: Koprivnica
Postovi: 297
Ne, AMD će i dalje podržavati starije kartice samo na tromjesječnoj bazi ...
Što se tiče 12.4 drivera,
instaliraj sam ih zbog bržeg morph -a, ali OpenGL ne radi kak spada pa natrag na 12.3 za mene ...
ZOX je offline   Reply With Quote
Staro 30.04.2012., 16:49   #11
Ivan_1
Lokacija: Duga Resa
Postovi: 823
Autor ZOX Pregled postova
Meni se povecao "3D business and gaming graphics performance" za 0,1 u Windows Experience Index
Staro 03.05.2012., 16:44   #12
dinos3
Dino Saur
dinos3's Avatar
Datum registracije: Jan 2012
Postovi: 941
ja imam problem na hd4670
probao sam preko software updatea ažurirati program i opet mi pokaze 12.3 verziju nakon inst , restart kompa nije pomoglo , onda sam probao ekspres unistall , pa onda skinuti 12.4 verziju s neta , no opet mi pokazuje 12.3 a ne 12.4 ..
dinos3 je offline   Reply With Quote
Staro 03.05.2012., 16:46   #13
Bluzer
Bluzer's Avatar
Lokacija: localhost
Postovi: 1,073
Kako riješiti glupavi bug da nestaje performance tab nakon što se klikne accept u njemu? To se pojavilo u 12.3 i nije riješeno do sad.
Staro 03.05.2012., 16:55   #14
dinos3
Dino Saur
dinos3's Avatar
Postovi: 941
ja nemam taj problem , meni to sto si naveo radi bez problema..
Staro 03.05.2012., 19:38   #15
alen.s
alen.s's Avatar
Postovi: 1,441
Autor Bluzer Pregled postova
nikako , ja sam se vratio na 12.1 bas zbog toga
Staro 06.05.2012., 02:39   #16
2 die 4
2 die 4's Avatar
Postovi: 2,284
Jel netko uspio riješiti problem sa zvukom preko HDMI-a nakon što se ugasi monitor/TV i opet upali?
Device not pluged in i jedino rješenje za sada mi je izvaditi kabel i ponovo ga staviti, ali to je frustrirajuće!
RedGreenBlue
Staro 06.05.2012., 10:13   #17
Elpresidente1
Datum registracije: May 2009
Postovi: 389
Autor dinos3;
Kad ljepo piše da za starije od 5xxx znači 4,3,2 od 12.3 apdjeti idu tromjesečno. znači 12.3 je zadnji za naše grafe.
Mene pad zeza vižn kontrol senter - neće se pokrenut znam da treba .net, al jel treba .net 3.5.1 ili još neš drugo.
Elpresidente1 je offline   Reply With Quote
Staro 10.05.2012., 12:07   #18
Goranbm
Goranbm's Avatar
Postovi: 1,238
Evo došla mi danas 6850 i skinuo sam drivere sa stranice 12.4. I nemam navedeni problem, Performance tab radi sasvim ok i nakon što se klikne Accept.
E sad pošto sam tek malo prije instalirao navedene drivere. Koji su to nedostatci na koje bi trebalo obratiti pažnju ? Vidim da ima problema sa HDMI zvukom netko je napisao. To mi nije toliki problem, jer ne koristim HDMI priključak. ima još nešto važno da ne radi kak spada ??
Goranbm je offline   Reply With Quote
Staro 10.05.2012., 12:39   #19
Thermaltake
1
Thermaltake's Avatar
Postovi: 3,623
Meni isto radi Performance tab skroz ok na 4870x2.
Staro 12.05.2012., 14:46   #20
alen.s
alen.s's Avatar
Postovi: 1,441
radi kad rokaš driver prek drivera , ako ideš clean install ( friški windowsi ) onda neradi
Staro 13.05.2012., 00:17   #21
Goranbm
Goranbm's Avatar
Postovi: 1,238
Ja nisam isao na friški install, ali sam obrisao drivere i očistio sam sa driver sweeperom, pošto sam prešao na novu grafu i radi ok...
Staro 14.05.2012., 11:47   #22
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Nakon 3 instalacije, svaki put u CCC-u piše da je 12.3.
Staro 15.05.2012., 20:52   #23
Roby86
Postovi: 73
Da, izgleda da je u nekom property fajlu ostala zapisana stara verzija drivera, a vjerujem da su novi driveri. Ja sam isto dva puta instalirao drivere.
Roby86 je offline   Reply With Quote
Staro 20.05.2012., 18:14   #24
gbijelic
gbijelic's Avatar
Lokacija: Oslo
Postovi: 806
Jel zna netko kako riješit problem sa nestajanjem ATI Overclock kartice nakon klika accept, naime stavio sam 12.3 i 12.4 verzije ali isti problem se dešava, znači kad instaliram drivere i CC mogu ući u ati overclock i sve funkcionira, a cim restartam komp kad odem na ati overclock trazi me potvrdu sa sam upoznat sa onim glupostima pravima bla bla i kad kliknem accept prebaci mi na home stranicu i ati overclock nestane ostane samo cpu power i sve sam update napravio na windowsima i džaba....
gbijelic je offline   Reply With Quote
Staro 20.05.2012., 18:17   #25
dinos3
Dino Saur
dinos3's Avatar
Postovi: 941
btw na 12.1 nema tog problema..
Staro 20.05.2012., 18:21   #26
gbijelic
gbijelic's Avatar
Lokacija: Oslo
Postovi: 806
inace igram bf3 i jedno vrijeme ide super sve 5 i samo odjednom sve uspori na sekund i dalje nastavi...a komp mi je phenom 2 x4 na 3GHz ati 4870 4GB DDR3 sve na low detaljima...
Staro 20.05.2012., 19:32   #27
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,831
Meni pak zna koji put bacit artefakte, dok monitor dignem iz sleep-a, al srećom ne moram ga restartat, neg samo s mišem klikam, i slika se vrati od desktopa... U igrama nisam primjetil neke anomalije..
Staro 20.05.2012., 23:06   #28
gbijelic
gbijelic's Avatar
Lokacija: Oslo
Postovi: 806
rjesio problem sa stavljanjem 12.1 zasad privremeno, a proc mi je bio na 65C dok sam igrao jer je bila neka žnj pasta na njemu
Staro 21.05.2012., 10:23   #29
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,120
Da li se isplati stavljati ovu verziju drivera na moj laptop sa HD6xxx grafičkama? Trenutni mi rade solidno no ako ovi rade bolje - zašto ne. Iako, stavio sam 12.1 jednom i od onda sam stalno dobivao BSOD.
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 21.05.2012., 11:59   #30
BladeRy
BladeRy's Avatar
Datum registracije: Aug 2008
Postovi: 2,000
12.4 ima bug da ne refresha u registryu sa novom verzijom drivera. Stavljeni su novi fileovi i sve al su zasrali sa tim detaljem. Ima i 12.4 hotfix ako nekog bas nervira, sve verzije fileova su iste al ce bar pisat 12.4 ispravno.
http://support.amd.com/us/kbarticles...24ahotfix.aspx
BladeRy je online   Reply With Quote
