Povratak   PC Ekspert Forum > Računala > Overclocking > Memorije
Staro 02.04.2012., 16:46   #1201
MAGARAC
MAGARAC's Avatar
Postovi: 5,989
Nije realno imao sam taj kit i crveni na 1.5 je cak nesto bolji kloker..
Staro 02.04.2012., 16:50   #1202
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,166
Autor MAGARAC Pregled postova
hm, zanimljivo, a sto se tice latencija? jer to je u biti zanimljivije od freq. jer koliko sam vidio nema neke razlike 1600mhz ili vise (za igre).
btw za info, koja granica V kod DDR3 je smatrana "safe"? negdje sam procitao nesto oko 1.9V?
edit: malo sam krivo vidio ili su krivo naveli. sad sam nasao podatak da nije preporucljivo vise od 1.65V za 24/7.
Zadnje izmijenjeno od: geronimo_2. 02.04.2012. u 20:07.
Staro 02.04.2012., 23:25   #1203
Vedranicio
@The Banan Man
Vedranicio's Avatar
Datum registracije: Mar 2012
Postovi: 179
evo ovako sutra kupujem još 2 gige za moj komp i zanima me koja marka bi bila najbolja (ili što već) :P
imam trenutno ovo
1 Slot
DIMM1: Transcend JM667QLJ-512M 512 MB
Field Value
Memory Module Properties
Module Name Transcend JM667QLJ-512M
Serial Number 0007B34Dh (1303578368)
Manufacture Date Week 49 / 2007
Module Size 512 MB (1 rank, 4 banks)
Module Type Unbuffered DIMM
Memory Type DDR2 SDRAM
Memory Speed DDR2-667 (333 MHz)
Module Width 64 bit
Module Voltage SSTL 1.8
Error Detection Method None
Refresh Rate Reduced (7.8 us), Self-Refresh
Memory Timings
@ 333 MHz 5-5-5-15 (CL-RCD-RP-RAS) / 20-35-3-5-3-3 (RC-RFC-RRD-WR-WTR-RTP)
@ 266 MHz 4-4-4-12 (CL-RCD-RP-RAS) / 16-28-2-4-2-2 (RC-RFC-RRD-WR-WTR-RTP)
@ 200 MHz 3-3-3-9 (CL-RCD-RP-RAS) / 12-21-2-3-2-2 (RC-RFC-RRD-WR-WTR-RTP)
Memory Module Features
Analysis Probe Not Present
FET Switch External Disabled
Weak Driver Supported
Memory Module Manufacturer
Company Name Transcend Information Inc.
2 SLOT
DIMM3: Crucial CT25664AA800.K16F
Field Value
Module Name Crucial CT25664AA800.K16F
Serial Number None
Manufacture Date Week 11 / 2011
Module Size 2 GB (2 ranks, 8 banks)
Memory Speed DDR2-800 (400 MHz)
Module Width 64 bit
Memory Timings
@ 400 MHz 6-6-6-18 (CL-RCD-RP-RAS) / 24-51-3-6-3-3 (RC-RFC-RRD-WR-WTR-RTP)
@ 333 MHz 5-5-5-15 (CL-RCD-RP-RAS) / 20-43-3-5-3-3 (RC-RFC-RRD-WR-WTR-RTP)
@ 266 MHz 4-4-4-12 (CL-RCD-RP-RAS) / 16-34-2-4-2-2 (RC-RFC-RRD-WR-WTR-RTP)
Company Name Micron Technology, Inc.
znači mičem ove od 512 i dodajem nove 2 gige.
zanima me koje 2 gige bi bile najbolje uze ove Corsair (logičan odgovr je još jedan corsair, ali nema ih trenutno u splitu gledao sam svugdje)
ako treba matična ona je asrock g31m-r2.0
http://www.google.hr/url?sa=t&rct=j&...w171iXAPf1oLMQ
Vedranicio je offline   Reply With Quote
Staro 02.04.2012., 23:33   #1204
geronimo_2
geronimo_2's Avatar
Postovi: 4,166
ti znas da neces vidjet/moc koristit svih 4gb sa 32bitnim OS-em?
Staro 02.04.2012., 23:44   #1205
Vedranicio
@The Banan Man
Vedranicio's Avatar
Postovi: 179
yep, instaliram windows 7 64x bitni sutra kad ih kupim :P pitam koje ću nisam neki ekspert za kompjutere
Staro 03.04.2012., 11:51   #1206
ShanTech
Datum registracije: Apr 2011
Postovi: 3,784
@Vedranicio
Kolko vidim ti imaš Crucial memoriju, a ne Corsair, ali i ne vidim razloga zašto bi kupovao takvo nešto. Kupi što jeftiniju memoriju sa što je moguće dužom garancijom.
Staro 18.04.2012., 19:43   #1207
Cvrle
Datum registracije: Apr 2012
Postovi: 31
pozdrav momci kupujem novu konfu pa me zanima koju memoriju da odaberem za svoj i5 2550k
imam par u vidu stavit cu 64bitni os a kako stvari stoje sa cjenama atm uzet cu 16 gigi ... evo par komada koji su mi upali u "oko" : Memorija PC-12800, 16 GB, MUSHKIN BlackLine FrostByte, 994043, DDR3 1600MHz, kit 4x4GB oko 900kn kosta ,
Memorija PC-12800, 16 GB, G.SKILL Ares series, F3-1600C9Q-16GAO, DDR3 1600MHz, kit 4x4GB ova je oko 800kn al je latency 9 dok je kod prve 8 ...
mada si razmisljam uzet 2 keksa od 4 gige i mir za sada kasnije stavim josh 2 keksa ako ce bit za time potrebe mada manje vise igram igre i slicno ... cisto sumljam da mi treba vise od 8 gigi za to ?
fala unaprijed !
malo sam pogledo i naso si dobru mem 8 gb 2 keksa po 4 i mir jeftinije je a necu vise moc iskoristit bar ne iducih god dve ! .
Memorija PC-12800, 8 GB, G.SKILL Ares series, F3-1600C9D-8GAO, DDR3 1600MHz, kit 2x4GB
kosta 429kn
Zadnje izmijenjeno od: Jelc. 18.04.2012. u 20:41.
Cvrle je offline   Reply With Quote
Staro 18.04.2012., 20:35   #1208
ShanTech
Postovi: 3,784
Ne treba za igre 16GB memorije, 8GB će biti i više nego dovoljno. Predlažem da se kupi memorija sa nižim hladnjacima i sa što je moguće dužom garancijom. Može i taj G.SKILL, može i 1333 i 1600, razlika se baš i ne bude primjetila u svakodnevnom radu.
http://www.nabava.net/radna-memorija...se=12629,70547
Nemoj postati zaredom, nego koristi Edit.
Staro 23.04.2012., 20:13   #1209
igo1000
igo1000's Avatar
Datum registracije: Mar 2010
Postovi: 3
gdje si to našao i po koliko
igo1000 je offline   Reply With Quote
Staro 24.04.2012., 12:51   #1210
mmatrix
Datum registracije: Mar 2008
Postovi: 121
Da li će biti problem natjerati 2 kita 2×4GB da rade u quad modu na Asrock Extreme4 X79?
mmatrix je offline   Reply With Quote
Staro 24.04.2012., 12:56   #1211
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Staro 24.04.2012., 12:58   #1212
mmatrix
Postovi: 121
Znam da podržava, više me onako interesira iz prakse da li pravi probleme ako su iz dva različita kita.
Staro 24.04.2012., 13:01   #1213
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Ako su oba kita pod memory support list i rade na isto mhz ( i v ) nebi trebalo bit problema...
Staro 24.04.2012., 20:56   #1214
geronimo_2
geronimo_2's Avatar
Postovi: 4,166
poz. jel zna tko jel ima ovog cuda negdje u EU za uzet?
http://www.newegg.com/Product/Produc...82E16820147096
http://www.ebay.co.uk/itm/Samsung-Gr...item1e6bd39ccc
uzeo bi mozda i iz US, ali mislim da je onda problem carine zbog ulaska u EU (slao bi u SLO)?.
Staro 24.04.2012., 22:02   #1215
Billkita
Billkita's Avatar
Lokacija: Čavle, Rijeka
Postovi: 199
Imaš u Casekingu. Šalju ti u Sloveniju. Možda ja nešto iskopam pa podjelimo poštarinu.
Ala homo, ala homo ča popit i na brige pozabit.
Billkita je offline   Reply With Quote
Staro 08.05.2012., 10:58   #1216
sNNooPY
sNNooPY's Avatar
Postovi: 1,908
Sto biste stavili od memorije za brand-new Ivy Bridge build i5 3570K i ASUS P8Z77-V Pro? Namjena: gaming.
8 ili 16GB? koliko je "realno" dovoljno za sad uz mogucnost upgradea kasnije?
sNNooPY je offline   Reply With Quote
Staro 08.05.2012., 11:19   #1217
geronimo_2
geronimo_2's Avatar
Postovi: 4,166
Autor sNNooPY Pregled postova
za gaming nebi isao iznad 2x4gb. sve preko je bacanje love IMHO.
jel ti bitan low voltage/low profile? ak je, ja uzeo ovo:
http://www.links.hr/?naziv=memorija-...kl=051.210.186
Staro 08.05.2012., 11:36   #1218
sNNooPY
sNNooPY's Avatar
Postovi: 1,908
eh, kad bi znao o cem pricas... ne kuzim sto je low voltage/low profile.
ostao sam u 2008. sto se tice "latest and greatest" u hardveru (Core 2 Duo, DDR2, ...).
ma bitno mi je da imam dovoljno memorije za igre i all-around posao (uz ponesto Lightrooma) ali da je upgradeable (jednog dana do 16GB ili 32GB).
pa sad...sto je low profile low voltage?
Staro 08.05.2012., 11:43   #1219
geronimo_2
geronimo_2's Avatar
Postovi: 4,166
low voltage - da radi u originalu na niskoj voltazi. standardi su AFAIK 1.35, 1.5 i 1.65V. ja bih uzeo 1.35 ili 1.5. nebih 1.65V
low profile - da cooleri/hladnjaci ne strse onako bolesno u vis pa da imas problema sa montazom nekih vecih coolera. btw ti kuleri ne sluze apsolutno nicemu osim marketingu (IMHO).
Staro 08.05.2012., 11:54   #1220
sNNooPY
sNNooPY's Avatar
Postovi: 1,908
aha. thnx na info. i mislio sam da je rijec o tome.
ma ne volim te memorije koje imaju coolere do neba. to je memorija jebote, ne CPU. ne znam zast to rade osim estetike... :/
dakle neki 2x4 par DDR3 1600 (citah na Anandtechu upravo da je 1600 neki "sweet spot" sto se tice brzine).
thnx.
Staro 08.05.2012., 12:00   #1221
geronimo_2
geronimo_2's Avatar
Postovi: 4,166
marketing
thnx.
da
Staro 08.05.2012., 12:03   #1222
syss
syss's Avatar
Postovi: 10,805
tim vođen sam i ja birao memoriju + obično taj ficlek aluminijuma kroz (obično) termalnu traku se ponaša više kao izolator nego hladnjak.
na kraju se odlučio za old skul sa 200 godina garancije:
Staro 08.05.2012., 12:11   #1223
geronimo_2
geronimo_2's Avatar
Postovi: 4,166
onaj spomenuti green samsung 30nm je po meni "the best/beast" kad bi ga mogli dobit do 450kn (2x4gb). low voltage/low profile/low proces i nema hladnjake. zakon. nabavit cu to prije ili kasnije
Staro 08.05.2012., 12:42   #1224
Wolverine
Wolverine's Avatar
Postovi: 12,425
Za IVB gledaj DDR3L module tj module koji rade na 1,28-1,35V
Imam ADATA 2x 8 GB 1600 MHz kit i vrtio sam ga na Core i7 3770K i radi odlično.
Tebi za igre i gluposti ne treba više od 2x 4GB.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 08.05.2012., 13:20   #1225
sNNooPY
sNNooPY's Avatar
Postovi: 1,908
thnx. da se onda fino ustediti na memoriji ak se na pada na te marketinske fore (ogromna brzina, veliki cooleri i sl.).
maticna ima mogucnost do 32GB tak da se ne brinem za kasnije ak bude trebao kakav upgrade.
thnx jos jednom. ovaj upgrade je jos uvijek u razmatranju i sigurno to necu uzimati isti cas, al kao sto sam rekao...lagano se vracam u CPU, chipset i mem svijet pa da budem u toku.
pozdrav!
Staro 11.05.2012., 23:28   #1226
tkalec1980
tkalec1980's Avatar
Datum registracije: Mar 2009
Lokacija: Baranja
Postovi: 24
Da li je ikako moguće i da li negdje postoji ovaka memorija, da se može uzeti samo 1 ploćica od 2gb ??
http://www.links.hr/?naziv=memorija-...kl=051.210.080
tkalec1980 je offline   Reply With Quote
Staro 09.06.2012., 09:58   #1227
Omerta
Omerta's Avatar
Lokacija: Grobnik - Rijeka
Postovi: 3,253
Znači, preporučuješ ovu memoriju?
Da se razumijemo, ovi hladnjaci me uopće ne interesiraju, ali kako gledam većina proizvođača ih je počela stavljat.
Ili pukni neku drugu istih karakteristika, cjene su sve tu negdje..
Staro 09.06.2012., 10:26   #1228
Wolverine
Wolverine's Avatar
Postovi: 12,425
Ako ti ne smetaju hladnjaci, da, to bi trebao biti dobar izbor za IVB.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 09.06.2012., 10:31   #1229
Omerta
Omerta's Avatar
Postovi: 3,253
Hvala ti.
Staro 27.06.2012., 11:00   #1230
Python
Python's Avatar
Datum registracije: Feb 2010
Postovi: 28
Možete li mi preporučiti neki dobar ram za sljedeću konfu: AMD Phenom II x4 955, Scythe Ninja 3,Asroc 870 Extreme 3, Nvidia GeForce 9600gt, Scythe Stronger 500w, Bitfenix Schinobi. Dosada sam imao jedan Crossair Vengence od 4gb, Ali je nije low profile pa ni je uz sam hladnjak. Želim si uzeti nešto 2x4gb ali nisam siguran što, ima ih low profile ali sam čuo da nisu nešto posebno kvalitetni. Dali je možda MUSKIN FrostByte bolji izbor? Ili možda neki drugi, ne znam recite mi.
Python je offline   Reply With Quote
