Staro 25.10.2010., 21:33   #121
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Autor McG Pregled postova
VLC player na App Storeu - za iPhone, iPod Touch i iPad s iOS-om 3.2 nadalje.
UJ!
Jel se da zastreamat i maxtv, to bi donjelo čist novu dimenziju odlasku na ćenifu?
Staro 27.10.2010., 14:24   #122
rams
80286
rams's Avatar
Datum registracije: Jul 2004
Lokacija: Dingolfing, DE
Postovi: 1,724
Autor Jelc Pregled postova
Hah, legenda !!
rams je offline   Reply With Quote
Staro 27.10.2010., 15:10   #123
Jelc
Super Moderators
Postovi: 17,485
Za sad je samo za filmeke-ali fino radi
Staro 14.11.2010., 00:44   #124
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
VLC media player 1.1.5
This is a minor release, focused on minor features, bugfixes and security issues:
- VideoLAN-SA-1006 security issue on Windows
- Game Music Emu support rewritten and activated
- integration of a new list of webshows from channels.com
- fixes on h264 playback hardware decoding using Intel GPU on Windows
- fixes on .webm live streams, and DVD
- multiple fixes in interfaces, scripts, demuxers and video outputs
- addition of libvlc_media_new_fd()
- translations
Sultan je offline   Reply With Quote
Staro 24.01.2011., 10:28   #125
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
VLC media player 1.1.6
  • Security updates in codecs and demuxers
  • Support for RTP/PCM 24bits, audio/L24
  • Support for MPC SV7/SV8 on Windows and MacOS builds
  • Faster Webm/VP8 decoding
  • Support for Midi on MacOS
  • Major updates in most language translations
  • Support for projectM visualisation on Windows
  • KDE and PulseAudio integration improvements
  • Subtitles fixes and improvements
  • Improvements in visualisations and interfaces
  • Codecs updates
  • Many miscellaneous fixes
Staro 02.02.2011., 09:57   #126
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
VLC media player 1.1.7
This release is a security update of the current stable version:
  • Fix for Matroska / WebM remote code execution vulnerability
  • Update for Hebrew, Japanese, Danish and Russian translations
Staro 24.03.2011., 08:32   #127
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
VLC media player 1.1.8
  • Security update regarding video width concerning some demuxers
  • Support for a new Dirac encoder based on libschroedinger
  • Package of the new VP8/Webm encoder 'Bali'
  • Notable updates in .mp4, .ogg, .ape demuxers
  • Fixes in skins2 supports of Winamp2 skins
  • Upgrade on the look of VLC for Mac OS X
  • Auto-detection for .txt subtitles is fixed
  • Fixes on Windows integration, notably regarding volume keys
  • Codecs updates
Staro 14.02.2012., 10:21   #128
ExtremePower
ExtremePower's Avatar
Datum registracije: Aug 2008
Lokacija: Moj dom Krapina
Postovi: 246
Molim bih one koji koriste ovaj player za pomoć.
Naime, unatrag 2 tjedna vlc mi se dosta puta smrznuo.
Sad, dal da se vratim na neku od prijašnjih stabilnijih verzija ili postoji drugačije rješenje (da zamjenim player)?
ExtremePower je offline   Reply With Quote
Staro 15.02.2012., 00:13   #129
doky
doky's Avatar
Datum registracije: Nov 2010
Postovi: 1,942
Ja VLC koristim već jedno godinu i pol svakodnevno i zapravo se nikada nije sam niti srušio niti smrznuo, jedino pamtim da se par puta smrznuo kad sam pokretao filmove koji se još nisu bili do kraja preuzeli tako da može biti da i nije do samog VLC-a. Probaj prvo kompletan uninstall pa staviti zadnju verziju.
doky je offline   Reply With Quote
Staro 15.02.2012., 01:03   #130
bor1s
bor1s's Avatar
Lokacija: Vratlo
Postovi: 300
Može mala pomoć u vezi VLC playera?
Zanima me kako da namjestim da mi titlovi budu u full screenu na dnu ekrana a ne na dnu vidljive slike. Recimo nešto kao opcija u
MPC HC --> Position subtitles relative to the video frame.
Nadam se da razumijete što želim.
bor1s je offline   Reply With Quote
Staro 18.02.2012., 21:36   #131
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
VLC media player 2.0 (changelog)
VLC 2.0 "Twoflower" is a major new version of our popular media player.
With faster decoding on multi-core, GPU, and mobile hardware and the ability to open more formats, notably professional, HD and 10bits codecs, 2.0 is a major upgrade for VLC. Twoflower has a new rendering pipeline for video, with higher quality subtitles, and new video filters to enhance your videos. It supports many new devices and BluRay Discs (experimental). Completely reworked Mac and Web interfaces and improvements in the other interfaces make VLC easier than ever to use. Twoflower fixes several hundreds of bugs, in more than 7000 commits from 160 volunteers.
Staro 20.02.2012., 20:15   #132
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,136
ohoho
nisam ga koristio od negdje 1.0x verzije
I dok sam cekao pravo GPU HD dekodiranje zaboravio na taj VLC
HumWeed je offline   Reply With Quote
Staro 21.02.2012., 16:55   #133
tiki66
tiki
tiki66's Avatar
Postovi: 2,729
Skinuo novu verziju, isprobao, cini se ok.
Napokon malo redizajna, sad izgleda donekle moderno
Staro 21.02.2012., 17:27   #134
Ordem
Datum registracije: Sep 2010
Lokacija: Vk
Postovi: 572
jel napokon prikazuje palatale (i ne, promjena encodinga ne pomaze) na nasim titlovima?
Ordem je offline   Reply With Quote
Staro 21.02.2012., 20:08   #135
tutix
tutix's Avatar
Postovi: 4,069
Meni pokazuje oduvijek. Eastern European (Windows-1250) i to je to.
Nego, jedna stvar koja mi ne radi. Ne želi mi učitat mapu sa serijama u playlistu prilikom pokretanja? Ima netko nekakav workaround ili rješenje? Znači treba mi library koji će se sam osvježit prilikom dodavanja novih stvari (kao u foobaru Album List ili u WMP-u). U VLC-u to ne radi a rekli su sredit sa ovom verzijom.
Staro 22.02.2012., 21:53   #136
Xenon
Postovi: 1,542
Ma taj VLC je postao bezveze.
Najbolja opcija je Windows Media Player 12 + K-Lite Mega Codec pack. Radi savršeno, mkv klizi, možeš si podesit tilove kao hoćeš, sound i sve. Svi ostali programi su mi do sada štucali kod playanja osim njihovog Media Player Classic. Imaju i codec pack za win 64bita.
Zadnje izmijenjeno od: Xenon. 22.02.2012. u 22:07.
Xenon je offline   Reply With Quote
Staro 22.02.2012., 23:27   #137
Facelessone
Facelessone's Avatar
Postovi: 4,204
Bravo ti. Pošto nitko drugi ne želi ja ču ti reći da s*r*š. I nije media player classic njihov. Evo ti posta da utvrdiš neko gradivo. Samo nemoj reć, joj, ovo mi je puno za pročitat i odmah odustat.
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 23.02.2012., 00:32   #138
Mad_Duke
Ako čovjeku radi sve u WMP-u kakve veze ima da gleda u tome?
Staro 23.02.2012., 00:40   #139
Facelessone
Postovi: 4,204
Nek njemu samo radi. Ali da je VLC beveze i da je WMP + klite najbolja opcija.....
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 23.02.2012., 01:40   #140
Xenon
Postovi: 1,542
Za mene je, VLC je bezveze je kako god tebi to zvučalo, meni ne treba nečije mišljenje, uvjerenje da bi koristio ono što mi ne radi kako treba.
Staro 23.02.2012., 01:50   #141
Facelessone
Postovi: 4,204
Boli mene slatka kifla kaj ti koristiš il kaj ti valja. Al kad pljuješ po nečemu onda se bar udostoji napisat zbog čega ti ne valja i koji je to problem koji imaš.
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 23.02.2012., 11:44   #142
Ordem
Lokacija: Vk
Postovi: 572
znaci najbolja je opcija defaultni windows player koji nema u startu podrsku za titlove i odredjene video formate pa se stoga mora koristiti u sprezi sa ogromnim codec packom (hrpa codeca koje ugl neces koristiti, koji ce se klati sa ostalim programima (nero, igre, itd)
naspram playera kojeg kad instaliras na cistu instalaciju windowsa ne treba ti vise nista za gledanje bilo kojeg video formata i citanje vecine subititlova. btw nova verzija VLCa ima ugradjenu GPU akceleraciju tako da ako ti je dosad sta stekalo, vise ne bi trebalo.
i u VLCu mozes podesiti titlove kako god hoces (pozicija, boja, transparentnost, font, podebljanje, sjena, itd) zajedno sa zvukom + ne moras se brinuti imas li odredjeni codec i to jos za odredjenu verziju windowsa (32 ili 64bit)
Staro 23.02.2012., 12:43   #143
Xenon
Postovi: 1,542
Malo bolje čitaj postove i u čemu je problem prije nego primjeniš taj primitivni stav. Da imaš iskustva ne bi pisao takve glupost.
Autor Ordem Pregled postova
Da, možeš sve podešavat kao VLC-u i čak ima više opcija. Koristio sam VLC znam sve o njemu. Ali jednostavno playanje šteka isto je tako i kod svih ostalih playera osim u WMP. To nije samo slučaj kod mene. Ne treba mi akcelerator jer ga ni sada ne koristim na WMP i imam relativno novi komp. I nemam problema s codecima.
Staro 23.02.2012., 13:41   #144
Ordem
Lokacija: Vk
Postovi: 572
ako ti video steka u svim playerima osim u windows media playeru onda ocito imas problema sa windowsima.
Staro 23.02.2012., 13:48   #145
Facelessone
Postovi: 4,204
Ja odustajem.
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 23.02.2012., 20:35   #146
tiki66
tiki
tiki66's Avatar
Postovi: 2,729
Mene je malo razocarala nova verzija jer na starijem kompu (WinXP, 1.6GHz, 768MB rama, 9550) video trza i ne vrti se dobro kao i na starijim verzijama. Nakon pol sata prckanja po opcijama nisam nista postigao, pa sam se vratio na 1.1.9.
Inace VLC mi je najbolji što se tice video fileova, cita sve bez problema. Nisu potrebni nikakvi dodatni codeci, i ne "svadja" se s drugim programima, postoji i portable verzija, brz je i lagan... Svakome kome instaliram Windowse, instaliram i VLC, i svi su se vec navikli da ako nesto ne mogu pogledati da ce otvoriti sa "čunjićem" ilitiga VLC-om
Staro 24.02.2012., 00:22   #147
Xenon
Postovi: 1,542
da, da sigurno, samo mi reci da mi driveri ili grafička ne valjaju .... i ne samo meni nego većini.
Staro 24.02.2012., 00:41   #148
doky
doky's Avatar
Postovi: 1,942
Ne znam kak ostalima no meni recimo VLC 2.0 leti čak i naspram MPCHC. Seekanje kroz 25GB, h.264, 1080p, DTS film je postalo praktički instantno. Dva definitivno najbolja rješenja za filmove su VLC i MPCHC, prvi odlično obavlja svoj posao te je dosta jednostavan za korištenje, a drugi ako se filmofil koji nije miran ako se svakodnevno ne igra s postavkama, za to je MPCHC + madVR must have.
A ove codec packove odavno ne želim vidjet na svom kompu.
Staro 24.02.2012., 03:57   #149
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,136
Autor dokis Pregled postova
pa kak bi inace gledao ikakav film ?
za sve ti treba codec pack
jedina razlika kod VLC-a jest sto on dodje sa "svojima"
inace ni jedan player ti nece ist vrtit bez codeca...
potpis
ili si si unistio windoze sa svim mogucim packovima koje si dosad nakacio
ili su ti stvari bas zbog loseg ne micanja starog ostale lose konfigurirane (da filteri trebaju biti podeseni)
a WMP necu komentirati... suxa
Staro 24.02.2012., 10:52   #150
doky
doky's Avatar
Postovi: 1,942
Autor HumWeed Pregled postova
Znam ja terminologiju. Mislio sam na codec pack otvorenog tipa koje svaka aplikacija može prizvat. Stvar je u tome što večini korisnika zatreba tek jedan ili dva filtera i par codeca, a ne želim ni znat koliko ih ti packovi stave i još gdje svi ti codeci ostavljaju tragova po sistemu, bilokakav konflikt ili problem će kad tad nastat. Ugrađeni codeci su druga stvar jer su birani i testirani da rade zajedno u zatvorenom sustavu.
