Staro 25.01.2012., 23:24   #1
Liquid Snake
Liquid Snake's Avatar
Postovi: 166
Catalyst 12.2 Preview Driver
Download:
AMD Catalyst 12.2 Preview driver for Windows Vista & Windows 7
Code:
Driver Packaging Version           8.94-120120a-132259E-ATI
Catalyst Version                   12.2
2D Driver Version                  8.01.01.1231
Direct3D Version                   7.14.10.0890
OpenGL Version                     6.14.10.11472
Catalyst Control Center Version    2012.0120.2218.39907
Release Notes:
http://support.amd.com/us/kbarticles...easenotes.aspx
The AMD Catalyst™ 12.2 Preview includes all of the features found in AMD Catalyst™ 12.1, plus additional fixes that are not included in the AMD Catalyst 12.1 release.
Please note that AMD Radeon HD 7900 users should keep using the 8.921.2 RC11 driver found here (the 12.2 preview does not supported the AMD Radeon HD 7900 Series): http://support.amd.com/us/kbarticles...C11Driver.aspx
Feature highlights of the AMD Catalyst™ 12.2 driver:
  • AMD Eyefinity 2.1 technology enhancements
  • Additional resolution support: Users can now choose from a larger set of resolutions when running AMD Eyefinity
  • Dynamic Configuration Changes: Switching between different display configurations will occur automatically when physically plugging/un-plugging displays
  • HydraVision™ enhancements: The Windows Task bar can now be moved and resized based on users preference
  • Profile Manager improvements: Increased support for Display Groups (including 5x1) and Extended configurations within the Profile Manager
Dreaming in digital. Living in realtime. Thinking in binary. Talking in IP.....Welcome to our world.
~DI
Liquid Snake je offline   Reply With Quote
Staro 18.03.2012., 22:43   #2
mrVivi
mrVivi's Avatar
Postovi: 323
da li još tko ima problema s ovom verzijom drivera prvo kad sam skido stoji da su 12.2 kad instaliram piše da su 12.3 onda nece CCC da se loada na startup-u tj nece da ucitava profile tu je i užasni FPS u igrama.
mrVivi je offline   Reply With Quote
Staro 19.03.2012., 12:29   #3
suedamA obmaR
Game, PC ,motobikes, bike
suedamA obmaR's Avatar
Datum registracije: Jan 2010
Lokacija: Sibenik
Postovi: 779
Kod mene je bija slićan problem, nešto se poremetilo u regigstriju i isto mi nije tija pokrenit AMD Vision control center.
Riješenje je izbrisat drivere s Driver Sweeperom u safe modu i ponovo instalirat, a ovo 12.3 ti je svima tako.
Edit: Mislim da mi se to desilo kad sam priko 12.2 Preview instalira 12.2 normalne(ne preview) drivere.
suedamA obmaR je offline   Reply With Quote
