Povratak   PC Ekspert Forum > Računala > Mobilno > Tableti
Staro 25.12.2011., 03:34   #1
potemkin.hr
Akutna lijenčina
potemkin.hr's Avatar
Lokacija: Fiume
Postovi: 1,834
Post PRESTIGIO MultiPad PMP5080B mini review
Kako sam u ponedjeljak kupio navedeni tablet, odlučio sam napraviti mini review nakon par dana korištenja i testiranja. Tablet je kupljen u Linksu za 1599 kuna (akcijska cijena, ista za sve načine plaćanja). [LINK]
SPECIFIKACIJE:
Code:
Features
G-Sensor
Procesor
CPU	ARM Cortex-A8 (Rockchip RK2918)
Internal Clock Rate	1 GHz
Display
Display	Integrated Color 8" (800x600) TFT
Display Features:
•  Capacitive Touch-screen
Memorija
Internal Memory Size	4 GB
Installed RAM Storage Capacity	512 MB
Flash Card	Supported Micro SD/Micro SDHC Card
Multimedia
Video Features	Video Playback
Supported Formats	JPEG BMP MP3 WMA AAC
WAV TXT AVI GIF PNG OGG DAT VOB 3GP FLAC APE
MP4 MOV RM MKV FB2 PDB RTF FLV PDF EPUB RMVB
Digital Camera
Digital Camera	Front : 2 Mpixel (1600x1200)
Software
Mobile Operating System	Android v2.3 (Gingerbread)
Applications Installed	Calculator
Clock
Alarm Clock
Battery
Battery Technology	Lithium Ion Polymer
Battery Current Capacity	5400 mAh
Battery Average Run Time	Video playback Time:
•  Max 4hr
Audio playback Time:
•  Max 6hr
Interface
Wi-Fi	1 (IEEE 802.11b/g/n)
Headset Port	1 (3.5-mm minijack)
HDMI	1
Miscellaneous
Package Type	Retail
Built-in Devices	Speaker
Included Accessories	Power Adapter
Dimensions&Weight
Depth	203.1 mm
Height	153.4 mm
Width	11.2 mm
Nominal Weight	0.51 kg
Warranty
Warranty Products returnable	Yes
Warranty Term (month)	24 month
PAKIRANJE I SADRŽAJ:
Uređaj dolazi u kvalitetnom pakiranju (jako čvrsti karton sa kvalitetnim printom) zajedno sa futrolom, punjačom, USB kabelom, priručnikom i garancijom.
Sam tablet je dobre izrade i nema nikakvog škripanja ni kod čvršćeg držanja ili pritiskanja, te dobro leži u ruci jer je kompletna stražnja strana istoga gumirana da se ne skliže. Futrola za spremanje tableta je iz kvalitetnog skaja (malo kontradiktorno – kvalitetna imitacija kože, ali jest tako)
Na vrhu uređaja se nalazi gumb za paljenje te 2 gumba za reguliranje glasnoće. Na dnu tableta se redom nalaze ovi konektori: Utor za punjač, miniHDMI, integrirani mikrofon, miniUSB te 3.5“ stereo jack za slušalice. Na poleđini uređaja su utor za microSD kartice, hardverska reset tipka te 2 zvučnika prosječne jačine i kvalitete. Na prednjoj strani se nalaze samo 4 hardverske touch tipke za navigaciju (redom: back, meni, home i search) te kamera rezolucije 2 megapiksela.
U paketu izostaje miniHDMI adapter te micro SD kartica za (vjerojatno) kasnije proširenje memorije uređaja.
HARDVER:
U tabletu kuca posljednji Rockchip 2918 čip, sa ARM cortex A8 procesorom na 1 GHz, te Vivante GC800 grafičkim čipom, koji bez muke vrti 1080p video. Bez dodatne kartice, uređaj posjeduje 4GB interne memorije te 512 MB RAM-a.
Ekran rezolucije 800*600 dijagonale 8“ (~20cm) je dobar za čitanje knjiga ili web stranica, dok nije savršeni za gledanje widescreen materijala. Brightness je dosta jaki, do te mjere da sam ga morao isključiti jer sam naviknut na nisku razinu svjetline ekrana. Ekran je kapacitivni, te samim time onemogućava bilo kakvo korištenje stylusa, dok registriranje prstiju i gesturesa radi bez problema (npr. Pinch zoom). Kao kod svakog glossy ekrana, jako svjetlo mu je najveći neprijatelj, onda postaje ogledalo.
Ono što me jako (ugodno) iznenadilo kod uređaja je trajanje baterije, koje NIJE deklariranih 4 sata kod gledanja videa, već ~6,5 sati sa konstantno uključenim Wirelessom te gamingom (maksimalno opterećenje do kraja napunjene baterije, pad sa 100 na 15% baterije do upozorenja o slaboj bateriji). Laganim surfanjem sa povremenim spajanjem na Internet bez problema bi se dalo iz njega još izvući koja 2-3 dodatna sata autonomije, na kojih 9 sata.
Punjenje sa ~10% baterije na 100% traje oko 2 sata, prilikom čega ga se može normalno koristiti.
Tablet nema 3G niti GPS, tako da ne može poslužiti za surfanje van objekta bez WLAN-a, niti može poslužiti kao GPS u automobilu, eventualno kao Car PC za multimediju/zabavu. Prijam wirelessa je prilično dobar, ne pada ispod 50% ni sa razmakom 2 kata od rutera.
Power gumb i gumbovi za glasnoću zvuka su postavljeni preblizu te je moguće nenamjerno gašenje uređaja, dok su suftverske touch tipke jako nezahvalne jer se ne može „na slijepo“ nabosti željena opcija već je uvijek potrebno gledati na njih, što se moglo izbjeći korištenjem pravih „fizičkih“ tipki.
SOFTWARE:
U pakiranju dolazi sa clean verzijom androida 2.3, a spajanjem na WiFi skida zadnji update. Prije bilo kakvog podešavanja preporučujem spajanje na WLAN te skidanje i instalaciju zadnjeg updatea. Defaultni launcher dolazi sa grupiranim mapama, ali se mogu maknuti te zamijeniti klasičnim shortcutima. Sučelje radi fluidno bez ikakvih zastajkivanja, te radi u portrait i landscape modu u sva 4 smjera. Napominjem da sa tabletom dolazi standardni google market, tako da nema nikakvih problema po pitanju aplikacija, a za neke koje nisu dostupne iz ovog ili onog razloga normalno radi ručno instaliravanje .APK-a preko ugrađenog file explorera. Sa uređajom ne dolazi puno bloatwarea, samo ugrađena office, ebook te file explorer aplikacija. Po defaultu ne dolazi sa Flash playerom, što je u neku ruku dobra stvar (kod web stranica nema milijardu i dvjesto popup prozora i adova), ali instalacijom flash radi normalno bez prevelikog udara na performanse kod surfanja. Za pisanje hrvatskih slova preporučujem tipkovnicu od Tomislava Gudelja sa android marketa (link), koja je jednostavna te besplatna. 2 glavna nedostatka UI-ju prepisujem nepostojanjem brojčanog indikatora razine baterije, za što je najspretnije rješenje instaliranje battery meter appa koji čuči u status baru. Problem je i izostanak nekakvog task killer appa (link) zbog čega je potrebno uvijek ići u settings ubijat stuck proces koji se vrti u pozadini (primjer: GemRB, pritiskom na home tipku proces šalje u pozadinu ali nastavlja sa realtime radom).
GAMING:
Isprobao sam malo kako se tabletić drži na polju gaminga, te došao do par zanimljivih spoznaja.
Kao prvi primjer bih naveo Dungeon Defenders, koji ne radi fluidno, ali ga je moguće zaigrati uz blagi stuttering (Ipak je Tegra igra). Igra bolje radi na maksimalnim nego minimalnim detaljima, što je malo čudno, te je jedan mali dio ekrana odrezani zbog rezolucije koja nije prilagođena za 4:3 tablete.
Druga igra koju sam isprobao je Minecraft: Pocket edition, koja doslovno leti i užitak ju je igrati na tabletu. Touch kontrole rade normalno i igra mi na tabletu radi puno brže nego na desktopu.
World of Goo i Plants vs Zombies su kao stvoreni za tablete, gdje do maksimuma dolazi do izražaja prilagođenost igre touch ekranima. Savjet: nemoje davati ženama/curama tablet s tim igrama, dugo ga nećete dobiti natrag
Za Old-school ekipu, uz pomoć GemRB-a moguće je zaigrati i sve Infinity engine igre (Icewind Dale, Baldur's gate serijali, kao i Planescape torment i Lionheart). Kontrola nije prilagođena do kraja tabletima, ali tko može odoljeti druženju sa Minscom i Booom iz fotelje?
SPAJANJE NA TV:
(link)
ARGUMENTI I MIŠLJENJE:
ZA:
* 8“ dijagonala – nit' premali nit' preveliki
* zadovoljavajući display, dobar brightness te kapacitivni multitouch ekran
* baterija iznad očekivanja
* dobra kvaliteta izrade
* video reprodukcija te mogućnost lakog spajanja na TV
* kvalitetna i atraktivna futrola
PROTIV:
* Jednojezgreni CPU
* softverske kontrolne tipke (back, menu, home, search)
* u kompletu nema slučalica, microSD kartice niti miniHDMI adaptera
* nema 3G/GPS
MIŠLJENJE:
Za 1600 kuna teško da se može naći nekvi bolji tablet jačih performansi, bolje izrade sa kapacitivnim ekranom. Ja sam osobno zadovoljan kupnjom, te ga osobno mogu preporučiti svakome tko misli potrošiti čim manje love za basic tablet dobre izrade i karakteristika.
_________________________________________________________________
Zadnje izmijenjeno od: nino. 08.05.2012. u 17:28. Razlog: Test spajanja na TV
potemkin.hr je offline   Reply With Quote
Staro 25.12.2011., 09:15   #2
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,626
Hvala na recenziji, meni se čini da je Prestigio prepakirao ovu Arnovu.
Ipak ovo mi se čini kao bolja kupnja. Ima ga u Kvarka za iste pare.
Jedino je malo deblji i ima bateriju manjeg kapaciteta, ali više pixela na ekranu sve to kompenzira.
S druge strane, vjerojatno možeš očekivati bolju podršku što se tiče apdejtova, a ako developerski bogovi daju, čak i ICS.
Zadnje izmijenjeno od: kopija. 25.12.2011. u 09:36.
kopija je online   Reply With Quote
Staro 25.12.2011., 09:37   #3
Postovi: 34,003
Nisi li spominjao da Energy nema Marketa? Sorry, ali u tom slučaju je Prestigio bolji.
Staro 25.12.2011., 12:10   #4
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,626
Autor coconut Pregled postova
Eh, da to mu je Ahilova peta definitivno.
Sorry, nisam htio zvučati negativistički, bitno je da si zadovoljan kupovinom.
Staro 26.12.2011., 10:40   #5
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Autor potemkin.hr Pregled postova
Ja se s ovim ne bih složio. Market po meni nije neophodan. Sve, ali apsolutno sve s marketa se može izguglati. Legalno ili drugačije. Na kraju krajeva, na to me naučio baš Prestigio, jer oni pola godine nisu imali podršku za market.
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
Zadnje izmijenjeno od: estugarda. 26.12.2011. u 10:47.
estugarda je offline   Reply With Quote
Staro 27.12.2011., 12:01   #6
taip@n
Master of the VCR
taip@n's Avatar
Postovi: 340
tnx
kad pogledaš cijene prestigia, zbrojiš sve fičrse i dodaš podršku, vrlo lagodne update firmwarea preko archosovog site-a, meni je prestigio pun pogodak... dobro, ima lošijih i boljih modela, ali sve u svemu za prosječne korisnike (ne za tehnički nabrijane freakove) je savršeno rješenje...
slažem se da market nije krucijalan, i prestigiov AppsLib nije za baciti...
mene 7070c savršeno zadovoljava po svim aspektima i bez rootanja i alternativnih romova, sve ovisi što tražiš od tableta. a ovi noviji modeli su još bolji...
♦ As i was going up the stair ♦ I met a man who wasn't there ♦ He wasn't there again today! ♦ I wish, I wish he'd stay away.♦
taip@n je offline   Reply With Quote
Staro 27.12.2011., 21:44   #7
fratartucko
Just married!!!!
fratartucko's Avatar
Lokacija: Zagreb-Bjelovar
Postovi: 85
Autor taip@n Pregled postova
Vlasnik sam Prestiđa 3384, naravno da ima gro mana, ali isto tako za 1200 ćuna nisam mogao ništa slično kupiti (nije da ne bih volio platiti više, ali isto tako volim platiti stambeni kredit i račun za plin)
Dovoljno brz, ima gingerbread, ma da ne duljim ja zadovoljan
fratartucko je offline   Reply With Quote
Staro 28.12.2011., 00:21   #8
s4vgR
s4vgR's Avatar
Postovi: 170
Jel možeš napisati kakav je uređaj s čitanjem PDF-ova. Konkretno, zanima me mogućnost skakanja sa stranice na stranicu (npr. s 54. na 132. ili sa sredine dokumenta na tri četvrtine), kako je to točno riješeno.
s4vgR je offline   Reply With Quote
Staro 28.12.2011., 12:02   #9
acer
Whatever :)
acer's Avatar
Datum registracije: Nov 2002
Lokacija: Rijeka,Bulevard
Postovi: 1,753
3g stikovi bi trebali raditi sa zadnjom verzijom FW-a.
Ja sam ga takodjer kupio i zasad sam zadovoljan,adapter sa miniUSB na usb ženski sam kupio u chipoteci za cijelih 6kn , adapter miniHDMI na HDMI sa takodjer jeftino kupio za 18kn
Ovaj tablet je isti kao i Mediacom Smartpad 810C
Nasao sam na talijanskom siteu alternativne FW-e,sa rootom, 3G stikovi kao i usb BT stikovi rade. Prema testovima baterija im traje skoro 8h.
Isprobat cu FW ove dane kad stignem, pa mogu i napisati samu proceduru flashanja ako ima zainteresiranih, mada je u principu vrlo jednostavno.
http://www.androidiani.com/forum/med...tpad-810c.html
Tu imate vise,site je inace na talijanskom,ja sam se posluzio Google translateom
GIGABYTE B450 AORUS PRO
Fractal Design Define XL R2
Chieftec A-80, CTG-750C, 750W
AMD Ryzen 5 3600
Be Quiet Dark Rock Pro 4
Asus Nvidia GTX 1060 OC Edition, 3GB
Avermedia Live Gamer HD Lite
GEIL Evo Spear AMD GASB416GB3200C16ADC, DDR4 3200MHz, kit 2x8GB
Kingston NVMe M.2, 1TB
LG BH16NS55 Bluray writer
LG GGW-H20L Bluray writer
27" Philips
Brother HL-2240
Das Keyboard 4 Professional, MX brown
Logitech mouse G402
Scanner HP Photosmart G3010
Cambridge Audio DacMagic 100
Scythe SDAR-2100 + Scythe Kro Craft Speaker SCBKS-1000
Windows 10 PRO x64
Zadnje izmijenjeno od: acer. 28.12.2011. u 12:17.
Staro 30.12.2011., 16:17   #10
sinke.ZG
sinke.ZG's Avatar
Postovi: 733
koji je zadnji softver za taj uredjaj
sinke.ZG je offline   Reply With Quote
Staro 30.12.2011., 16:48   #11
jeti
Datum registracije: Jul 2011
Lokacija: Bosna
Postovi: 12
hmm sto kazete na ovaj video izgleda da bi taj rockchip 2918 mogao pogonit ice cream sendwich.. sto znaci da bi prestigio multipad 5080b mogao dobit upgrade na 4.0 jel da?
jeti je offline   Reply With Quote
Staro 30.12.2011., 17:44   #12
acer
Whatever :)
acer's Avatar
Postovi: 1,753
Zadnja verzija softwarea je PMP5080B Firmware v.1.0.21, izaslo 28.12
AMD Ryzen 5 3600
27" Philips
Brother HL-2240
Logitech mouse G402
Windows 10 PRO x64
Staro 30.12.2011., 17:53   #13
Toncek
member
Toncek's Avatar
Lokacija: Dalmacija
Postovi: 758
@acer
Mozes li isprobati radi li 3G?
Toncek je offline   Reply With Quote
Staro 30.12.2011., 18:01   #14
acer
Whatever :)
acer's Avatar
Postovi: 1,753
A ne mogu jer izgleda adapter koji sam kupio ne radi,niti jedan stick ne prepoznaje.
Narucio sam ga preko Dealextrema,pa kad dodje mogu probat.
AMD Ryzen 5 3600
27" Philips
Brother HL-2240
Logitech mouse G402
Windows 10 PRO x64
Staro 30.12.2011., 18:11   #15
sinke.ZG
sinke.ZG's Avatar
Postovi: 733
Autor acer Pregled postova
sorry , mislio sam koja je zadnja verzija OS-a
Staro 30.12.2011., 18:57   #16
Toncek
member
Toncek's Avatar
Lokacija: Dalmacija
Postovi: 758
Sa Prestigio stranice:
New firmware update available (V1.0.18)
The new firmware allows now 3G Modem Support, meaning that you can connect your device to Internet anytime and anywhere with a 3G Modem by a provider of your choice.
Please note, in order to connect to 3g Modem you would need a separate MINI USB To USB Adapter.
Samo trebam potvrdu da radi s t-mobile usb stickovima pa ako netko uspije neka obavezno javi.
Staro 30.12.2011., 20:41   #17
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,626
Autor jeti Pregled postova
Taj update će doć od strane XDA developera.
Prestigio će prije izdat novi model sa ICS-om nego nadogradit postojeće modele.
Staro 31.12.2011., 11:27   #18
dfranc
Datum registracije: Nov 2011
Lokacija: Daruvar
Postovi: 308
Možda bi trebalo napraivti ovakav kabel.pozz
http://www.youtube.com/watch?v=p10LgZFIawo
http://www.youtube.com/watch?NR=1&fe...&v=E1Ovlii0Rec
http://www.youtube.com/watch?feature...&v=COkLEJGo6vo
Zadnje izmijenjeno od: dfranc. 31.12.2011. u 12:23.
dfranc je offline   Reply With Quote
Staro 31.12.2011., 12:25   #19
potemkin.hr
Akutna lijenčina
Lokacija: Fiume
Postovi: 1,834
Ho-Ho-Ho!
Zadnja verzija (v.1.0.21) dolazi u božićnom duhu krcata crapwareom (kojih 10ak trash i trial aplikacija, nasreću se sve mogu maknuti bez roota).
Nekakva primjetna poboljšanja u odnosu na prošli firmware nisam vidio, tako da nije obavezan upgrade...
Ima neki changelog za FW updateove da znate koja verzija što donosi? Tražio po netu pa nigdje naći...
Staro 31.12.2011., 20:03   #20
Mačak Pero
Mačak Pero's Avatar
Datum registracije: Dec 2011
Postovi: 8
Ho-Ho-Ho!
Uz svaki update dostupan na službenim stranicama, unutar .zip filea postoje release notes, koje donose popise izmjena aktualne i svih prijašnjih verzija. Ovo je uz zadnju verziju:
PMP5080BRU V1.1.16
1. Some OSD improved
2. add 3G function that user can connect internet with 3G dangle via USB Host
PMP5080B V1.0.17
1. Some OSD localization improvements
2. 3G sign was removed if it's not used
3.Power consumption improvement
PMP5080B V1.0.18 & PMP5080BRU V1.1.18
1. fixed security issue
PMP5080B V1.0.21 & PMP5080BRU V1.1.21
1. Update Prestigio launcher and weather widget
2. fixed some OSD issue
3. fix skype video call issue
4. 3G icon setting added
Što se tiče 3G, meni osobno nije potreban, jer za to koristim Wi-FI hotspot na HTC Wildfireu, ali vidio sam da na Prestigio Facebook stranici neki pričaju kako to koriste, pa tamo možda nađete više informacija. Također, naletio sam na jedan post sa pitanjem hoće li za PMP5080b biti dostupan Ice Cream Sandwich, na što je odgovoreno potvrdno, iako se konkretan datum ne spominje.
Zadnje izmijenjeno od: Mačak Pero. 31.12.2011. u 20:11.
Mačak Pero je offline   Reply With Quote
Staro 31.12.2011., 20:53   #21
jeti
Lokacija: Bosna
Postovi: 12
Autor Mačak Pero Pregled postova
PMP5080BRU V1.1.16
PMP5080B V1.0.17
hvala na ovoj vaznoj informaciji za Ice Cream Sandwich!
Znaci moci cemo i 3g koristit pomocu usb-a ekstra.. Nego može li mi tko reći jel mogu pomocu 3g usb modema koristit tj primati pozive, sms itd?
Zadnje izmijenjeno od: jeti. 02.01.2012. u 14:51.
Staro 05.01.2012., 14:44   #22
potemkin.hr
Akutna lijenčina
Lokacija: Fiume
Postovi: 1,834
Potvrđujem radosnu vijest
Čekamo daljnje vijesti kada nam ICS stiže...
Zadnje izmijenjeno od: potemkin.hr. 05.01.2012. u 15:04.
Staro 09.01.2012., 11:12   #23
ogy_dogy
ogy_dogy's Avatar
Datum registracije: Aug 2011
Lokacija: Viškovo
Postovi: 260
pohvale za review, ja se nisam uspio natjerati da ga napisem. Ugl moram reci da sam ugodno iznenadjen tabletom, za lagani gejming, gledanje video klipova, citanje knjiga tab je savrsen. Dimenzije su mi odlicne, 7" mi je premalo, 10 je preveliko, 8 mi taman stane u borsu =D
Sto se tice updejta moja preporuka je snimanje ovog zadnjeg jer omogucava skype video. Ova funkcija je jedna od osnovnih razloga zbog kojeg sam kupio ovaj model i bio sam razocaran u pocetku dok nije radio. Sad je sve 5. Sto se tice kamere za video pozive je dovoljna, jednu stepenica iznad nikakve. Iako sam probao i google goggles i fakat radi, ali je smotano jer je upereno u krivu stranu...
Jos jedna funkcija koju sam trazio je usb host, koji je naveden od strane prestigia i ne radi. Nabavio sam si taj adapter kao i kolega i nista mi ne prepoznaje, ni mis, stick, tipkovnicu... Nista. Vjerojatno radi samo sa 3g stickovima. Kontaktirao sam proizvodjaca u svezi s hostom i receno mi je da ga odnesem u servis. Problem je sto sam lijen i ne da mi se cekati mjesec dana da ga dobijem natrag, tako da cu jos malo sacekati. Ionako sam misljenja da je problem u romu koji bi trebao imati usb host opciju u postavkama...
P.s. Jos jedna sitnica, kupio sam si stylus za kapacitativni display i ... Bacoio novce =P jednostavno prelose radi, malo hvata pa malo ne.. Uzas, a ja sam mislio da ce biti nesto ko htc scribe =D=D
Eto toliko od mene. Sad se moramo samo nadati ics-u =)
ogy_dogy je offline   Reply With Quote
Staro 09.01.2012., 11:44   #24
acer
Whatever :)
acer's Avatar
Postovi: 1,753
Ovako sto se tice adapter koliko sam uspio naci na netu obicni adapteri ne radi.
Probao sam mini USB na USB zenski nista, preko adaptera usb(ž) na usb(ž) i opet nista.
Izgleda da mora biti bas OTG adapter jer je nekakva razlika izmedju obicnih adaptera i OTG adaptera,koliko sam skuzio OTG ima jos nekakav dodatni pin.
Vise o tome imate na linku ispod:
http://www.edn.com/article/492321-Un..._On_The_Go.php
http://www.maxim-ic.com/app-notes/index.mvp/id/1822
Narucio sam sa Dealextrema OTG adapter,poslan je i sad cekam da dodje pa cu probati 3G stick i obican USB stick.
http://www.dealextreme.com/p/mini-us...r-2-pack-50944
AMD Ryzen 5 3600
27" Philips
Brother HL-2240
Logitech mouse G402
Windows 10 PRO x64
Staro 09.01.2012., 12:38   #25
ogy_dogy
ogy_dogy's Avatar
Lokacija: Viškovo
Postovi: 260
Odlicno, javi ako uspijes
Staro 09.01.2012., 23:58   #26
jeti
Lokacija: Bosna
Postovi: 12
taman htio otic danas do linksa da si kupim prestigia 5080 kad ono na str pise artikal nije dostupan koji k***c...
Staro 10.01.2012., 00:21   #27
ogy_dogy
ogy_dogy's Avatar
Lokacija: Viškovo
Postovi: 260
Imaš ga u ventexu (ja sam tamo uzeo, bilo 30kn skuplje ali links ga nije imao pa reko j.. ga :P) a ima ti ga i netcom...
Zadnje izmijenjeno od: ogy_dogy. 10.01.2012. u 18:40.
Staro 10.01.2012., 00:27   #28
potemkin.hr
Akutna lijenčina
Lokacija: Fiume
Postovi: 1,834
Autor ogy_dogy Pregled postova
Imaš ga u vemilu (ja sam tamo uzeo, bilo 30kn skuplje ali links ga nije imao pa reko j.. ga :P) a ima ti ga i netcom...
To još posluje? Nisu kao propali a HG Spot im se skoro pridružio?
Staro 10.01.2012., 00:43   #29
jeti
Lokacija: Bosna
Postovi: 12
ee super ali jel ima vemil i netcom u Osijeku.. Iz bosne sam pa mi je Osijek nekakvih 85km tako da bi isao na sigurnu kupnju! Nanervira se za links sad kad sam skastio nema ga a jbt!
Gdje bi mogao naci u Osijeku ovaj tablet?
Zadnje izmijenjeno od: jeti. 10.01.2012. u 01:27.
Staro 10.01.2012., 07:18   #30
Postovi: 34,003
Zamoli nekog frenda da ti ga naruči poštom na svoju adresu.
