Staro 21.12.2011., 12:15   #1
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,491
Nvidia Forceware v290.53 beta driveri
This is the second beta release from the R290 family of drivers. For more information, read the 290.53 driver article on GeForce.com.
This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, 400, and 500-series desktop GPUs as well as ION desktop GPUs.
New in 290.53
Optimizations for The Elder Scrolls V: Skyrim
Increases performance by up to 25% in The Elder Scrolls V: Skyrim vs. 290.36 drivers (measured with GeForce GTX 560 at 19x10 Ultra – Indoor Scene). Results will vary depending on your GPU, system configuration, and in-game location.
Updates the NVIDIA Control Panel ambient occlusion support for The Elder Scrolls V: Skyrim to a higher performance profile.
Added new 3D Vision laser sight /crosshair options to better match Skyrim crosshairs.
For a full Skyrim tweak guide, visit GeForce.com.
NVIDIA SLI
Adds SLI profiles for Trine 2, WRC 2: FIA World Rally Championship 2011, and Afterfall: InSanity.
3D Vision
Fixes issues with Call of Duty Modern Warfare 3 not launching into 3D Vision mode
Added new 3D Vision laser sight /crosshair options to better match The Elder Scrolls Skyrim crosshairs
Added or updated the following 3D Vision game profiles:
AaaaaAAaaaAAAaaAAAAaAAAAA!!! for the Awesome – rated Good
The Adventures of Tintin: The Game – rated Excellent
Assassin’s Creed: Revelations – rating changed to Fair
Driver San Francisco – updated settings to work better in 3D Vision
Elder Scrolls V: Skyrim – updated in-game compatibility message
Hard Reset – updated in-game compatibility message. FXAA x2 and x4 are now supported by the game
Ignite – rated Good
Jane's Advanced Strike Fighters – rated Fair
Jurassic Park: The Game – rated Good
Orcs Must Die! – rated Good
PAYDAY The Heist – rated Poor
PT Boats - Knights of the Sea – rated Good
PT Boats - South Gambit – rated Good
Race 07 – updated in-game compatibility message
Race Room – rated Good
Serious Sam 3: BFE – rated Poor
SkyDrift – rated Good
Star Wars: The Old Republic – rated Good
Stronghold 3 – rated Good
Take on Helicopters – rated Fair
Trine 2 – rated 3D Vision Ready
Waves – rated Excellent
Key Bug Fixes
Fixes some random instances of triangular artifacts when playing Battlefield 3 (fix is now enabled for GeForce 400 and 500 series GPUs).
Fixes a default panel resolution/ timing bug in 290.36.
Other Details
Supports multiple languages and APIs for GPU computing: CUDA C, CUDA C++, CUDA Fortran, OpenCL, DirectCompute, and Microsoft C++ AMP.
Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, DirectX 11, and OpenGL, including 3-way SLI, Quad SLI, and SLI support on SLI-certified Intel and AMD motherboards.
http://www.geforce.com/Drivers
meni su evo bolji od .36 bete jer sam tamo imao problema sa rezolucijom u igrama, sad je ok
Staro 21.12.2011., 12:54   #2
mhadina
mhadina's Avatar
Postovi: 436
25%
Kako je u Skyrimu?
  • Vidiš li čovjeka koji se sam sebi mudrim čini? Znaj, i od bezumnika ima više nade nego od njega!
  • San dolazi od mnogo briga, a lud govor od mnogo riječi.
  • Neka su ti mnogi poznanici, ali pouzdanik samo jedan od tisuću.
  • Ne ponizuj se pred budalom i ne budi pristran pred mogućnicima.
  • Ne budi silovit na jeziku a lijen i mlitav na djelu.
mhadina je offline   Reply With Quote
Staro 21.12.2011., 16:16   #3
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,491
Staro 23.12.2011., 17:07   #4
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Skyrim gets up 25% per.
Mogu potvrdit da to nije daleko od istine. Sada je igra u pecinama i sl. zakucana na 60fps i ne mrda. Prije se znala spustit na 40. Govorim o stvarno visokim postavkama sa FXAA i tweakovima.
Staro 24.12.2011., 00:11   #5
Ivica121
Ivica121's Avatar
Datum registracije: Feb 2010
Lokacija: underground
Postovi: 71
Autor MAGARAC Pregled postova
Šta nije FXAA manje zahtjevan od klasičnog AA odnosno MSAA?
Ivica121 je offline   Reply With Quote
Staro 24.12.2011., 03:56   #6
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
FXAA injector ili kak se vec zove.
Problem sa Skyrimom je bio u zatvornem prostorima i onda bi fps pao za sa 60 na 50 ili manje. Vani nema problema kako god se narihta. Sad te razlike vise skoro da nema. FXAA bi trebao bit manje zahtjevan i je ali samo za Nvidiu dok radeonke imaju problema. AMD ima morfological AA koj je ekskluziva za njihove grafe ali po kvaliteti nije kao FXAA koji je jako blizu MSAA isto kao sto njihov Adaptive AA nije kvalitetan kao Nvidijin Transparency AA mada su to male razlike.
Zadnje izmijenjeno od: MAGARAC. 24.12.2011. u 04:06.
Staro 24.12.2011., 12:00   #7
Ivica121
Ivica121's Avatar
Postovi: 71
Ja koristim FXAA gdje god ga mogu uključit. Da se osvrnem na Skyrim, na otvorenom mi je radio super, ali u špiljama mi je štekalo i sad nakon ovih drivera igra radi super i vani i unutra.
Staro 02.01.2012., 17:59   #8
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Jel ima ko ovakav problem ?
Staro 03.01.2012., 11:56   #9
Autor xulos Pregled postova
imao frend. reinstalirao W7 i sad više nema. to je očito windows related error.
Staro 03.01.2012., 12:10   #10
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Jebat ga , neda mi se zato rusit winse .Snimio ja njih i rade ko podmazani
Staro 03.01.2012., 12:39   #11
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,853
nema sta to biti do winsa. Ili je java related problem, ili je krivo compajliran package za instalaciju.
