Staro 27.11.2011., 16:06   #1
dropTable
dropTable's Avatar
Datum registracije: Nov 2011
Lokacija: Vž
Postovi: 48
High-end ventilatori [12cm]
Prošlo je podosta vremena od kad se zadnji put pričalo o ventilatorima s kontrolom okretaja, tehnologije su napredovale, novi proizvodi su na tržištu.
U nastavku pogledajte tehničke karakteristike nekih od ventilatora koji pružaju kontrolu vrtnje, nisku razinu buke i viski stupanj protoka zraka. Pošto IRL ne mora biti onako kako je zapisao proizvođac, treba testirati. Uglavnom evo popisa:
ARCTIC F12
Max Noise: n/a - 25dBA
Fan speed: 400 - 1350RPM
Airflow: 74CFM
Warranty: 6yr
Scythe "KAMA PWM"
Noise: n/a - 24.89dBA
Fan speed: 310 - 1200 RPM
Airflow: 12.38 - 52.71 CFM
Life Expectance: 30,000 hrs
Coolermaster Excalibur
Noise: 13 - 30 dBA
Fan speed: 600 - 2000 RPM
Airflow: 26.4 - 85.6 CFM
Life Expectance: 100,000 hrs
Enermax UCTB12P
Noise: 8 - n/a dBA
Fan speed: 500 - 1,500 RPM
Airflow: 26.51 - 71.25 CFM
Nexus D12SL-12 PWM
Noise: 15.5 - 26,9 dBA
Fan speed: 500 - 2000 RPM
Airflow: n/a - 76 CFM
Life Expectance: n/a
Akasa Viper PWM
Noise: 6.9 -28.9 dBA
Fan speed: 600 -1900 RPM
Airflow: n/a - 83.63 CFM
Life Expectance: 50,000 hrs
Cooler Master Blade Master
Noise: 13 – 32 dBA
Airflow: 21.2 - 76.8 CFM
Life Expectance: 40,000 hrs
Coolink SWiF2-120P
Noise: 8.5 - 27.1 dBA
Fan speed: 800 - 1700 RPM
Airflow: 35.6-75.1 CFM
Gelid Solutions Wing 12 PL UV Reactive
Noise: 10 - 26.8 dBA
Fan speed: 600 - 1800 RPM
Airflow: n/a - 75.6 CFM
Warranty: 3yr
Noiseblocker NB-Multiframe M12-P
Noise: 12 - 29 dBA
Fan speed: 1000 - 2000 RPM
Airflow: 43 - 78 CFM
Warranty: 6yr
Scythe Kaze-Jyuni Slip Stream
Noise: 7.05 - 37 dBA
Fan speed: 470 - 1900 RPM
Airflow: 23 - 110 CFM
Noctua NF-F12 PWM
Noise: n/a - 22.4 dBA
Fan speed: 300 - 1500 RPM
Airflow: 54,97 CFM
Warranty: 6yr
ヽ(´ー`)ノ
Zadnje izmijenjeno od: dropTable. 27.11.2011. u 16:33.
dropTable je offline   Reply With Quote
Staro 27.11.2011., 16:40   #2
Postovi: 8,237
Dobar je popis, ali bi trebalo stalno nadopunjavati bazu jer ventilatora ima puno puno više na tržištu. Možda bi bilo zgodno da naznačiš koji su dostupni kod nas!
Staro 27.11.2011., 16:47   #3
dropTable
dropTable's Avatar
Lokacija: Vž
Postovi: 48
Autor Pupo Pregled postova
a da narucis prek neta?
ヽ(´ー`)ノ
Staro 27.11.2011., 16:57   #4
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
Autor dropTable Pregled postova
Da, super solucija, i platit poštarinu 50% vrijednosti venta.....
Staro 27.11.2011., 17:16   #5
dropTable
dropTable's Avatar
Lokacija: Vž
Postovi: 48
Autor jopis Pregled postova
ja se pitam kolko je "taj" vent meni vrijedan, a ne koja je samo cijena
ヽ(´ー`)ノ
Staro 27.11.2011., 17:17   #6
Elpresidente1
Datum registracije: May 2009
Postovi: 389
http://forum.pcekspert.com/showthread.php?t=185602
http://forum.pcekspert.com/showthread.php?t=222182
Dodaj rađe tamo da se ne razvodni sad na 100 mjesta, a već i ima.
Elpresidente1 je offline   Reply With Quote
Staro 28.11.2011., 11:33   #7
dropTable
dropTable's Avatar
Lokacija: Vž
Postovi: 48
Kakva su iskustva sa navedenim ventovima, ima li tko informaciju o boljem (i provjereno) high-end ventu?
ヽ(´ー`)ノ
Staro 28.11.2011., 13:13   #8
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,758
Kad se vec pise o high-end ventovima, mozda bi bilo dobro nadopisati iznos statickog pritiska,
posto je to jedna od vaznijih karakteristika kod hladjenja cpu-a ili stvaranja negativnog tlaka unutar kucista...
Sn4k3 je online   Reply With Quote
Staro 28.11.2011., 16:47   #9
Postovi: 8,237
Eo malo rezultata s testa sa pravom opremom u realnim uvjetima.
izvor: XS
Zanimljivo kako neki jeftiniji ventovi poput F12 stoje jako dobro na ljestvici, dok neki skupi i razvikani modeli podbacuju u testovima.
Zadnje izmijenjeno od: Pupo. 28.11.2011. u 16:57.
