Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Nvidia 71.84 Drivers
NVIDIA has released ForceWare version 71.84 beta drivers for Windows 9x, ME, 2000, and XP at their nZone web site. This driver has passed WHQL tests and will be posted at NVIDIA.com after receiving an electronic signature from WHQL, which is expected any day now. The new driver increases the performance of NVIDIA graphics processing units (GPUs) in single and multi GPU configurations. The number of games with SLI profiles has increased to over 70 titles and personal application profiles can be created using CoolBits. Više: http://www.nzone.com/object/nzone_do...etadriver.html Podržane igre i aplikacije: http://www.nzone.com/object/nzone_sl...ifiedapps.html NVIDIA SLI application Profiles using Coolbits: http://www.nzone.com/object/nzone_sli_appprofile.html |
Ronon Dex
Lokacija: DS9
Postovi: 1,625
Vrlo dobri driveri, rade mi odlično. Temperatura GPU-a se nije podigla, šta je boljka mnogih novijih beta drivera. |
Datum registracije: Feb 2004
Lokacija: 220 km/h a mozda i malo brze,cekam novi auto
Postovi: 180
ce biti dobri za 6800 ultru?
Lokacija: st
Postovi: 1,084
@ virty jesi možda proba 71.50 od leadtek-a? ako jesi koja ti je razlika u odnosu na 71.84?
ASUS K8N & Zalman NB32K @ HTT x3 / A64 3000+ 263x8 / 2x256MB TwinMOS @ 210 / Club3D 5200 & Zalman ZM80C-HP / Maxtor 30GB, 2MB / WD Caviar 80GB, 8MB / Maxtor DM10 250GB, 16MB / Xilence 420W / CoolerMaster Centurion 5 |
#6 | |
Ronon Dex
Lokacija: DS9
Postovi: 1,625
#8 | |||||||
Datum registracije: Jun 2004
Lokacija: Kaštela<->Varaždin
Postovi: 178
ja ih instalira i temperature iste ka i prije,jos nisam OC
Datum registracije: Jul 2004
Postovi: 151
Evo izasli su i offical 71.84, iliti NAPOKON offical drajveri nakon sto sam probo 100 beta ![]() |
Sruk
Datum registracije: Sep 2004
Postovi: 1,163
Driveri su super,prva koji su,po meni, bolji od onih zadnjih(koji nisu Beta) Uz njih sam napravio čudo od kartice! uf,nisam dobro pazio kad sam čito postove, mislio sam da se proča o BETI 71.84-pa sam misliona njih., sad skidam ove 71.84 Forceware |
#11 | |
Ronon Dex
Lokacija: DS9
Postovi: 1,625
Lokacija: Vrulja
Postovi: 484
Sto se mene tice 71.84Beta driveri su za sada najbolji driveri koi su do sada izisli. Kartica radi stabilno na 561/1180. dalje nisam probao jer mi temp. ide do 59°C pa se boim da se nesto neplanirano ne desi. Ako netko moze reci do kud moze temp. ici da znam dali je jos mogu kloknuti neka javi. Pozdrav Moki! |
The Dark Side of Moon
Postovi: 3,945
dobri su drajveri sam daju manje 3dmarka al koda je to bitno
#16 | |
Postovi: 293
Kakvih problema? Kak si skino temp dolje (samo nemoj reci da si mijenjao pastu jer nisam bas toliko upucen da bi to radio pa da jos shebem grafu), kuciste je dobro ventilirano (bas sam ga nedavno mijenjao)? |
#17 |
Sruk
Postovi: 1,163
imao sam sve OC,i bez ijednog dodatnog venta u kućištu... prvi problemi su se javili kad sam imo fx5200 OC tem u kutiji je otišla prek 42+C tak da sam moro skinut bočnu stranicu, onda je prašina naletila na cooler i temp je odlazila u visine-pa sam stalno moro čistiti. ali i unatoč čitom Cooleru i otvorenoj stranici temp je išla na 67C u igricama.i onda sam kupio novo kućište i clocknuo karticu na 450/1200-i temp ne dolazi ni do 55C. AeroCool Silver Engine-Links 506kn |
