Datum registracije: Apr 2004
Postovi: 301
WOW! ULTRA HIGH END ENTUSIAST PERVERZIJA ati mobo
omfg, da imam para, neda bi je kupio neg bi kupio 2 ![]() btw, procitate malo detaljnije opis, i obavezno pogledajte slikice, i shvaticete zasto je ovo jedna od boljih ploca koje sam vidio uzivotu ![]() CPU Power Delivery: -4 phase CPU power supply with the ability to deliver 170+ Amps -provision for passive, water block or active air cooled mosfets (heatsink form factor is the same as the northbridge) -voltage range to 2.7V but artificially clamped to 2.0V -voltage increments as fine as 20 mV Memory Power Delivery: -upto 30 Amps delivery potential -voltage range to 4.0V -voltage increments as fine as 20 mV -adjustable VTT (memory termination voltage) to +/- 10% of memory VDD NB Power Delivery: -NB core has it's own power rail with 4 discrete steps HT Power Delivery: - HT I/O has it's own power rail with 4 discrete steps PCI-E 1.2V Power Delivery: - PCI-E 1.2V I/O has it's own power rail with 4 discrete steps PCI-E 1.8V Power Delivery: - PCI-E 1.8V I/O has it's own power rail with 2 discrete steps Board Features: Onboard Devices: -twin Silicon Image SI3132 SATA II w/ NCQ chips connected via PCI-E, each chip providing 2 SATA ports. (8 SATA ports total; 4 are SATAI and 4 are SATAII w/NCQ) -Marvel Gigabit LAN connected via PCI-E -one general purpose single lane PCI-E slot (provisioned for 1 more single lane general purpose slot if one SI3132 is not populated as a build option) -Azalia audio support via SB450 using Realtek codec -POST code LED display -Firewire support with ViaVT6306 -VGA and DVI outputs via Radeon Xpress 200G (enabling upto 4 monitor outputs using an ATI add in card and ATI Surroundview) -onboard power and reset switches -onboard VID code LED display Overclocking Options: -HTT frequency upto 500 MHz -All relevant memory timings and adjustments including support for new Rev E CPUs -HT link ratios X1, X2, X3, X4,X5 -Independent PCI-E overclocking for the graphics bus Thermal Monitoring: -thermal monitoring of CPU power delivery circuitry, CPU, NB and ambient That's all I can remember for now. Here are some pictures of the motherboard and the custom Danger Den waterblocks that will be made available for sale specifically for this application. btw... vodeno hladjeni mosfeti? omg...
HARDCORE 4 LIFE athlon xp 2500+ @ 3200+ (11x200) gigabyte ga7n400l ( n force2 ) gigabyte radeon9600pro (@ 510/700 ) 2x256 Samsung ddr400 ŽENE SU KAO RAM, ŠTO VIŠE IMAŠ TO BOLJE |
Džabe si krečio!
Postovi: 5,191
U kujac! Moro si to postat! Sad padam u depru i molim boga da mi padne slučajno jedna s neba. Kak zgleda...vodeno na mosfetima, isssss, voltaže!!!!!!!!!! ![]() |
Lokacija: Ispred kompa
Postovi: 2,004
vec je postano u rubrici Overclocking. kasnis!
Postovi: 301
oh.. nisam vidio sry ![]()
