Staro 18.10.2011., 20:55   #1
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Arctic Cooling Accelero Mono PLUS
Specifikacije:
Max. Cooling Capacity 200 Watts
Heatpipe Ø 6 mm x 5
Heatsink Material Aluminum fins x 43, thickness 0.4 mm
Fan (mm) 120 mm, 400 - 1,500 RPM (controlled by PWM)
Bearing Fluid Dynamic Bearing
Noise Level 0.4 Sone
Current, Voltage 0.08A - 0.13A, 4.2V - 12.0V
Dimensions (Product) 136 (L) x 138 (W) x 51 (H) mm
Dimensions (Packaging) 140 (L) x 140 (W) x 58 (H) mm
Net Weight 348 g
Limited Warranty 6 years
Accessories
Heatsink 26 pcs
Screw (M2) 4 pcs
Washer 4 pcs
Spacer (2.0 mm) 4 pcs
Spacer (4.0 mm) 4 pcs
G-1 Thermal Glue (2.0 g Grey Compound) 1 bag
G-1 Thermal Glue (2.0 g White Compound) 1 bag
Mixing Wand 1 pc
4-Pin Fan Power Adapter 1 pc
VGA Bracket 1 pc
Mounting Plate 2 pcs
itemnumber DCACO-V430001-BL
UPC 0872767004665
Gross Weight 0.8 kg
Cijena: 59,95$
Podržane grafičke:
AMD Radeon
6000 6950, 6870, 6850, 6790, 6770
5000 5870, 5850, 5830
4000 4890, 4870, 4850, 4830, 4770
3000 3870, 3850
2000 2600 XT
1000 1950 XTX, 1950 XT, 1950 Pro, 1950 GT, 1900 XTX, 1900 XT, 1900 GT, 1800 XT, 1800 XL, 1800 GTO, 1650 XT, 1650 Pro, 1600 XT, 1600 Pro, 1550, 1300 XT, 1300 Pro, 1300
NVIDIA
GTX 560Ti, 560, 550Ti, 550, 465, 460 SE, 460
GTS 450, 250, 240 (OEM), 150 (OEM)
GT 340, 330, 320, 130 (OEM)
9000 9800 GTX+, 9800 GTX, 9800 GT, 9600 GT, 9600 GSO 512, 9600 GSO
8000 8800 GTX (G80), 8800 GTS 512 (G92), 8800 GTS (G92), 8800 GTS (G80), 8800 GT, 8800 GS (9600GSO)
7000 7950 GT, 7900 GTX, 7900 GT, 7900 GS, 7800 GTX 512, 7800 GTX, 7800 GT
6000 6800 XT AGP, 6800 XT, 6800 Ultra Extreme, 6800 Ultra, 6800 LE, 6800 GT, 6800 GS AGP, 6800 GS, 6800 AGP, 6800, 6600 LE, 6600 GT AGP, 6600 GT, 6600 DDR2, 6600
Recenzije: Nema
Conclusion: Iako bi valjalo pričekati koji review i da vidimo cijenu kad dođe u nas (Links/ADM-a), smatram da je bolja kupovina (i po pitanju cijene i performansi) AC S1 rev. 2 s neka 2 vulgaris 12cm venta (nažalost trenutno nedostupan).
Kao šta stara "poslovica" kaže Fata je Fata ali dvaput je dvaput - odnosi se na broj ventova
Pomelo mi sig -.-
Staro 19.10.2011., 14:12   #2
b1tterman
Takozvani influenser
b1tterman's Avatar
Lokacija: Dublin
Postovi: 650
zanimljiv dizajn, samo u kakvo kućište stane ta grdosija?
b1tterman je offline   Reply With Quote
Staro 19.10.2011., 14:20   #3
Postovi: 8,231
Kupujte S1 dok ih još ima, sigurno će bit EOL
Autor b1tterman Pregled postova
Ke?
Staro 19.10.2011., 15:39   #4
Drvoje
Drvoje's Avatar
Postovi: 4,037
Daleko je to od grdosije - ovo je praktično uvećani Arctic Cooling L2 Pro, pogledaj malo njihove druge modele (ili drugih proizvođača), taman je nekakve "srednje" veličine/težine
Autor Pupo Pregled postova
S1 PLUS je ionako tek proizveden (valjda je to duhovni nasljednik), samo je pitanje Linksovih "nameta" , u odnosu na S1 Rev. 2
Alternativa je naravno lurkanje polovnjača po tržnjacima
Pomelo mi sig -.-
Staro 19.10.2011., 16:30   #5
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
S obzirom da GTX 470, GTX 465, GTX 480, GTX 570, GTX 580 nisu podrzane, cemu ovaj kuler ?
Staro 19.10.2011., 16:46   #6
Postovi: 8,231
Autor xulos Pregled postova
Pa low/mid segmentu, tako i izgleda uostalom. Jedino cijena nije low. Jel ti izgleda baš da bi mogao držat te kartice hladnje?
Staro 19.10.2011., 20:12   #7
Elpresidente1
Datum registracije: May 2009
Postovi: 389
Pa S1 rev 2 bude sigurno EOL, ali zato postoji S1 PLUS. Isti vrag sa nekom plastikom okolo i pomaknutom bazom. Ljepši mi je stari iako ovaj novi paše i na moju kartu.
Edit: a j.g sori nisam pročital taj tvoj post poslje, kad sam tup.
Zadnje izmijenjeno od: Elpresidente1. 19.10.2011. u 20:56.
Elpresidente1 je offline   Reply With Quote
Staro 19.10.2011., 20:22   #8
Drvoje
Drvoje's Avatar
Postovi: 4,037
Autor Drvoje Pregled postova
Autor Elpresidente1 Pregled postova
"Yes captain obvious!"
Inače izgledom oba nisu ništa specijalno (S1 + i S Rev. 2), posebno kad DIY metodom prikeljiš par ventova, ali koga uopće briga za ljepotu - važna je termalna učinkovitost i cijena
Usput thread je o AC Mono + modelu
Pomelo mi sig -.-
Staro 19.10.2011., 21:29   #9
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
jedino za gtx 480 i 580 nisam siguran ali 470ku i ostalu ekipu bi drzao u granicama normale, 350 grama i 5 hitpajpi nije uopce lose.
BTW : http://www.kitguru.net/components/gr...oler-review/2/
Ovo su takva dva "spojena" obicnim komadom lima da se drza jedan za ddrugi i hlade 6990, IMHO ako je 1 takav u stanju ohladiti 1 gpu od 6970 mislim da bi i ove nvidie izdrzao
Staro 19.10.2011., 21:53   #10
Postovi: 8,231
Kom će onda prodat ostale kulere ak ovaj bude mogao na sve
Staro 19.10.2011., 21:53   #11
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
470 je gora od bilo koje AMD kartice za ohladit i ovaj polovicni hladnjak nebi bio optimalan izbor za nju..AMD se moze hladit i sa slabijim hladnjacima a high end Nvidia nema sansi..
Sve je savrseno jasno kad se otvore grafe i stave jedna pored druge, nebo i zemlja..
MAGARAC je online   Reply With Quote
