Staro 26.07.2011., 22:48   #121
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Cooler Master Intros Hyper 612S CPU Cooler
Cooler Master rolled out its newest performance CPU cooler, the Hyper 612S. It is a large tower-type heatsink that is designed to maximize heat dissipation at lower fan speeds. It does so with a different orientation of copper heat pipes. The heat pipes pass through the base, and along the length of the aluminum fin stack, rather than its breadth. As a result heat is dissipated more uniformly along the air column. The fins are designed to curve air path, to improve heat dissipation. Ventilation is care of a 120 mm fan, although there's provision for dual fan "push-pull" set up.
The cooler measures 140x128x163 mm, weighing 806 g. The bundled 120 mm fan has a top speed of 1300 RPM ±10% pushing 52.6 CFM of air, and uses a 3-pin fan connector. A "Silent mode adapter" (intermediate resistor) slows it down to 900 RPM, reducing its air flow to 36.4 CFM. Between full speed and silent modes, the rated noise levels vary between 22.5 and 16.1 dBA. The Hyper 612S supports all current CPU socket types, including Intel LGA1366/1156/1155/775, and AMD Socket AM3/AM2+/AM2. Available in the markets by S
eptember, the Hyper 612S is expected to be priced around 45 Euros.
C L O W N I N G A R O U N D
Staro 26.07.2011., 23:47   #122
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Autor mhadina Pregled postova
Ovo bi kao trebala biti revolucija zračnog hlađenja odnosno by by vodeno
Kad ja to vidim na Q6600 overvoltanom a da se ne topi lagano, onda može proć
Mislim, ideja je zanimljiva.
@Doink - pajpova nikad dosta, ocito cemo cekat jos 9 godina da se netko sjeti ruknut gore 76 pajpova
Staro 02.08.2011., 11:40   #123
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
MAGARAC je online   Reply With Quote
Staro 19.08.2011., 08:40   #124
Doink the Clown
Postovi: 6,214
Cooler Master Unveils GeminII S524: Ultimate Versatility Realized
Cooler Master, an industry leading chassis, thermal solution, peripheral, and accessory manufacturer, uncovers the ultimate follow-up to the widely popular GeminII CPU Cooler, the GeminII S524. The GeminII S524 is the embodiment of versatility, efficiency, and silence.
GeminII S524, a unique alternative to traditional CPU & system memory cooling. Rotated 90 degrees, it harnesses the constant flow of cool air from the side of the system and directs it to the heatsink fins to cool the CPU. Unique to this design, the GeminII S524 channels a portion of this cool air to the system memory to help dissipate the heat generated by critical system components. Benefiting from a larger heatsink surface area, increased clearance for high-end system memory modules, and an easily upgradeable fan, the GeminII S524 claims its position as a transformative cooling solution while maintaining an impressive performance-to-noise ratio.
Electroplated Copper Base and 140mm Fan Support
GeminII S524 is an evolutionary new step in CPU cooling. It features a total of five high-grade 6mm thick copper heat pipes that emerge from a large copper base that, combined, offer optimal heat conduction; quickly spreading and removing heat generated by the CPU. To prevent corrosion of its copper surfaces without impacting its heat conductivity, the GeminII S524 base and all heat pipes have been electroplated with a microscopic layer of nickel. The increased surface area of the heatsink and revised fin design of GeminII S524 not only improve its cooling performance but allow for the installation of a 140mm fan, making it a highly flexible cooling solution suitable for any computing environment.
The GeminII S524 will be available worldwide in August 16th, 2011 for $39.99 MSRP at retail and online locations that carry your favorite Cooler Master, CM Storm, and Choiix products.
Staro 24.08.2011., 10:46   #125
Dottore
Dottore's Avatar
Postovi: 7,619
Alpenfohn Triglav
EKL will release the Alpenföhn Triglav in September, the first CPU cooler with three 10mm heatpipes. The cooler is equipped with a 120mm fan and supports Intel LGA 775/1155/1156 and AMD AM2/AM2+/AM3/AM3+/FM1 processors.
Triglav comes equipped with a 120mm Hydro Bearing fan operating at 850 to 1500 RPM (21.4 dB sound output), is bundled with some thermal compound, and has a recommended price tag of €39.90
Alpenföhn Triglav CPU Cooler Review
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 03.09.2011., 00:52   #126
Dottore
Dottore's Avatar
Postovi: 7,619
Phanteks PH-TC14PE_RD
With summer almost behind us as always we will see many new products introduced into the market from just about every company in the world in order to make it in time for the Christmas shopping spree we are all used to. What is really rare however is to see new companies emerge just after the summer period and today on our test bench we have a product by one such company called Phanteks. The product in hand is called the PH-TC14PE and as you can see from the above image it's a very large sandwich type CPU Cooler.
Phanteks PH-TC14PE_RD CPU Cooler Review
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 06.09.2011., 22:50   #127
Doink the Clown
Postovi: 6,214
MSI Develops Dust Removal Technology for Graphics Cards
Off late, MSI has been at the forefront of graphics card innovations. The latest is what the company refers to as "Dust Removal Technology". Dust buildup on the surface of heatsink fins can reduce cooling efficiency. Without giving us too many details about its testing, MSI claims that a
clean cooler can keep temperatures down by as much as 15°C. Dust Removal Technology uses a simple method of running fans in the opposite rotation, drawing air from the heatsink and pushing it out through its intakes, with 100% fan speed for 30 seconds at system startup can work to reduce dust accumulation in the tough to clean parts of the cooler. Since the "dust removal" happens on each system startup, cleaning happens on a very regular basis. MSI plans to implement the Dust Removal Technology on all its new and upcoming graphics cards.
Staro 06.09.2011., 22:57   #128
Postovi: 8,201
Dobro da su se sjetili, taj sistem se na nekim drugim stvarima/sistemima koristi valjda otkad postoje ventovi koji su pokretani elektromotorom.
Staro 13.09.2011., 22:30   #129
Doink the Clown
Postovi: 6,214
Alpenfohn Unveils Himalaya High-End CPU Heatsink
Alpenfohn unveiled its latest high-end CPU cooler, the Himalaya. Decked entirely in aluminum and nickel-plated copper, the Himalaya is a large tower-type cooler, with added innovations in the spread of heat pipes through the aluminum fin stack and the arrangement of fins in the stack itself. From the base, six U-shaped nickel-plated copper heat pipes arise, passing through the aluminum fin stack along the length and breadth of the aluminum fins. Fins are arranged in inverted sets of five producing a pattern along the column of the stack, which works to improve heat dissipation.
As a large heatsink the Alpenfohn Himalaya measures 40 x 164 x 55 mm, weighing 880 g. It makes use of a 140 mm Wing Boost PWM-controllable fan that spins between 300 to 1100 RPM with 10 to 19.4 dBA rated noise output. The cooler is compatible with all modern CPU socket types available in the market, including Intel LGA1155, LGA1156, LGA1366, and LGA775; and AMD FM1, AM3+, AM3, AM2+, and AM2. It will be priced at €59.90.
http://www.techpowerup.com/151997/Al...-Heatsink.html
Staro 24.09.2011., 12:41   #130
Dottore
Dottore's Avatar
Postovi: 7,619
HR-02 Macho
HR-02 Macho
Heatsink Specifications:
Dimension: Length 140mm x Width 102mm x Height 162mm
Weight: 860g (including fan and mounting brackets)
Heatpipe: 6mm heatpipe*6 units
Copper Base: C1100 Pure copper nickel plated
npr. razlika od HR-02
Size: Length 110mm x Width 140mm x Height 160mm
Weight: 860 g (excluding fan and bracket system)
Heatpipe: 6mm sintered heatpipe *6 units
Copper base: C1100 pure nickel plated copper base
Review:
Hardcop
Benchmarkreviews.com
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 24.09.2011., 18:17   #131
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Učinkovit hladnjak i dobra MSRP od cca 40$.
Pitanje je oće li doć do Linksa, i po kojoj cijeni (vjerojatno cca 300kn) -.-
Pomelo mi sig -.-
Staro 24.09.2011., 18:43   #132
cccp
cccp's Avatar
Datum registracije: Feb 2004
Postovi: 1,030
Čitao sam HardOCP review pred koji mjesec i čudio se cijeni od 40 dolara za tako dobar hladnjak.
cccp je offline   Reply With Quote
Staro 24.09.2011., 21:10   #133
Dottore
Dottore's Avatar
Postovi: 7,619
Točno, u Austriji sam vidio cijenu 38,7 eura sa standarnim 140mm vent., a dok pravi HR-02 bez venta dođe 45,7 eura. Znači, razlika u 7 eura
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 29.09.2011., 18:53   #134
Doink the Clown
Postovi: 6,214
Prolimatech Announces Panther CPU Cooler
Prolimatech presents the Panther, their newest CPU cooler aimed to take the mid-range by storm, while featuring the same excellent quality as all products from Prolimatech. Besides the mounting for all modern AMD and Intel based systems, the Panther CPU cooler also includes a 120 mm fan with PWM functionality. This complete package manages to impress with an excellent price/performance ratio.
Prolimatech has set the bar with the high-end Genesis cooler, so it is only natural that the company takes their experience and engineering capabilities and develop the Panther, a potent solution for the mainstream market. The Panther utilizes less material in the most efficient manner possible, keeping a maximum of surface area while offering compact dimensions. It is also the first CPU cooler from Prolimatech which ships with a fan.
Prolimatech has taken its inspiration for this new cooler from the Armageddon, which results in the same excellent performance at a brand new price point. Both feature the same heatpipe shape, with the only difference being the number of such element as the Panther offers four 6 mm pipes.
In terms of construction, the cooler makes no compromises and offers the same level of quality as one has come to expect from Prolimatech. High quality Nickel plating has been applied to the entire cooler which does not only protect the unit but also results in a great look and feel. On top of that, the crossed fins increase the robustness of the Panther cooler.
The sophistication of this construction also shows in the shape of the heatpipes. These end in a row next to each other, so that each of them has unrestricted access to the fresh airflow of the included fan. This maximizes the efficiency of the Panther CPU cooler, while keeping the dimensions to a minimum.
The 120 mm fan with PWM connector can be controlled automatically by every modern mainboard in the market to keep the noise to a bare minimum. This cooling unit also features transparent red blades along with red LEDs. Prolimatech has also included a second set of clips, allowing the installation of another such fan for a push/pull configuration, further raising the performance bar on this cooler. Also part of the package is the award winning PK-1 thermal past and the very sturdy mounting kit with backplate for Socket 1155, 1156, AM2, AM2+ and AM3.
The Prolimatech Panther CPU cooler is available immediately for a price of 39.90 Euro on www.caseking.de.
Staro 04.10.2011., 13:56   #135
Doink the Clown
Postovi: 6,214
Arctic Intros Accelero Twin Turbo 6990 Graphics Card Cooler
Arctic slipped in the latest member in its reputed Accelero Twin Turbo series of graphics card coolers, the Accelero Twin Turbo 6990. As the name suggests, it is tailored for the top of the line AMD Radeon HD 6990 dual-GPU graphics card. The cooler is designed to cool everything on the obverse side of the PCB, that includes the two AMD Cayman GPUs, the VRM, and the bridge chip.
The cooler's design consists of two main heat-pipe fed heatsinks over the two GPUs cooled by 120 mm fans, which are connected by a common base. The main heatsinks maintain contact with the GPUs through cutouts in this base, while other components pass heat on to the base. There is a third central heatsink that relies on the air-flow from the two ventilated heatsinks. In all, the heatsink measures 300 (L) x 138 (W) x 50 (H) mm, and weighs 820 g. It doesn't replace the AMD reference backplate, so PCB bending is checked that way. Backed by a 6-year warranty, the Accelero Twin Turbo 6990 is priced at US $150.
Staro 11.10.2011., 09:06   #136
Doink the Clown
Postovi: 6,214
Sandy Bridge-E Stock Watercooling: Enthusiast Overclocking Right Out Of The Box
Intel have finally confirmed that they will be including water cooling as an enthusiast solution for their upcoming Core i7-3000 series Sandy Bridge-E processors due for release on November 14 – a first for Intel and something for AMD to match. They have gone with Asetek due to their high quality products and good reputation, which will be branded with the distinctive Intel blue logos. The 12cm radiator fan will actually be illuminated in Intel Blue, giving a classy look to the kit. On top of that, they will actually sell the kit separately, so no one need feel left out. The E-series chips are already significantly faster than the current Sandy Bridge offerings, but water cooling will be able to stretch that lead even further and should make for some exciting overclocking achievements. Perhaps 6GHz or more 24/7 reliable operation is within reach? No prices as yet.
Staro 14.10.2011., 09:33   #137
Doink the Clown
Postovi: 6,214
Zalman Announces CNPS12X High-End CPU Cooler
Zalman announced its latest high-end CPU air cooler, the CNPS12X. This beast was first shown to public at this year's Computex trade-show, back in early June. Between then and now, the CNPS12X got some important retention module changes that make it fully compatible with the upcoming LGA2011 socket on which "Sandy Bridge-E" Core i7 processors are based, as well as AMD AM3+ and FM1. Measuring 151 x 132 x 154 mm (L x W x H), and weighing exactly 1 kg, the CNPS12X uses a design that's essentially identical to that of the NH-D14 from Noctua, that of two fin stacks. It's just that the stacks here are somewhat circular in shape, and that the CNPS12X uses three fans: an intake (before the first stack), a conveyer (between the two stacks), and an exhaust (after the second stack). All three fans are 120 mm in size, and are illuminated by blue LEDs.
The fans seem to be using 3-pin (voltage) method of speed control. Supplied with the cooler are three RC5 intermediate resistors, which make the fans spin at speeds between 850 and 1100 RPM with as low as 22 dBA noise output. Without the RC5, the fans spin between 950 and 1200 RPM, with at least 24 dBA noise output. The heatsink is made almost entirely of dark nickel-plated copper, with certain aluminum parts. Heat is conveyed to the two copper fin stacks by six nickel-plated copper heat pipes, that make direct contact with the CPU at base. Zalman did not give out pricing and availability information.
Staro 15.10.2011., 08:10   #138
mhadina
mhadina's Avatar
Postovi: 436
Vidim da se išlo više na propuh nego disipacijsku površinu. Zgodan je al bit će skup, mislim si ak je 11X bio preko 500, ovaj moguće prebaci 600kn...
Za Sandy ionak manje važno jer se ne grije, jedino ko voli nove igračke i testirati...taj ga čeka
  • Vidiš li čovjeka koji se sam sebi mudrim čini? Znaj, i od bezumnika ima više nade nego od njega!
  • San dolazi od mnogo briga, a lud govor od mnogo riječi.
  • Neka su ti mnogi poznanici, ali pouzdanik samo jedan od tisuću.
  • Ne ponizuj se pred budalom i ne budi pristran pred mogućnicima.
  • Ne budi silovit na jeziku a lijen i mlitav na djelu.
mhadina je offline   Reply With Quote
Staro 15.10.2011., 12:57   #139
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,853
3 venta?
Izgleda kao jet motor sad, nadam se da je tiši.
Spoiler alert!
Staro 15.10.2011., 13:13   #140
BojanZD
BojanZD's Avatar
Postovi: 1,398
Stvarno nepotrebno 3 venta + što su ventovi specifični samo za taj cooler i nemoš stavit neki drugi vent ako poželiš, il ne daj Bože rikne jedan od ova 3 zalman venta.
BojanZD je offline   Reply With Quote
Staro 15.10.2011., 13:40   #141
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,853
Nisam iskomentirao onaj intelov rashladni sistem, moram reći da iako vrlo sličan H50 ima puno bolje riješene cijevi. Ova rebrasta su smeće na H50, prelako pucaju.
Spoiler alert!
Staro 15.10.2011., 14:05   #142
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Autor BojanZD Pregled postova
Slazem se s navedenim, ali svejedno mislim da ce ovaj cooler biti zvjerka. Jedino ce cijena vjerojatno biti paprena..
Staro 15.10.2011., 14:26   #143
Postovi: 8,201
Autor Sn4k3 Pregled postova
To je men ista špranca ko i ona 9500 serija koja se baš nije proslavila... Sumnjam u dominaciju tog zalmana...
Zadnje izmijenjeno od: Pupo. 15.10.2011. u 15:03.
Staro 15.10.2011., 15:10   #144
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Meni prije lici na 9900 max modele (mozda si na to mislija) - a on je, svidjalo se to nama ili ne, jako dobar cooler...
Pogledaj samo usporedbu tog CNPS 9900 MAX sa H100 - Link. Evo i review tog hladnjaka...
Zadnje izmijenjeno od: Sn4k3. 15.10.2011. u 15:16.
Staro 15.10.2011., 16:03   #145
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,544
To je mi djeluje nemoguce da je on s tih 6 hitpajpi i tom velicinom/tezinom bolji od NH-D14 ili od H100... nemoj misliti da napadam tebe, nego jednostavno mi je cudno da je bolji i to za toliko stupnjeva
Staro 15.10.2011., 17:57   #146
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Da, meni je takodjer bilo cudno - no ipak je guru3d vjerodostojna stranica, a napominju da je ambijentalna temperatura iznosila oko 21 stupanj ako se ne varam..
Na drugim reviewima je primjerice performansama slican Prolimatech-u Super Mega, no spominju nesto visu ambijentalnu temp (oko 25-26 stupnjeva).
Dobro, ipak pricamo o cooleru koji prakticki samo izgledom lici na novi CNPS12X - ostale karakteristike su razlicite. Koliko ce se to odraziti na performanse, vidit cemo.
No kad se radi o estetici i obradi opcenito (pogotovo baze), IMHO Zalman radi jedne od najlipsih coolera.
Zalman CNPS 12X First Look
Zadnje izmijenjeno od: Sn4k3. 15.10.2011. u 18:04.
Staro 15.10.2011., 18:16   #147
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Autor xulos Pregled postova
Zasto se bezveze opterecujete oko idle temperature koja je ionak najmanje bitna. Ja imam na 20 c sobne od 20 do 25c idle sa H100, poprilicna razlika od njihovih 33c ali to je najmanje bitna stvar. Ni DH14 a pogotovo h100 nece pokazat zube sve dok se proc posteno ne nakloka sa puno voltaze. Onda nastaju razlike u loadu a ovi testovi na stock postavkama i blagi OC ne govore dovoljno.
Mislim da je sad vec vrijeme da se hladnjaci usporeduju na SBovima ili cak na FXovima, kad dodu jer su to procevi kaj potezu do 5ghz na zraku sto je velika razlika u odnosu na 4.0 ili 4.2 na starijim procevima a osim toga ak je dobar na jednom ne znaci da ce usto tako dobar bit i na drugom.
Zadnje izmijenjeno od: MAGARAC. 15.10.2011. u 18:31.
Staro 17.10.2011., 16:20   #148
w0lfram_
Rasvjetno tijelo
w0lfram_'s Avatar
Postovi: 374
bome cijena i je paprena, pojavija se u našim webshopovima, najniža cijena 719kn
LINK NA NABAVU
Pošteni trgovci: 1, 2, 3, 4, 5, 6, 7, 8, 9,10
w0lfram_ je offline   Reply With Quote
Staro 20.10.2011., 10:00   #149
Doink the Clown
Postovi: 6,214
Cooler Master Announces Hyper 412 PWM CPU Cooler
Cooler Master, an industry leading chassis, thermal solution, peripheral, and accessory manufacturer brings a new CPU cooler to light, the powerful Hyper PWM CPU Cooler, which targets a delicate balance between cooling potential and noise. The Hyper 412 PWM perform extraordinarily well while maintaining minimal noise levels.
The Hyper 412 PWM CPU Cooler is designed for optimum heat dissipation at low fan speeds. This is thanks to wider fin gaps and a precise heat pipe layout that directs each of their four heat pipes across CPU “hot zones”. These heat pipes are arranged using Cooler Master’s patented CDC™ technology, creating a virtual vapor chamber for maximum cooling potential. The 412 PWM comes with a high-grade PWM that is controllable via BIOS and OS-based tuning applications.
Easy installation of fans and dual fan design options
End your reliance on other, more time consuming, fan mounts with the included quick-snap brackets. With these brackets, changing, adding, and cleaning fans become a simple task that requires only a few moments of your time. Those with more extreme cooling needs may attach an optional second fan with the extra included quick-snap fan brackets. Whatever the application, the Hyper 412 PWM presents versatile cooling options that tailors noise and performance to any need. Covering all of their bases, Hyper 412 PWM comes ready to mount the latest Intel LGA 2011 and AMD FM1 processors.
For more information, visit the product page.
http://www.techpowerup.com/153823/Co...PU-Cooler.html
Staro 20.10.2011., 19:09   #150
Drvoje
Drvoje's Avatar
Postovi: 4,037
Taj Hyper 412 nomenklaturom, dimenzijama i (vjerojatno) učinkovitošću se smješta između Hypera 212+ i Hypera 612S.
Dakle cijena između 269 i 349kn - nadam se blizu ove prve
Pomelo mi sig -.-
