Staro 11.10.2011., 23:24   #1
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,795
Dobavljiva low profile graficka s podrskom za 3 monitora
Pozdrav svima,
trenutno u masini imam GT 520 koja (navodno) ne podrzava output na 3 monitora. OK, nema veze, rekoh, valjda ATI ima nesto, kad ono busanje u prsa u specifikacijama kako sve kartice podrzavaju sa zeljenim chipom 3, ako ne i 4 monitora.
Kad ono, prc Milojka - http://www.gigabyte.com/products/pro...px?pid=3835#sp -> Multi-view - 2
Postoji li neka graficka koja ce bez problema hendlati 3 monitora a da je low profile?
http://www.techpowerup.com/reviews/S...Passive/3.html tj. http://www.adm.hr/product_info.php?c...ucts_id=10274; moze li netko potvrditi ovo: "Display connectivity is one DVI port, one full size HDMI port and one removable analog VGA output. On higher-end AMD cards we usually see quite expansive display output options, the HD 6450 limits them slightly by using a DVI output that does not carry an analog VGA output signal. Nevertheless, you may still use up to three displays at the same time.", obzirom da http://www.sapphiretech.com/presenta...=&lid=1&leg=0# nista ne kaze o tome...
Programer
Zadnje izmijenjeno od: Bubba. 11.10.2011. u 23:35.
Staro 11.10.2011., 23:35   #2
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Ovo bi moglo bit to kaj tražiš.
Opis
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 11.10.2011., 23:38   #3
Perki
Lokacija: VG
Postovi: 775
Ovako nešto?
http://xfxforce.com/en-gb/products/G...ries/6450.aspx
http://www.nabava.net/trazilica.php?tp=0&q=xfx+6450
Ključ kod ATI kartica je da barem jedan od izlaza mora biti displayport. Bez toga nema eyefinity-a. Trebat će ti još i adapter (dongle), ako priključuješ na monitor bez istoga.
http://xfxforce.com/en-gb/Products/A...sOverview.aspx
http://www.nabava.net/trazilica.php?tp=0&q=xfx+dongle
Kod nvidie za tri monitora trebaju dvije kartice.
Trust me - I know what I'm doing!
Perki je online   Reply With Quote
Staro 11.10.2011., 23:40   #4
Postovi: 7,568
Autor Bubba Pregled postova
Možeš i na GeForce modele spojiti više od dva monitora, samo kaj je kod nas teško naći kartice poput Zotac GTX 550 Ti Multiview. AMD-ATi podržava i do pet-šest monitora na jednoj kartici, ali biseri to čuvaju za skuplje modele i onda ih nakrcaju sa svom silom HDMI, DVI i Display Port tehnikalija, pa si kombiniraš kaj ti treba. Low-profile su općenito najlošije opremljeni, ali ovaj Zotac ili Galaxy i PowerColor imaju pokoji nestandardni model opremljen samo s digitalnim izlazima za više od dva monitora. Raspitaj se da li koji od naših dućana može naručiti te egzotične modele, jer u suprotnom si osuđen na gamersko-clockerske verzije.
Staro 11.10.2011., 23:52   #5
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,795
Opis
Eh, jes, kao sto sam editirao u postu, samo me poprilicno muci radi li to u praksi...
Eh, bas to. Naravno, eventualno u ovoj Safiretovoj izvedbi...
Trenutno na GT 520 imam dva Zmazunga, jedan na DVI a drugi na HDMI->DVI adapteru. Jel' aktivan ili nije, pojma nemam, kako to provjeriti?
Autor McG Pregled postova
Ova ne da nije low profile, nego je dupla.
Ma u nacelu me boli cuna kakvi ce izlazi biti, tj. treci moze komotno biti analogni, jer ce ionako vrtiti monitor za telku. Ali mi je strahovito bitno podrzava neki suvisli overlay na tom trecem izlazu, kako ce se na tome vrtiti telka s TV tunera i HD p0rn.
Programer
Staro 12.10.2011., 00:09   #6
domis
Lokacija: Hrvatistan
Postovi: 4,165
ako me pamcenje dobro sluzi, sve matrox grafe su mogle vise od 2 monitora upogoniti i prije eyefinity-a pa bi mogel mozda u tom smjeru pogledati, mozda su negdje jos koji modeli ostali na policama
evo vidim u melcompu ih ima
http://www.melcomp.hr/katalog/index.cgi
Staro 12.10.2011., 00:35   #7
Perki
Lokacija: VG
Postovi: 775
Uf, sorry, zayeb. Malo bolje sam pogledao, ono je hdmi, a ne display port. Bez toga ništa. Još jednom, barem jedan od izlaza mora biti displayport.
Traži dalje.
EDIT: Kod xfx-a ima jedan 5450 model koji bi odovarao, al ostaje pitanje dobavljivosti.
http://xfxforce.com/en-gb/products/G...?product=34876
Zadnje izmijenjeno od: Perki. 12.10.2011. u 00:56.
Staro 12.10.2011., 01:42   #8
ThePornstar
Postovi: 4,403
Za početak, mislim da bi najbolje bilo kontaktirat Sapphire što se tiče toga. (brzi su sa odgovorima)
Ako je uvjet stvarno DisplayPort kako kolega kaže, onda bih ja na tvojem mjestu otišel u Zagriu (odnosno Microline) i pitati može li se recimo SAPPHIRE HD 6450 OC 512MB GDDR5 (sa display portom) naručiti preko njih. Mislim da bi oni itekako izašli u susret.
Autor Frung Pregled postova
Možda bi ovo pomoglo, ako je opcija ugraditi više low profile grafičkih, na matičnoj vjerojatno postoji još koji x1 slot.
http://www.tomshardware.co.uk/forum/249291-12-card
E ovo se zove mod
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Zadnje izmijenjeno od: ThePornstar. 12.10.2011. u 02:53.
Staro 12.10.2011., 02:27   #9
Frung
Frung's Avatar
Lokacija: zg westside
Postovi: 625
Frung je offline   Reply With Quote
Staro 12.10.2011., 08:10   #10
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,795
Kada bih bio siguran da bi to radilo, odmah bih uzeo jos jednu GT 520...
Jel, da opravdam - jedno su specifikacije PCI-e sabirnice, samo se bojim da je ova HP-ova masina i njezina implementacija nesto sasvim drugo.
OTOH, upravo mi je palo na pamet da ovo cudo u sebi AMD 780V chipset.
http://www.amd.com/us/products/deskt...v-chipset.aspx
ATI SurroundView™
Allows support for up to four independent monitors for systems equipped with an additional ATI Radeon™ discrete graphics card
ATI Hybrid Graphics
Improve your system performance by enabling the ability for both discrete graphics and integrated graphics to render simultaneously
Bi li to radilo s Sapphire HD 6450?
Programer
Zadnje izmijenjeno od: Bubba. 12.10.2011. u 08:54.
Staro 12.10.2011., 09:37   #11
Postovi: 23,603
Postavljaš teško pitanje, ne vjerujem da postoji kakav HP lab koji bi to mogao testirati.
U prevodu žrtvuj se pa isprobaj i prijavi rezultat.
Opet slažeš nešto ala Burza - Broker punkt ?
Staro 12.10.2011., 10:04   #12
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Možda da probaš nabaviti USB 2.0/3.0 video adapter/grafičkom s VGA/DVI/HDMI izlazom?
http://www.ebay.com/sch/i.html?_from...All-Categories
Kod nas ima onaj HP-ov, 571AA model, ako me sjećanje dobro služi.
Inače, na IDF-u su baš predstavili jako puno proizvoda na tu temu, a još su k tome i cijenovno sve više pristupačniji.
Zadnje izmijenjeno od: Matth€w. 12.10.2011. u 11:01.
Matth€w je offline   Reply With Quote
Staro 12.10.2011., 10:47   #13
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,795
Autor Nikky Pregled postova
Jebemti PiSiEksperte.
IOW - jesam, zrtvovao sam se, sad moram samo otici po graficku, reinstalirati Windowse i jos 100 divnih predivnih stvarcica.
Ne, nego moja Mišel Obama ovaj puta zeli TV u sobi, pa cu to izvesti sve preko postojece HP masine i zrtvovati svoje CUDA projekte zbog nje, a moram zadrzati dva monitora na kojima radim (volim ju, ali ne toliko da se rijesim dva monitora dok ona eventualno gleda seriju/TV na trecem ekranu).
Da je burza/broker punkt, placao bih tudjom lovom pa bih znao rjesenje.
Autor Matth€w Pregled postova
Inače, na IDF-u su baš predstavili jako puno proizvoda na tu tema, a još su k tome i cijenovno sve više pristupačniji.
Koliko vidim, ovi el cheapo s Ibeja imaju male rezolucije, i pitanje je kako bi odhendlali 10 metara kabla. Uz to, ovo "brzo nabavljivo" je znacilo da mogu dati pare danas i dobiti to najkasnije sutra inace je brainfuck neminovan ako ne slozim to do kraja tjedna.
Programer
Zadnje izmijenjeno od: Bubba. 12.10.2011. u 10:52.
Staro 12.10.2011., 10:48   #14
Postovi: 34,057
Sapphire ima Flex seriju grafa koje po defaultu podržavaju 3 monitora bez ikakvih adaptera. Koliko se sjećam, prva iz te serije je bila 5770 Flex. Nažalost, mislim da nema low profile modela iz te serije.
http://www.sapphiretech.com/presenta...n=&lid=1&leg=0
Staro 12.10.2011., 11:00   #15
Postovi: 23,603
Mislim da je u konkretnom slućaju bolje da dragoj složiš neku "mikrovalnu" za gledanje Kućanica, puno manje zahebancije.
Nekakav Brazos ili ION2 bi tu sjeo ko budali šamar
Staro 12.10.2011., 11:01   #16
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Ma, kao i obično, problem je u našem tržištu, odnosno distributerima/zastupnicima. Proizvoda ovakvog tipa ima jako puno, samo naravno, ne kod nas.
Staro 12.10.2011., 15:09   #17
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,795
Previse kablova, vremena, volje i na kraju krajeva - love.
Ne mozes im zamjeriti. Kome ces to prodati u nasoj banani, Fleksu koji treba samo sto vise memorije i gigaherca da bi pokrenuo Simse 4?
Programer
Staro 12.10.2011., 15:43   #18
Postovi: 7,568
OTOH, upravo mi je palo na pamet da ovo cudo u sebi AMD 780V chipset. Bi li to radilo s Sapphire HD 6450?
Štanga. Za Hybrid Graphics mora biti diskretna iz HD 2000, 3000 ili 4000 serije. Zayeb je kaj tražiš baš low profile, jer kolko god se tvrdilo da rade sva tri izlaza istovremeno, proizvođači uredno trpaju dual-link DVI konektore i onda zahvaljujući tome možeš iskoristiti još samo jedan izlaz. Adapteri su pak šou za sebe, a velika većina ih radi kak spada, jedino ako imaš DisplayPort na kartici, pa onda na njega spajaš kaj god hoćeš.
Staro 12.10.2011., 15:52   #19
Roberto
Roberto's Avatar
Postovi: 2,651
Nedavno sam bio u potrazi sa nečim sličnim za frenda.
Ovo mi se učinilo dobrim (ali i skupim) rješenjem:
http://www.multi-monitors.com/produc...138-plpx16.htm
Frend je na kraju odustao od cijele priče tako da ne znam ništa iz prve ruke. dobavljivost kod nas je, naravno, 0 bodova.
Staro 12.10.2011., 16:04   #20
Postovi: 34,057
Alo, 400$! Dodaj tome i cijenu za 3 dp adaptera, pa te ispadne k'o Sv. Petra kajgana.
btw, nije li bilo nekih ploča sa integ. grafom koje su mogle raditi na sva 3 izlaza (vga, dvi i hdmi) istovremeno? Čini mi se da su bile neke Asrockice u pitanju.
Staro 12.10.2011., 16:11   #21
Postovi: 7,568
Dva su zasad za IGP (bilo AMD ili Intel), a mogućnost tri istovremena izlaza dolazi tek s Ivy Bridge arhitekturom.
Staro 12.10.2011., 16:13   #22
D1viry
D1viry's Avatar
Lokacija: Slavonija
Postovi: 2,066
Ova podržava Eyefinity, barem na AMD-ovim stranicama tako piše. Dolazi sa low profile limovima.
Eh, još samo da nađem verziju sa DP.
Edit: Ova podržava eyefinity definitivno, samo nisam nikad čuo za ovaj shop. Vjerojatno ima i drugdje.
Edit2: Pitaj Krešu odakle je nabavio za test Sapphire HD5570 1GB.
Pošten trgovac: 1,2,3,4,5,6
Zadnje izmijenjeno od: D1viry. 12.10.2011. u 16:33.
Staro 12.10.2011., 16:21   #23
Mad_Duke
Autor D1viry Pregled postova
Ovo se čini kao OK. Pogotovo ako nije problem kroz neki drugi prolaz za PCI izvuči ovaj VGA van (ako već ne ide full size vnutra).
Za ne grafički rad većinom je tak svejedno dal se radi o VGA i DVIu dok god je kabel normalan.
Staro 12.10.2011., 16:32   #24
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,795
Mislim da se nismo skuzili (tj. duboko se nadam ); naime, ova ploca ima AMD 780V s Radeon 3100 karticom koja sigurno podrzava dva monitora, vec sam isprobao.
Sada kada umetnem ovu novu graficku HD kuracpalacxyz, nadao sam se da ce proradi taj cuveni SurroundView koji bi mi omogucio ganjanje 4 monitora (dva sa ploce, tj. chipseta, dva sa nove graficke)...
Programer
Staro 12.10.2011., 19:14   #25
Postovi: 7,568
Da, ja sam krivo skužil. Mislil sam da hoćeš spojiti IGP i diskretnu, pa dobiti Hybrid mod.
Staro 13.10.2011., 10:01   #26
vranjba
vranjba's Avatar
Datum registracije: Aug 2009
Postovi: 613
meni taj SurroundView radi sa ati 5570 i 3200 integriranom
CPU: AMD Phenom II X2 545 @X4 B45 + AC Freezer 64 Pro PWM
MBO: Asrock a780GXH @ bios 1.70
RAM: Kingmax 2x2GB PC2-8500
VGA: Sapphire HD5570 1GB
Zvučna: Asus xonar d1
HDD: WD6401AALS + WD2000JB + WD3200AAJS
PSU: Corsair cx400W
Case: Gigabyte GZ-X6
Keyboard: Logitech mk520 + Microsoft Natural Wireless Mouse 6000
Daljnski: Mce ir
Zvučnici: Swans d1080mkii 08
Monitori: Philips 220SW + HP L1950g
TV: Panasonic TX-P50C3E
AIO: HP Deskjet F4280
OS: Windows 7 x64
HP Compaq nx7010
CPU: Pentium centrino 2.0 GHz
RAM: 1gb + 512mb PC2700
VGA: ATI Mobility Radeon 9200 32mb
HDD: wd 40 GB
OS: Win XP SP3 x32
CPU: Pentium 3 1.0 GHz + Glacialtech igloo 2520
MBO: Intel D815EFV
RAM: 2x 256mb PC133
HDD: Maxtor 80gb + Seagate Barracuda 7200.7 160gb
PSU: Codegen 400W
OS: Win XP SP3 x32
PCI Lan: Linksys cisco gigabit EG1032 v3
Routher: Thomson ST780i WL
Net: T-com Flat
Acernote lite 350pc
CPU: Pentium 100 MHz
RAM: 8 mb edo onboard
VGA: chips&tech f65545
HDD: ibm 540 mb
OS: win 95
CPU: pentium 166 MHz
MBO: ga 586vx rev 3.37
RAM: 4x16 mb edo ram
VGA: Ati 3D rage II +dvd 4 mb
HDD: quantum fireball se2.1a 2.1 gb
PSU: seasonic ssa-200g
Monitor: Acer 13"
OS: dos 6.22
vranjba je offline   Reply With Quote
Staro 13.10.2011., 10:03   #27
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,795
Autor vranjba Pregled postova
Huh.
Jesi nesto posebno prtljao po BIOS-u ili radi po defaultu? Koja je primarna graficka onda, ova na ploci ili u PCI-e slotu? Windowsi?
Programer
Staro 13.10.2011., 10:43   #28
vranjba
vranjba's Avatar
Postovi: 613
U biosu jesam nešto mislim da se isto zove SurroundView ili extended view i driverima se isto mislim mora neka kvačica zakačiti
pod primarnu sam namjestio pci-e
kad dođem kući napišem točno što je sve zakačeno
windowsi su 7 x64
PSU: Corsair cx400W
Daljnski: Mce ir
OS: Windows 7 x64
HP Compaq nx7010
HDD: wd 40 GB
OS: Win XP SP3 x32
MBO: Intel D815EFV
RAM: 2x 256mb PC133
PSU: Codegen 400W
OS: Win XP SP3 x32
Net: T-com Flat
Acernote lite 350pc
HDD: ibm 540 mb
OS: win 95
Monitor: Acer 13"
OS: dos 6.22
Staro 13.10.2011., 10:47   #29
tomov
tomov's Avatar
Datum registracije: Feb 2011
Postovi: 592
Mislim da će ti raditi bez beda jer ATI gura priču u smjeru multimedije i kompatibilnosti.
Hybrid Crossfire zaboravi ali uredno će ti komp raditi sa dvije zasebne kartice...
Huh.
Mislim da ti je sve plug'n'pray - samo ostavi uključenu integrušu i to je to. Kasnije kroz ATI manager naštimaš sve što hoćeš.
tomov je offline   Reply With Quote
Staro 13.10.2011., 12:03   #30
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,795
windowsi su 7 x64
OK, thanks, ja cu probati sada to pokaciti sve, pa sto Bog (ATI ) da...
Autor tomov Pregled postova
Fala kurcu, iako se njihovih drivera grozim vise nego icega...
To mi i treba, 3D se ionako pokrece samo kad Jelc dodje kod mene s Visageom pa pokrecu neke Java Flash OpenGL hentai p0rn igre...
Bas cu vidjeti; a sreca moja, upravo sada su nasli drkati sa Driver Sweeperom...
http://forums.guru3d.com/showthread.php?t=331125
Edit:
Maknuh GT520, drivere i sve ostalo, nabio HD 6450, ukljucio SurroundView u BIOS-u i voila - 3 monitora su tu.
Za sad sam naletio na ogroman problem - MPC-HC jednostavno ne zeli raditi niti na jednom drugom monitoru osim primarnom. Windows Media Player vrti p0rn bez problema, s druge strane.
Code:
Problem signature:
  Problem Event Name:    APPCRASH
  Application Name:    mpc-hc64.exe
  Application Version:    1.5.2.3456
  Application Timestamp:    4e29d4f8
  Fault Module Name:    mpc-hc64.exe
  Fault Module Version:    1.5.2.3456
  Fault Module Timestamp:    4e29d4f8
  Exception Code:    c0000005
  Exception Offset:    0000000000142edf
  OS Version:    6.1.7601.2.1.0.256.48
  Locale ID:    1050
  Additional Information 1:    2839
  Additional Information 2:    283985495968e214ef0761801936089b
  Additional Information 3:    231c
  Additional Information 4:    231c080ac6678880c5c0e3b52912c5db
Morao sam odabrati VMR-9 (renderless) kao DirectShow Video output (umjesto EVR CUstom Pres.), kako bih to popravio, pa sad ne znam na sto to tocno utjece, ali za sada je OK.
Eto, jos jednom za kraj, 100% pouzdano - AMD 780V i HD 6450 rade bez problema u SurroundView modu, tj. s podrskom za 4 monitora sve skupa.
Javim jos dojmova.
Programer
Zadnje izmijenjeno od: Bubba. 13.10.2011. u 18:02.
