Staro 26.09.2011., 23:19   #121
Audi45
Audi45's Avatar
Lokacija: Slav. Brod
Postovi: 491
Sve o ljudstvu imas tu
Ukratko odgovor na tvoje pitanje:
There are two main reasons why retraining an old crew is preferred over recruiting a fresh one:
Retention of Secondary Specializations
Fresh crews, regardless of what primary specialization that they started with, will not have any Secondary Specializations. Since secondary specializations are not lost, it is better to retrain the old crew so that the bonuses that they provide are kept, even if it means the tankers in the crew will have a drop in primary specialization.
Continuation of the Crew Member's Career
Crew member will keep their statistics and awards regardless of what vehicle they are put in. Even though a retrained veteran might preform as well as a fresh tanker, the veteran's personal records are kept, including medals.
Audi45 je offline   Reply With Quote
Staro 27.09.2011., 09:38   #122
chief_wolfinjo
nisam imao vremena ovih dana al budem danas igrao.. možda si i nekaj kupim... dal su skupi tenkovi kad se kupuje za real money
Staro 27.09.2011., 19:34   #123
Nybelung
Premium tenkovi se kupuju samo za mlaćenje credita. Jeftiniji su za održavanje i zarađuju više.
Najbolji premium tenk je Type 59, jer zarađuje puno a nije skup. Košta 7500 golda što je malo manje od 30 eura.
Ja bi radije uzeo 3 mjeseca premium računa nego tog tenka.
Staro 27.09.2011., 23:55   #124
scp
scp's Avatar
Datum registracije: Dec 2010
Postovi: 327
Ne znam kako vama, al WoT je vjerojatno najcrappy igra sto se tice balancea ikad napravljena. Ne mogu vjerovat da sam placao premium...Odlicna ideja, losa igra.
scp je offline   Reply With Quote
Staro 28.09.2011., 01:03   #125
Audi45
Audi45's Avatar
Postovi: 491
Nemoj igrati.
Puna mi je kapa kukanja o balancu timova na off. forumu i u igri.
Kad se dobije onda su zasluzni sami, kada se gubi onda je kriv team balance
Zanimljivo na partijama gdje je vecina tenkova tiera 8, 9, 10 takvog kukanja gotovo da i nema.
Do sada nisam izgubio niti jednu jedinu partiju zbog loseg team balanca
vec zbog pojedinih idiota, nesposobnog tima, vlastite greske (gluposti).
Igra nije savrsena, daleko od toga, ali je zabavna, kvalitetna i ono najbitnije
svako malo određene akcije, novi tenkovi , mape, game modovi itd.
Ovo je jedina igra koja daje dojam da je tu zbog sebe same, zabave i igraca, a ne zgrtanja para. Osobni subjektivni dojam.
Ne svida ti se, nemoj igrati.
Nesto ne valja ili je jako lose, potkrijepi sa nekim barem poludokazom i preko
foruma prijavi problem game devel. i biti ce ispravljen u iducem upgradeu,
brojni problemi su ispravljeni na ovaj nacin.
Ma za sve je kriv krvavi team balance, nek ide u tri p.... strinine
Odoh spavati da me opet ne zajebe....
Staro 28.09.2011., 01:20   #126
Nybelung
Autor Audi45 Pregled postova
Nemoj igrati.
Ja se tim plačipi*kama samo podsmjehnem.
Maloprije je neki Čeh kukao kako mu je Tiger preslab i da su developeri smradovi. Pomislio sam da je lik neki profić, da je toliko savladao Tigera da mu i najmanji detalji sad smetaju...
Kad ono k*rac, čim je počela partija zabio se frontalno u T29 i nastavio kukat.
Staro 28.09.2011., 01:25   #127
Ecips Dlo
Ecips Dlo's Avatar
Datum registracije: May 2009
Lokacija: brlog
Postovi: 489
Svaki tenk ima svoje prednosti i mane,a na igracu je dal ce on znati iskoristit te prednosti.
Ecips Dlo je offline   Reply With Quote
Staro 28.09.2011., 09:09   #128
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
-.- Kako sam pojeo govno s M3 Lee jer tenk nema kupolu -.- i sada bi trebao skupiti 33000 exp-a da bi ga zamjenio :S.
' alt='' border=0>
Vejita je offline   Reply With Quote
Staro 28.09.2011., 10:10   #129
Nybelung
Autor Vejita Pregled postova
Igraj s njim kao da igraš Tank Destroyera. I zadrži se u bazi prvu minutu, možda uloviš kojeg scout-a.
Bit ćeš ponosan kad ga se riješiš. Ja ću si napravit majicu:
Staro 28.09.2011., 10:50   #130
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
Tenk je poprilicno jak ali me smeta kaj rusim drvece kada ne trebam i onda si otkrijem lokaciju. I jos koristim high explosive municiju.
' alt='' border=0>
Staro 28.09.2011., 11:17   #131
BojanZD
BojanZD's Avatar
Postovi: 1,398
Nemoj igrati.
Lako je ovako komentirat kad si u društvu tier 8,9,10 tenkova pa su svi tu negdje ili slabiji.
Šta reći na situaciju kad te sa M3 Lee strpa u mapu prepunu T29, Panthera, IS-ova i slične ekipa pa se snađi-nisi ni TD, nisi ni scout, nisi na heavy tank.
Jebo si si ježa kako god okreneš!
Mene uvije kida jedna stvar vezano za balance-dok sam ja igrao sa Ltractorom redovito bi se u protivničkom timu našao Hetzer ili M3Lee pa me zdrobe, a kad sam se ja dokopao Hetzera odjednom me stavlja protiv PZIV, VK3001H, Shermana i tak..
Nemože balance uvijek bit savršen, al sve češće se događa da bude totalni shit.
BojanZD je online   Reply With Quote
Staro 28.09.2011., 11:55   #132
Audi45
Audi45's Avatar
Postovi: 491
Gle jucer sam sa PZIII ostao sam 1 na 1 sa KV, kojega naravno nemogu ni pipnuti i popusio, nije team balance kriv sto su moji krkani sa KVovima izginuli
odmah u pocetku.
Isto tako sa Pantherom sam ostao sam protiv 2 KT i Lowa, dakle tri na jedan
Panthera ima 75 mm top kojim nemogu nista navedenim.
Ali zato Panthera brza a oni spori i neokretni i pobjedio sam zauzevsi njihovu bazu, dok su se oni dovukli do mene.
Nije team balanc los, kombinira tenkove iz razlicitih tierova i upravo je zato
zabavno.
Ili jos jedan primjer.
S tigrom me sutnio protiv e 100, mousa, is 7, t 30, kompanije, bio sam najslabiji tenk prvi do mene jedan jedini e 75
da se razumijemo tigar iako havey tank i sa HE shellovima ne nanosi gotovo nikakvu stetu navedenim, preeeespor za scouta
i sto sam trebao proklinjati team balance.
Cucao sam u grmlju u bazi i skupio 35 - 40 hitova iako nisam nanio nikakvu stetu skupio para i exp. ko govana, dobio nagrade sharpshooter i jos nesto ne sjecam se vise sto.
Autor Nybelung Pregled postova
Sa tigrom treba znati igrati, protiv is ili t29 u close combatu nema sanse a isti su tier (slabiji armor, top, brzina i okretnost).
Tigar je sniper tenk, ima jebeno preciznu 88icu i rate of fire tako da sa distance radi cuda.
Autor Ecips Dlo Pregled postova
Upravo to, u pocetku sam proklinjao tigra, dok ga nisam skuzio, poslije sam ga obozavao, na kraju bilo mi ga zao prodati i prijeci na KT.
Zadnje izmijenjeno od: Audi45. 28.09.2011. u 12:17.
Staro 28.09.2011., 12:35   #133
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
Mene danas okinio među tier 7 .... znate kakve sam imao sanse protiv njih.
' alt='' border=0>
Staro 28.09.2011., 14:08   #134
scp
scp's Avatar
Postovi: 327
Nemoj igrati.
Osobno sam se trudio igrati igru jer obozavam i proucavam WW2 opcenito. Takodjer podupirem tu ideju da se igre nebi trebale igrati radi zgrtanja para, ali kad ocajni balance, slaba optimizacija i glup team (ne precesto ali dogadja se puno) prelako odvracaju paznju od uzivanja u igri.
Ne, naravno, nikada nije problem u balanceu, pogotovo kad sjednem u T1 heavy 5 puta zaredom i budem na vrhu dok u mom timu ispod mene sjede 2 Panzer IV, a u enemy teamu na vrhu 3 KV-a sa 107. To nije balance issue, kriv je tim
Da ne spominjem to sto moras placati da bi igrao s ekipom od troje i sta vec ne, jer je grindanje XP-a i creditsa prakticki nemoguce bez sjedenja pred kompom 12 sati dnevno ako nemas premium account. Radije cu potrosit lovu i vrijeme na bolje igre, i ne moras mi govoriti da ne igram ako mi se ne svidja, jer ocito da sam prestao igrati i nije mi bio potreban tvoj savjet u vezi toga.
BTW: u WoT definitivno nisam bio loš, štoviše bio sam poprilicno dobar, igrao sam T44 sa frendovima iz Cape Towna. Redovito smo dobivali gameove samo nas trojica. 3 T44 čuda rade kad igraju zajedno i u high tier gameovima. Ali kazem, jednostavno previse problema koji odvracaju od igre da bi se moglo dugorocno i intenzivno igrati.
Zadnje izmijenjeno od: scp. 28.09.2011. u 14:14.
Staro 28.09.2011., 17:41   #135
Gumby
Gumby's Avatar
Datum registracije: Feb 2003
Lokacija: Velika Gorica
Postovi: 499
Meni je igra OK, ne namjeravam uzeti premium account, želim igrati potpuno neobavezno, kad mi se da, i s guštom.
Ali zna biti frustrirajuća. Zacrtao sam si kao primarni cilj PzIV i sad sam došao do Pz38NA. I tenk je fora, ali u 90% mečeva me stavi među tier 7, 8, a i 9. I to je to. Kao trebao bih scoutati, a jurim s Praga EPA/3 vrtoglavih 35km/h
Mogu čučati iza velike braće, šprihericom iritirati godzile preko puta i skupljati stotinjak xp-a po partiji čekajući da skupim dovoljno za Pragu NR.
Sanjam dan kad ću parkirati u garažu nekog monstruma da i ja nekog oneshot-am
Doctor!!!...
Doctor!!!...
MY BRAIN HURTS...
Gumby je offline   Reply With Quote
Staro 28.09.2011., 19:16   #136
Audi45
Audi45's Avatar
Postovi: 491
Autor scp Pregled postova
E pa o tome ja i govorim, sa razvijenim pzIV i poslije sa VK3001H obozavao sam skidati KVjce i T1HT, iako imaju strasan top, za armor imaju lim, dva do tri hitca i bye bye KV i nije bitno sa koje ga strane tucem. Iako je bolje (lakse) naguziti ih.
Pogotovo VK3001H koji je brz u 3pm, skines ga sa pol muke.
Naravno da nemas sanse ako si statican i cekas ih.
I to nije kriv team balance.
Koliko me je puta bacio sa tigrom protiv dva ili tri ISusa ili T29, neke sam bitke dobio neke izgubio.
Pa i spominjani M3 Lee naleti na njega frontalno sa med. tenkom tier 4, 5 sanse da prezivis jednake nuli, ali zato bokove i guzu ima tako mekane
Sto se tice xp i creditsa nije tocno da moras imati prem. da bi negdje dogurao.
Igram igricu nekih 4 mjeseca po sat, max dva dnevno sve sa standardnim acc. i imam KT, GW Pantheru, JagdPanthera, Pantheru.
Staro 28.09.2011., 19:52   #137
Nybelung
Autor Gumby Pregled postova
Prvi takav monstrum je KV. On je smrt za sve ispod Tier 5, a sa 150mm topom i Tier 5 oneshot-am.
Staro 29.09.2011., 00:19   #138
Ecips Dlo
Ecips Dlo's Avatar
Lokacija: brlog
Postovi: 489
A TD object OS sve ispod 8
Staro 29.09.2011., 03:31   #139
Baja 001
Baja 001's Avatar
Postovi: 7,504
Ludi strike s SPGom 5 killeva, nikad nisan toliko napravio s Bisonom dosad
Sada se uzima novi SPG
Staro 29.09.2011., 18:54   #140
Audi45
Audi45's Avatar
Postovi: 491
Cijena odredenih tenkova snizene (prepolovljene).
Staro 29.09.2011., 19:33   #141
Baja 001
Baja 001's Avatar
Postovi: 7,504
Mene u ovoj igri daleko najviše živcira čekanje do matcha, i prije matcha...
Staro 29.09.2011., 21:21   #142
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
A jbg imas previse brz PC pa uđes prije svih . Ono prodaj komp i kupi si skatulu kao ja i budes cekao samo oko 30 sec. :P ... I ono sada gamad spusta cjene tenkova kada idem na T5. -.-
' alt='' border=0>
Staro 29.09.2011., 22:14   #143
Baja 001
Baja 001's Avatar
Postovi: 7,504
Pa obično oko 1 minutu čekam, a onaj "room" prije igre nekad i po 2 minute.
Staro 29.09.2011., 22:20   #144
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
-.- Ja tamo oko 5 sec cekam.
' alt='' border=0>
Staro 30.09.2011., 01:10   #145
Baja 001
Baja 001's Avatar
Postovi: 7,504
Ma ubije me čekanje, više čekan nego igran
Staro 30.09.2011., 02:01   #146
Nybelung
Ja ne znam o kakvom čekanju vi raspravljate. U borbu me ubaci instantno, najduže sam 10-15 sekundi čekao i to u 5 ujutro. Nakon što prođe loading ubaci me ravno na odbrojavanje. Znači ukupno manje od 40 sek. od pritiska tipke "Battle" do početka masakra.
Nijedan MMO nije brži od ovoga; na WoW-u sam znao po 4 sata čekat da krene raid, koji bi onda propao u prvih 20 minuta.
Staro 30.09.2011., 02:03   #147
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
Tako je i kod mene. Loading mi je najduzi i to oko 20-30 sec.
' alt='' border=0>
Staro 30.09.2011., 02:36   #148
Audi45
Audi45's Avatar
Postovi: 491
Potpis
Staro 30.09.2011., 12:37   #149
Pepermint
Pepermint's Avatar
Postovi: 587
Potpis
isto i kod mene, najkasnije sam ušao kad je odbrojavanje došlo do 20
Pepermint je offline   Reply With Quote
Staro 30.09.2011., 17:09   #150
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
Fuuuuu taman mislio rijesio se onog govneta Lee-a i kupio T1 heavy i on ispade najveci šit do sada .... ono okinem crit i liku skinem 0%. -.- Imam faking osjecaj da pucam corke.
' alt='' border=0>
