Staro 09.08.2011., 10:05   #1
pci_e3x
Premium spammer
pci_e3x's Avatar
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
Nvidia Forceware v280.47 Beta/Developer driver
NVIDIA R280.47
NVIDIA has published the third iteration (first is R280.28) of its OpenGL 4.2 driver for developers. This OpenGL 4.2 driver is intended for GeForce GTX 400 / GTX 500 series as well as for Quadro (Quadro Plex 7000, Quadro 6000, Quadro 5000, Quadro 4000, Quadro 2000, Quadro 600).
R280.47 exposes the same number of OpenGL extensions than R280.28: 289 extensions (complete list is available here) and is based on a new branch: r280_19-31 whereas R280.28 is based on r280_19-2. More information about NV GL4 drivers here.
R280.47 Vista / Win7 64-bit
R280.47 Vista / Win7 32-bit
R280.47 XP 64-bit
R280.47 XP 32-bit
Zadnje izmijenjeno od: pci_e3x. 13.09.2011. u 11:48.
Staro 10.08.2011., 23:54   #2
NemoRS
NemoRS's Avatar
Postovi: 518
Kad sam stavio ove drivere s nvidijine stranice za primjetio sam da su mi odjednom prestali raditi i kao oporavili se.Takosam barem u donjoj kucici dobio poruku od windowsa. E sad jel to problem ili trebam vratit stare ili sto?Zasto se to dogadja?
NemoRS je offline   Reply With Quote
Staro 11.08.2011., 10:43   #3
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
Autor NemoRS Pregled postova
pojavilo se i meni dosad samo jednom i to par minuta nakon instalacije.
Al ako ti se nepojavi češće onda se netribaš brinuti
Staro 11.08.2011., 12:04   #4
Baja 001
Baja 001's Avatar
Postovi: 7,504
Je li vridi ovo išta da se ne zajebajen? Sada su zadnji WHQL.
Staro 11.08.2011., 13:57   #5
NemoRS
NemoRS's Avatar
Postovi: 518
Danas opet stali na par sekundi
Staro 11.08.2011., 16:38   #6
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
Onda skini 280.26 WHQL. Pa vidi oće li radit uredno
@Baja - nisam napravio nikakav benchmark da usporedim sadašanju i prošlu verziju drivera, ali volim da mi je sve up to date
Staro 11.08.2011., 17:26   #7
NemoRS
NemoRS's Avatar
Postovi: 518
Skinuo sam i njih i napravio cistu instalaciju. I odmah nakon instalacije isto. U cemu je problem???
Staro 11.08.2011., 18:42   #8
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,200
to se i meni s prošlima dešavalo, http://forum.pcekspert.com/showpost....&postcount=549
sad sam na 280.26 i ok je..neznam do čega je
Staro 11.08.2011., 18:45   #9
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor pci_e3x Pregled postova
Vidiš koliko san ja update kad iman 275 WHQL
Staro 12.08.2011., 14:22   #10
dart_tom
dart_tom's Avatar
Lokacija: osijek
Postovi: 452
bogme i ja imao isti slucaj,bezveze u idlu samo se srušio driver,i jos poslije toga jedan BSOD
imamo isgu karticu,tko zna mozda ima veze!
inace do sada nikakvih problema ni BSOD ni jedan
edit-evo opet mi se srušio driver iz ćista mira ;(
Zadnje izmijenjeno od: dart_tom. 12.08.2011. u 22:46.
dart_tom je offline   Reply With Quote
Staro 12.08.2011., 15:42   #11
NemoRS
NemoRS's Avatar
Postovi: 518
Uvijek sam skidao najnovijei nikad nije bilo problema. Sad sam vratio 275.33 i za sad je ok. Nebi smjelo imati veze sa modelom kartice ali ko zna...
Staro 13.08.2011., 06:55   #12
NemoRS
NemoRS's Avatar
Postovi: 518
Jucer nakon sto sam stavio stare drivere nisam imao niti jedan problem da kucnem u drvo, dok su ovi novi malo malo prestajali radit. U cemu je problem s njima zaista neznam no znam da cu ih po prvi puta preskocit dok se ne pojave novi. I jos da netko nebih mislio da nisam isprobao WHQL jesam i isto!
Staro 13.08.2011., 10:16   #13
dart_tom
dart_tom's Avatar
Lokacija: osijek
Postovi: 452
http://forums.guru3d.com/showthread.php?t=349082
evo i ja se vratio na stare i za sadaviše nema problema,uglavnom na kraju mi se 280 poćeo rušit svakih pol sata,izgleda da su nešto gadno opet s.ebali
Zadnje izmijenjeno od: dart_tom. 13.08.2011. u 10:23.
Staro 13.08.2011., 10:29   #14
izi
izi's Avatar
Lokacija: Vinkovci - Slavonski Brod
Postovi: 139
Ja bas nikakvih problema nemam, jest da mi je pri kraju instalacije javio da su se srusili, ali odmah se vratili i sve stima...vec 3-4 dana.
izi je offline   Reply With Quote
Staro 22.08.2011., 10:11   #15
alengrosevic
alengrosevic's Avatar
Postovi: 3,775
nakon 2 tjedna koristenja ovih drivera niti jedan driver crash, sve radi kao podmazano...
Staro 22.08.2011., 14:13   #16
T0X1C
n00b
T0X1C's Avatar
Postovi: 246
Meni na GTS-ici rade ko podmazani od instalacije.
Ali zato frendu otkad ih je stavio na GTX560 Ti, raspad sustava, tako da se vratio na 275 dok se ne ohrabri opet isprobat 280.
T0X1C je online   Reply With Quote
Staro 24.08.2011., 08:13   #17
padobranac
padobranac's Avatar
Datum registracije: May 2011
Lokacija: Zagorje
Postovi: 24
Ja imam MSI GTX 560 tI Hawk.
Počelo mi se dešavati isto ovo, svako malo se driveri sruže, pa slika poblesavi, pa se zmješa... I to svakih par minuta!
Od prve (i jedine) instalacije imam original drivere s CD-a,
od početka je sve bilo savršeno.
Odjedanput je počelo zezat, ali ja sam nisam apsolutno ništa updejtao.
Jel moguće da su se driveri sami updejtali a ja nisam skužio?
Pod driver version mi piše 8.17.12.6644 (27.12.2010.)
To su očito stari driveri...?
Sad neznam kaj stavljat, najnovije, ili šta...
padobranac je offline   Reply With Quote
Staro 24.08.2011., 08:29   #18
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,746
Skini najnovije sluzbene (ne betu) drivere sa nevidijine stranice, a prije instalacije novih napravi uninstall starih drivera i ciscenje sa Driver sweeperom (Link) za svaki slucaj.
Staro 24.08.2011., 13:00   #19
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,200
vidim ima nas dosta sa ''nestajanjem slike'', neznam kak su to uspjeli,no nadam se da će ispravit.
Staro 24.08.2011., 13:17   #20
padobranac
padobranac's Avatar
Lokacija: Zagorje
Postovi: 24
Evo stavio sam
280.26-desktop-win7-winvista-64bit-english-whql
i nakon jedno sat vremena srušilo se.
Ja od početka 6. mjeseca (kupnje novog kompa) nisam imal nikakvih problema do prije par dana. Drivere sam nisam mjenjao/updejtao do sad, danas.
A do sada su bili 266.44.
EDIT: evo upravo se desilo rušenje AutoCad-a, očito zbog drivera/grafičke
... i nakon toga ode i SolidWorks
Zadnje izmijenjeno od: padobranac. 24.08.2011. u 13:23.
Staro 25.08.2011., 12:34   #21
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
bump izašla verzija 280.36
i ja sam imao ponekih restartiranja drivera (280.28), al to je ritko kad bilo i većinom povezano s MPC-HC
baš me zanima oće li s ovim bit restarta
Staro 25.08.2011., 12:51   #22
Verbum
Postovi: 682
Od svih drivera koji su izašli u zadnjih 9 mjeseci koliko imam 460GTX uvjerljivo najbolje mi rade 275.33 i zato ne mrdam sa njih još neko vrijeme.
Zadnje izmijenjeno od: Verbum. 25.08.2011. u 12:59.
Verbum je offline   Reply With Quote
Staro 25.08.2011., 14:36   #23
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
i ja imam taj problem, vratio sam se na 275.33
javi da li si ih imao, ne da mi se opet instalirati pa deinstalirati....
DeadMan+ je offline   Reply With Quote
Staro 25.08.2011., 15:09   #24
Dottore
Dottore's Avatar
Postovi: 7,599
Desilo se prije kojih dva dana na BFBC2 nestaje slika pa se vrati za 3-5sec (3-4 puta). Graficka je 8800 GTS.
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 25.08.2011., 22:37   #25
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
Autor DeadMan+ Pregled postova
ok, zasad ovako:
instalirao oko 13h, igrao malo fear3, css, bc2
malo videa gledao u mpc-hc
i driveri se nisu nikako srušili.
Staro 26.08.2011., 17:48   #26
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,200
ja uopće ne vidim ove 280.36 za skinut :S
al vidio sam na sajtu 300.1 al nema linka još
Staro 26.08.2011., 19:09   #27
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
jer su ovi stavljeni pod Developer.Download
Staro 30.08.2011., 02:08   #28
d0X
Kostolomac
d0X's Avatar
Postovi: 1,446
Negdje na guru3d sam pročitao da će izbaciti do sredine 9. mjeseca nove drajvere koji će fixati crasheve. Izgleda da su zafrknuli power stateove. Naročito ispaštaju korisnici GTX560Ti
Staro 05.09.2011., 21:38   #29
ehohr
ehohr's Avatar
Postovi: 348
Ja na GTX 570 probao sve drivere, 266 i novije verzije nijednom nisam dobio da su mi prestali radit driver ali zato na svim osim na 266 driverima imam frame dropove, u igricama mi se pojavljuju bijeli artefakti. A na 266 mi dode BSOD tu i tamo, nekad s javi 2 puta u par sati, nekad nista par dana ali redovito se jave. Vise nemam pojma da li da mijenjam drivere, da li je mozda graficka malo pukla.
Temp graficke je oko 60 uvijek, jedino sto s novim driverima nemam BSOD ali mi je neigrivo zbog tih frame dropova, konkretno u heroes of newerth mi se svaki par sekudni pojave nekakvi bijeli tragovi kao da se slika raspada. u ostali igrama je to puno rijede.
ehohr je offline   Reply With Quote
Staro 13.09.2011., 11:47   #30
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
update na: 280.47 (prošla verzija: 280.36)
