Staro 21.07.2011., 04:28   #91
Postovi: 10,170
1. Ako radis downgrade, treba ti backup jer gubis podatke osim onoga sa sd kartice. Skini my backup pro i spremi poruke, appove, itd...
2. Instaliraj htc sync, odi na shipped-roms.com (android sekcija, bravo model) i skini WWE FROYO RUU ROM u verziji koja ti je bila prije ili preflesaj istu verziju koju imas sad, mozda rijesi problem. Proguglaj na youtubeu kako izgleda postupak flesanja RUU ROMa, tri klika misem i 10ak min vremena.
Staro 21.07.2011., 13:28   #92
golfw12
golfw12's Avatar
Postovi: 424
a za downgradenje jel trebam gold cardradit ili ne,malo sam zbunjen pošto sam tek sad došao u svijet androida
probaču stavit ovu verziju
OTA_Bravo_Froyo_HTC_WWE_2.29.405.2-2.10.405.2_R_P_release8gn61bgo3rswcw24.zip
popodne kad dođem doma
ne treba ti gold card jer nasi HTC uređaji nisu brandani.
znači čisti downgrade radim,dobro javim ako negdje zapnem
CPU: AMD Ryzen 5 PRO 4650G@3.7GHz@ CM Hyper 212X
MBO: Gigabyte B450 AORUS PRO
RAM: 2 x 8 GB DDR4 3200Mhz CL16 Kingston HyperX Predator RGB
GPU: Radeon Onboard Graphics
SSD: Samsung 1Tb, NVMe
HDD: Seagate 1TB, Sata III
PSU: Corsair RM650X 650W
CASE: Phanteks ECLIPSE P400
MONITOR: AOC 24G2U @ 144HZ
MOUSE: Logitech MX518 Batman Edition
KEYBOARD: Logitech K200
PERIPHERY: RAZER Goliathus Control Alpha
OS: Windows 10 Home x64
PRINTER: HP LaserJet Pro M12w
CONNECT: T-Com VDSL 30/6 Mb Flat
CPU: Intel® Core™ i5-8250U@1.6GHz
RAM: 2 x 8 GB DDR4 2400Mhz
GPU: Intel® UHD Graphics 620
HDD: 256 GB M.2 SSD
PSU: HP 90W
LCD: 1.920 x 1.080 FHD-Display SVA
Zadnje izmijenjeno od: golfw12. 21.07.2011. u 13:39.
golfw12 je offline   Reply With Quote
Staro 21.07.2011., 13:32   #93
spawn
spawn's Avatar
Postovi: 8,457
Staro 21.07.2011., 18:34   #94
Postovi: 10,170
Autor golfw12 Pregled postova
NE skidaj OTA update nego RUU!
RUU_Bravo_Froyo_HTC_WWE_2.29.405.2_Radio_32.49.00.32U_5.11.05.27_release_151783_signed.exe
Staro 21.07.2011., 19:03   #95
golfw12
golfw12's Avatar
Postovi: 424
krivi sam linko, ruu sam skinio,piše sad 2.1-update 1 i imam sad pod wifi unable to start wifi
HDD: 256 GB M.2 SSD
PSU: HP 90W
Staro 21.07.2011., 19:36   #96
Postovi: 10,170
Probaj napraviti factory reset. Podrazumijevam da si onaj backup od prije par postova već napravio.
Vidio sam taj problem sa greškom oko wifi-a, ali ne sjećam se koje je bilo rješenje...
Staro 21.07.2011., 19:49   #97
spawn
spawn's Avatar
Postovi: 8,457
Skini ovaj s linka kojeg ti je kolega XLR stavio
Staro 22.07.2011., 10:32   #98
golfw12
golfw12's Avatar
Postovi: 424
Autor xlr Pregled postova
probaću factory reset, sad ako neko zna koji je najbolji custom rom za desire a da sve provjereno radi,nek linka da probam taj stavit ako ni to neupali onda je možda wifi na mobu riknio
HDD: 256 GB M.2 SSD
PSU: HP 90W
Staro 22.07.2011., 10:52   #99
Postovi: 10,170
Wifi ti sigurno nije riknuo, net je prepun slučajeva kao ovaj tvoj, samo nemam pojma koje je točno rješenje. Problem leži negdje u driverima za wifi (u kernelu) i tu se nešto kolje. Neki preporučaju flešanje nekog kernela od richardtrip-a samo nisam imao baš vremena ići u detalje... A ni flešanje bez rootanja mi ne drži vodu.
Za custom rom moraš rootati i opet otvaraš vrata za nove probleme. Riskiraš i da ti kolegica poludi zbog novog roma jer s njim dolaze/odlaze i neke funkcionalnosti
Probaj radije staviti zadnji dostupni RUU i nakon toga napravi factory reset
RUU_Bravo_Froyo_HTC_WWE_2.29.405.5_Radio_32.49.00.32U_5.11.05.27_release_159811_signed.exe
Staro 25.07.2011., 14:38   #100
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,410
Pitanje: dal se može rutat Desire s Androidom 2.2.1 ili treba prvo downgrade na 2.1 kao i s Wildfire-om?
Trebal bi root zbog nekih aplikacija, a da ROM po mogućnosti ostane čim bliže stock HTC-u. Znači, zanima me koji je najbezbolniji postupak za dobit rutanog stock Froyu na Desire-u .
Zadnje izmijenjeno od: stef. 25.07.2011. u 15:11.
Staro 25.07.2011., 15:13   #101
Postovi: 10,170
Slobodno rootaj zadnjim unrevokedom, sve je podržano.
Root ti neće promjeniti rom, već samo između ostalog dobivaš mogućnost stavljanja drugog roma.
Staro 25.07.2011., 17:03   #102
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,410
OK, uređaj je bio PVT4, a dobivanje root-a stvarno lako. Ali nije riješilo problem. VPNC app (Cisco IPSec VPN kompatibilni klijent) je dobio root, ali mi sad javlja da ne može pristupiti TUN device-u ("TUN device missing" -> fali tun.ko modul). Izgleda da ću ipak morati prčkati po kernelu/modulima/custom ROMovima .
Bio bih zhvalan, ak me netko može uputiti u smjeru rješenja. Trenutno kopam po netu.
EDIT: Čini mi se da Ginger ima TUN po defoltu.
Zadnje izmijenjeno od: stef. 25.07.2011. u 17:26.
Staro 25.07.2011., 18:15   #103
Postovi: 10,170
Točno, stock romovima to fali. Mislim da svi custom romovi (2.3+) imaju VPN podršku, čak i Sense romovi. E sad dolazi li to po difoltu s Gingerbreadom, ne znam. Na Froyo romovima je to bio dodatak koji se redovito naglašavao...
A od preporuka ti ne mogu dati ništa osim za Oxygen ili CM7. Sense romove ne koristim, na ova dva navedena sam proveo previše vremena s razlogom.
Staro 25.07.2011., 18:28   #104
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,410
CM7.0.3 za Wildfire ima TUN, upogonio sam VPN bez pol frke.
Pretpostavljam da ima i za Desire. Bacam se dalje na istraživanje.
Staro 01.08.2011., 11:32   #105
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,539
Ako nekog zanima, HTC je održao obećanje i ponudio kakav takav GB update. Nudi se kao RUU (vjerojatno neće doći kao OTA) i obrisat će sve osim kartice. Valjda će uskoro izdati source kernela a onda kao i obično počinje tweakanje custom romova
Android 2.3 Update for HTC Desire
This update is only recommended for expert users who want to experience Android 2.3 and understand the limitations which apply to this update to the HTC Desire. Due to memory constraints several applications have been removed from this update and we are only offering the ROM upgrade utility (RUU) for you to download. Please note that flashing this ROM will erase your previous customizations, including any messages, emails, contacts, and other personal information. We suggest you take advantage of your Google account and other backup solutions available on the Android Market to ensure you do not lose your personal data. Your SD Card will not be erased or modified.
The major changes in this update include:
- All customizations, including operator applications, will be removed
- All wallpapers, except the default wallpaper, will be removed and placed online on the HTC Developer website
- Several HTC applications will be removed and placed online on the HTC Developer website
- The official Facebook application will be removed and is downloadable on the Android Market.
To download this update, please visit… http://developer.htc.com/
Note: This Rom update is for development only and not for general public use. Upgrades to non-authorized phones may result in loss of functionality. In addition certain functions may no longer be usable after re-flashing the ROM, including but not limited to MMS and SMS and HTC also disclaims liability for any unusable functions. HTC disclaims liability for the loss and/or leakage of any personal data resulting from the re-flashing of the ROM.
Exclusions: Due to concerns raised from our partners, the following regional variants are not-compatible with this upgrade: Germany (Deutsch Telekom), North America, South America, South Korea, and Japan.
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 01.08.2011., 11:41   #106
Postovi: 34,023
Još uvijek nije navedeno koje su to aplikacije izbačene. Ja ću ipak pričekati nešto svrsishodnije jer mi ovo ne ulijeva previše povjerenja. Osim toga, postavljam si pitanje bi li t-mobile korisnici mogli imati problema obzirom da nije kompatibilan s mobovima izdanim od njemačkog 'šefa' (Deutsche Telekom je ustvari njemački T-Mobile).
Staro 01.08.2011., 12:21   #107
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,539
Stvarno su mogli su napisati što su izbacili. Ispada da su se između redova s "only recommended for expert users" obraćali onima koji su rootali i mogu napraviti nandroid backup. Bitno je da je GB tu a xda developeri će učiniti ostalo. I tako već imam GB jako dugo a ovim bi samo mogao biti još bolji.
Edit: Izbacili su facebook
Edit2: Koga baš jako svrbi instalirati GB a ne želi izgubiti root, link.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Zadnje izmijenjeno od: LAcy. 01.08.2011. u 14:59.
Staro 02.08.2011., 10:53   #108
n E v E n
n E v E n's Avatar
Lokacija: At Home
Postovi: 208
Autor Babaloo Pregled postova
Pošto planiram uskoro nabaviti HTC Desire veoma povoljno, zanimaju me samo dojmovi korisika što se tiče baterije. Da li je istina da da se baterija mora puniti svaki dan? Može li se to razvući na dva dana gašenjem svih onih servisa navedenih u prethodnim postovima? I,treće da li je tko od vlasnika dotičnog mobitela isprobao ovu Mugenovu bateriju od 3200 mAh? Razmišlja čak i o kupnji navedene baterije pošto koiko vidim po testovima stvarno značajno produljuje rad s mobitelom
Pozdrav,
Evo ja sam "ponosni" vlasnik te baterije. Kupljena prije mjesec danas, i za sada su ocjene samo 3.
Baterija je prvo PRESKUPA, dobit ces jedan dan vise sto je jadno ako platis 80 dolara za bateriju.
Ja nazalost nisam toliko impresioniran vijekom trajanja baterije, ALI sto ne znaci da ti neces biti, pa ako ti nije zao 80 dolara kupi je. Doci ce ti na kucnu adresu oznacena kao gift u vrijednosti od 10 dolara u roku od 2 tjedna.
eto toliko
everybody lie!
n E v E n je offline   Reply With Quote
Staro 02.08.2011., 12:51   #109
Postovi: 34,023
Koliko vidim uz izbačenu FB aplikaciju, navodi se da je izbačen i Teeter (ajme štete). Ugalvnom, ja ću pričekati neki službeni update jer mi ovo ni ne liči na takvo nešto.
Staro 02.08.2011., 13:52   #110
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,539
Ovo je službeni i čini se jedini update koji ćeš dočekati. Preporuka je pričekati na neki custom rom (zapravo već postoje) koji ima A2SD i njega flashati.
Ovaj nemoj jer se za sada ne može rootati!
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 02.08.2011., 13:54   #111
Postovi: 34,023
Vjerojatno se neću ni zamarati time nego uzeti drugi mob i riješen problem. Ovaj mi ionako javlja 'low memory' kad god instaliram neku aplikaciju.
Staro 03.08.2011., 15:01   #112
Postovi: 10,170
Odavno je rootanje i flešanje poštenog roma prestalo biti zamaranje. Da, kupovina novog uređaja je najbolje rješenje. Not.
Tužno je što HTC izbacuje okrljaštene mobove out of the box i onda ljudi moraju kemijati po njima. Zbog toga mislim da više niti neću kupiti HTC, ali daleko od toga da ću u skorije vrijeme prodati Desire. Kad ga jednom središ taj mob je fakat zvijer. Evo, danas upravo srezao ROM na <70MB i proširio /data particiju na 362MB (default size je 147MB). Low space, što je to? Hoću reći, ako netko ima par dana vremena da vidi što njegov mob može, neće ostati razočaran. Najlakše je kupiti novi mob, ali s njim kupujete i njegove dječje bolesti, nove probleme itd... Ruku na srce, kod Desirea je sve rješeno i gotovo svakom problemu se zna i uzrok. Scena je još uvijek živa i to je najbitnije.
Staro 04.08.2011., 01:48   #113
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
jel zna tko od vas kak najlakse rootati desire z?? kaj god otvorim na google-u to je procedura koja mi odma ubije volju + na pola foruma kaj sam nasao kak se roota taj mob u objasnjenju postupka potrebno je vec znati neke stvari jer im se neda korak po korak radit tutorial za nubove...
i onda kad vidim to sve jednostavno izgubim volju jer mi se neda 3 sata kemijati po tome...
evo primjer:
http://forum.xda-developers.com/wiki...FDZ.29_and_DHD
aj nek mi netko normalan kaze jel postoji kompliciraniji i duzi nacin?? a vise manje ove brze i jednostavne metode sam sve probao i nije bilo uspjeha...
Zadnje izmijenjeno od: zwer54. 04.08.2011. u 02:03.
Staro 09.08.2011., 14:34   #114
Night
Lokacija: Dbk
Postovi: 1,314
Autor stef Pregled postova
Jesi uspio upogoniti Cisco VPN na Desireu sa stock romom? I ja se mučim s time, ali mi ne ide.
Staro 10.08.2011., 11:11   #115
Postovi: 34,023
Jel netko probao onaj službeni GB? Nekako me strah izgubiti sve podatke bez obzira što sam pomoću MyBackupa napravio backup svega na karticu.
Staro 10.08.2011., 13:28   #116
Bluzer
Bluzer's Avatar
Lokacija: localhost
Postovi: 1,073
Autor coconut Pregled postova
Svi pričaju da je brutalno nestabilno i da ima dosta bugova, najviše vezano uz poruke.
Staro 10.08.2011., 13:32   #117
n E v E n
n E v E n's Avatar
Lokacija: At Home
Postovi: 208
koji ce vam drek "official" ROM, kad zapravo i nije official, vec je pusten samo za developere kao sto i pise na HTC Developer site-u.
Ima dosta gotovih ROM-ova na xda-developers.com site-u.
everybody lie!
Staro 10.08.2011., 14:25   #118
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,539
Samo flashajte taj službeni GB, obrisati će vam sve i još će te ostati u čudu kad shvatite ta je bootloader lockan i da se ne može unlockat te samim time ni instalirati custom rom.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 10.08.2011., 14:28   #119
knocker
Lokacija: Kaštela
Postovi: 295
pitanje, evo donio mi kolega desire koji kad se upali samo pokaze logo HTC i onda se restarta i kad opet upali stoji HTC s bijelom pozadinom i nista dalje. Kako rješit problem, ako netko može pomoć. Hvala.
knocker je offline   Reply With Quote
Staro 10.08.2011., 14:40   #120
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,539
Vjerojatno je u bootloopu, ugasi ga i upali dok držiš volume down tipku. Uđi u recovery, mountaj sd card, skini neki rom (recimo ovaj), prebaci na karticu, restartaj recovery, napravi full wipe i u advanced i onda flashaj taj novi rom. Ako je potrebno, particioniraj karticu prema navedenim zahtjevima.
MacBook M1 Pro
MacBook Air M2
Moto Edge
