Staro 05.06.2011., 21:08   #91
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Spire Announces the Swirl Universal CPU Cooler
Spire Corp officially introduced its new Swirl CPU cooler today. Utilizing three (3) sintered powder all copper 8mm thick heat pipes and a vertical cylinder design the Swirl is ready to push your CPU to maximum performance. The Swirl is constructed with a combination of an all copper base and all-direction aluminum fins to provide sufficient heat-transfer and good cooling for the hot 130W ~ 150W micro-processors. The Swirl heat-sink and heat-pipes are both soldered and protected with a thin layer of dark-nickel coating to protect from oxidation and to preserve awesome looks. The vertical mounted fan is equipped with 4 bright red LEDs that give a cool glow inside your enclosure. Universal support for both Intel and AMD based systems makes this a versatile solution for any PC system. The Swirl is one of the most appealing coolers on the market and a great solution for those enthusiasts, gamers and professionals alike.
Main Features:
  • Three (3) 8mm all copper U-shaped copper heat-pipes
  • Straight lined heat-pipes allowing air to easily pass through
  • All-directional 45 aluminum fins for best surface rate
  • Dark-Nickel coated heat-sink to preserve killer looks from oxidation
  • Vertical 7.5cm long 9 blade red LED Ball-bearing DC fan
  • Manual fan (RPM) speed control unit included
  • PCI controller allows user to manually set RPM from 800~2000RPM
  • High Quality, Long MTBF Japanese No.1 Ball bearing
  • Supports Intel 1155/1156 & 1366 sockets and AM2/AM3 sockets
  • 5 Year supported manufacturer warranty
http://www.techpowerup.com/146852/Sp...PU-Cooler.html
Ovi iz Spirea baš ne mogu složiti neki pošten hladnjak
C L O W N I N G A R O U N D
Staro 05.06.2011., 21:13   #92
izi
izi's Avatar
Lokacija: Vinkovci - Slavonski Brod
Postovi: 139
Glupo je sto vjerovatno samo njihov vent moze na to cudo, treba vidit review mozda cak i nije los nacin izvedbe
izi je offline   Reply With Quote
Staro 05.06.2011., 21:19   #93
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Autor izi Pregled postova
Jel itko zna mozda dali bi archon ili venomous x prekrivali koji memorijski slot na asrock p67 PRO3? To mi je zasad briga, jer Corsair Vengeance su jako visoki hladnjaci Gledao sam ovaj "review" (http://www.youtube.com/watch?v=mIuJqogdVYo) pa vidim njemu nijedan ne prekriva, ali ipak to je stara neka maticna. Po mojim racunicama Archon bi taman stao, cak bi mozda i dirao prvi mem slot, a venomous bi ga prekrivao.
http://forum.pcekspert.com/showthread.php?t=213523
Uzalud mi trud...
Staro 05.06.2011., 21:21   #94
Overclock
Overclock's Avatar
Datum registracije: Mar 2009
Lokacija: Zagorje
Postovi: 1,001
Kaj fali thermax eclipse II ? (je da im je to jedini posteni )
Staro 05.06.2011., 21:28   #95
izi
izi's Avatar
Postovi: 139
Autor MAGARAC Pregled postova
Joj sry...zaboravio sam da si ti probavao plocu. Hvala
Staro 05.06.2011., 21:45   #96
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Stane na sve p67 ploce. Nema brige sto se ta dva tice. Cak mozes nakeljit dve debele Delte gore a da ne diraju memu.
Staro 06.06.2011., 08:55   #97
Doink the Clown
Postovi: 6,214
Autor Dizel Pregled postova
Nabijem vas Zapustio sam komp totalno u zadnjih pola godine, pa da i ja nešto kupim, tek toliko - iskreno, nemam razloga zašto bih to uzeo, ali nek se pare vrte.
Ako tko prodaje polovnog Venomusa, rado bih na PM čuo cifru, bečka škola [trgovački smjer] ipak prevladava u mojoj svijesti nad tim šajni sajlent triplvent GSX VVTi forama
Truljo je rezerviran vidim
Kad stigne očekujem podrobno izvješće s dojmovima... I da, welcome to the club
Staro 11.06.2011., 04:17   #98
sharyn
sharyn's Avatar
Datum registracije: Jun 2010
Lokacija: grubišno polje
Postovi: 565
hej hoj bećari
zanima me što mislite o ovom cooleru http://www.zalman.com/eng/product/Pr...ad.asp?idx=350
i gdje on stoji u usporedbi sa noctuom d14?
poz sharyn
sharyn je offline   Reply With Quote
Staro 11.06.2011., 11:51   #99
DiTech
DiTech's Avatar
Postovi: 342
Malo odskrolas gore i imas u review-u od nzxt-a tablicu.
http://www.tweaktown.com/reviews/412...ew/index6.html
DiTech je offline   Reply With Quote
Staro 11.06.2011., 13:53   #100
zkljaja
Brat od Đon Vejna
zkljaja's Avatar
Lokacija: zg-vg
Postovi: 1,204
Autor sharyn Pregled postova
hej hoj bećari
poz sharyn
Emile sreco prvo ti sebi uzmi nes vece od 17" crta pa onda uzimaj Noctuu, grijeh imat takav komp na tak malom ekranu. (pa se cudis kak je Psiho bolji od tebe)
Inace taj kuler je odlican, i za 2500k na stocku neznam sta ce ti vise.
kejti
Zadnje izmijenjeno od: zkljaja. 11.06.2011. u 14:00.
zkljaja je online   Reply With Quote
Staro 14.06.2011., 13:26   #101
DiTech
DiTech's Avatar
Postovi: 342
Moze preporuka koji kontroler za vent kupiti i gdje? Imam ventilatore CM i Scy sa 3 pina.
hvala.
Staro 20.06.2011., 14:16   #102
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,555
Staro 26.06.2011., 10:18   #103
izi
izi's Avatar
Postovi: 139
Jel ovo neka pogreska ili sto? Links u ponudi ima venomous x black i HR-02!
http://www.links.hr/index.php?option...egorija=050907
Prije 4 dana pitam u Slavonskom Brodu da li planiraju radit sa Thermalrigtom, kaze frajer ne planiraju.
Zadnje izmijenjeno od: izi. 26.06.2011. u 10:30.
Staro 26.06.2011., 10:28   #104
Baja 001
Baja 001's Avatar
Postovi: 7,504
Zašto bi bila pogreška. I da oni jesu pasivni hladnjaci.
Staro 26.06.2011., 10:47   #105
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
559kn majke ti garave...koje oko da im izvadim za te pare?
Staro 26.06.2011., 11:00   #106
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,555
Zato jer ih nisu imali dugo u ponudi
Trebas vidjet kolko je NH-D14 kod oprića
Staro 26.06.2011., 11:04   #107
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Nadam se da i olovke šilji za te pare
Staro 26.06.2011., 11:24   #108
izi
izi's Avatar
Postovi: 139
Toga sam se i ja odmah sjetio, uz noctu-u dobijes i 2 odlicna venta za istu cijenu kao sto je venomous x u linksu.
Staro 26.06.2011., 11:26   #109
TheBEaST
TheBEaST's Avatar
Postovi: 666
Ima, ima, u ponedjeljak predvečer sam skužil da su ih stavili u ponudu sa još nekom novom robom i da su raspoloživi na centralnom skladištu. Odmah zval u Links Vž da mi uzmu jednog sa centralnog skladišta za preuzimanje tu u poslovnici. Stiže sutra najvjerojatnije jer su ovaj tjedan radili samo u pon i utorak.
Cijena je takva, kaj se može. Na kraju me sa popustom ispadne 540kn. Prije nestašice su bili i skuplji, oko 650kn. Čekam već par mjeseci da stignu i neda mi se zajebavat više oko toga s narudžbom izvana jer bi ionak došlo sa poštarinom i carinom tu negdje, možda i više, čak i dok bi nas više uzimalo.
Al si ti ventovi ružni ko da ne velim kaj.
TheBEaST je offline   Reply With Quote
Staro 26.06.2011., 11:54   #110
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,555
Autor TheBEaST Pregled postova
Al ti ventovi pusu ko da ne velim 2x kaj .I uvijek bi prije dao za Nh-D14 600 kn nego za VX 550kn .
Staro 26.06.2011., 12:09   #111
TheBEaST
TheBEaST's Avatar
Postovi: 666
Autor xulos Pregled postova
A dobro, svako ima svoje veselje. Ja to nebi jednostavno nebi mogel trpjeti sljedećih par godina u svom 690 II Advanced sa crnom unutrašnjošću i pleksi prozorom gdje se V-X Black uklapa idealno.
Noctua je i glomazna i zauzme pola matične, a V-X sa jednom ventom je tu negdje što se tiče temperature i cijene.
Staro 26.06.2011., 12:22   #112
Dottore
Dottore's Avatar
Postovi: 7,653
Za Noctuu bi dao nego VX bez venta. Cijene su su mu u zadnje vrijeme sve više napuhane.
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 27.06.2011., 11:30   #113
Doink the Clown
Postovi: 6,214
Prolimatech Intros Megahalems Black Series CPU Heatsink
Prolimatech released a new variant of its iconic Megahalems CPU heatsink, called the Black Series Megahalems. With the same exact dimensions as the original at 130 x 158.7 x 74 mm (LxWxH), the new variant uses black colored aluminum fins. The coating doesn't make for a polished, glossy surface, but a grainy one, which increases surface area. The design remains the same: six nickel-plated copper heat pipes pass through a base, conveying heat to two aluminum fin stacks that are arranged along each arm of the U-shape the heat pipes make. The Black Series Megahalems is compatible with all the current CPU socket types, including AMD AM3+, AM3, AM2+, AM2; Intel LGA1155, LGA1156, LGA1366, and LGA775. The Prolimatech Megahalems Black Series is listed on Caseking.de for €54.90.
Scythe Releases Third Edition of Mugen CPU Cooler Series
Japanese cooling expert Scythe is announcing today the successor of popular Mugen 2 CPU Cooler. Mugen 2 CPU Cooler was awarded many times and is well known world-wide to mainstream users, Overclocker and Enthusiasts. During the development process main focus was set on improvement of performance and mounting mechanism as well as shrinking the heatsink dimensions. New Mugen 3 CPU Cooler is ready to take on the legacy.
While optimizing the performance the whole heatsink design of Mugen 3 CPU Cooler was re-worked which resulted in creation the improved fin-structure M.A.P.S. (Multiple Airflow Pass-Through Structure). Enhancements were achieved by reducing the aerodynamic resistance as well as improving of the overall heatsink stability. Furthermore Mugen 3 is equipped with total of six high-quality copper-heatpipes where the predecessor had only five. Typical for Scythe is the excellently processed and flat surface of the copper base which was refined by a thin nickel layer to prevent corrosion.
Mugen 3 is equipped with a popular 120 mm axial fan from the Slip Stream PWM Silent series. Using the PWM function of the axial fan mainboards are able to control the fan speed between 300 and 1.600 RPM, which allows a constant airflow between 14,7 and 88,11 CFM respectively 24.98 and 149.67 m³/h. While working at the specified fan speed range the operation noise is rated from silent 9.60 to moderate 32.15 dBA.
Furthermore the mounting mechanism F.M.S.B. (Flip Mount Super Back-Plate) was improved and upgraded to 4th version. Hence resulted in enhanced back-plate and allows easier and faster mounting procedure of Mugen 3 CPU Cooler. Compatibility list is includes Intel sockets LGA1155, LGA1156, T / LGA775 and LGA1366 as well as AMD sockets AM2, AM2+, AM3 and the new AM3+.
Scythe Mugen 3 CPU Cooler carries the same 35,90 EUR (excl. VAT/TAX) price tag as the predecessor Mugen 2 at its time. For more information, visit the product page.
Staro 27.06.2011., 13:07   #114
skyman
skyman's Avatar
Datum registracije: Aug 2008
Postovi: 775
Što se tiče noctua fanova, očito neki nisu čuli za akrilni sprej (oko 30 kn)..pa ako vam paše uz unutrašnjost kućišta mogu bit i roze boje..a ti fanovi itekako vrijede svake kune
skyman je offline   Reply With Quote
Staro 04.07.2011., 16:28   #115
Doink the Clown
Postovi: 6,214
Staro 05.07.2011., 20:05   #116
TheBEaST
TheBEaST's Avatar
Postovi: 666
Zanimljiv review.
BTW, hoće li biti što od one grupne narudžbe? Ja sam u međuvremenu kupio V-X Black, ali bi uzeo par ventilatora ako će nas par ljudi naručivati izvana.
Staro 05.07.2011., 20:35   #117
prt scr
Datum registracije: Jan 2011
Lokacija: wild west
Postovi: 321
Zanimljiv review.
ja bi možda isto uzeo ventilator,neki tihi i da ima dobar protok jer me ovaj na yasya kuleru lagano ubija,čuje se jako strujanje zraka,šta bi preporučili možda ima i ovdje?
prt scr je offline   Reply With Quote
Staro 19.07.2011., 07:54   #118
Doink the Clown
Postovi: 6,214
ENERMAX Announces ETS-T40 Series CPU Coolers
ENERMAX is proud to announce the release of all new CPU Cooler line, ETS-T40 series. It has world leading thermal resistance value down to an incredible 0.09°C/W. With patented VGF, SEF, HDT, and VEF design, plus ENERMAX renowned Twister-bearing fan, ETS-T40 can easily cool down hot-spoil heavy-duty CPU without adding system noise. The unique spoilers design redirects the air through the windless area behind the heat pipes of 52 fins to maximize air convection rate and remove the heat that conventional design cannot reach.
vStack Effect Flow (patented): By applying Bernoulli’s Law, the four bumps at the exhaust area enhance the air speed, pressure, and its direction to enforce the heat transfer. Bernoulli’s Law is applied in aviation industry to design airplane’s wing. ENERMAX RD team ingeniously uses this aerodynamic physics on fins to enhance the airflow without adding fan speed.
wVacuum Effect Flow: A unique design creates an air channel with fin flaps, forcing the air go through the fins and bringing the additional air into the heat sink. Besides our fin design, ETS-T40’s four ø6mm heat pipes with Directed Touch Technology (patented) rapidly bring the heat away from CPU to fins and eliminate any CPU hot spot to ensure system reliability under heavy-duty computing application.
Equipped with ENERMAX Twister-bearing fan w/PWM control, ETS-T40 offers ultra-silence and durability performance. Furthermore, it contains additional pair solid metal springs accessory for optional dual fan installation to support extreme non-stop system redundancy cooling requirement, universal brackets to meet the newest sockets on the market such as Intel LGA 775/1155/1156/1366 and AMD AM2/AM2+/AM3/AM3+/FM1, and high thermal conductivity grease Dow Corning TC-5121 to ensure the best thermal conduction between CPU and the heat sink.
ENERMAX ETS-T40 CPU Cooler has three models with different fan design (dual color LED, single color LED, non-LED).
  • ETS-T40-VD MSRP USD 49.99
  • ETS-T40-TA MSRP USD 49.99
  • ETS-T40-TB MSRP USD 39.99
For more information, visit this page.
http://www.techpowerup.com/149222/EN...U-Coolers.html
Staro 19.07.2011., 12:16   #119
b00tstrap
b00tstrap's Avatar
Datum registracije: Jul 2011
Lokacija: Belišće
Postovi: 5
Dali se mogu ugradjivati aftermarket ventilatori u laptope?
b00tstrap je offline   Reply With Quote
Staro 19.07.2011., 12:59   #120
mhadina
mhadina's Avatar
Postovi: 436
vijest
Ovo bi kao trebala biti revolucija zračnog hlađenja odnosno by by vodeno
  • Vidiš li čovjeka koji se sam sebi mudrim čini? Znaj, i od bezumnika ima više nade nego od njega!
  • San dolazi od mnogo briga, a lud govor od mnogo riječi.
  • Neka su ti mnogi poznanici, ali pouzdanik samo jedan od tisuću.
  • Ne ponizuj se pred budalom i ne budi pristran pred mogućnicima.
  • Ne budi silovit na jeziku a lijen i mlitav na djelu.
mhadina je offline   Reply With Quote
