Staro 25.05.2011., 23:53   #241
kmica
inženjering
kmica's Avatar
Postovi: 32
pošto scythe na svom web-u ne navodi statički pritisak za s-flex ventova zanima me da li je ovaj podatak točan
Scythe SFF21G S-Flex Fluid Dynamic Bearing Case Fan
Airflow: 75 CFM
Noise: 35 dBA
Static Pressure: 3.78 mm-H20
Rotation Speed: 1900 RPM
Connector: 3-Pin (4-Pin adapter included)
Bearing Type: Fluid Dynamic Bearing
Current Draw: 0.24 A
http://www.svc.com/sy-fan-sff21g.html
1 / 2 / 3 / 4 / 5 / 6
kmica je offline   Reply With Quote
Staro 20.06.2011., 12:56   #242
Kulezg
Kulezg's Avatar
Datum registracije: Jun 2011
Postovi: 31
Dobar sajt...
Evo ljudi ima i ovdje: http://www.acousticpc.com/index_quie...uter_fans.html
za kupovat ventova, dobra stvar je sta salju u HR i moze se paypalom placat, a jedino jos nisam sazno kolike su im postarine (cekam odgovor od njih na mail).
Pozz!
Kulezg je offline   Reply With Quote
Staro 11.07.2011., 21:37   #243
prt scr
Datum registracije: Jan 2011
Lokacija: wild west
Postovi: 321
koji ventilator bi preporučili za scythe yasya hladnjak?
dakle da ima dobar protok zraka i da je tih jer se ovaj slip stream dosta čuje,tj. čuje se strujanje zraka
mora bit 120mm
prt scr je offline   Reply With Quote
Staro 12.07.2011., 00:27   #244
Dottore
Dottore's Avatar
Postovi: 7,706
S-flex (ako nađeš) ili Gentle-typhoon
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 12.07.2011., 11:09   #245
prt scr
Lokacija: wild west
Postovi: 321
Autor Dottore Pregled postova
a noctua nf-s12b,jel bi ona bila najbolja?
http://www.noctua.at/pdf/infosheets/...12b_flx_en.pdf
ima airflow 100.6 m3/h
Staro 12.07.2011., 11:18   #246
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
Taj bi bio najbolji koji mozes kupiti kod nas ( mislim da oprić ima ) .
Staro 12.07.2011., 11:54   #247
prt scr
Lokacija: wild west
Postovi: 321
Autor xulos Pregled postova
a ovaj nf-p12
http://www.noctua.at/pdf/infosheets/..._nf_p12_en.pdf
da li je bitniji veći airflow ili static presure?
scythe yasya nije ravan hladnjak,već ima one izbočine pa zato pitam koji bi ventilator bio najefikasniji
Staro 12.07.2011., 12:05   #248
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
Opcenito je dobar veci static pressure posto zrak iz venta na procu nailazi na veliki otpor.Sto veci static pressure ti je bitniji ako imas gusce zbijene listice na kuleru.Yasya je "grbav" samo odnazad tako da to nema veze.Od te dvije noctue uzmi onu koja je jeftinija jer su obje jako dobri ventovi.
Staro 12.07.2011., 12:42   #249
prt scr
Lokacija: wild west
Postovi: 321
pa stvar je u tome da dođu isto kod oprića
yasya je grbav sa obje strane i ima dosta guste listiće
valjda je onda nf-p12 bolji izbor
Staro 12.07.2011., 12:56   #250
BojanZD
BojanZD's Avatar
Postovi: 1,398
NF-P12 dolazi sa NH D14 coolerom,a tu se pokazao jako dobar- znači nemoš fulat!
Šteta što ti buka smeta, Delta ventovi ubijaju protokom i pritiskom-kao stvoreni za single tower coolere.
BojanZD je offline   Reply With Quote
Staro 13.07.2011., 12:43   #251
prt scr
Lokacija: wild west
Postovi: 321
Autor BojanZD Pregled postova
misliš delta su bolji ali su bučniji,njih nema u hr?
imam sveukupno u kućištu 10 ventilatora(dakle sve,od napajanja do grafičke itd.)
ovaj od procesora je najbučniji,njega ću zamijenit a za ove ću kupit kabel 12V to 7V i mislim da će tad bit prilično tiho
Staro 13.07.2011., 13:55   #252
Dottore
Dottore's Avatar
Postovi: 7,706
Ne kužim što želiš za preporuku ventilatora a kad nisi ispunio Moj komp??? Ovako iz nule možemo pogađati praznu slamu..
Ako imaš 120mm ventove ugrađene , onda zamjeni NF-P12 ventove i mirna bosna.
Osobno imam Noctu-e P12, S12 i P14 ventove u kučištu i još S-Flex ,Minebea i Gentlee-typhon.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 13.07.2011., 15:01   #253
prt scr
Lokacija: wild west
Postovi: 321
zamijenit ću samo od procesora vent,kućište je NZXT tempest evo i njegovi ventilatori su odlični
Staro 13.07.2011., 15:03   #254
BojanZD
BojanZD's Avatar
Postovi: 1,398
A sad ti svi ventovi rade na 12V?
Staro 13.07.2011., 15:05   #255
prt scr
Lokacija: wild west
Postovi: 321
da, kad su spojeni na napajanje
Staro 13.07.2011., 22:56   #256
Dottore
Dottore's Avatar
Postovi: 7,706
A zasto nisu spojeni na maticnu? Tebi je bitna tisina a spajas direktno na napajanje na 12V. Mislim da si upravo nasao svoj odgovor.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 13.07.2011., 22:58   #257
prt scr
Lokacija: wild west
Postovi: 321
ma nema šanse,na matičnoj imam možda 2 3-pinska koja su mi nedostupna zbog hladnjaka,grafičke itd. a imam 6 vent koje bih trebao spojit
možda sad uzmem scythe kaze q sa 8
Staro 26.07.2011., 09:04   #258
lateralus_eye
lateralus_eye's Avatar
Postovi: 603
ja ću naručivati neke stvari ukljućujući i ventove sa http://www.performance-pcs.com/catalog/index.php pa ako je netko za da skupa naručimo neka se javi...
lateralus_eye je offline   Reply With Quote
Staro 27.07.2011., 18:38   #259
Shaka111
Shaka111's Avatar
Datum registracije: Mar 2009
Postovi: 650
evo ja narucio sebi 4 ovakva...
http://www.coolink-europe.com/en/categories/23_29.html
javim dojmove i temp na cooleru kada ih dobijem i ubacim u racunalo
Shaka111 je offline   Reply With Quote
Staro 27.07.2011., 20:36   #260
iggi
Lokacija: qǝɹƃɐz
Postovi: 441
Ako će se naručivati ja bi uzeo ovu delticu. Mislim da bi uz pomoć kojeg otpornika bila za svakodnevnu uporabu.
Delta 120x25mm WFB1212H
iggi je offline   Reply With Quote
Staro 27.07.2011., 23:58   #261
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,762
Ako vec ciljas na Deltu, zasto se za*ebavati s otpornicima i slicno?
Uzmi si odma Delta AFC1212D-PWM koja ima PWM i nemas problema sa bukom.
Jest skuplja za 4$ ali je i dosta jaca po statickom pritisku i kolicini zraka koju moze pogurati.
Staro 28.07.2011., 07:32   #262
iggi
Lokacija: qǝɹƃɐz
Postovi: 441
Kada razmislim čak bi i bilo bolje, pa da je 10$ više ne igra ulogu.
Zadnje izmijenjeno od: iggi. 28.07.2011. u 07:45.
Staro 09.08.2011., 11:19   #263
NemoRS
NemoRS's Avatar
Postovi: 518
Nadam se da ste vidjeli dolazak Coolmasterovih ventova za smjesnu cijenu. Imam ih ja i sad sam si opet narucio. Mislim da za tu cijenu nema boljih.
NemoRS je offline   Reply With Quote
Staro 09.08.2011., 11:52   #264
prt scr
Lokacija: wild west
Postovi: 321
Autor NemoRS Pregled postova
misliš ove u linksu,nema nikakvih specifikacija
Staro 09.08.2011., 12:45   #265
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,762
Ako mislis na Blade Mastera , itekako ima specifikacija - samo ne na Linksovoj stranici.
Ovi ventovi dolaze sa Hyper 212+ hladnjakom i pokazali su se jako dobri, a uz to imaju i dosta jak staticki pritisak..
Ako pak mislis na Sickleflow, takodjer dosta solidni ventovi za sicu..
Staro 09.08.2011., 13:29   #266
NemoRS
NemoRS's Avatar
Postovi: 518
http://www.links.hr/index.php?naziv=...kl=050.908.224
http://www.links.hr/index.php?naziv=...kl=050.908.231
Ovakve sam si ja narucio.sutra dolaze. Neznam gdje naci s boljim protokom tu kod nas. Htio sam ih s ebaya narucivat kad ono odjednom se vamo pojavili. MOzda nekome smeta sto su led ali meni ce se ukomponirat fino s mojim kucistem u kojem je naprijed 230mm crveni led vent. Ovaj Sickleflow ima 70 CFM i relativno je tih.
Staro 10.08.2011., 22:26   #267
NemoRS
NemoRS's Avatar
Postovi: 518
Stigli ventovi.Kuciste je apoteka, a kako je tek hladno i crveno unutra
Staro 14.08.2011., 02:17   #268
skyman
skyman's Avatar
Datum registracije: Aug 2008
Postovi: 775
Evo i ja uzeo ovaj MegaFlow 200mm..tiho, radi puno propuha..malo sam ga uspoređivao sa stock ventovima što dolaze s haf 932 Advanced i HAF X..čak su i tiši od stock ventova..iako su po specifikacijama isti ventovi..al eto očito su malo dorađeni..uglavnom jako dobra kupnja kome stane ta mrcina u kućište
skyman je offline   Reply With Quote
Staro 20.08.2011., 22:50   #269
pdx
pdx's Avatar
Datum registracije: Dec 2009
Lokacija: krk
Postovi: 515
decki meni bi trebalo ukupno 4x fanova , 3x 120mm i 1x 200mm , 1x 200mm za protok zraka na Corsair 600t , jedan od iza na kucistu 120mm i 2x 120mm za corsair H100. ja nisam pratio te ventove al ako bi netko tko ih je dosta promjenio , pa da preporuci u jednom postu i to je to , bez kompliciranja cijena mi nije bitna , iz vana bi narucivao pa samo preporucite.
pdx je offline   Reply With Quote
Staro 20.08.2011., 23:02   #270
Dottore
Dottore's Avatar
Postovi: 7,706
Pogledaj NF-P12 za radijator i vanjski ispuh NF-S12BFLX
Za 200mm nemam iskustva osim 120 i 140mm
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
